For many years now I've been running Indigo (4/5/6/7) with all-Insteon equipment, using the PowerLinc 2413U interface. At the moment, I'm running Indigo 7.5 on macOS 10.14.5 Mojave on a headless late 2014 Mac mini. I would like to expand my system to include door locks, remote sensors and other equipment that either aren't available from Insteon, or that are poorly implemented by Insteon, so I have decided to add Z-Wave capability to my system.
I have just purchased an Aeotec Z-Stick Gen5. I plugged it into the Mac mini, enabled the Z-Wave interface in Indigo, and configured it successfully. Indigo now seems to see the Z-Stick: on the status bar at the bottom left of the Indigo window, I see "Z-Wave" in green, right next to the words "PowerLinc 2413U" also in green. However, the Z-Stick does not appear as an option in the Target Device dropdown list in either the Send Raw Z-Wave Command dialog, nor the Modify Configuration Parameter dialog. In fact, the Target Device dropdown list in both dialogs is effectively empty, saying only in light-gray text, "- select an item -".
I have tried reloading the Z-Wave interface. That had no discernible effect and generated no errors in the log. I also tried disabling and renenabling the Z-Wave interface. That also had no discernible effect and generated no errors in the log (although the log captured the actions... the Disable said "closed connection to Z-Stick Gen5 (ZW090)", and the Enable said "connected to Z-Stick Gen5 (ZW090) interface on /dev/cu.usbmodem14701 (firmware 1.01, minimum SDK 6.51.06)"
Admittedly, I don't yet have any Z-Wave devices set up to test with the stick, but I was hoping to send a Raw Z-Wave Command to stop it's annoying Red-Yellow-Blue flashing. Online, I found the hex bytes necessary to stop the flashing, but when I go to the Send Raw Z-Wave Command dialog, I can't select the Z-Stick from the Target Device drop down.
Have I missed something? Does anyone have any suggestions?
