I'm somewhat certain that my inability to contact/include a long-working LED bulb started right after I updated to 2021.2 from 2021.1 (the beta version that fixed the Monterey issue). I cannot Include it following the usual steps, just get "failed to assign return route" errors when I try to use the existing, or a new, Node ID.
Maybe it's just gone bad at the wrong moment. However when I turn it off/on four times it goes into Inclusion mode, and Indigo assigns it a new Node ID, so some amount of communication is happening. The rest of the network seems fine.
Any ideas what could cause that?
-jonathan
Z-Wave Indigo Device "Boy's Room Lamp" Z-Wave Properties:
Indigo Z-Wave Version: 2021.2.0
Node ID: 25
Model: LED Bulb (LB60Z-1)
Model ID: 47543038
Manufacturer: LinearLinc
Manufacturer ID: 014F
Protocol Version: 3.95
Application Version: 5.08
Model Definition Version: 0
Library Type: 3
Class Name: Dimmable Power Switch
Class Hierarchy: 04 : 11 : 01
Command Class Base: 26
Command Versions: 20v1 85v1 86v1 27v1 70v1 72v1 73v1 59v1 5Av1 26v1 7Av1 5Ev1
Features: routing, beaming
Neighbors: 3, 4, 5, 7, 8, 10, 13, 14, 18, 19
Associations: 1:[1]
Config Values: - none -
