Ring Alarm - Retrofit Alarm Kit
Wed Jan 05, 2022 1:17 pm
jenwill1 offline
I have been looking for a good way to bring wired door contacts into Indigo.
I have a new house with security wiring in place for all the doors and a couple of motion and glass break sensors.
I have looked at installing a Lyric security system with their 5800C2W retrofit wired panel (Indigo plugin + HomeKit maybe), Konnected (HomeKit maybe) and Ring (maybe Indigo to HomeKit).
When I was looking at Ring I noticed that they have a Retrofit Alarm Kit for $149... that appears to be a wave device. The literature says if you can't communicate between the Retrofit panel and the Ring Base to install the Ring zwave extender.... It's an 8 zone panel.
Since indigo is supporting some of the Ring sensors, I wondered if it was a possibility to bring in the retrofit panel for this purpose versus trying to use a Mimo2+ or install a full security system.
Thu Jan 06, 2022 8:29 pm
Dual offline
Re: Ring Alarm - Retrofit Alarm Kit
The Ring Retrofit Alarm Kit looks very interesting. I don’t think it existed when I did my house, or I was unaware of it. My house had a wired alarm kit when I bought it. I removed all keypads and motions and patched the drywall before painting the whole house. Wired contact sensors are still in place. However I did not use them and I installed z-wave contact sensors on all doors but none of the windows.
I am guessing that the retrofit kit could be connected to an indigo z-wave stick similar to the ring keypad. You would need to reverse engineer the messages from the retrofit kit similar to what was done for the Ring Keypad.
Fri Jan 07, 2022 9:16 am
cesarvog offline
I had an old wired alarm system in place for several years. I've wanted to integrate it to Indigo for a long time, but there was no plugin to support the integration. Then I just decided to rip the panels apart and add a Fibaro Smart Implant to each motion sensor and program the interface in Indigo myself. It's been working flawlessly ever since.
Sat Jan 08, 2022 9:25 pm
Dual offline
Another alternative for you. Zooz Zen16. I have not used one. I have used other Zooz products and I am happy with them. The price point for 3 inputs is excellent. Much cheaper than the Ring device if it supports 8 inputs for $150. I am not sure if the Zen16 is supported by Indigo yet.
https://smile.amazon.com/dp/B0846DZJD8/
Sun Jan 09, 2022 8:39 am
jenwill1 offline
Thanks for the suggestions... I need to decide if I want an alarm system or just utilize the wired door contacts. House burned down in the neighborhood a couple of weeks ago and makes me think I should have my smoke detectors go to a central alarm.... Will post on where it goes from here !
Wed Jan 26, 2022 10:46 am
jenwill1 offline
Each alarm system I looked at had it's own quirks... having it's own app, having choices whether to monitor or not, connecting to existing wire systems, location of wiring (13 feet up in my case) etc.
The Ring Alarm seems to be a pretty good solution although you have to use a wave fire/smoke alarm listener to utilize an existing wired detector system. So I thought I would try the Retrofit Kit (RRK) and see if I can get Indigo to communicate with it enough to tie in the wired door contacts and make a few triggers and action groups for notifications. If I can't get it to work then I'll go to the route of the Ring Alarm (non-pro version).
Ring uses an app to include the RRK to the Wave controller in the Ring Alarm, so there is really no instructions on
So... I included the RRK with debugging, using the encrypted inclusion in Indigo. Seemed to include ok, but there are a few debug lines suggesting it's not responding to certain controller requests. It sets up basically 8 notification sensors after the sync.
I put a 1k resistor on a similar contact switch, which tested within spec for the RRK using a multimeter >0 and <5.7 k ohms. Could not get any notifications from the device.
Cannot get the RRK to transmit during its wake notification, or when I request a get status request either...
Any help would be appreciated in trying to get the device to communicate !!
Below is the Event Log inclusion.. Apologize it is quite long.
started controller inclusion mode with encryption
Z-Wave Debug RCVD inclusionMode ready: 01 07 00 4A 01 01 00 00 B2
Z-Wave Debug RCVD inclusionMode node found: 01 07 00 4A 01 02 00 00 B1
Z-Wave Debug RCVD inclusionMode adding slave node: 01 1B 00 4A 01 03 39 14 04 07 01 5E 55 9F 85 59 8E 60 80 70 5A 72 71 73 6C 86 84 7A EB
Z-Wave Debug RCVD inclusionMode node respondCmds: 5E 55 9F 85 59 8E 60 80 70 5A 72 71 73 6C 86 84 7A
Z-Wave Debug RCVD inclusionMode node added: 01 07 00 4A 01 05 39 00 8F
Z-Wave Debug SENT exitInclusionMode: 01 04 00 4A 05 B4
Z-Wave Debug RCVD exitInclusionMode: 06 (ACK)
Z-Wave Debug RCVD inclusionMode finished: 01 07 00 4A 01 06 39 00 8C
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 39 83
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 53 9C 01 04 07 01 7A (no inbound callback)
Z-Wave Debug . . getNodeProtocolInfo: node 057, class name: Notification Sensor
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Notification Sensor : Notification Sensor (04 : 07 : 01)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 00
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 60 84 85 86 80 6C 8E 70 71 72 73 55 59 5A 7A 5E 9F
Z-Wave Debug . . getNodeProtocolInfo: encrypt class commands:
Z-Wave Debug . . getNodeProtocolInfo: features: routing, battery, beaming, waking
Z-Wave controller included module: 057 - Notification Sensor
Z-Wave querying module for encryption support
Z-Wave Debug SENT requestSecuritySchemes: 01 0A 00 13 39 03 98 04 00 25 B8 DD
Z-Wave Debug RCVD requestSecuritySchemes: 01 07 00 13 B8 00 00 02 51 (node ACK)
Z-Wave Debug RCVD requestSecuritySchemes: 01 09 00 04 00 39 03 98 05 00 55
Z-Wave Debug . . requestSecuritySchemes: node 057, schemeIndex 0
Z-Wave starting encryption key exchange with module
Z-Wave Debug SENT nonceRequest: 01 09 00 13 39 02 98 40 25 B9 9A
Z-Wave Debug RCVD nonceRequest: 01 07 00 13 B9 00 00 02 50 (node ACK)
Z-Wave Debug RCVD nonceReport: node 057, nonce 81 C4 19 91 73 A5 4F 81
Z-Wave Debug SENT setNetworkSecurityKey: ** ** ** ** (encrypted)
Z-Wave Debug RCVD setNetworkSecurityKey: 01 07 00 13 BA 00 00 02 53 (node ACK)
Z-Wave Debug RCVD nonceFetch: node 057
Z-Wave Debug SENT nonceReport: 01 11 00 13 39 0A 98 80 F3 BE 26 61 D5 09 07 13 25 BB 8A
Z-Wave Debug RCVD nonceReport: 01 07 00 13 BB 00 00 02 52 (node ACK)
Z-Wave Debug RCVD encryptedPacket: 00 98 07 (decrypted)
Z-Wave Debug RCVD keyVerify: 01 08 00 04 00 39 02 98 07 FF
Z-Wave completed encryption key exchange with module
Z-Wave stopped controller inclusion mode
Z-Wave Syncing - started for "057 - Notification Sensor"
Z-Wave Debug SENT getNodeNeighbors: 01 06 00 80 39 01 01 40
Z-Wave Debug RCVD getNodeNeighbors: 01 20 01 80 06 00 00 00 00 08 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 10 (no inbound callback)
Z-Wave Debug . . getNodeNeighbors: nodeId 057, neighbors: 2, 3, 44, 55
Z-Wave Syncing - retrieved module neighbors list: 2, 3, 44, 55
Z-Wave Syncing - assigning return route to "057 - Notification Sensor"
Z-Wave Debug SENT assignReturnRoute: 01 05 00 46 39 01 84
Z-Wave Debug RCVD assignReturnRoute: 01 04 01 46 01 BD (no inbound callback)
Z-Wave Debug RCVD assignReturnRoute: 01 05 00 46 01 00 BD
Z-Wave Debug . . assignReturnRoute: node 057, success 1
Z-Wave Debug SENT requestNodeInfo: 01 06 00 60 39 24 BC 38
Z-Wave Debug RCVD nodeInfoFrame: 01 0C 00 49 84 39 06 04 07 01 5E 55 9F 97
Z-Wave Debug . . nodeInfoFrame: node 057, combined class list: 80v1 20v1 84v1 85v1 86v1 8Ev1 55v1 59v1 5Av1 5Ev1 9Fv1 60v1 6Cv1 70v1 71v1 72v1 73v1 7Av1
Z-Wave Debug SENT nonceRequest: 01 09 00 13 39 02 98 40 25 BD 9E
Z-Wave Debug RCVD nonceRequest: 01 07 00 13 BD 00 00 03 55 (node ACK)
Z-Wave Debug RCVD nonceReport: node 057, nonce D1 E9 1E 28 28 92 0F 3A
Z-Wave Debug SENT requestEncryptedCmdClasses: 98 02 (encrypted)
Z-Wave Debug RCVD requestEncryptedCmdClasses: 01 07 00 13 BE 00 00 03 56 (node ACK)
Z-Wave Debug RCVD unsolicited nonceFetch while waiting for nonce reply -- requeuing and bailing
Z-Wave Debug . . requestEncryptedCmdClasses: requeuing 1 unsolicited packets
Z-Wave Debug SENT nonceReport: 01 11 00 13 39 0A 98 80 66 46 74 C5 BE 45 5D 3E 25 BF 45
Z-Wave Debug RCVD nonceReport: 01 07 00 13 BF 00 00 02 56 (node ACK)
Z-Wave Debug RCVD encryptedPacket: 00 98 03 00 85 59 8E 60 80 70 5A 72 71 73 6C 86 84 7A (decrypted)
Z-Wave Debug RCVD requestEncryptedCmdClasses: 01 17 00 04 00 39 11 98 03 00 85 59 8E 60 80 70 5A 72 71 73 6C 86 84 7A FF
Z-Wave Debug RCVD requestEncryptedCmdClasses: node 057, classes 85 59 8E 60 80 70 5A 72 71 73 6C 86 84 7A
Z-Wave Debug SENT nonceRequest: 01 09 00 13 39 02 98 40 25 C0 E3
Z-Wave Debug RCVD nonceRequest: 01 07 00 13 C0 00 00 02 29 (node ACK)
Z-Wave Debug RCVD nonceReport: node 057, nonce D7 E4 B7 15 6E 9D 44 00
Z-Wave Debug SENT requestManufactureInfo: 72 04 (encrypted)
Z-Wave Debug RCVD requestManufactureInfo: 01 07 00 13 C1 00 00 02 28 (node ACK)
Z-Wave Debug . . requestManufactureInfo: requeuing 1 unsolicited packets
Z-Wave Debug SENT nonceReport: 01 11 00 13 39 0A 98 80 66 46 74 C5 BE 45 5D 3E 25 C2 38
Z-Wave Debug RCVD nonceReport: 18 (RETRANSMIT REQUEST)
Z-Wave Debug SENT nonceReport: 01 11 00 13 39 0A 98 80 66 46 74 C5 BE 45 5D 3E 25 C2 38 (re-sent because retransmit request)
Z-Wave Debug . . nonceReport: requeuing 1 unsolicited packets
Z-Wave Debug RCVD nonceReport: 01 07 00 13 C2 00 00 02 2B (node ACK)
Z-Wave Debug RCVD nonceReport: node 057, nonce 97 10 1A D5 8C 43 64 1F (saved for next send)
Z-Wave Debug RCVD encryptedPacket: 00 72 05 03 46 0B 01 01 01 (decrypted)
Z-Wave Debug RCVD requestManufactureInfo: 01 0E 00 04 00 39 08 72 05 03 46 0B 01 01 01 FF
Z-Wave Debug . . requestManufactureInfo: node 057, manufacturerId 0346, productId 0B010101
Z-Wave Debug . . requestManufactureInfo: Ring, Notification Sensor
Z-Wave Syncing - retrieved manufacture and model names: Ring - 0346, Notification Sensor - 0B010101
Z-Wave Debug SENT requestVersInfoGen: 86 11 (encrypted)
Z-Wave Debug RCVD requestVersInfoGen: 01 07 00 13 C3 00 00 03 2B (node ACK)
Z-Wave Debug RCVD nonceReport: node 057, nonce A1 44 43 1D C8 86 48 9F (saved for next send)
Z-Wave Debug timeout waiting for reply from module (retrying)
Z-Wave Debug SENT nonceRequest: 01 09 00 13 39 02 98 40 25 C4 E7
Z-Wave Debug RCVD nonceRequest: 01 07 00 13 C4 00 00 02 2D (node ACK)
Z-Wave Debug RCVD nonceReport: node 057, nonce E9 26 F9 18 27 16 9A 17
Z-Wave Debug RCVD requestVersInfoGen: 01 07 00 13 C5 00 00 02 2C (node ACK)
Z-Wave Debug . . requestVersInfoGen: requeuing 1 unsolicited packets
Z-Wave Debug SENT nonceReport: 01 11 00 13 39 0A 98 80 48 84 5F 23 C1 A6 2E 79 25 C6 B5
Z-Wave Debug SENT nonceReport: 01 11 00 13 39 0A 98 80 48 84 5F 23 C1 A6 2E 79 25 C6 B5 (re-sent because retransmit request)
Z-Wave Debug RCVD nonceReport: 01 07 00 13 C6 00 00 02 2F (node ACK)
Z-Wave Debug RCVD nonceReport: node 057, nonce F7 45 19 85 D2 99 E4 E4 (saved for next send)
Z-Wave Debug RCVD encryptedPacket: 00 86 12 03 06 04 01 06 01 01 01 06 (decrypted)
Z-Wave Debug RCVD requestVersInfoGen: 01 11 00 04 00 39 0B 86 12 03 06 04 01 06 01 01 01 06 FF
Z-Wave Debug . . requestVersInfoGen: node 057, protoVers 6.04, appVers 1.06
Z-Wave Syncing - retrieved protocol version 6.04, app version 1.06
Z-Wave Debug SENT requestVersInfoCmdClass: 86 13 84 (encrypted)
Z-Wave Debug RCVD requestVersInfoCmdClass: 01 07 00 13 C7 00 00 02 2E (node ACK)
Z-Wave Debug RCVD nonceReport: node 057, nonce A9 D7 CD 6F 1E EB 37 44 (saved for next send)
Z-Wave Debug SENT nonceRequest: 01 09 00 13 39 02 98 40 25 C8 EB
Z-Wave Debug RCVD nonceRequest: 01 07 00 13 C8 00 00 02 21 (node ACK)
Z-Wave Debug RCVD nonceReport: node 057, nonce FB 5A 08 E2 41 75 56 34
Z-Wave Debug RCVD requestVersInfoCmdClass: 01 07 00 13 C9 00 00 02 20 (node ACK)
Z-Wave Debug . . requestVersInfoCmdClass: requeuing 1 unsolicited packets
Z-Wave Debug SENT nonceReport: 01 11 00 13 39 0A 98 80 98 96 3F 55 81 79 BF 62 25 CA 78
Z-Wave Debug SENT nonceReport: 01 11 00 13 39 0A 98 80 98 96 3F 55 81 79 BF 62 25 CA 78 (re-sent because retransmit request)
Z-Wave Debug RCVD nonceReport: 01 07 00 13 CA 00 00 02 23 (node ACK)
Z-Wave Debug RCVD nonceReport: node 057, nonce DA 65 94 B7 3E 82 E1 C0 (saved for next send)
Z-Wave Debug RCVD encryptedPacket: 00 86 14 84 02 (decrypted)
Z-Wave Debug RCVD requestVersInfoCmdClass: 01 0A 00 04 00 39 04 86 14 84 02 FF
Z-Wave Debug . . requestVersInfoCmdClass: node 057, class command 84 using version 2
Z-Wave Debug . . requestVersInfoCmdClass: node 057, combined class list: 80v1 20v1 84v2 85v1 86v1 8Ev1 55v1 59v1 5Av1 5Ev1 9Fv1 60v1 6Cv1 70v1 71v1 72v1 73v1 7Av1
Z-Wave Debug SENT requestVersInfoCmdClass: 86 13 60 (encrypted)
Z-Wave Debug RCVD requestVersInfoCmdClass: 01 07 00 13 CB 00 00 02 22 (node ACK)
Z-Wave Debug RCVD nonceReport: node 057, nonce 34 F2 5A 14 A4 38 4F E7 (saved for next send)
Z-Wave Debug SENT nonceRequest: 01 09 00 13 39 02 98 40 25 CC EF
Z-Wave Debug RCVD nonceRequest: 01 07 00 13 CC 00 00 02 25 (node ACK)
Z-Wave Debug RCVD nonceReport: node 057, nonce 4B C8 2C B7 FA 0A 3D 4E
Z-Wave Debug RCVD requestVersInfoCmdClass: 01 07 00 13 CD 00 00 03 25 (node ACK)
Z-Wave Debug SENT nonceReport: 01 11 00 13 39 0A 98 80 83 00 6F 20 9D 82 29 E0 25 CE 27
Z-Wave Debug RCVD nonceReport: 01 07 00 13 CE 00 00 03 26 (node ACK)
Z-Wave Debug RCVD nonceReport: node 057, nonce 86 4B 29 9A F2 73 BF 14 (saved for next send)
Z-Wave Debug RCVD encryptedPacket: 00 86 14 60 04 (decrypted)
Z-Wave Debug RCVD requestVersInfoCmdClass: 01 0A 00 04 00 39 04 86 14 60 04 FF
Z-Wave Debug . . requestVersInfoCmdClass: node 057, class command 60 using version 4
Z-Wave Debug . . requestVersInfoCmdClass: node 057, combined class list: 80v1 20v1 84v2 85v1 86v1 8Ev1 55v1 59v1 5Av1 5Ev1 9Fv1 60v4 6Cv1 70v1 71v1 72v1 73v1 7Av1
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Notification Sensor : Notification Sensor (04 : 07 : 01, base 00)
Z-Wave Syncing - retrieved command classes: 80v1 20v1 84v2 85v1 86v1 8Ev1 55v1 59v1 5Av1 5Ev1 9Fv1 60v4 6Cv1 70v1 71v1 72v1 73v1 7Av1
Z-Wave Syncing - retrieved encrypt commands: 60 80 84 85 86 6C 8E 70 71 72 73 59 5A 7A
Z-Wave Syncing - retrieved capabilities: routing, battery, beaming, waking
Z-Wave Debug SENT requestWakeInterval: 84 05 (encrypted)
Z-Wave Debug RCVD requestWakeInterval: 01 07 00 13 CF 00 00 03 27 (node ACK)
Z-Wave Debug RCVD nonceReport: node 057, nonce AD 2D 48 B6 31 8E 8D 7E (saved for next send)
Z-Wave Debug SENT nonceRequest: 01 09 00 13 39 02 98 40 25 D0 F3
Z-Wave Debug RCVD nonceRequest: 01 07 00 13 D0 00 00 02 39 (node ACK)
Z-Wave Debug RCVD nonceReport: node 057, nonce A2 D8 41 A0 BB D7 D0 A0
Z-Wave Debug RCVD requestWakeInterval: 01 07 00 13 D1 00 00 02 38 (node ACK)
Z-Wave Debug . . requestWakeInterval: requeuing 1 unsolicited packets
Z-Wave Debug SENT nonceReport: 01 11 00 13 39 0A 98 80 2B BA B2 F6 0D 29 59 D7 25 D2 5E
Z-Wave Debug SENT nonceReport: 01 11 00 13 39 0A 98 80 2B BA B2 F6 0D 29 59 D7 25 D2 5E (re-sent because retransmit request)
Z-Wave Debug RCVD nonceReport: 01 07 00 13 D2 00 00 02 3B (node ACK)
Z-Wave Debug RCVD nonceReport: node 057, nonce 1F 1D FA 86 42 0C 3E D1 (saved for next send)
Z-Wave Debug RCVD encryptedPacket: 00 84 06 00 70 80 00 (decrypted)
Z-Wave Debug RCVD requestWakeInterval: 01 0C 00 04 00 39 06 84 06 00 70 80 00 FF
Z-Wave Debug . . requestWakeInterval: node 057, interval 480 minutes, wakeTarget 000
Z-Wave Syncing - retrieved wake interval of 480 minutes
Z-Wave Debug SENT setWakeInterval: 84 04 00 0E 10 01 (encrypted)
Z-Wave Debug RCVD setWakeInterval: 01 07 00 13 D3 00 00 03 3B (node ACK)
Z-Wave Debug RCVD nonceReport: node 057, nonce A5 DE BE 9C A0 C1 9F 3C (saved for next send)
Z-Wave Syncing - device "057 - Notification Sensor" wake interval changed to 60 minutes
Z-Wave Debug SENT requestMultiEndPointInfo: 60 07 (encrypted)
Z-Wave Debug RCVD requestMultiEndPointInfo: 01 07 00 13 D4 00 00 03 3C (node ACK)
Z-Wave Debug . . requestMultiEndPointInfo: requeuing 1 unsolicited packets
Z-Wave Debug SENT nonceReport: 01 11 00 13 39 0A 98 80 2B BA B2 F6 0D 29 59 D7 25 D5 59
Z-Wave Debug SENT nonceReport: 01 11 00 13 39 0A 98 80 2B BA B2 F6 0D 29 59 D7 25 D5 59 (re-sent because retransmit request)
Z-Wave Debug RCVD nonceReport: 01 07 00 13 D5 00 00 03 3D (node ACK)
Z-Wave Debug RCVD nonceReport: node 057, nonce DC 5E 6A 15 79 AA D2 B3 (saved for next send)
Z-Wave Debug RCVD encryptedPacket: 00 60 08 40 08 00 (decrypted)
Z-Wave Debug RCVD requestMultiEndPointInfo: 01 0B 00 04 00 39 05 60 08 40 08 00 FF
Z-Wave Debug . . requestMultiEndPointInfo: node 057, numEndPoints 8, sameClass True, notStatic False
Z-Wave Debug SENT requestMultiEndPointDetails: 60 09 01 (encrypted)
Z-Wave Debug RCVD requestMultiEndPointDetails: 01 07 00 13 D6 00 00 02 3F (node ACK)
Z-Wave Debug RCVD nonceReport: node 057, nonce EC E0 73 D6 60 21 76 53 (saved for next send)
Z-Wave Debug SENT nonceRequest: 01 09 00 13 39 02 98 40 25 D7 F4
Z-Wave Debug RCVD nonceRequest: 01 07 00 13 D7 00 00 02 3E (node ACK)
Z-Wave Debug RCVD nonceReport: node 057, nonce 43 B0 EA 6A 50 36 2A 2F
Z-Wave Debug RCVD requestMultiEndPointDetails: 01 07 00 13 D8 00 00 03 30 (node ACK)
Z-Wave Debug . . requestMultiEndPointDetails: requeuing 1 unsolicited packets
Z-Wave Debug SENT nonceReport: 01 11 00 13 39 0A 98 80 EA 2A C0 4A B0 AE 36 C5 25 D9 8D
Z-Wave Debug SENT nonceReport: 01 11 00 13 39 0A 98 80 EA 2A C0 4A B0 AE 36 C5 25 D9 8D (re-sent because retransmit request)
Z-Wave Debug RCVD nonceReport: 01 07 00 13 D9 00 00 02 30 (node ACK)
Z-Wave Debug RCVD nonceReport: node 057, nonce 5E 40 65 51 38 C6 61 93 (saved for next send)
Z-Wave Debug RCVD encryptedPacket: 00 60 0A 01 07 01 5E 85 59 8E 71 6C (decrypted)
Z-Wave Debug RCVD requestMultiEndPointDetails: 01 11 00 04 00 39 0B 60 0A 01 07 01 5E 85 59 8E 71 6C FF
Z-Wave Debug . . requestMultiEndPointDetails: node 057, endPoint 1, notStatic False, class hierarchy 07 : 01
Z-Wave Debug . . requestMultiEndPointDetails: node 057, combined multi-endpoint types: 1:(07 : 01)
Z-Wave Debug . . requestMultiEndPointDetails: node 057, combined multi-endpoint classes: 1:[5E 85 59 8E 71 6C]
Z-Wave Debug . . requestMultiEndPointDetails: node 057, combined multi-endpoint types: 1:(07 : 01), 2:(07 : 01)
Z-Wave Debug . . requestMultiEndPointDetails: node 057, combined multi-endpoint classes: 1:[5E 85 59 8E 71 6C], 2:[5E 85 59 8E 71 6C]
Z-Wave Debug . . requestMultiEndPointDetails: node 057, combined multi-endpoint types: 1:(07 : 01), 2:(07 : 01), 3:(07 : 01)
Z-Wave Debug . . requestMultiEndPointDetails: node 057, combined multi-endpoint classes: 1:[5E 85 59 8E 71 6C], 2:[5E 85 59 8E 71 6C], 3:[5E 85 59 8E 71 6C]
Z-Wave Debug . . requestMultiEndPointDetails: node 057, combined multi-endpoint types: 1:(07 : 01), 2:(07 : 01), 3:(07 : 01), 4:(07 : 01)
Z-Wave Debug . . requestMultiEndPointDetails: node 057, combined multi-endpoint classes: 1:[5E 85 59 8E 71 6C], 2:[5E 85 59 8E 71 6C], 3:[5E 85 59 8E 71 6C], 4:[5E 85 59 8E 71 6C]
Z-Wave Debug . . requestMultiEndPointDetails: node 057, combined multi-endpoint types: 1:(07 : 01), 2:(07 : 01), 3:(07 : 01), 4:(07 : 01), 5:(07 : 01)
Z-Wave Debug . . requestMultiEndPointDetails: node 057, combined multi-endpoint classes: 1:[5E 85 59 8E 71 6C], 2:[5E 85 59 8E 71 6C], 3:[5E 85 59 8E 71 6C], 4:[5E 85 59 8E 71 6C], 5:[5E 85 59 8E 71 6C]
Z-Wave Debug . . requestMultiEndPointDetails: node 057, combined multi-endpoint types: 1:(07 : 01), 2:(07 : 01), 3:(07 : 01), 4:(07 : 01), 5:(07 : 01), 6:(07 : 01)
Z-Wave Debug . . requestMultiEndPointDetails: node 057, combined multi-endpoint classes: 1:[5E 85 59 8E 71 6C], 2:[5E 85 59 8E 71 6C], 3:[5E 85 59 8E 71 6C], 4:[5E 85 59 8E 71 6C], 5:[5E 85 59 8E 71 6C], 6:[5E 85 59 8E 71 6C]
Z-Wave Debug . . requestMultiEndPointDetails: node 057, combined multi-endpoint types: 1:(07 : 01), 2:(07 : 01), 3:(07 : 01), 4:(07 : 01), 5:(07 : 01), 6:(07 : 01), 7:(07 : 01)
Z-Wave Debug . . requestMultiEndPointDetails: node 057, combined multi-endpoint classes: 1:[5E 85 59 8E 71 6C], 2:[5E 85 59 8E 71 6C], 3:[5E 85 59 8E 71 6C], 4:[5E 85 59 8E 71 6C], 5:[5E 85 59 8E 71 6C], 6:[5E 85 59 8E 71 6C], 7:[5E 85 59 8E 71 6C]
Z-Wave Debug . . requestMultiEndPointDetails: node 057, combined multi-endpoint types: 1:(07 : 01), 2:(07 : 01), 3:(07 : 01), 4:(07 : 01), 5:(07 : 01), 6:(07 : 01), 7:(07 : 01), 8:(07 : 01)
Z-Wave Debug . . requestMultiEndPointDetails: node 057, combined multi-endpoint classes: 1:[5E 85 59 8E 71 6C], 2:[5E 85 59 8E 71 6C], 3:[5E 85 59 8E 71 6C], 4:[5E 85 59 8E 71 6C], 5:[5E 85 59 8E 71 6C], 6:[5E 85 59 8E 71 6C], 7:[5E 85 59 8E 71 6C], 8:[5E 85 59 8E 71 6C]
Z-Wave Syncing - retrieved multi-endpoint types: 1:(07 : 01), 2:(07 : 01), 3:(07 : 01), 4:(07 : 01), 5:(07 : 01), 6:(07 : 01), 7:(07 : 01), 8:(07 : 01)
Z-Wave Syncing - retrieved multi-endpoint classes: 1:[5E 85 59 8E 71 6C], 2:[5E 85 59 8E 71 6C], 3:[5E 85 59 8E 71 6C], 4:[5E 85 59 8E 71 6C], 5:[5E 85 59 8E 71 6C], 6:[5E 85 59 8E 71 6C], 7:[5E 85 59 8E 71 6C], 8:[5E 85 59 8E 71 6C]
Z-Wave Debug SENT requestAssociationGroupCount: 85 05 (encrypted)
Z-Wave Debug RCVD requestAssociationGroupCount: 01 07 00 13 DA 00 00 02 33 (node ACK)
Z-Wave Debug RCVD nonceReport: node 057, nonce DB B9 47 E0 ED 4A F4 8C (saved for next send)
Z-Wave Debug SENT nonceRequest: 01 09 00 13 39 02 98 40 25 DB F8
Z-Wave Debug RCVD nonceRequest: 01 07 00 13 DB 00 00 02 32 (node ACK)
Z-Wave Debug RCVD nonceReport: node 057, nonce F0 FC D6 0F FE 8E CD AA
Z-Wave Debug RCVD requestAssociationGroupCount: 01 07 00 13 DC 00 00 03 34 (node ACK)
Z-Wave Debug . . requestAssociationGroupCount: requeuing 1 unsolicited packets
Z-Wave Debug SENT nonceReport: 01 11 00 13 39 0A 98 80 61 61 BC 3D C3 4C EB 9C 25 DD 57
Z-Wave Debug SENT nonceReport: 01 11 00 13 39 0A 98 80 61 61 BC 3D C3 4C EB 9C 25 DD 57 (re-sent because retransmit request)
Z-Wave Debug RCVD nonceReport: 01 07 00 13 DD 00 00 02 34 (node ACK)
Z-Wave Debug RCVD nonceReport: node 057, nonce D4 7B CB C3 9E 99 36 31 (saved for next send)
Z-Wave Debug RCVD encryptedPacket: 00 85 06 02 (decrypted)
Z-Wave Debug RCVD requestAssociationGroupCount: 01 09 00 04 00 39 03 85 06 02 FF
Z-Wave Debug . . requestAssociationGroupCount: node 057, group count: 2
Z-Wave Debug SENT requestAssociations: 85 02 01 (encrypted)
Z-Wave Debug RCVD requestAssociations: 01 07 00 13 DE 00 00 03 36 (node ACK)
Z-Wave Debug RCVD nonceReport: node 057, nonce 6C B9 3F 2E 49 BF C7 29 (saved for next send)
Z-Wave Debug SENT nonceRequest: 01 09 00 13 39 02 98 40 25 DF FC
Z-Wave Debug RCVD nonceRequest: 01 07 00 13 DF 00 00 02 36 (node ACK)
Z-Wave Debug RCVD nonceReport: node 057, nonce 7A A3 23 4C DF 70 D1 31
Z-Wave Debug RCVD requestAssociations: 01 07 00 13 E0 00 00 03 08 (node ACK)
Z-Wave Debug . . requestAssociations: requeuing 1 unsolicited packets
Z-Wave Debug SENT nonceReport: 01 11 00 13 39 0A 98 80 03 86 4E 31 EC C0 C0 74 25 E1 70
Z-Wave Debug SENT nonceReport: 01 11 00 13 39 0A 98 80 03 86 4E 31 EC C0 C0 74 25 E1 70 (re-sent because retransmit request)
Z-Wave Debug RCVD nonceReport: 01 07 00 13 E1 00 00 02 08 (node ACK)
Z-Wave Debug RCVD nonceReport: node 057, nonce 87 38 99 21 54 EA 59 20 (saved for next send)
Z-Wave Debug RCVD encryptedPacket: 00 85 03 01 01 00 (decrypted)
Z-Wave Debug RCVD requestAssociations: 01 0B 00 04 00 39 05 85 03 01 01 00 FF
Z-Wave Debug . . requestAssociations: node 057, group: 1, num associations: 0, max associations: 1, replies left: 0
Z-Wave Debug . . requestAssociations: node 057, group: 1, associations: []
Z-Wave Syncing - retrieved group 1 associations: []
Z-Wave Debug SENT requestAssociations: 85 02 02 (encrypted)
Z-Wave Debug RCVD requestAssociations: 01 07 00 13 E2 00 00 02 0B (node ACK)
Z-Wave Debug RCVD nonceReport: node 057, nonce 55 C6 04 61 C2 8F 9F 66 (saved for next send)
Z-Wave Debug SENT nonceRequest: 01 09 00 13 39 02 98 40 25 E3 C0
Z-Wave Debug RCVD nonceRequest: 01 07 00 13 E3 00 00 02 0A (node ACK)
Z-Wave Debug RCVD nonceReport: node 057, nonce DF EF 1E ED B6 97 3B 7A
Z-Wave Debug RCVD requestAssociations: 01 07 00 13 E4 00 00 02 0D (node ACK)
Z-Wave Debug SENT nonceReport: 01 11 00 13 39 0A 98 80 17 9F FC 0F 68 87 B9 00 25 E5 3B
Z-Wave Debug SENT nonceReport: 01 11 00 13 39 0A 98 80 17 9F FC 0F 68 87 B9 00 25 E5 3B (re-sent because retransmit request)
Z-Wave Debug RCVD nonceReport: 01 07 00 13 E5 00 00 02 0C (node ACK)
Z-Wave Debug RCVD nonceReport: node 057, nonce 00 7B FD 74 AC C2 01 A5 (saved for next send)
Z-Wave Debug RCVD encryptedPacket: 00 85 03 02 01 00 (decrypted)
Z-Wave Debug RCVD requestAssociations: 01 0B 00 04 00 39 05 85 03 02 01 00 FF
Z-Wave Debug . . requestAssociations: node 057, group: 2, num associations: 0, max associations: 1, replies left: 0
Z-Wave Debug . . requestAssociations: node 057, group: 2, associations: []
Z-Wave Debug SENT addInterfaceAssociation: 85 01 01 01 (encrypted)
Z-Wave Debug RCVD addInterfaceAssociation: 01 07 00 13 E6 00 00 02 0F (node ACK)
Z-Wave Debug RCVD nonceReport: node 057, nonce 23 08 FC 24 93 C3 B8 75 (saved for next send)
Z-Wave Syncing - added group 1 association to interface
Z-Wave Debug . . addInterfaceAssociation: node 057, group: 1, associations: [1]
Z-Wave Debug SENT requestBatteryLevel2: 80 02 (encrypted)
Z-Wave Debug RCVD requestBatteryLevel2: 01 07 00 13 E7 00 00 02 0E (node ACK)
Z-Wave Debug . . requestBatteryLevel2: requeuing 1 unsolicited packets
Z-Wave Debug SENT nonceReport: 01 11 00 13 39 0A 98 80 17 9F FC 0F 68 87 B9 00 25 E8 36
Z-Wave Debug SENT nonceReport: 01 11 00 13 39 0A 98 80 17 9F FC 0F 68 87 B9 00 25 E8 36 (re-sent because retransmit request)
Z-Wave Debug RCVD nonceReport: 01 07 00 13 E8 00 00 03 00 (node ACK)
Z-Wave Debug RCVD nonceReport: node 057, nonce CA 98 F9 49 B0 F7 E1 9D (saved for next send)
Z-Wave Debug RCVD encryptedPacket: 00 80 03 63 (decrypted)
Z-Wave Debug RCVD requestBatteryLevel: 01 09 00 04 00 39 03 80 03 63 FF
Z-Wave Debug . . requestBatteryLevel: node 057, level 99
Z-Wave Syncing - retrieved battery level of 99%
Z-Wave Syncing - created device "057 - Notification Sensor"
Z-Wave Syncing - created device "057 - Notification Sensor 2"
Z-Wave Syncing - created device "057 - Notification Sensor 3"
Z-Wave Syncing - created device "057 - Notification Sensor 4"
Z-Wave Syncing - created device "057 - Notification Sensor 5"
Z-Wave Syncing - created device "057 - Notification Sensor 6"
Z-Wave Syncing - created device "057 - Notification Sensor 7"
Z-Wave Syncing - created device "057 - Notification Sensor 8"
Z-Wave Syncing - complete
Z-Wave Debug terminatingSyncUI
Wed Jan 26, 2022 10:54 am
jenwill1 offline
Here is the link to the Zwave manual for the Kit
https://support.ring.com/hc/en-us/articles/360038043371
Wed Jan 26, 2022 12:38 pm
Try excluding it, re-including it without encryption, and re-syncing it. That may not be a long term solution, but I want to rule out the extra overhead of all the encryption commands from being an issue while we troubleshoot it.
After that trip the inputs again and watch the Event Log for any debug messages (it may not update the device states but you may still see some commands). If you don't let me know and I'll have you send some custom raw commands to try to get it broadcasting commands to Indigo.
Wed Jan 26, 2022 1:46 pm
jenwill1 offline
Synced without encryption.. Here's the log. Encrypted it's sets up basically 8 Notification sensors and without it sets up 9. No love on the inputs yet Matt. Send me the commands and I'll give them a shot. Thanks
Jan 26, 2022 at 1:37:23 PM
Z-Wave Debug intiatingSyncUI (timeout in 1500 seconds)
Z-Wave Debug SENT enterInclusionMode: 01 04 00 4A C1 70
Z-Wave Debug RCVD enterInclusionMode: 06 (ACK)
Z-Wave started controller inclusion mode
Z-Wave Debug RCVD inclusionMode adding slave node: 01 1B 00 4A 01 03 3C 14 04 07 01 5E 55 9F 85 59 8E 60 80 70 5A 72 71 73 6C 86 84 7A EE
Z-Wave Debug RCVD inclusionMode node added: 01 07 00 4A 01 05 3C 00 8A
Z-Wave Debug RCVD inclusionMode finished: 01 07 00 4A 01 06 3C 00 89
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 3C 86
Z-Wave Debug . . getNodeProtocolInfo: node 060, class name: Notification Sensor
Z-Wave controller included module: 060 - Notification Sensor
Jan 26, 2022 at 1:37:52 PM
Z-Wave Syncing - started for "060 - Notification Sensor"
Z-Wave Debug SENT getNodeNeighbors: 01 06 00 80 3C 01 01 45
Z-Wave Debug . . getNodeNeighbors: nodeId 060, neighbors: 2, 3, 44, 55
Z-Wave Syncing - assigning return route to "060 - Notification Sensor"
Z-Wave Debug SENT assignReturnRoute: 01 05 00 46 3C 01 81
Z-Wave Debug . . assignReturnRoute: node 060, success 1
Z-Wave Debug SENT requestNodeInfo: 01 06 00 60 3C 24 31 B0
Z-Wave Debug RCVD nodeInfoFrame: 01 1A 00 49 84 3C 14 04 07 01 5E 55 9F 85 59 8E 60 80 70 5A 72 71 73 6C 86 84 7A 6A
Z-Wave Debug . . nodeInfoFrame: node 060, combined class list: 80v1 20v1 84v1 85v1 86v1 8Ev1 55v1 59v1 5Av1 5Ev1 9Fv1 60v1 6Cv1 70v1 71v1 72v1 73v1 7Av1
Z-Wave Debug SENT requestManufactureInfo: 01 09 00 13 3C 02 72 04 25 32 BA
Z-Wave Debug RCVD requestManufactureInfo: 01 07 00 13 32 00 00 02 DB (node ACK)
Z-Wave Debug RCVD requestManufactureInfo: 01 0E 00 04 00 3C 08 72 05 03 46 0B 01 01 01 F9
Z-Wave Debug . . requestManufactureInfo: node 060, manufacturerId 0346, productId 0B010101
Z-Wave Debug SENT requestVersInfoGen: 01 09 00 13 3C 02 86 11 25 33 5A
Z-Wave Debug RCVD requestVersInfoGen: 01 07 00 13 33 00 00 02 DA (node ACK)
Z-Wave Debug RCVD requestVersInfoGen: 01 11 00 04 00 3C 0B 86 12 03 06 04 01 06 01 01 01 06 48
Z-Wave Debug . . requestVersInfoGen: node 060, protoVers 6.04, appVers 1.06
Z-Wave Debug SENT requestVersInfoCmdClass: 01 0A 00 13 3C 03 86 13 84 25 34 D9
Z-Wave Debug RCVD requestVersInfoCmdClass: 01 07 00 13 34 00 00 02 DD (node ACK)
Z-Wave Debug RCVD requestVersInfoCmdClass: 01 0A 00 04 00 3C 04 86 14 84 02 DD
Z-Wave Debug . . requestVersInfoCmdClass: node 060, class command 84 using version 2
Z-Wave Debug . . requestVersInfoCmdClass: node 060, combined class list: 80v1 20v1 84v2 85v1 86v1 8Ev1 55v1 59v1 5Av1 5Ev1 9Fv1 60v1 6Cv1 70v1 71v1 72v1 73v1 7Av1
Z-Wave Debug SENT requestVersInfoCmdClass: 01 0A 00 13 3C 03 86 13 60 25 35 3C
Z-Wave Debug RCVD requestVersInfoCmdClass: 01 07 00 13 35 00 00 02 DC (node ACK)
Z-Wave Debug RCVD requestVersInfoCmdClass: 01 0A 00 04 00 3C 04 86 14 60 04 3F
Z-Wave Debug . . requestVersInfoCmdClass: node 060, class command 60 using version 4
Z-Wave Debug . . requestVersInfoCmdClass: node 060, combined class list: 80v1 20v1 84v2 85v1 86v1 8Ev1 55v1 59v1 5Av1 5Ev1 9Fv1 60v4 6Cv1 70v1 71v1 72v1 73v1 7Av1
Z-Wave Debug SENT requestWakeInterval: 01 09 00 13 3C 02 84 05 25 36 49
Z-Wave Debug RCVD requestWakeInterval: 01 07 00 13 36 00 00 02 DF (node ACK)
Z-Wave Debug RCVD requestWakeInterval: 01 0C 00 04 00 3C 06 84 06 00 70 80 00 BF
Z-Wave Debug . . requestWakeInterval: node 060, interval 480 minutes, wakeTarget 000
Z-Wave Debug SENT setWakeInterval: 01 0D 00 13 3C 06 84 04 00 0E 10 01 25 37 56
Z-Wave Debug RCVD setWakeInterval: 01 07 00 13 37 00 00 03 DF (node ACK)
Z-Wave Syncing - device "060 - Notification Sensor" wake interval changed to 60 minutes
Z-Wave Debug SENT requestMultiEndPointInfo: 01 09 00 13 3C 02 60 07 25 38 A1
Z-Wave Debug RCVD requestMultiEndPointInfo: 01 07 00 13 38 00 00 02 D1 (node ACK)
Z-Wave Debug RCVD requestMultiEndPointInfo: 01 0B 00 04 00 3C 05 60 08 40 08 00 E9
Z-Wave Debug . . requestMultiEndPointInfo: node 060, numEndPoints 8, sameClass True, notStatic False
Z-Wave Debug SENT requestMultiEndPointDetails: 01 0A 00 13 3C 03 60 09 01 25 39 AD
Z-Wave Debug RCVD requestMultiEndPointDetails: 01 07 00 13 39 00 00 02 D0 (node ACK)
Z-Wave Debug RCVD requestMultiEndPointDetails: 01 0F 00 04 00 3C 09 60 0A 01 07 01 5E 6C 98 9F 99
Z-Wave Debug . . requestMultiEndPointDetails: node 060, endPoint 1, notStatic False, class hierarchy 07 : 01
Z-Wave Debug . . requestMultiEndPointDetails: node 060, combined multi-endpoint types: 1:(07 : 01)
Z-Wave Debug . . requestMultiEndPointDetails: node 060, combined multi-endpoint classes: 1:[5E 6C 98 9F]
Z-Wave Debug . . requestMultiEndPointDetails: node 060, combined multi-endpoint types: 1:(07 : 01), 2:(07 : 01)
Z-Wave Debug . . requestMultiEndPointDetails: node 060, combined multi-endpoint classes: 1:[5E 6C 98 9F], 2:[5E 6C 98 9F]
Z-Wave Debug . . requestMultiEndPointDetails: node 060, combined multi-endpoint types: 1:(07 : 01), 2:(07 : 01), 3:(07 : 01)
Z-Wave Debug . . requestMultiEndPointDetails: node 060, combined multi-endpoint classes: 1:[5E 6C 98 9F], 2:[5E 6C 98 9F], 3:[5E 6C 98 9F]
Z-Wave Debug . . requestMultiEndPointDetails: node 060, combined multi-endpoint types: 1:(07 : 01), 2:(07 : 01), 3:(07 : 01), 4:(07 : 01)
Z-Wave Debug . . requestMultiEndPointDetails: node 060, combined multi-endpoint classes: 1:[5E 6C 98 9F], 2:[5E 6C 98 9F], 3:[5E 6C 98 9F], 4:[5E 6C 98 9F]
Z-Wave Debug . . requestMultiEndPointDetails: node 060, combined multi-endpoint types: 1:(07 : 01), 2:(07 : 01), 3:(07 : 01), 4:(07 : 01), 5:(07 : 01)
Z-Wave Debug . . requestMultiEndPointDetails: node 060, combined multi-endpoint classes: 1:[5E 6C 98 9F], 2:[5E 6C 98 9F], 3:[5E 6C 98 9F], 4:[5E 6C 98 9F], 5:[5E 6C 98 9F]
Z-Wave Debug . . requestMultiEndPointDetails: node 060, combined multi-endpoint types: 1:(07 : 01), 2:(07 : 01), 3:(07 : 01), 4:(07 : 01), 5:(07 : 01), 6:(07 : 01)
Z-Wave Debug . . requestMultiEndPointDetails: node 060, combined multi-endpoint classes: 1:[5E 6C 98 9F], 2:[5E 6C 98 9F], 3:[5E 6C 98 9F], 4:[5E 6C 98 9F], 5:[5E 6C 98 9F], 6:[5E 6C 98 9F]
Z-Wave Debug . . requestMultiEndPointDetails: node 060, combined multi-endpoint types: 1:(07 : 01), 2:(07 : 01), 3:(07 : 01), 4:(07 : 01), 5:(07 : 01), 6:(07 : 01), 7:(07 : 01)
Z-Wave Debug . . requestMultiEndPointDetails: node 060, combined multi-endpoint classes: 1:[5E 6C 98 9F], 2:[5E 6C 98 9F], 3:[5E 6C 98 9F], 4:[5E 6C 98 9F], 5:[5E 6C 98 9F], 6:[5E 6C 98 9F], 7:[5E 6C 98 9F]
Z-Wave Debug . . requestMultiEndPointDetails: node 060, combined multi-endpoint types: 1:(07 : 01), 2:(07 : 01), 3:(07 : 01), 4:(07 : 01), 5:(07 : 01), 6:(07 : 01), 7:(07 : 01), 8:(07 : 01)
Z-Wave Debug . . requestMultiEndPointDetails: node 060, combined multi-endpoint classes: 1:[5E 6C 98 9F], 2:[5E 6C 98 9F], 3:[5E 6C 98 9F], 4:[5E 6C 98 9F], 5:[5E 6C 98 9F], 6:[5E 6C 98 9F], 7:[5E 6C 98 9F], 8:[5E 6C 98 9F]
Z-Wave Syncing - retrieved multi-endpoint classes: 1:[5E 6C 98 9F], 2:[5E 6C 98 9F], 3:[5E 6C 98 9F], 4:[5E 6C 98 9F], 5:[5E 6C 98 9F], 6:[5E 6C 98 9F], 7:[5E 6C 98 9F], 8:[5E 6C 98 9F]
Z-Wave Debug SENT requestAssociationGroupCount: 01 09 00 13 3C 02 85 05 25 3A 44
Z-Wave Debug RCVD requestAssociationGroupCount: 01 07 00 13 3A 00 00 02 D3 (node ACK)
Z-Wave Debug RCVD requestAssociationGroupCount: 01 09 00 04 00 3C 03 85 06 02 4C
Z-Wave Debug . . requestAssociationGroupCount: node 060, group count: 2
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 3C 03 85 02 01 25 3B 41
Z-Wave Debug RCVD requestAssociations: 01 07 00 13 3B 00 00 02 D2 (node ACK)
Z-Wave Debug RCVD requestAssociations: 01 0B 00 04 00 3C 05 85 03 01 01 00 4F
Z-Wave Debug . . requestAssociations: node 060, group: 1, num associations: 0, max associations: 1, replies left: 0
Z-Wave Debug . . requestAssociations: node 060, group: 1, associations: []
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 3C 03 85 02 02 25 3C 45
Z-Wave Debug RCVD requestAssociations: 01 07 00 13 3C 00 00 02 D5 (node ACK)
Z-Wave Debug RCVD requestAssociations: 01 0B 00 04 00 3C 05 85 03 02 01 00 4C
Z-Wave Debug . . requestAssociations: node 060, group: 2, num associations: 0, max associations: 1, replies left: 0
Z-Wave Debug . . requestAssociations: node 060, group: 2, associations: []
Z-Wave Debug SENT addInterfaceAssociation: 01 0B 00 13 3C 04 85 01 01 01 25 3D 43
Z-Wave Debug RCVD addInterfaceAssociation: 01 07 00 13 3D 00 00 02 D4 (node ACK)
Z-Wave Debug . . addInterfaceAssociation: node 060, group: 1, associations: [1]
Z-Wave Debug SENT requestBatteryLevel2: 01 09 00 13 3C 02 80 02 25 3E 42
Z-Wave Debug RCVD requestBatteryLevel2: 01 07 00 13 3E 00 00 08 DD (node ACK)
Z-Wave Debug RCVD requestBatteryLevel: 01 09 00 04 00 3C 03 80 03 63 2D
Z-Wave Debug . . requestBatteryLevel: node 060, level 99
Z-Wave Syncing - created device "060 - Notification Sensor"
Z-Wave Syncing - created device "060 - Notification Sensor 2"
Z-Wave Syncing - created device "060 - Notification Sensor 3"
Z-Wave Syncing - created device "060 - Notification Sensor 4"
Z-Wave Syncing - created device "060 - Notification Sensor 5"
Z-Wave Syncing - created device "060 - Notification Sensor 6"
Z-Wave Syncing - created device "060 - Notification Sensor 7"
Z-Wave Syncing - created device "060 - Notification Sensor 8"
Z-Wave Syncing - created device "060 - Notification Sensor 9"
Z-Wave Debug SENT requestAlarmSensorStatus: 01 09 00 13 3C 02 71 04 25 3F B4
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 07 00 13 3F 00 00 02 D6 (node ACK)
Z-Wave Debug waiting up to 3.0 seconds for module reply after sending request
Z-Wave Debug timeout waiting for module reply after sending request (not critical)
Z-Wave sent "060 - Notification Sensor" status request
Z-Wave Debug SENT requestBatteryLevel1: 01 09 00 13 3C 02 80 02 25 40 3C
Z-Wave Debug RCVD requestBatteryLevel1: 01 07 00 13 40 00 00 02 A9 (node ACK)
Z-Wave Error device "060 - Notification Sensor 2" does not support status request command
Z-Wave received "060 - Notification Sensor" status update battery level 99%
Jan 26, 2022 at 1:38:39 PM
Z-Wave Debug RCVD requestReply1: 01 08 00 04 00 3C 02 5A 01 96 (hex)
Mon Jan 31, 2022 4:36 pm
jenwill1 offline
Not sure where to go from here on getting this device to communicate. I've tried multiple encrypted/non-encrypted inclusions and the device does not respond to status requests, parameter reads or raw z-wave commands. Device is asleep or inoperable....
The device's LED will blink be green three times/every 3 seconds during the inclusion/sync process... the Indigo will finish it's include/sync on the event log.. and the device continues to blink 3 times/3 seconds then it will alternate Green/Red Led suggesting from the documentation below the device has not finished the inclusion and times out on inclusion, then ending with another three green blinks. So it seems it never completes the sync.
Here is a snippet from the instruction manual on classic inclusion. I turn on the inclusion in Indigo and jump to step 3. Not sure if step 2 impacts inclusion... not sure if it is a security key or a needed software input into the ring app.
Classic Inclusion Steps:
1. Initiate add flow in the Ring Alarm mobile application – Follow the guided add flow instructions provided in the Ring Alarm Mobile application
2. Select add manually and enter the 5 digit DSK pin found on the package of the Ring Alarm Retrofit Kit or the 5 digit DSK pin found on the inside of the top cover of the device.
3. Press the Learn Button below the battery terminals, and the device will enter classic inclusion mode which implements both classic inclusion with a Node Information Frame, and Network Wide Inclusion. During Classic Inclusion mode, the Green LED will blink three times every three seconds. When Classic inclusion times-out, the device will blink red and blue. (should be red/green as below?)
Led behavior for Inclusion - Blink Pattern
Smart Start Started - Green LED Three Times
Classic Inclusion Started - Green LED Three Times every three seconds.
Classic Inclusion Timed-Out - Green and Red several times.
Inclusion Successful (Authenticated S2) - Green LED on solid
Inclusion Not Successful (Self-Destruct) - Red LED on solid
Note:
• This product can be operated in any Z-Wave network with other Z-Wave certified devices from other manufacturers. All mains operated nodes within the network will act as repeaters regardless of vendor to increase reliability of the network.
• This is a SmartStart enabled product which can be added into a Z-Wave network by scanning the Z-Wave QR Code present on the product with a controller providing SmartStart inclusion. No further action is required and the SmartStart product will be added automatically within 10 minutes of being switched on in the network vicinity. This product can also be operated in any Z-Wave network with other Z-Wave certified devices from other manufacturers.
Anyone have any ideas on what to try would be greatly appreciated ! In way over my head !
Tue Feb 01, 2022 9:45 am
whmoorejr offline
There is an smoke alarm relay $22 that will tie a wired smoke alarm system to a panel. It has a N/O and a N/C output for whatever the application. Then just program it as a "Fire" zone.
https://www.amazon.com/gp/product/B0039PF21U/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
For my alarm, I used a traditional panel as the backbone; a DSC panel for all the wired stuff. I added an envisalink to bring all the wired zones (32 of them) into indigo. Why so many zones? I added a bunch. I programmed the pannel to add "Automation" zones. So, wired devices that won't set off an armed alarm but can be used to do something in indigo.... like the doorbell, and some outside motion sensors.
I basically do my own monitoring, but I do pay envisalink to monitor my system for the insurance discount.
Bill
My Plugin: My People
Wed Feb 02, 2022 2:22 pm
I'm not sure about the inclusion funniness, but let's move forward with sending manual commands to add multi-endpoint associations for group 2 back to the Z-Stick to see if that works. Try the following with the Z-Wave debug logging still enabled:
1) Use the Z-Wave->Send Raw Z-Wave Command menu command to send the following raw commands to the first device name as shown in the tab panel groups of the device dialog (likely called "Notification Sensor"):
0x8E 0x01 0x02 0x00 0x01 0x01
3) Capture Event Log snippets (debugging enabled) for when the inputs are changed, if any as well as the output from sending the raw command.
4) Presuming none or some of the inputs don't send commands, try sending the following commands (again to the first device in the group):
0x8E 0x01 0x02 0x00 0x01 0x02
0x8E 0x01 0x02 0x00 0x01 0x03
0x8E 0x01 0x02 0x00 0x01 0x04
0x8E 0x01 0x02 0x00 0x01 0x05
0x8E 0x01 0x02 0x00 0x01 0x06
0x8E 0x01 0x02 0x00 0x01 0x07
0x8E 0x01 0x02 0x00 0x01 0x08
0x8E 0x01 0x02 0x00 0x01 0x09
5) Presuming none or some of the inputs still don't send commands, repeat steps 1 to 4 but this time target the other devices in group. Does that get it working for other inputs?
Note I'm not expecting the sensor device states in Indigo to correctly update after this, but am hoping you start to receive some Z-Wave commands from the module when the inputs are changed (visible only in debug logging messages). You'll then be able to create Triggers on the raw commands being received.
Wed Feb 02, 2022 3:20 pm
jenwill1 offline
Step 1 sent to the root device (Notification Sensor)
Feb 2, 2022 at 2:37:17 PM
Z-Wave Debug SENT sendRawZwaveCommand: 01 0D 00 13 40 06 8E 01 02 00 01 01 25 82 8D
Z-Wave Debug RCVD sendRawZwaveCommand: 01 07 00 13 82 01 03 C0 AB (node NAK)
Z-Wave Error send "064 - Notification Sensor" raw command failed [8E 01 02 00 01 01]
Step 4 commands sent to root device
Feb 2, 2022 at 2:47:06 PM
Z-Wave Debug SENT sendRawZwaveCommand: 01 0D 00 13 40 06 8E 01 02 00 01 02 25 86 8A
Z-Wave Debug RCVD sendRawZwaveCommand: 01 07 00 13 86 01 03 C1 AE (node NAK)
Z-Wave Error send "064 - Notification Sensor" raw command failed [8E 01 02 00 01 02]
Z-Wave Debug SENT sendRawZwaveCommand: 01 0D 00 13 40 06 8E 01 02 00 01 03 25 87 8A
Z-Wave Debug RCVD sendRawZwaveCommand: 01 07 00 13 87 01 03 C3 AD (node NAK)
Z-Wave Error send "064 - Notification Sensor" raw command failed [8E 01 02 00 01 03]
Z-Wave Debug SENT sendRawZwaveCommand: 01 0D 00 13 40 06 8E 01 02 00 01 04 25 88 82
Z-Wave Debug RCVD sendRawZwaveCommand: 01 07 00 13 88 01 03 C2 A3 (node NAK)
Z-Wave Error send "064 - Notification Sensor" raw command failed [8E 01 02 00 01 04]
Z-Wave Debug SENT sendRawZwaveCommand: 01 0D 00 13 40 06 8E 01 02 00 01 05 25 89 82
Z-Wave Debug RCVD sendRawZwaveCommand: 01 07 00 13 89 01 03 A8 C8 (node NAK)
Z-Wave Error send "064 - Notification Sensor" raw command failed [8E 01 02 00 01 05]
Z-Wave Debug SENT sendRawZwaveCommand: 01 0D 00 13 40 06 8E 01 02 00 01 06 25 8A 82
Z-Wave Debug RCVD sendRawZwaveCommand: 01 07 00 13 8A 01 03 BD DE (node NAK)
Z-Wave Error send "064 - Notification Sensor" raw command failed [8E 01 02 00 01 06]
Z-Wave Debug SENT sendRawZwaveCommand: 01 0D 00 13 40 06 8E 01 02 00 01 07 25 8B 82
Z-Wave Debug RCVD sendRawZwaveCommand: 01 07 00 13 8B 01 03 B0 D2 (node NAK)
Z-Wave Error send "064 - Notification Sensor" raw command failed [8E 01 02 00 01 07]
Z-Wave Debug SENT sendRawZwaveCommand: 01 0D 00 13 40 06 8E 01 02 00 01 08 25 8C 8A
Z-Wave Debug RCVD sendRawZwaveCommand: 01 07 00 13 8C 01 03 B6 D3 (node NAK)
Z-Wave Error send "064 - Notification Sensor" raw command failed [8E 01 02 00 01 08]
Z-Wave Debug SENT sendRawZwaveCommand: 01 0D 00 13 40 06 8E 01 02 00 01 09 25 8D 8A
Z-Wave Debug RCVD sendRawZwaveCommand: 01 07 00 13 8D 01 03 BA DE (node NAK)
Z-Wave Error send "064 - Notification Sensor" raw command failed [8E 01 02 00 01 09]
No responses to Endpoint 2 when I trip the wired door sensor.
Sending Step 1 and 4 commands to endpoint 2 (Notification Sensor2)…..
Feb 2, 2022 at 3:01:16 PM
Z-Wave Debug SENT sendRawZwaveCommand: 01 23 00 13 40 1C 60 0D 01 05 8E 01 02 00 01 06 8E 01 02 00 01 01 8E 01 02 00 01 01 8E 01 02 00 01 01 25 96 4E
Z-Wave Debug RCVD sendRawZwaveCommand: 01 07 00 13 96 01 03 DB A4 (node NAK)
Z-Wave Error send "064 - Notification Sensor 6" raw command failed [8E 01 02 00 01 06 8E 01 02 00 01 01 8E 01 02 00 01 01 8E 01 02 00 01 01]
Feb 2, 2022 at 3:02:46 PM
Z-Wave Debug SENT sendRawZwaveCommand: 01 11 00 13 40 0A 60 0D 01 01 8E 01 02 00 01 02 25 97 E6
Z-Wave Debug RCVD sendRawZwaveCommand: 01 07 00 13 97 01 02 A9 D6 (node NAK)
Z-Wave Error send "064 - Notification Sensor 2" raw command failed [8E 01 02 00 01 02]
When I publish the root device details…
Feb 2, 2022 at 3:08:43 PM
Z-Wave Indigo Device "064 - Notification Sensor" Z-Wave Properties:
Indigo Z-Wave Version: 2021.2.0
Node ID: 64
Model: Notification Sensor
Model ID: 0B010101
Manufacturer: Ring
Manufacturer ID: 0346
Protocol Version: 6.04
Application Version: 1.06
Model Definition Version: 0
Library Type: 3
Class Name: Notification Sensor
Class Hierarchy: 04 : 07 : 01
Command Class Base: 00
Command Versions: 80v1 20v1 84v2 85v1 86v1 8Ev1 55v1 59v1 5Av1 5Ev1 9Fv1 60v4 6Cv1 70v1 71v1 72v1 73v1 7Av1
Multi-Endpoint Types: 1:(07 : 01), 2:(07 : 01), 3:(07 : 01), 4:(07 : 01), 5:(07 : 01), 6:(07 : 01), 7:(07 : 01), 8:(07 : 01)
Multi-Endpoint Classes: 1:[5E 6C 98 9F], 2:[5E 6C 98 9F], 3:[5E 6C 98 9F], 4:[5E 6C 98 9F], 5:[5E 6C 98 9F], 6:[5E 6C 98 9F], 7:[5E 6C 98 9F], 8:[5E 6C 98 9F]
Features: routing, battery, beaming, waking
Neighbors: 3, 28, 44, 45, 55
Associations: 1:[1] 2:[]
Config Values: - none -
Seems like the device thinks it’s not included…. The only response I have gotten from the device was a device get status command just after the Indigo inclusion finishes and before the inclusion led’s turn off on the device.
Thanks for your efforts. Let me know when this gets to be too much and we’ll shut it down.
Will
Wed Feb 02, 2022 5:14 pm
I didn't realize the module was battery powered. You'll need to wake it so you can send those raw commands. If the manual doesn't have steps to wake it, then exclude and re-include (and re-sync) as it will probably stay awake a while after that.
Wed Feb 02, 2022 6:30 pm
jenwill1 offline
I excluded/included without encryption. I was able to send the first command step 1, I tried to send Step 4 first line but the include led went out on the device and it failed. I then tried to send the first command in step 4 again and pressed the include button.... failed again. I tested the first contact and no report.
Although the manual says it can work with any 3rd party controller.... Could this device require to be encrypted and the 5 digit DSK pin entered to complete the inclusion process ??
Grasping at straws, thanks Matt.
Will
Feb 2, 2022 at 5:30:02 PM - Step 1 to root device
Z-Wave Debug SENT sendRawZwaveCommand: 01 0D 00 13 42 06 8E 01 02 00 01 01 25 C4 C9
Z-Wave Debug RCVD sendRawZwaveCommand: 01 07 00 13 C4 00 00 09 26 (node ACK)
Z-Wave sent "066 - Notification Sensor" raw command [8E 01 02 00 01 01]
Feb 2, 2022 at 5:30:32 PM - Step 4 to root device after device inclusion led ceased to blink...
Z-Wave Debug SENT sendRawZwaveCommand: 01 0D 00 13 42 06 8E 01 02 00 01 02 25 C5 CB
Z-Wave Debug RCVD sendRawZwaveCommand: 01 07 00 13 C5 01 04 05 2E (node NAK)
Z-Wave Error send "066 - Notification Sensor" raw command failed [8E 01 02 00 01 02]
Here's the device details afterward...
Feb 2, 2022 at 5:36:33 PM
Z-Wave Indigo Device "066 - Notification Sensor" Z-Wave Properties:
Node ID: 66
Model ID: 0B010101
Manufacturer: Ring
Library Type: 3
Neighbors: 3, 28, 65
