Zooz ZEN71 On/Off relay reported as ZEN72 Dimmer in Indigo
Mon Dec 20, 2021 9:40 am
eme jota ce offline
The ZEN71 isn't on Indigo's list of supported devices but Indigo can control and track it's On/Off status.
Thought I could report this device via the Indigo app, but couldn't find it.
Here's the log report on the device:
batteryLevel : None
buttonConfiguredCount : 0
buttonGroupCount : 0
configured : True
description : Inclusion = 3 top button three ties quickly.   Exclusion = tap down button 3 times quickly.
deviceTypeId : zwRelayType
displayStateId : onOffState
displayStateImageSel : PowerOff
displayStateValRaw : False
displayStateValUi : off
enabled : True
energyAccumBaseTime : None
energyAccumTimeDelta : None
energyAccumTotal : None
energyCurLevel : None
errorState :
folderId : 700035933
     com.perceptiveautomation.indigoplugin.zwave : (dict)
          address : 5 (integer)
          indigoObjVersion : 10 (integer)
          userConfigVal001 : false (bool)
          userConfigVal002 : 0 (integer)
          userConfigVal008 : 2 (integer)
          userConfigVal009 : 0 (integer)
          userConfigVal010 :  (string)
          userConfigVal011 : 1 (integer)
          userConfigVal012 : 0 (integer)
          userConfigVal013 : false (bool)
          userConfigVal018 :  (string)
          userConfigVal023 :  (string)
          userConfigVal024 :  (string)
          userConfigVal025 :  (string)
          userEnergyPollingEnabled : false (bool)
          userPollAfterActivity : true (bool)
          userPollInterval : 0 (integer)
          userPollingEnabled : true (bool)
          userWakeInterval : 60 (integer)
          version : 10.00 (string)
          zwAppVersMajor : 10 (integer)
          zwAppVersMinor : 0 (integer)
          zwAssociationsMap : (dict)
               g1 : (list)
                    Item : 1 (integer)
               g2 : (list)
               g3 : (list)
          zwAssociationsMapStr : 1:[1] 2:[] 3:[] (string)
          zwClassCmdBase : 37 (integer)
          zwClassCmdMap : (dict)
               c108 : 1 (integer)
               c112 : 1 (integer)
               c114 : 1 (integer)
               c115 : 1 (integer)
               c122 : 1 (integer)
               c133 : 1 (integer)
               c134 : 1 (integer)
               c135 : 1 (integer)
               c142 : 1 (integer)
               c159 : 1 (integer)
               c32 : 1 (integer)
               c37 : 1 (integer)
               c39 : 1 (integer)
               c85 : 1 (integer)
               c89 : 1 (integer)
               c90 : 1 (integer)
               c91 : 1 (integer)
               c94 : 1 (integer)
          zwClassCmdMapStr : 20v1 85v1 25v1 86v1 87v1 27v1 6Cv1 8Ev1 70v1 72v1 73v1 55v1 59v1 5Av1 5Bv1 7Av1 5Ev1 9Fv1 (string)
          zwClassIds : (list)
               Item : 4 (integer)
               Item : 16 (integer)
               Item : 1 (integer)
          zwClassInstanceCountMap : (dict)
          zwClassInstanceCountMapStr : - none - (string)
          zwClassName : Relay Power Switch (string)
          zwConfigVals : (dict)
               p1 : 0 (integer)
               p11 : 1 (integer)
               p12 : 0 (integer)
               p13 : 0 (integer)
               p2 : 0 (integer)
               p8 : 2 (integer)
               p9 : 0 (integer)
          zwConfigValsStr : 1:0 2:0 8:2 9:0 11:1 12:0 13:0 (string)
          zwDevSubIndex : 0 (integer)
          zwEncryptClassCmdMap : (dict)
          zwEncryptClassCmdMapStr : - none - (string)
          zwEncryptionStatusStr : Not Supported (string)
          zwEndpointClassMap : (dict)
          zwEndpointClassMapStr : - none - (string)
          zwEndpointDevTypeMap : (dict)
          zwEndpointDevTypeMapStr : - none - (string)
          zwFeatureListStr : routing, beaming (string)
          zwLibType : 3 (integer)
          zwManufactureId : 634 (integer)
          zwManufactureName : Zooz (string)
          zwModelDefnVers : 1 (integer)
          zwModelId : 1879089153 (integer)
          zwModelName : Dimmer Switch (ZEN72) (string)
          zwNodeNeighbors : (list)
               Item : 2 (integer)
               Item : 4 (integer)
               Item : 6 (integer)
               Item : 18 (integer)
               Item : 19 (integer)
               Item : 22 (integer)
               Item : 24 (integer)
               Item : 26 (integer)
               Item : 32 (integer)
               Item : 33 (integer)
               Item : 40 (integer)
               Item : 56 (integer)
               Item : 65 (integer)
               Item : 66 (integer)
               Item : 67 (integer)
          zwNodeNeighborsStr : 2, 4, 6, 18, 19, 22, 24, 26, 32, 33, 40, 56, 65, 66, 67 (string)
          zwProtoVersMajor : 7 (integer)
          zwProtoVersMinor : 13 (integer)
          zwShowDumpDevToLog : true (bool)
          zwShowEnergyPollingUI : false (bool)
          zwShowMainUI : true (bool)
          zwShowManualModifyConfigParmUI : false (bool)
          zwShowPollingUI : false (bool)
          zwShowSubmitModelInfoUI : false (bool)
          zwShowWakeIntervalUI : false (bool)
          zwWakeInterval : 0 (integer)
lastChanged : 2021-12-20 10:20:26
lastSuccessfulComm : 2021-12-20 10:20:26
ledStates : []
model : Dimmer Switch (ZEN72)
onState : False
ownerProps : com.perceptiveautomation.indigoplugin.zwave : (dict)
          g1 : (list)
               Item : 1 (integer)
          g2 : (list)
          g3 : (list)
          c108 : 1 (integer)
          c112 : 1 (integer)
          c114 : 1 (integer)
          c115 : 1 (integer)
          c122 : 1 (integer)
          c133 : 1 (integer)
          c134 : 1 (integer)
          c135 : 1 (integer)
          c142 : 1 (integer)
          c159 : 1 (integer)
          c32 : 1 (integer)
          c37 : 1 (integer)
          c39 : 1 (integer)
          c85 : 1 (integer)
          c89 : 1 (integer)
          c90 : 1 (integer)
          c91 : 1 (integer)
          c94 : 1 (integer)
     zwClassIds : (list)
          Item : 4 (integer)
          Item : 16 (integer)
          Item : 1 (integer)
          p1 : 0 (integer)
          p11 : 1 (integer)
          p12 : 0 (integer)
          p13 : 0 (integer)
          p2 : 0 (integer)
          p8 : 2 (integer)
          p9 : 0 (integer)
          Item : 2 (integer)
          Item : 4 (integer)
          Item : 6 (integer)
          Item : 18 (integer)
          Item : 19 (integer)
          Item : 22 (integer)
          Item : 24 (integer)
          Item : 26 (integer)
          Item : 32 (integer)
          Item : 33 (integer)
          Item : 40 (integer)
          Item : 56 (integer)
          Item : 65 (integer)
          Item : 66 (integer)
          Item : 67 (integer)
pluginId : com.perceptiveautomation.indigoplugin.zwave
protocol : ZWave
remoteDisplay : True
states : States : (dict)
subModel :
subType :
supportsAllOff : False
supportsStatusRequest : True
version : 10.00
Mon Jan 24, 2022 4:51 pm
Re: Zooz ZEN71 On/Off relay reported as ZEN72 Dimmer in Indi
Thanks, we'll get that definition corrected so it shows in Indigo as an on/off relay and not a dimmer.
Thu May 19, 2022 8:09 am
eme jota ce offline
Hi Matt,
In Indigo 2022.1 (and likely prior versions), the ZEN71 is incorrectly identified by Indigo as ZEN72.
In the attached screenshot, Z-Wave address numbers 2 and 4 are actually ZEN71's not ZEN72's.
**As a side note to anyone who plans to update their Zooz firmware (windows only), double check the model number on the device before updating. Zooz supported confirmed that I bricked the two devices( shown as ZEN72 in the screenshot) by applying the ZEN72 firmware, because they are actually ZEN71's.
Screen Shot 2022-05-18 at 10.24.09 AM.png (51.23 KiB) Viewed 1630 times
Fri May 20, 2022 2:46 pm
Sorry, this one slipped through the cracks, but I've now added the definition for the ZEN71 so it will be in 2022.1.1.
Sat May 21, 2022 3:15 pm
eme jota ce offline
Thanks, and no problem. You guys have been busy. 2022 is working great for me.
Thu May 26, 2022 10:49 am
Indigo 2022.1.1 is now available and should fix this Z-Wave bug.
Fri Jun 03, 2022 11:23 pm
gbreeze offline
any chance the change for the ZEN71 broke support for the ZEN72? Trying to add a new ZEN72 this evening and it is coming up as unknown...
It also has some really nasty side effects added as a generic module. If you try to issue on On command to it from Indigo - hangs the Z-Wave interface and requires restarting the interface... Seem to report status OK (and it responded fine to an Off command initially), but I'm excluding it as I can't have the interface Z-wave restarting and taking every other device on my Z-wave network down with it.
Sat Jun 04, 2022 1:24 pm
It is possible. I'm afraid Zooz might have used the same internal model ID for both of them, which would be most unfortunate. Can you re-sync your ZEN72 and copy/paste the Event Log results into a reply for me? Also, if you happen to have a ZEN71, then re-sync and paste the results of that one as well.
And that said, the behavior you are describing sounds more like a Z-Wave network (interference or range) issue.
Sat Jun 04, 2022 7:44 pm
gbreeze offline
If they used the same model ID, wouldn't it have come up as a ZEN71 vs. unknown?
Here's the log:
Indigo Z-Wave Version: 2022.2.1
Node ID: 15
Model: Dimmable Power Switch
Model ID: 7000A002
Manufacturer: Zooz
Manufacturer ID: 027A
Protocol Version: 7.13
Application Version: 10.00
Model Definition Version: 0
Library Type: 3
Class Name: Dimmable Power Switch
Class Hierarchy: 04 : 11 : 01
Command Class Base: 26
Command Versions: 20v1 26v4 27v1 5Ev1 70v1 5Bv1 85v1 8Ev1 59v1 55v1 86v1 72v1 5Av1 87v1 73v1 9Fv1 6Cv1 7Av1
Features: routing, beaming
Neighbors: 4, 5, 7, 16
Associations: 1:[1] 2:[] 3:[]
Config Values: - none -
Note that I also submitted it as an unknown module through the workflow/link within Indigo.
When this switch is associated with the Zwave interface it seems to cause the interface to hang. Not sure if it's a bad switch, or something else is at play, but that is he behavior I'm observed thus far.
Sun Jun 05, 2022 8:51 am
eme jota ce offline
I see ZEN72's as "Dimmable Power Switch" in Indigo's Model column. See screenshot.
Zen71's show as "Relay Switch (ZEN71)" in the column.
Hope this is helpful.
Screen Shot 2022-06-05 at 10.47.48 AM.png (48.3 KiB) Viewed 1407 times
Mon Jun 06, 2022 1:08 pm
gbreeze offline
Here's the log:
Node ID: 15
Model ID: 7000A002
Manufacturer: Zooz
Library Type: 3
FYI - I updated the ZEN72 to the latest firmware 10.10,. That was an adventure unto itself, but in the process it seems that the issue with it hanging my z-wave setup has disappeared (and it's a bit frustrating to not know with certainty the cause).
The ZEN72 shows up as an unknown device as far as Indigo is concerned when re-added. Here's the Indigo log data for the switch post update:
Node ID: 18
Model ID: 7000A002
Manufacturer: Zooz
Application Version: 10.10
Library Type: 3
Neighbors: 4, 7, 9, 16
Associations: 1:[1] 2:[] 3:[] 4:[]
Does Indigo key off the "Model ID" only for identification, or some combination of data fields?
Mon Jun 06, 2022 3:34 pm
Okay, good it does use a different model ID than the ZEN72. The next version of Indigo will map this model ID to our ZEN72 device definition, which will show the scene Triggers and device settings UI for the ZEN72.
Mon Jun 06, 2022 7:10 pm
gbreeze offline
Thanks Matt!
Just a heads up that the new firmware for the ZEN72 changes some of the parameter behaviors as detailed here:
https://www.support.getzooz.com/kb/article/849-zen72-700-series-dimmer-change-log/
The new 2.0 ZEN72s are also supposed to ship with the same firmware, as detailed here, as well as some seeming hardware hardening (I was told by Zooz support recently that these are not yet shipping)::
https://www.support.getzooz.com/kb/article/538-zen72-dimmer-switch-700-advanced-settings/
Wed Jun 29, 2022 11:55 am
Indigo 2022.1.2 is now available and should fix support for the ZEN72.
Fri Jul 01, 2022 12:17 pm
gbreeze offline
Thanks Matt. Indigo 2022.1.2 did indeed resolve the challenges I was experiencing. The log entries on startup post upgrade indicated the devices need to be resync'd guided the way.
