Thought I could report this device via the Indigo app, but couldn't find it.
Here's the log report on the device:
- Code: Select all
batteryLevel : None
buttonConfiguredCount : 0
buttonGroupCount : 0
configured : True
description : Inclusion = 3 top button three ties quickly. Exclusion = tap down button 3 times quickly.
deviceTypeId : zwRelayType
displayStateId : onOffState
displayStateImageSel : PowerOff
displayStateValRaw : False
displayStateValUi : off
enabled : True
energyAccumBaseTime : None
energyAccumTimeDelta : None
energyAccumTotal : None
energyCurLevel : None
errorState :
folderId : 700035933
com.perceptiveautomation.indigoplugin.zwave : (dict)
address : 5 (integer)
indigoObjVersion : 10 (integer)
userConfigVal001 : false (bool)
userConfigVal002 : 0 (integer)
userConfigVal008 : 2 (integer)
userConfigVal009 : 0 (integer)
userConfigVal010 : (string)
userConfigVal011 : 1 (integer)
userConfigVal012 : 0 (integer)
userConfigVal013 : false (bool)
userConfigVal018 : (string)
userConfigVal023 : (string)
userConfigVal024 : (string)
userConfigVal025 : (string)
userEnergyPollingEnabled : false (bool)
userPollAfterActivity : true (bool)
userPollInterval : 0 (integer)
userPollingEnabled : true (bool)
userWakeInterval : 60 (integer)
version : 10.00 (string)
zwAppVersMajor : 10 (integer)
zwAppVersMinor : 0 (integer)
zwAssociationsMap : (dict)
g1 : (list)
Item : 1 (integer)
g2 : (list)
g3 : (list)
zwAssociationsMapStr : 1:[1] 2:[] 3:[] (string)
zwClassCmdBase : 37 (integer)
zwClassCmdMap : (dict)
c108 : 1 (integer)
c112 : 1 (integer)
c114 : 1 (integer)
c115 : 1 (integer)
c122 : 1 (integer)
c133 : 1 (integer)
c134 : 1 (integer)
c135 : 1 (integer)
c142 : 1 (integer)
c159 : 1 (integer)
c32 : 1 (integer)
c37 : 1 (integer)
c39 : 1 (integer)
c85 : 1 (integer)
c89 : 1 (integer)
c90 : 1 (integer)
c91 : 1 (integer)
c94 : 1 (integer)
zwClassCmdMapStr : 20v1 85v1 25v1 86v1 87v1 27v1 6Cv1 8Ev1 70v1 72v1 73v1 55v1 59v1 5Av1 5Bv1 7Av1 5Ev1 9Fv1 (string)
zwClassIds : (list)
Item : 4 (integer)
Item : 16 (integer)
Item : 1 (integer)
zwClassInstanceCountMap : (dict)
zwClassInstanceCountMapStr : - none - (string)
zwClassName : Relay Power Switch (string)
zwConfigVals : (dict)
p1 : 0 (integer)
p11 : 1 (integer)
p12 : 0 (integer)
p13 : 0 (integer)
p2 : 0 (integer)
p8 : 2 (integer)
p9 : 0 (integer)
zwConfigValsStr : 1:0 2:0 8:2 9:0 11:1 12:0 13:0 (string)
zwDevSubIndex : 0 (integer)
zwEncryptClassCmdMap : (dict)
zwEncryptClassCmdMapStr : - none - (string)
zwEncryptionStatusStr : Not Supported (string)
zwEndpointClassMap : (dict)
zwEndpointClassMapStr : - none - (string)
zwEndpointDevTypeMap : (dict)
zwEndpointDevTypeMapStr : - none - (string)
zwFeatureListStr : routing, beaming (string)
zwLibType : 3 (integer)
zwManufactureId : 634 (integer)
zwManufactureName : Zooz (string)
zwModelDefnVers : 1 (integer)
zwModelId : 1879089153 (integer)
zwModelName : Dimmer Switch (ZEN72) (string)
zwNodeNeighbors : (list)
Item : 2 (integer)
Item : 4 (integer)
Item : 6 (integer)
Item : 18 (integer)
Item : 19 (integer)
Item : 22 (integer)
Item : 24 (integer)
Item : 26 (integer)
Item : 32 (integer)
Item : 33 (integer)
Item : 40 (integer)
Item : 56 (integer)
Item : 65 (integer)
Item : 66 (integer)
Item : 67 (integer)
zwNodeNeighborsStr : 2, 4, 6, 18, 19, 22, 24, 26, 32, 33, 40, 56, 65, 66, 67 (string)
zwProtoVersMajor : 7 (integer)
zwProtoVersMinor : 13 (integer)
zwShowDumpDevToLog : true (bool)
zwShowEnergyPollingUI : false (bool)
zwShowMainUI : true (bool)
zwShowManualModifyConfigParmUI : false (bool)
zwShowPollingUI : false (bool)
zwShowSubmitModelInfoUI : false (bool)
zwShowWakeIntervalUI : false (bool)
zwWakeInterval : 0 (integer)
lastChanged : 2021-12-20 10:20:26
lastSuccessfulComm : 2021-12-20 10:20:26
ledStates : []
model : Dimmer Switch (ZEN72)
onState : False
ownerProps : com.perceptiveautomation.indigoplugin.zwave : (dict)
g1 : (list)
Item : 1 (integer)
g2 : (list)
g3 : (list)
c108 : 1 (integer)
c112 : 1 (integer)
c114 : 1 (integer)
c115 : 1 (integer)
c122 : 1 (integer)
c133 : 1 (integer)
c134 : 1 (integer)
c135 : 1 (integer)
c142 : 1 (integer)
c159 : 1 (integer)
c32 : 1 (integer)
c37 : 1 (integer)
c39 : 1 (integer)
c85 : 1 (integer)
c89 : 1 (integer)
c90 : 1 (integer)
c91 : 1 (integer)
c94 : 1 (integer)
zwClassIds : (list)
Item : 4 (integer)
Item : 16 (integer)
Item : 1 (integer)
p1 : 0 (integer)
p11 : 1 (integer)
p12 : 0 (integer)
p13 : 0 (integer)
p2 : 0 (integer)
p8 : 2 (integer)
p9 : 0 (integer)
Item : 2 (integer)
Item : 4 (integer)
Item : 6 (integer)
Item : 18 (integer)
Item : 19 (integer)
Item : 22 (integer)
Item : 24 (integer)
Item : 26 (integer)
Item : 32 (integer)
Item : 33 (integer)
Item : 40 (integer)
Item : 56 (integer)
Item : 65 (integer)
Item : 66 (integer)
Item : 67 (integer)
pluginId : com.perceptiveautomation.indigoplugin.zwave
protocol : ZWave
remoteDisplay : True
states : States : (dict)
subModel :
subType :
supportsAllOff : False
supportsStatusRequest : True
version : 10.00
