Never had this issue when doing sync on a z-wave device. After upgrading to 2021.2, on an M1 mac-min with MacOS 12.1, sync for a GE Smart Motion Switch (26931), generates the following error:
Z-Wave Syncing - started for "Master Closet-Lights"
Z-Wave Syncing - retrieved module neighbors list: 6, 9, 10, 13, 14, 15, 18, 20, 21, 24, 25, 26, 27, 28, 29, 31, 32, 39, 49, 50, 51, 52, 55, 58, 59, 62, 63, 64, 65, 92, 94, 99, 103, 108, 112, 119, 126, 127, 128, 131, 136, 140, 141, 145, 147, 157, 159, 162, 167, 168, 180, 181, 182, 194, 195, 196, 197, 198
Z-Wave Syncing - assigning return route to "137 - Master Closet-Lights"
Z-Wave Error Error in plugin execution:
File "/Library/Application Support/Perceptive Automation/Indigo 2021.2/IndigoPluginHost.app/Contents/Resources/PlugIns/serialinterface.py", line 517, in startCommThread
self.processCommThread()
File "/Library/Application Support/Perceptive Automation/Indigo 2021.2/IndigoPluginHost.app/Contents/Resources/PlugIns/serialinterface.py", line 691, in processCommThread
self.processQueueInPacket(packet) # Subclass is required to define.
File "zwaveinterface.py", line 2883, in processQueueInPacket
File "zwaveinterface.py", line 2855, in _processFuncCall
File "zwaveinterface.py", line 2921, in _processCommandReply
File "zwaveinterface.py", line 2904, in _processFuncTriggersAndBroadcast
File "zwaveinterface.py", line 2853, in _processFuncCall
File "zwavecmd_manufactureinfo.py", line 79, in _processManufactureInfo
File "zwavenode.py", line 607, in _updateModelInfoFromIDs
AttributeError: 'module' object has no attribute 'kModelDefinition'
Z-Wave Error exc type is <type 'exceptions.AttributeError'>
Z-Wave Error restarting serial connection in 5.0 seconds
Z-Wave connected to Z-WaveMe USB Stick (ZME UZB1) interface on /dev/cu.usbmodem2201 (firmware 5.39, minimum SDK 6.81.01)
Z-Wave Error Error trying to communicate with "137 - Master Closet-Lights".
Z-Wave Error device "Patio Sensor-Motion" should be re-synced using the "Define and Sync..." button in the device edit dialog (the internal device definition has been revised)
Z-Wave Error failed to get module 137 info from controller ('module' object has no attribute 'kModelDefinition')
Any suggestions? Is this an issue with the driver?
JP
