I've purchased new smoke sensors: Heiman HS3SA-Z
They are discovered as a "notification sensor", but when using a smoke detector tester, nothing is shown in the event log.
How can I use these smoke sensors please?
Regards
Z-Wave Syncing - started for "_new brandvarnare"
Z-Wave Debug SENT getNodeNeighbors: 01 06 00 80 60 01 01 19
Z-Wave Debug RCVD getNodeNeighbors: 01 20 01 80 01 48 41 48 1C 01 09 03 0E 00 00 08 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0F (no inbound callback)
Z-Wave Debug . . getNodeNeighbors: nodeId 096, neighbors: 1, 12, 15, 17, 23, 28, 31, 35, 36, 37, 41, 49, 52, 57, 58, 66, 67, 68, 92
Z-Wave Syncing - retrieved module neighbors list: 1, 12, 15, 17, 23, 28, 31, 35, 36, 37, 41, 49, 52, 57, 58, 66, 67, 68, 92
Z-Wave Syncing - assigning return route to "096 - _new brandvarnare"
Z-Wave Debug SENT assignReturnRoute: 01 05 00 46 60 01 DD
Z-Wave Debug RCVD assignReturnRoute: 01 04 01 46 01 BD (no inbound callback)
Z-Wave Debug RCVD assignReturnRoute: 01 05 00 46 01 00 BD
Z-Wave Debug . . assignReturnRoute: node 096, success 1
Z-Wave Debug SENT requestNodeInfo: 01 06 00 60 60 24 7F A2
Z-Wave Debug RCVD nodeInfoFrame: 01 17 00 49 84 60 11 04 07 01 5E 85 8E 59 55 86 72 5A 73 80 9F 71 84 6C 54
Z-Wave Debug . . nodeInfoFrame: node 096, combined class list: 20v1 5Ev1 85v1 8Ev1 59v1 55v1 86v1 72v1 5Av1 73v1 80v1 9Fv1 71v1 84v1 6Cv1
Z-Wave Debug SENT requestManufactureInfo: 01 09 00 13 60 02 72 04 25 80 54
Z-Wave Debug RCVD requestManufactureInfo: 01 05 00 13 80 00 69 (node ACK)
Z-Wave Debug RCVD requestManufactureInfo: 01 0E 00 04 00 60 08 72 05 02 60 80 02 10 00 1A
Z-Wave Debug . . requestManufactureInfo: node 096, manufacturerId 0260, productId 80021000
Z-Wave Debug . . requestManufactureInfo: Heiman, Notification Sensor
Z-Wave Syncing - retrieved manufacture and model names: Heiman - 0260, Notification Sensor - 80021000
Z-Wave Debug SENT requestVersInfoGen: 01 09 00 13 60 02 86 11 25 81 B4
Z-Wave Debug RCVD requestVersInfoGen: 01 05 00 13 81 00 68 (node ACK)
Z-Wave Debug RCVD requestVersInfoGen: 01 0F 00 04 00 60 09 86 12 06 05 03 03 01 FF 00 F4
Z-Wave Debug . . requestVersInfoGen: node 096, protoVers 5.03, appVers 3.01
Z-Wave Syncing - retrieved protocol version 5.03, app version 3.01
Z-Wave Debug SENT requestVersInfoCmdClass: 01 0A 00 13 60 03 86 13 84 25 82 33
Z-Wave Debug RCVD requestVersInfoCmdClass: 01 05 00 13 82 00 6B (node ACK)
Z-Wave Debug . . requestVersInfoCmdClass: requeuing 1 unsolicited packets
Z-Wave Debug RCVD requestVersInfoCmdClass: 01 0A 00 04 00 60 04 86 14 84 02 81
Z-Wave Debug . . requestVersInfoCmdClass: node 096, class command 84 using version 2
Z-Wave Debug . . requestVersInfoCmdClass: node 096, combined class list: 20v1 5Ev1 85v1 8Ev1 59v1 55v1 86v1 72v1 5Av1 73v1 80v1 9Fv1 71v1 84v2 6Cv1
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Notification Sensor : Notification Sensor (04 : 07 : 01, base 00)
Z-Wave Syncing - retrieved command classes: 20v1 5Ev1 85v1 8Ev1 59v1 55v1 86v1 72v1 5Av1 73v1 80v1 9Fv1 71v1 84v2 6Cv1
Z-Wave Syncing - retrieved capabilities: routing, battery, beaming, waking
Z-Wave Debug SENT requestWakeInterval: 01 09 00 13 60 02 84 05 25 83 A0
Z-Wave Debug RCVD requestWakeInterval: 01 05 00 13 83 00 6A (node ACK)
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 24 06 31 05 04 22 00 2F E8
Z-Wave Debug . . requestVarSensorStatus: node 036, endpoint None, type 4, raw value 2200...
Z-Wave Debug . . requestVarSensorStatus: 4.7 W (float: 4.700000)
Z-Wave Debug received "Laundry Washingmachine" power load to 4.7 W
Z-Wave Debug timeout waiting for reply from module (retrying)
Z-Wave Debug SENT requestWakeInterval: 01 09 00 13 60 02 84 05 25 84 A7
Z-Wave Debug RCVD requestWakeInterval: 01 05 00 13 84 00 6D (node ACK)
Z-Wave Debug RCVD requestWakeInterval: 01 0C 00 04 00 60 06 84 06 00 0E 10 01 0C
Z-Wave Debug . . requestWakeInterval: node 096, interval 60 minutes, wakeTarget 001
Z-Wave Syncing - retrieved wake interval of 60 minutes
Z-Wave Debug SENT setWakeInterval: 01 0D 00 13 60 06 84 04 00 0E 10 01 25 85 B8
Z-Wave Debug RCVD setWakeInterval: 01 05 00 13 85 00 6C (node ACK)
Z-Wave Syncing - device "096 - _new brandvarnare" wake interval changed to 60 minutes
Z-Wave Debug SENT requestAssociationGroupCount: 01 09 00 13 60 02 85 05 25 86 A4
Z-Wave Debug RCVD requestAssociationGroupCount: 01 05 00 13 86 00 6F (node ACK)
Z-Wave Debug RCVD requestAssociationGroupCount: 01 09 00 04 00 60 03 85 06 02 10
Z-Wave Debug . . requestAssociationGroupCount: node 096, group count: 2
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 60 03 85 02 01 25 87 A1
Z-Wave Debug RCVD requestAssociations: 01 05 00 13 87 00 6E (node ACK)
Z-Wave Debug RCVD requestAssociations: 01 0C 00 04 00 60 06 85 03 01 05 00 01 12
Z-Wave Debug . . requestAssociations: node 096, group: 1, num associations: 1, max associations: 5, replies left: 0
Z-Wave Debug . . requestAssociations: node 096, group: 1, associations: [1]
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 60 03 85 02 02 25 88 AD
Z-Wave Debug RCVD requestAssociations: 01 05 00 13 88 00 61 (node ACK)
Z-Wave Debug RCVD requestAssociations: 01 0B 00 04 00 60 05 85 03 02 05 00 14
Z-Wave Debug . . requestAssociations: node 096, group: 2, num associations: 0, max associations: 5, replies left: 0
Z-Wave Debug . . requestAssociations: node 096, group: 2, associations: []
Z-Wave Debug SENT requestBatteryLevel2: 01 09 00 13 60 02 80 02 25 89 A9
Z-Wave Debug RCVD requestBatteryLevel2: 01 05 00 13 89 00 60 (node ACK)
Z-Wave Debug RCVD requestBatteryLevel: 01 09 00 04 00 60 03 80 03 61 73
Z-Wave Debug . . requestBatteryLevel: node 096, level 97
Z-Wave Syncing - retrieved battery level of 97%
Z-Wave Syncing - complete
Z-Wave sent "_new brandvarnare" status request
Z-Wave received "_new brandvarnare" status update battery level 97%
