Incorrect Device Classification?
Fri Dec 03, 2021 11:31 pm
jheddings offline
I'm using a GE Smart Motion Switch (26931) and Indigo seems to think it is a Dimmer. According to the docs, it is on/off only. It's not a major issue, but there are some built-in functions that attempt to "set brightness to 0" rather than "turn switch off."
Is there a way to force the device to behave like a simple switch rather than a dimmer?
Device details:
Indigo Z-Wave Version: 2021.1.1
Node ID: 26
Model: Smart Motion Switch (26931)
Model ID: 494D3032
Manufacturer: General Electric
Manufacturer ID: 0063
Protocol Version: 4.54
Application Version: 5.39
Model Definition Version: 1
Library Type: 3
Class Hierarchy: 04 : 10 : 01
Command Class Base: 25
Command Versions: 20v1 60v4 25v1 86v1 27v1 2Bv1 2Cv1 8Ev1 70v1 71v1 72v1 73v1 56v1 59v1 5Av1 7Av1 5Ev1 85v1
Multi-Endpoint Types: 1:(10 : 01), 2:(07 : 01)
Multi-Endpoint Classes: 1:[5E 59 25], 2:[5E 59 71]
Features: routing, beaming
Neighbors: 2, 12
Associations: 1:[1] 2:[] 3:[]
Config Values: - none -
Sun Dec 05, 2021 8:57 pm
Re: Incorrect Device Classification?
Looks like this module was sharing a device definition with the dimmer version. I'll get it broken out into its own definition that is a relay in the next release of Indigo. You'll need to re-sync it once we release it and it'll then change the device to an on/off relay.
Thu Dec 16, 2021 12:02 pm
Indigo 2021.2.0 is now available and should update the GE Smart Motion Switch (26931). device type to relay (note a re-sync might be required).
Sun Dec 19, 2021 12:27 am
jheddings offline
Thanks, Matt!!
