Recommendations forZWave Plugin Lamp Modules
Sun Oct 17, 2021 10:08 am
gskarp offline
Does anyone have a recommendation for ZWave plugin modules? I have had quite a few fail after only a few months. Just wanted to see if anyone has had luck with a specific model.
Sun Oct 17, 2021 11:57 pm
Dual offline
Re: Recommendations forZWave Plugin Lamp Modules
I have a number of the Zooz ZEN06 modules. All good.
Mon Oct 18, 2021 6:25 am
jalves offline
If you need a double module, the Zooz ZEN25 is a good choice. Two separate outlets each individually controlled.
Jeff
Tue Oct 19, 2021 4:59 am
I have a few Leviton units that don't support any of your "fancy" features--they do on/off/dim--that's all. No encryption, no NWI, no energy--just light control. These rely on an older version of the Z-Wave spec, but in my experience they *always* work and I've never had one go sideways (that I can recall).
I also have several Aeon units that do more of the "fancy" stuff. I find these will have the occasional 'No Ack' event and I've found the best way to recover from that is to pull power for 15-30 seconds which resets them. By no means common, but in instances where they are hard to get to it can be a bit frustrating.
