Z-Wave Dimmers Activating Without Reason
Posted: Fri Oct 15, 2021 3:53 pm
Hi, I have a house full of z-wave switches and dimmers which are all working very well with Indigo and Homekit; except for two dimmers in particular which are very problematic. The problem is they randomly turn on quite frequently, sometimes off as well but generally on. This is particularly a problem in the master bedroom. I've enabled the debug logs and i can see that the devices seem to think they're being activated, though they aren't. Strangely i find if i reboot the mac mini that hosts indigo the problems go away for a day or so. Log sample below:
- Code: Select all
16 Oct 2021 at 8:36:08 am
Z-Wave Debug RCVD nodeInfoFrame: 01 14 00 49 84 04 0E 04 11 01 26 27 72 86 73 70 2B 2C 85 EF 20 83
Z-Wave Debug queueing full request of "004 - Master Bedroom Main Light" (activity detected)
Z-Wave Debug RCVD dimmerSetLevel: 01 09 00 04 08 04 03 20 01 FF 23
Z-Wave Debug . . dimmerSetLevel: node 004, endpoint None, value 255
Z-Wave received "Master Bedroom Main Light" status update is on
Z-Wave Debug RCVD dimmerSetLevel: 01 09 00 04 00 04 03 20 01 FF 2B
Z-Wave Debug polling status of node "004 - Master Bedroom Main Light" (post-activity full request)
Z-Wave Debug SENT requestDimmerStatus: 01 09 00 13 04 02 26 02 25 40 A2
Z-Wave Debug RCVD requestDimmerStatus: 01 07 00 13 40 00 00 05 AE (node ACK)
Z-Wave Debug waiting up to 3.0 seconds for module reply after sending request
Z-Wave Debug RCVD requestDimmerStatus: 01 09 00 04 00 04 03 26 03 27 F7
Z-Wave Debug . . requestDimmerStatus: node 004, endpoint None, value 39
16 Oct 2021 at 8:38:10 am
Z-Wave Debug RCVD nodeInfoFrame: 01 14 00 49 84 0A 0E 04 11 01 26 27 72 86 73 70 2B 2C 85 EF 20 8D
Z-Wave Debug queueing full request of "010 - Dining Lounge" (activity detected)
Z-Wave Debug RCVD dimmerSetLevel: 01 09 00 04 08 0A 03 20 01 FF 2D
Z-Wave Debug . . dimmerSetLevel: node 010, endpoint None, value 255
Z-Wave received "Dining Lounge" status update is on
Z-Wave Debug RCVD dimmerSetLevel: 01 09 00 04 00 0A 03 20 01 FF 25
Z-Wave Debug polling status of node "010 - Dining Lounge" (post-activity full request)
Z-Wave Debug SENT requestDimmerStatus: 01 09 00 13 0A 02 26 02 25 41 AD
Z-Wave Debug RCVD requestDimmerStatus: 01 07 00 13 41 00 00 02 A8 (node ACK)
Z-Wave Debug RCVD requestDimmerStatus: 01 09 00 04 00 0A 03 26 03 28 F6
Z-Wave Debug . . requestDimmerStatus: node 010, endpoint None, value 40
Z-Wave Debug RCVD dimmerSetLevel: 01 09 00 04 08 04 03 20 01 00 DC
Z-Wave Debug . . dimmerSetLevel: node 004, endpoint None, value 0
Z-Wave received "Master Bedroom Main Light" status update is off
Z-Wave Debug RCVD dimmerSetLevel: 01 09 00 04 00 04 03 20 01 00 D4
Z-Wave Debug SENT requestDimmerStatus: 01 09 00 13 04 02 26 02 25 42 A0
Z-Wave Debug RCVD requestDimmerStatus: 01 07 00 13 42 00 00 04 AD (node ACK)
Z-Wave Debug RCVD requestDimmerStatus: 01 09 00 04 00 04 03 26 03 00 D0
Z-Wave Debug . . requestDimmerStatus: node 004, endpoint None, value 0
