I have about 180 nodes and it all used to be very stable but for the last month or so it is getting more and more UNstable and is really making me crazy.
I get "allot" of no ack and Indigo is not receiving data from my nodes sometimes.
I have optimized my network, rebooted every node and Indigo, tried different interfaces (Gen5 and UZM), turned on Z-wave debug and tried to find something in there, disabled unnessesary plugins and so on, to no avail.
Intermittent the network is very slow, for example I have 3 dimmers in a virtual device group that can take up to 10s to turn on (they turn on in a slow sequence), they used to be momentary more or less. If I turn them off and then on again it is usually lightning fast.
Door sensors (multiple) is not reaching Indigo, they used to and my Fibaro smoke sensors start to beep when they can't reach Indigo (not so funny at night).
For some reason Indigo is trying to fetch energy data from my Qubino dimmers/switches temperature sub-node and I get no ack.
Re-syncing the node above resultet in this:
28796977 2021-08-29 19:16:56.736 FALSE 8 Z-Wave Syncing - module returned parameter 65 instead of parameter 66 "Button down duration" (ignoring)
28796976 2021-08-29 19:16:56.734 FALSE 8 Z-Wave Syncing - module returned parameter 65 instead of parameter 66 "Button down duration" (ignoring)
28796897 2021-08-29 19:14:51.283 FALSE 8 Z-Wave Syncing - module returned parameter 65 instead of parameter 66 "Button down duration" (ignoring)
28796893 2021-08-29 19:14:43.854 FALSE 8 Z-Wave Syncing - module returned parameter 61 instead of parameter 65 "Button tap duration" (ignoring)
28796890 2021-08-29 19:14:35.574 FALSE 8 Z-Wave Syncing - module returned parameter 3 instead of parameter 60 "Minimum value" (ignoring)
28796889 2021-08-29 19:14:35.573 FALSE 8 Z-Wave Syncing - module returned parameter 3 instead of parameter 60 "Minimum value" (ignoring)
28796883 2021-08-29 19:14:14.14 FALSE 8 Z-Wave Syncing - module returned parameter 30 instead of parameter 1 "Input 1 mode" (ignoring)
28796882 2021-08-29 19:14:14.138 FALSE 8 Z-Wave Syncing - module returned parameter 30 instead of parameter 1 "Input 1 mode" (ignoring)
Some time I get flooded w/ the same data from multiple nodes (temperature for eample, 20+ messages w/ the same value in the log), removing/inserting the interface usually resolves it.
And so on...
Where should I start to get to the bottom with all this?
Could my Mac be to old/slow (normally 10% CPU load)? Can bad z-wave performance be mac-h/w related or is there something else going on?
Indigo 2021.1.1 (same problems w/ 7.5).
Mac Mini 2010 w/ 8GB RAM and High Sierra, SSD.
