GoControl Z-Wave Plus Dimmable LED Flood Light LBR30Z-1
Sun Aug 15, 2021 8:33 am
Different Computers offline
GoControl Z-Wave Plus Dimmable LED Indoor Flood Light Bulb - LBR30Z-1 Anyone using this model successfully with Indigo? I only see one GoControl bulb listed in the compatible bulbs section of the official list.
Tremendous buy right now at https://www.zwaveproducts.com/collectio ... lood-light
I’m getting sick of my old GE zigbee/hue floodlights never staying connected to the hub.
At this price it’s about worth risking it.
Mon Aug 16, 2021 5:34 pm
Re: GoControl Z-Wave Plus Dimmable LED Flood Light LBR30Z-1
I checked and no one has submitted the details or mentioned that module before. Looking at the manual though I'm pretty confident it will work fine out-of-the-box without a definition. There won't be built-in UI for the configuration parameters but you can still modifying them with the Interfaces->Z-Wave->Modify Configuration Parameter... menu item.
That is a good price!
Tue Aug 17, 2021 10:42 am
They should be arriving this week. I'll post details once I get them.
Mon Aug 23, 2021 12:57 pm
got my bulbs!
I think this is all you need. Right now they work, but Indigo doesn't really know what they are.
 Z-Wave                          Syncing - started for "048 - Dimmable Power Switch"
   Z-Wave                          Syncing - retrieved module neighbors list: 4
   Z-Wave                          Syncing - assigning return route to "048 - Dimmable Power Switch"
   Z-Wave                          Syncing - retrieved manufacture and model names: LinearLinc - 014F, Dimmable Power Switch - 47544252
   Z-Wave                          Syncing - retrieved protocol version 4.05, app version 5.16
   Z-Wave                          Syncing - retrieved class hierarchy: Routing Slave : Mulitlevel Switch : Dimmable Power Switch (04 : 11 : 01, base 26)
   Z-Wave                          Syncing - retrieved command classes: 20v1 85v1 86v1 27v1 70v1 72v1 73v1 59v1 5Av1 26v1 7Av1 5Ev1
   Z-Wave                          Syncing - retrieved encrypt commands: - none -
   Z-Wave                          Syncing - retrieved capabilities: routing, beaming
   Z-Wave                          Syncing - retrieved group 1 associations: []
   Z-Wave                          Syncing - added group 1 association to interface
   Z-Wave                          Syncing - created device "Rear Corner Spot"
   Z-Wave                          Syncing - started for "Rear Corner Spot"
   Z-Wave                          Syncing - assigning return route to "048 - Rear Corner Spot"
   Z-Wave                          Syncing - retrieved group 1 associations: [1]
Thu Aug 26, 2021 1:36 pm
Was there anything else you need to add this, aside from the above?
Thu Aug 26, 2021 2:17 pm
Are there useful configuration parameters supported by the module we should add UI for?
Sat Aug 28, 2021 8:04 am
It’s just a light bulb so the standard bulb UI should be fine. It is dimmable. It does not have any color temperature controls, but it is a Z wave repeater.
Sun Oct 02, 2022 9:23 am
Hurricane Ian gave us a power outage, and when that was over, he left behind unresponsive Z-wave bulbs.
I've followed the reset directions at https://www.gocontrol.com/manuals/LBR30Z-1-Install.pdf and tried to define and sync these back, but no luck so far.
Anyone have suggestions on how to get these back working *without* deleting the Indigo device and losing all the logic associated with them?
EDIT: Got this to work by changing the device type to something spare, then deleting the bulb from the controller, then re-including it. Though Indigo said it was already found on the controller.
Users browsing this forum: Ericbo and 3 guests
