I have the August Smart Lock Pro + Connect. I paired the lock via Z-Wave to Indigo, and I also have the August Home plugin installed, linked to the Z-Wave Indigo lock device, and the Doorsense device also setup/linked. Things work great, but I do notice that the August Home status for the lock and Doorsense lag (assuming because of the inherent polling delay with the August API).
So, my question is - is it possible to get the Doorsense status via Z-Wave similar to how I get lock status via Z-Wave? On forums for other home automation software, people seem to indicate Doorsense status is supported over Z-Wave. Is this an Indigo limitation and/or something the August Home plugin may be able to augment/improve? In the current implementation, the Doorsense device created via the August Home plugin doesn't react as quickly as I would like since it is dependent on the API and its laggyness.
