Zooz Z-Wave Plus S2 MultiSiren ZSE19
Sat May 22, 2021 9:13 pm
diefledermaus offline
I have purchased a Zooz Z-Wave Plus S2 MultiSiren ZSE19 I cannot get it to be seen beyond a basic device . It’s not directly supported. I can trigger it with an event. I cannot tell it what sound to choose. I cannot read the temperature from the device..
Anyone have one of these and give me some advice how to trigger the sounds and read the temp /humidity info
Sun May 23, 2021 4:44 pm
Re: Zooz Z-Wave Plus S2 MultiSiren ZSE19
The next version of Indigo will include a device definition for the ZSE19, which will offer at least preliminary (if not full) support.
Fri Jun 18, 2021 2:55 pm
Indigo 2021.1.0 is now available and includes support for the Zooz Multisiren (ZSE19).
Mon Jan 10, 2022 3:34 pm
3AT offline
I am seeing very strange behavior when trying to add one of these MutlSirens.
It seems to include properly, but this is what happens when trying to sync:
Z-Wave controller included module: 153 - Siren
Z-Wave stopped controller inclusion mode
Z-Wave Syncing - started for "153 - Siren"
Z-Wave Syncing - retrieved module neighbors list: 1, 2, 5, 9, 10, 11, 12, 17, 18, 26, 29, 37, 38, 41, 48, 50, 51, 52, 54, 55, 56, 63, 64, 67, 68, 69, 76, 77, 78, 79, 81, 84, 85, 93, 98, 101, 115, 117, 118, 122, 123, 127, 130, 131, 134
Z-Wave Syncing - assigning return route to "153 - Siren"
Z-Wave Error Error in plugin execution:
File "/Library/Application Support/Perceptive Automation/Indigo 2021.2/IndigoPluginHost.app/Contents/Resources/PlugIns/serialinterface.py", line 517, in startCommThread
self.processCommThread()
File "/Library/Application Support/Perceptive Automation/Indigo 2021.2/IndigoPluginHost.app/Contents/Resources/PlugIns/serialinterface.py", line 691, in processCommThread
self.processQueueInPacket(packet) # Subclass is required to define.
File "zwaveinterface.py", line 2883, in processQueueInPacket
File "zwaveinterface.py", line 2855, in _processFuncCall
File "zwaveinterface.py", line 2921, in _processCommandReply
File "zwaveinterface.py", line 2904, in _processFuncTriggersAndBroadcast
File "zwaveinterface.py", line 2853, in _processFuncCall
File "zwavecmd_manufactureinfo.py", line 79, in _processManufactureInfo
File "zwavenode.py", line 607, in _updateModelInfoFromIDs
AttributeError: 'module' object has no attribute 'kModelDefinition'
Z-Wave Error exc type is <type 'exceptions.AttributeError'>
Z-Wave Error restarting serial connection in 5.0 seconds
Z-Wave Error Syncing - failed
Z-Wave Error Timeout waiting for "153 - Siren". Module might be asleep, or is unreachable.
Z-Wave connected to Z-Stick 7 (ZWA010) interface on /dev/cu.SLAB_USBtoUART (firmware 7.15, minimum SDK 7.00.00)
Z-Wave found module included in controller with no matching device (missing or disabled): 153 - Siren
It crashes the controller, then resets it with "sync failed."
I am using a Zooz ZST10 700 USB stick. So far I've tried excluding, device full reset, and running the Indigo installer again, all with no change in this behavior.
Tue Jan 11, 2022 4:25 pm
This appears to be a bug. We'll get it fixed ASAP.
Tue Jan 11, 2022 4:53 pm
I just sent you a direct email with instructions to hopefully fix the issue.
Tue May 10, 2022 3:24 pm
Indigo 2022.1.0 is now available and fixes this problem.
Sun Jul 03, 2022 2:54 pm
So I have this installed but I cannot find a way to control the audio be it the volume or the sound file. I might be able through a raw binary zwave command but I do not know what byte does what.
Mon Jul 04, 2022 12:08 pm
It has been a while since I added support for this one (and it is a very complex definition), but there should be configuration parameters for the choosing the audio tone and volume, then you use the on/off command to the Audio Speaker relay device Indigo creates to activate it.
If you aren't seeing any device settings, then the model ID on yours probably doesn't match Indigo's definition. In that case re-sync it and copy/paste the Event Log window results into a reply.
Sun Jul 10, 2022 9:33 am
Z-Wave Syncing - retrieved manufacture and model names: Zooz - 027A, Multisiren (ZSE19) - 000C0003
Z-Wave Syncing - retrieved protocol version 5.03, app version 1.04
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Relay Switch : Siren (04 : 10 : 05, base 25)
Z-Wave Syncing - retrieved command classes: 20v1 25v1 5Ev1 85v1 59v1 55v1 86v1 72v1 5Av1 73v1 98v1 9Fv1 6Cv1 7Av1 80v1 71v1 70v1 31v5 79v1
Z-Wave Syncing - retrieved capabilities: routing, battery, beaming, security, frequentWaking
Z-Wave Syncing - retrieved parameter 1 "Alarm duration" is 180 seconds
Z-Wave Syncing - retrieved parameter 2 "Temperature interval" is 30 minutes
Z-Wave Syncing - retrieved battery level of 100%
Z-Wave Syncing - complete
Z-Wave sent " upstairs alarm" status request
Z-Wave received " upstairs alarm" status update battery level 100%
Sun Jul 10, 2022 10:59 am
That is the correct model ID (which matches are device definition), so my description above should be accurate. You have to press the button to edit the device settings, then you should see the UI to choose the audio file # and the sound volume. I don't recall how or if you can add a custom audio file with this device. I know with one of these types of modules you connect it via a USB cable to your Mac and you can upload files to it. The details should be in the manual for how it works (or if it supports custom audio files).
Sun Jul 10, 2022 1:35 pm
Okay but from what I read on the device there is a three byte set you can apply to the device to make the changes.
https://www.support.getzooz.com/kb/arti ... -settings/
and it has a large command class set whichI think Indigo supports
COMMAND_CLASS_ZWAVEPLUS_INFO_V2
COMMAND_CLASS_ASSOCIATION_V2
COMMAND_CLASS_ASSOCIATION_GRP_INFO
COMMAND_CLASS_TRANSPORT_SERVICE_V2
COMMAND_CLASS_VERSION_V3
COMMAND_CLASS_MANUFACTURER_SPECIFIC_V2
COMMAND_CLASS_DEVICE_RESET_LOCALLY
COMMAND_CLASS_POWERLEVEL
COMMAND_CLASS_SECURITY
COMMAND_CLASS_SECURITY_2
COMMAND_CLASS_SUPERVISION
COMMAND_CLASS_FIRMWARE_UPDATE_MD_V2
COMMAND_CLASS_BATTERY
COMMAND_CLASS_NOTIFICATION_V4
COMMAND_CLASS_SWITCH_BINARY
COMMAND_CLASS_CONFIGURATION
COMMAND_CLASS_SENSOR_MULTILEVEL
COMMAND_CLASS_SOUND_SWITCH
If you notice the attached screen grab I can select these as a parameter for the device but not as a an event trigger response if I try to set this parameter the event log shows Timeout waiting for command to be sent.
Screen Shot 2022-07-10 at 3.18.07 PM.png (48.61 KiB) Viewed 2079 times
so it looks like indigo can see the parameters but cannot talk to the device enough to send or set them. Now one thing I did learn is with smartthings to choose the audio file you have to use a dimmer command and the number of the file. Not ideal for an interface seeting.
I also attempted to do a modify Zwave parameter but I could not see the audio component just the overarching siren. and I tried to apply new parameters as you will see in the other screen shot but it seemed to have no effect.
Screen Shot 2022-07-10 at 3.29.26 PM.png (31.95 KiB) Viewed 2079 times
I do not know if this helps.
Mon Jul 11, 2022 10:15 am
Is your siren battery operated? If so, try powering it temporarily while changing the settings. Also, copy/paste the Event Log window contents showing the results of trying to change both settings (sound tone and sound volume) so we can see exactly what is occurring. Lastly, try temporarily moving the siren to be within a few feet of your Z-Wave controller to see if that works.
Tue Jul 19, 2022 6:40 pm
the error is Z-Wave error timeout waiting for command to be sent.
this is a spurious reply to the command which I can only currently make changes via the edit device settings
running a full event log I now see
uiSoundSwitchTone : 5 (string)
uiSoundSwitchVolume : 8 (string)
clicking on on the alarm is the default alarm sound still, turning on the speaker does not produce any sound.. So While It seems I can change settings they are not effectively being used.
I have yet to try the python script as my python skills are limited.
I do not know where the setting go within the two python lines
indigo.devices[882011891].states["zwaveSoundSwitchTone"] # State "zwaveSoundSwitchTone" of "023 - Audio Speaker"
indigo.devices[882011891].states["zwaveSoundSwitchVolume"] # State "zwaveSoundSwitchVolume" of "023 - Audio Speaker"
Script address : 23
batteryLevel : None
buttonConfiguredCount : 0
buttonGroupCount : 0
configured : True
description :
deviceTypeId : zwSoundSwitchType
displayStateId : onOffState
displayStateImageSel : PowerOff
displayStateValRaw : False
displayStateValUi : off
enabled : True
energyAccumBaseTime : None
energyAccumTimeDelta : None
energyAccumTotal : None
energyCurLevel : None
errorState :
folderId : 0
com.perceptiveautomation.indigoplugin.zwave : (dict)
SupportsSoundTone : true (bool)
SupportsSoundVolume : true (bool)
address : 23 (integer)
disableStatusLogging : false (bool)
indigoObjVersion : 10 (integer)
modelNameAndFirmware : Multisiren (ZSE19), firmware 1.04 (string)
propsPushTickler : 11 (string)
tempAlwaysFalse : false (bool)
userEnergyPollingEnabled : false (bool)
userPollInterval : (string)
userPollingEnabled : false (bool)
userWakeInterval : (string)
version : 1.04 (string)
zwAssociationsMapStr : (string)
zwClassCmdBase : 37 (integer)
zwDevSubIndex : 1 (integer)
zwEncryptionStatusStr : (string)
zwManufactureId : 634 (integer)
zwManufactureName : Zooz (string)
zwModelId : 786435 (integer)
zwModelName : Multisiren (ZSE19) (string)
zwNodeNeighborsStr : (string)
zwShowDumpDevToLog : false (bool)
zwShowEnergyPollingUI : false (bool)
zwShowMainUI : false (bool)
zwShowManualModifyConfigParmUI : false (bool)
zwShowPollingUI : false (bool)
zwShowSubmitModelInfoUI : false (bool)
zwShowWakeIntervalUI : false (bool)
configured : True
description :
enabled : True
errorState :
folderId : 0
propsPushTickler : 13 (string)
uiSoundSwitchTone : 15 (string)
uiSoundSwitchVolume : 75 (string)
lastChanged : 2022-07-19 21:27:15
lastSuccessfulComm : 2022-07-19 21:27:15
ledStates : []
model : Multisiren (ZSE19)
name : 023 - Audio Speaker
onState : False
Fri Aug 25, 2023 6:47 pm
surlyone offline
I am having a similar problem.
pulled the old out, excluded the hardware readded it ( sans encryption, had previously tried it WITH encryption) .... and yet manual changes to the sound file and volume are not "sticky"
Any pointers? ( 2022.2.2)
Z-Wave Syncing - started for "074 - Siren"
Z-Wave Debug SENT getNodeNeighbors: 01 06 00 80 4A 01 01 33
Z-Wave Debug RCVD getNodeNeighbors: 01 20 01 80 60 80 01 04 00 00 85 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 38 (no inbound callback)
Z-Wave Debug . . getNodeNeighbors: nodeId 074, neighbors: 6, 7, 16, 17, 27, 49, 51, 56, 66, 67
Z-Wave Syncing - retrieved module neighbors list: 6, 7, 16, 17, 27, 49, 51, 56, 66, 67
Z-Wave Syncing - assigning return route to "074 - Siren"
Z-Wave Debug SENT assignReturnRoute: 01 05 00 46 4A 01 F7
Z-Wave Debug RCVD assignReturnRoute: 01 04 01 46 01 BD (no inbound callback)
Z-Wave Debug RCVD assignReturnRoute: 01 05 00 46 01 00 BD
Z-Wave Debug . . assignReturnRoute: node 074, success 1
Z-Wave Debug SENT requestNodeInfo: 01 06 00 60 4A 24 D0 27
Z-Wave Debug RCVD nodeInfoFrame: 01 1B 00 49 84 4A 15 04 10 05 5E 85 59 55 86 72 5A 73 98 9F 6C 7A 80 71 25 70 31 79 90
Z-Wave Debug . . nodeInfoFrame: node 074, combined class list: 20v1 25v1 5Ev1 85v1 59v1 55v1 86v1 72v1 5Av1 73v1 98v1 9Fv1 6Cv1 7Av1 80v1 71v1 70v1 31v1 79v1
Z-Wave Debug SENT requestManufactureInfo: 01 09 00 13 4A 02 72 04 25 D1 2F
Z-Wave Debug RCVD requestManufactureInfo: 01 07 00 13 D1 00 00 02 38 (node ACK)
Z-Wave Debug RCVD requestManufactureInfo: 01 0E 00 04 00 4A 08 72 05 02 7A 00 0C 00 03 B7
Z-Wave Debug . . requestManufactureInfo: node 074, manufacturerId 027A, productId 000C0003
Z-Wave Debug . . requestManufactureInfo: Zooz, Multisiren (ZSE19)
Z-Wave Debug SENT requestVersInfoGen: 01 09 00 13 4A 02 86 11 25 D2 CD
Z-Wave Debug RCVD requestVersInfoGen: 01 07 00 13 D2 00 00 02 3B (node ACK)
Z-Wave Debug RCVD requestVersInfoGen: 01 11 00 04 00 4A 0B 86 12 03 05 03 01 03 01 01 00 01 39
Z-Wave Debug . . requestVersInfoGen: node 074, protoVers 5.03, appVers 1.03
Z-Wave Syncing - retrieved protocol version 5.03, app version 1.03
Z-Wave Debug SENT requestVersInfoCmdClass: 01 0A 00 13 4A 03 86 13 31 25 D3 FD
Z-Wave Debug RCVD requestVersInfoCmdClass: 01 07 00 13 D3 00 00 03 3B (node ACK)
Z-Wave Debug RCVD requestVersInfoCmdClass: 01 0A 00 04 00 4A 04 86 14 31 05 19
Z-Wave Debug . . requestVersInfoCmdClass: node 074, class command 31 using version 5
Z-Wave Debug . . requestVersInfoCmdClass: node 074, combined class list: 20v1 25v1 5Ev1 85v1 59v1 55v1 86v1 72v1 5Av1 73v1 98v1 9Fv1 6Cv1 7Av1 80v1 71v1 70v1 31v5 79v1
Z-Wave Debug SENT requestAssociationGroupCount: 01 09 00 13 4A 02 85 05 25 D4 DC
Z-Wave Debug RCVD requestAssociationGroupCount: 01 07 00 13 D4 00 00 03 3C (node ACK)
Z-Wave Debug RCVD requestAssociationGroupCount: 01 09 00 04 00 4A 03 85 06 01 39
Z-Wave Debug . . requestAssociationGroupCount: node 074, group count: 1
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 4A 03 85 02 01 25 D5 D9
Z-Wave Debug RCVD requestAssociations: 01 07 00 13 D5 00 00 03 3D (node ACK)
Z-Wave Debug RCVD requestAssociations: 01 0B 00 04 00 4A 05 85 03 01 05 00 3D
Z-Wave Debug . . requestAssociations: node 074, group: 1, num associations: 0, max associations: 5, replies left: 0
Z-Wave Debug . . requestAssociations: node 074, group: 1, associations: []
Z-Wave Syncing - retrieved group 1 associations: []
Z-Wave Debug SENT addInterfaceAssociation: 01 0B 00 13 4A 04 85 01 01 01 25 D6 DE
Z-Wave Debug RCVD addInterfaceAssociation: 01 07 00 13 D6 00 00 03 3E (node ACK)
Z-Wave Syncing - added group 1 association to interface
Z-Wave Debug . . addInterfaceAssociation: node 074, group: 1, associations: [1]
Z-Wave Debug SENT requestConfigVal2: 01 0A 00 13 4A 03 70 05 01 25 D7 29
Z-Wave Debug RCVD requestConfigVal2: 01 07 00 13 D7 00 00 03 3F (node ACK)
Z-Wave Debug RCVD requestConfigVal: 01 0C 00 04 00 4A 06 70 06 01 02 00 B4 7A
Z-Wave Debug . . requestConfigVal: node 074, parm index 1, value 180 (size 2)
Z-Wave Debug . . requestConfigVal: node 074, combined config vals: 1:180
Z-Wave Debug SENT requestConfigVal2: 01 0A 00 13 4A 03 70 05 02 25 D8 25
Z-Wave Debug RCVD requestConfigVal2: 01 07 00 13 D8 00 00 03 30 (node ACK)
Z-Wave Debug RCVD requestConfigVal: 01 0C 00 04 00 4A 06 70 06 02 02 00 1E D3
Z-Wave Debug . . requestConfigVal: node 074, parm index 2, value 30 (size 2)
Z-Wave Debug . . requestConfigVal: node 074, combined config vals: 1:180 2:30
Z-Wave Debug SENT requestBatteryLevel2: 01 09 00 13 4A 02 80 02 25 D9 D3
Z-Wave Debug RCVD requestBatteryLevel2: 01 07 00 13 D9 00 00 03 31 (node ACK)
Z-Wave Debug RCVD requestBatteryLevel: 01 09 00 04 00 4A 03 80 03 50 68
Z-Wave Debug . . requestBatteryLevel: node 074, level 80
Z-Wave Syncing - retrieved battery level of 80%
Z-Wave Syncing - created device "074 - Siren"
Z-Wave Syncing - created device "074 - Audio Speaker"
Z-Wave Syncing - created device "074 - Tamper"
Z-Wave Syncing - created device "074 - Temperature"
Z-Wave Syncing - created device "074 - Humidity"
Z-Wave Debug terminatingSyncUI
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 06 0A 32 02 21 74 00 00 46 E7 00 00 23
Z-Wave Debug . . requestMeterLevel: node 006, endpoint None, meterType 01, raw value 7400...
Z-Wave Debug . . requestMeterLevel: 18.151 W (float: 18.151000)
Z-Wave Debug received "Kitchen oversink 6" power load to 18.151 W
HomeKit Bridge Debug Indigo device Kitchen oversink 6 changed and is linked to HomeKit, checking if that change impacts HomeKit
HomeKit Bridge Debug Kitchen oversink 6 started as a HomeKit Lightbulb
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 10 0A 32 02 21 74 00 00 00 00 00 00 94
Z-Wave Debug . . requestMeterLevel: node 016, endpoint None, meterType 01, raw value 7400...
Z-Wave Debug . . requestMeterLevel: 0.000 W (float: 0.000000)
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 46 0A 32 02 21 74 00 00 00 00 00 00 C2
Z-Wave Debug . . requestMeterLevel: node 070, endpoint None, meterType 01, raw value 7400...
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 13 0A 32 02 21 74 00 00 00 00 00 00 97
Z-Wave Debug . . requestMeterLevel: node 019, endpoint None, meterType 01, raw value 7400...
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 07 0A 32 02 21 74 00 00 00 00 00 00 83
Z-Wave Debug . . requestMeterLevel: node 007, endpoint None, meterType 01, raw value 7400...
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 11 0A 32 02 21 74 00 00 00 00 00 00 95
Z-Wave Debug . . requestMeterLevel: node 017, endpoint None, meterType 01, raw value 7400...
Z-Wave Debug RCVD requestMeterLevel: 01 15 00 04 00 16 0F 32 02 21 44 00 00 00 A6 00 3C 00 00 00 A6 00 9E
Z-Wave Debug . . requestMeterLevel: node 022, endpoint None, meterType 01, raw value 4400...
Z-Wave Debug . . requestMeterLevel: 1.66 kWh (float: 1.660000)
Z-Wave Debug RCVD requestMeterLevel: 01 15 00 04 00 16 0F 32 02 21 4C 00 00 00 B3 00 3C 00 00 00 B3 00 96
Z-Wave Debug . . requestMeterLevel: node 022, endpoint None, meterType 01, raw value 4C00...
Z-Wave Debug . . requestMeterLevel: 1.79 kVAh (float: 1.790000)
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 06 0A 32 02 21 74 00 00 47 F8 00 00 3D
Z-Wave Debug . . requestMeterLevel: 18.424 W (float: 18.424000)
Z-Wave Debug received "Kitchen oversink 6" power load to 18.424 W
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 46 0E 32 02 21 64 00 00 65 F4 01 2C 00 00 65 F4 FF
Z-Wave Debug . . requestMeterLevel: node 070, endpoint None, meterType 01, raw value 6400...
Z-Wave Debug . . requestMeterLevel: 26.100 kWh (float: 26.100000)
Z-Wave Debug SENT setSoundSwitchConfigSetLevel: 01 0B 00 13 4A 04 79 05 03 01 25 DA 28
Z-Wave Error timeout waiting for command to be sent
Z-Wave Debug RCVD setSoundSwitchConfigSetLevel: 01 07 00 13 DA 00 00 7F 4E (node ACK)
