Heatit Z-TRM3 Thermostat?
Sun May 16, 2021 10:11 am
jrcitizen offline
I checked on the Indigo compatibility list for the Heatit Z-TRM3 thermostat, but it is not on the list. I do not have this thermostat yet, but wondering if...
a) Any plans to fully support in a future update?
b) Does anyone have this thermostat today, and how well does it work in Indigo? Any gotchas I need to know about?
Thu May 20, 2021 2:50 pm
Re: Heatit Z-TRM3 Thermostat?
We'll look into adding support for it once someone has one and submits the device profile from Indigo to us. We currently support the TRM2fx, so adding support for this model shouldn't be too difficult. Basic functionality will likely work out-of-the-box with the current version of Indigo.
Thu May 20, 2021 3:54 pm
RAID5 offline
I have it and can submit that right now, installed mine a week ago, some things show up and work and some doesn’t.
RAID5 "A happy Swede addicted to automation"
Thu May 20, 2021 4:15 pm
Great. Re-sync it and also copy/paste the Event Log results into a reply for me here. Also describe what is not working. Thanks.
Thu May 20, 2021 4:16 pm
RAID5 offline
I think i have submitted a request now. :D
Thu May 20, 2021 4:17 pm
RAID5 offline
Here is the requested sync.
The only thing that work is that I can request a status update and see the set temperature.
The device is divided in 4, 1 Thermostat and 3 Multilevel Sensors.
None of the sensors are reporting anything ( I have currently not connected any external sensors to it, just the built in one)
May 20, 2021 at 11:59:52 PM
Z-Wave Syncing - started for "Tims Room Floor Heating - Thermostat"
Z-Wave Syncing - retrieved module neighbors list: 3, 4, 5, 7, 8, 10, 11, 14, 18, 20, 22, 26, 27, 29, 31, 32, 33, 34, 36, 37, 38, 41, 42, 44, 45, 50, 53, 54, 55, 56, 59, 61, 62, 64, 65, 66, 67, 68, 69, 70, 73, 75, 78, 87, 88, 90, 91
Z-Wave Syncing - assigning return route to "093 - Tims Room Floor Heating - Thermostat"
Z-Wave Syncing - retrieved manufacture and model names: HeatIT - 019B, General Thermostat (v2) - 00030203
Z-Wave Syncing - retrieved protocol version 6.07, app version 4.00
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Thermostat : General Thermostat (v2) (04 : 08 : 06, base 40)
Z-Wave Syncing - retrieved command classes: 20v1 40v1 42v1 43v1 85v1 86v1 60v4 6Cv1 32v3 8Ev1 70v1 72v1 73v1 55v1 98v1 59v1 5Av1 7Av1 5Ev1 9Fv1
Z-Wave Syncing - retrieved encrypt commands: 40 42 43 85 86 8E 59 5A 60 32 70 72 73 7A
Z-Wave Syncing - retrieved capabilities: routing, beaming, security
Z-Wave Syncing - retrieved multi-endpoint types: 1:(08 : 06), 2:(21 : 01), 3:(21 : 01), 4:(21 : 01)
Z-Wave Syncing - retrieved multi-endpoint classes: 1:[5E 6C 98 9F], 2:[5E 6C 98 9F], 3:[5E 6C 98 9F], 4:[5E 6C 98 9F]
Z-Wave Syncing - retrieved group 1 associations: []
Z-Wave Syncing - retrieved group 3 associations: []
Z-Wave Syncing - retrieved group 4 associations: []
Z-Wave Syncing - retrieved group 5 associations: []
Z-Wave Syncing - added group 1 association to interface
Z-Wave Syncing - complete
Fri May 21, 2021 3:28 pm
jrcitizen offline
Notwithstanding the Indigo update, how do you find the unit? One of the reviews on Vesternet makes it sound a bit tempermental... whats your experience been?
Sat May 22, 2021 12:12 am
RAID5 offline
My experience is that it is very stable, I have only clicked troughs it’s menus and installed it in the wall. I set it for 22C and it has worked really well. Can you please refer the the review and I can read it and comment on that. I read somewhere that there was a firmware upgrade to it, I have not looked in to that, I was in a hurry to install it, because the old was broken.
Tue May 25, 2021 4:26 pm
shapa offline
To warn everyone - the previous model has nearly burned my house.
The thermostat relay was staying in the "on" mode, ignoring safety limits, and in some areas, the floor was ~100C, basically burning hot. It used to work fine for ~3-4 years.
Some parts of the floor are damaged irreversibly.
We are fortunate that my wife noticed the issue, and we were at home.
Fri Dec 03, 2021 4:24 pm
RAID5 offline
How far away are we to get support for this device?
Fri Dec 03, 2021 4:34 pm
I hope to have it supported in the next release. No specific ETA on the release date yet.
Fri Dec 03, 2021 4:35 pm
RAID5 offline
Sounds promising, looking forward to that. Thanks for a quick response.
Thu Dec 16, 2021 11:56 am
Indigo 2021.2.0 is now available and includes support for the HeatIt Thermostat (Z-TRM3).
Fri Dec 17, 2021 3:30 pm
RAID5 offline
Hi, I downloaded the new version but it didn't work for me.
I removed and added the device from Indigo, but it still doesn't work.
Do I have to unpair the device and pair the device as a z-wave unit to get it working?
Z-Wave Syncing - started for "093 - Thermostat"
Z-Wave Syncing - retrieved module neighbors list: 3, 4, 5, 7, 8, 10, 11, 14, 18, 20, 22, 26, 27, 29, 31, 32, 33, 34, 36, 37, 38, 41, 42, 44, 45, 50, 53, 54, 55, 56, 59, 61, 62, 64, 65, 66, 67, 68, 69, 70, 73, 75, 78, 87, 88, 90, 91, 97, 98
Z-Wave Syncing - assigning return route to "093 - Thermostat"
Z-Wave Syncing - retrieved manufacture and model names: HeatIT - 019B, Thermostat (Z-TRM3) - 00030203
Z-Wave Syncing - added group 1 multi association to interface
Z-Wave Error device "093 - Internal Sensor" does not support status request command
Z-Wave Error device "093 - Thermostat" does not support setpoint command
Z-Wave Error device "093 - Thermostat" does not support setHvacMode command
Sat Dec 18, 2021 4:28 pm
We are looking into this. The module seems to be misreporting its capabilities. On one hand it reports that the endpoint 1 device is a thermostat, on the other hand it doesn't list any of the thermostat command classes as being supported by endpoint 1. So Indigo creates a thermostat device mapped to endpoint 1, but then when it tries to send commands to it realizes it doesn't support (or claims to not support) those commands and doesn't send them.
