Custos BVS-ZWU support
Thu May 13, 2021 7:58 am
7rdr7 offline
https://custos.store/products/custos-ba ... kit-z-wave
https://products.z-wavealliance.org/pro ... quencyId=2
This looks like a well designed product. Is it on the radar for inclusion into the next Indigo release.
Fri May 14, 2021 12:59 pm
Re: Custos BVS-ZWU support
We won't know for sure until someone has one and tries it out, but based on the manual I think it will probably work without a device definition. If you get one then copy/paste the Event Log results of the sync into a reply for us (along with a description of how well it works).
Sun May 16, 2021 6:59 am
7rdr7 offline
Thanks. Ordered. I'll post the results.
Thu May 20, 2021 2:16 pm
7rdr7 offline
Hey Matt,
It works, on/off.. The internal temperature sensor does not appear in the association. Other features are not present as there is no driver for Indigo. Overall, it's a well made, powerful little device.
Z-Wave Syncing - started for "Outside Water Tap"
Z-Wave Syncing - retrieved module neighbors list: 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 26, 33, 34, 36, 45, 62, 65, 76, 90, 92, 96, 108, 118, 126, 134, 135, 136, 148, 156, 157, 159, 161, 162, 163, 164, 165, 169, 177, 178, 185, 186, 187, 189, 190, 212, 217, 221, 222, 223, 224, 225, 226, 228, 229, 230, 231, 232
Z-Wave Syncing - assigning return route to "037 - Outside Water Tap"
Z-Wave Syncing - retrieved manufacture and model names: Unknown - 0270, Relay Switch - 0101000A
Z-Wave Syncing - retrieved protocol version 7.13, app version 3.03
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Relay Switch : -- (04 : 10 : 00, base 25)
Z-Wave Syncing - retrieved command classes: 20v1 85v1 22v1 71v1 25v1 86v1 87v1 6Cv1 8Ev1 70v1 31v11 72v1 73v1 55v1 98v1 59v1 5Av1 7Av1 5Ev1 9Fv1
Z-Wave Syncing - retrieved capabilities: routing, beaming, security
Z-Wave Syncing - retrieved group 3 associations: []
Z-Wave Syncing - retrieved group 4 associations: []
Z-Wave Syncing - retrieved group 5 associations: []
Z-Wave Syncing - complete
Z-Wave sent "Outside Water Tap" status request
Fri May 28, 2021 1:18 pm
Thanks, we'll look into adding a definition that supports the temperature sensor and the water leak notification state.
Sat May 29, 2021 10:25 am
7rdr7 offline
Thanks Matt. It's working very well.
Thu Aug 05, 2021 2:03 am
Indigo 2021.1.1 is now available and adds support for the temperature sensor and leak detection of the BVS-ZWU.
Thu Aug 05, 2021 7:32 am
7rdr7 offline
Thanks Matt!
Users browsing this forum: No registered users and 34 guests
