Aeon Labs ZW120 V’s ZWA008 - reverse On/Off
Sun Apr 25, 2021 5:03 am
raoul offline
I have both sensors and due to a change with the control page use of them I’ve found that the ZWA008 has an option to reverse On/Off commands, unfortunately the ZW120 doesn’t have this option. Is it possible to add it in some way?
Thank you.
Sun Apr 25, 2021 2:59 pm
Re: Aeon Labs ZW120 V’s ZWA008 - reverse On/Off
There are a couple of configuration parameters for the ZW120 to reverse the on/off commands sent but in the version of the module I have I ran into a firmware bug that prevented them from working well (so I didn't add UI for them). You can, however, try manually setting them using the Interfaces->Z-Wave->Modify Configuration Parameter... menu item. Try setting both parameter 1 and parameter 3 to have a value of 1. Note you may have to press the button on the ZW120 to wake it for the parameters to be set. Check the Event Log window to see if it works.
Tue Apr 27, 2021 2:36 am
raoul offline
Thanks Matt,
Unfortunately it doesn’t appear to make any difference if either or both of those parameters are set to 0 or 1. I’ll look at taking it up with Aeon Labs.
