Hi, I added a z-wave remote and noticed reception was intermittent from the position I wanted to use it.
So... I added a z-wave range extender and manually added it as an association with the remote.
That helped and it is working but I want to make sure the less reliable path direct to my gateway (node 1) does not receive and transmit the signal from the remote since it sometimes reads the keys incorrectly.
Is if safe (OK) to manually remove node 1 from the association list for the remote?
Thanks in advance for any help....
