The Inovelli docs mention 'Z-wave Association' when configuring two Inovelli switches in a 3-way configuration. I want the same switch experience on both ends, so an aux switch will not do in this case.
https://support.inovelli.com/portal/en/ ... imitations
Mentions in case 1 that 'Z-Wave Association' is the best way to have the switches behave as if they were both controlling the endpoint. The method appears to function much like the Caseta switches in that the remote switch is simply a remote control that controls another physical switch that is directly attached to the load.
Does Indigo have the capacity to configure the 'Z-Wave Association'? I don't own any Inovelli switches, but would like to convert my Caseta installation to them. Why? The apparent inability to detect the button press on the Caseta switch is a big limitation.
Many thanks in advance for your time!!
