Swidget R1015S not reporting energy details with Indigo 7.5
Fri Dec 25, 2020 2:43 pm
drbrain offline
I added a Swidget switch with the control module to Indigo 7.4 and re-synced it with Indigo 7.5:
Indigo Device "Garage fan" Z-Wave Properties:
Indigo Z-Wave Version: 7.5.0
Node ID: 56
Model: Smart Outlet (R1015S)
Model ID: 00010001
Manufacturer: Swidget
Manufacturer ID: 0345
Protocol Version: 6.02
Application Version: 6.01
Model Definition Version: 1
Library Type: 6
Class Hierarchy: 04 : 10 : 01
Command Class Base: 25
Command Versions: 20v1 60v4 22v1 25v1 86v1 27v1 6Cv1 72v1 8Ev1 32v2 73v1 55v1 56v1 59v1 5Av1 85v1 5Ev1 9Fv1
Multi-Endpoint Types: 1:(10 : 01), 2:(31 : 01)
Multi-Endpoint Classes: 1:[5E 85 59 8E 25 32 9F 6C], 2:[5E 85 59 8E 32 9F 6C]
Features: routing, beaming, energyMeter
Neighbors: 1, 2, 3, 4, 5, 6, 8, 9, 10, 11, 12, 13, 14, 15, 20, 22, 24, 29, 31, 32, 35, 37, 39, 47, 52, 53, 54, 57, 58, 60, 61
Associations: - none -
Config Values: - none -
This caused the non-controlled outlet to appear in Indigo 7.5, but neither device is showing power usage statistics in the UI like I see for other devices that monitor power (Aeotec ZW096, ZW099). These devices should report power per the "Multi-Endpoint Classes" or the data sheet.
Do I need to remove, reset and re-add the device for this to show up, or do we only have on/off support in Indigo 7.5?
Sat Dec 26, 2020 1:41 pm
Re: Swidget R1015S not reporting energy details with Indigo
Yes, try excluding it from the Z-Wave controller, re-including it, and finally re-syncing it.
If that doesn't work then copy/paste the Event Log results of all those steps into a reply for us.
Sat Jan 02, 2021 6:42 pm
drbrain offline
I tried following the instructions for deleting a z-wave device, but putting the Swidget in ADD/REMOVE mode would get two flashes of blue before the LED turned red indicating some failure of communication.
Nothing of note was logged when trying to exclude the device in Indigo (besides started/stopping/stopped controller exclusion mode).
I then performed a factory reset of the Swidget controller and re-added the device the usual way in Indigo, but still no display of power usage in the UI.
   Z-Wave                          started controller inclusion mode
   Z-Wave                          controller included module: 064 - Relay Power Switch
   Z-Wave                          stopped controller inclusion mode
   Z-Wave                          Syncing - started for "064 - Relay Power Switch"
   Z-Wave                          Syncing - retrieved module neighbors list: 2, 3, 4, 5, 6, 9, 10, 11, 12, 13, 14, 15, 16, 22, 27, 29, 30, 32, 34, 37, 38, 39, 44, 47, 52, 53, 54, 57, 58, 60, 61, 62
   Z-Wave                          Syncing - assigning return route to "064 - Relay Power Switch"
   Z-Wave                          Syncing - retrieved manufacture and model names: Swidget - 0345, Smart Outlet (R1015S) - 00010001
   Z-Wave                          Syncing - retrieved protocol version 6.02, app version 6.01
   Z-Wave                          Syncing - retrieved class hierarchy: Routing Slave : Relay Switch : Relay Power Switch (04 : 10 : 01, base 25)
   Z-Wave                          Syncing - retrieved command classes: 20v1 85v1 86v1 8Ev1 55v1 56v1 59v1 5Av1 5Ev1 9Fv1 60v4 22v1 25v1 27v1 6Cv1 72v1 32v2 73v1
   Z-Wave                          Syncing - retrieved encrypt commands: - none -
   Z-Wave                          Syncing - retrieved capabilities: routing, beaming
   Z-Wave                          Syncing - retrieved multi-endpoint types: 1:(10 : 01), 2:(31 : 01)
   Z-Wave                          Syncing - retrieved multi-endpoint classes: 1:[5E 85 59 8E 25 32 9F 6C], 2:[5E 85 59 8E 32 9F 6C]
   Z-Wave                          Syncing - group 1 association to interface not supported by module (skipping)
   Z-Wave                          Syncing - created device "064 - Outlet and Energy/Power"
   SQL Logger                      creating table device_history_1802660502 for "064 - Outlet and Energy/Power"
   Z-Wave                          Syncing - created device "064 - Energy/Power Only"
   Z-Wave                          sent "064 - Outlet and Energy/Power" status request
   Z-Wave                          received "064 - Outlet and Energy/Power" status update is on
   Z-Wave                          sent "064 - Outlet and Energy/Power" off
   Z-Wave                          sent "064 - Outlet and Energy/Power" on
Also, the SQL Logger table created only has id, ts, and onoffstate columns.
I'm not sure what "group 1 association to interface not supported by module (skipping)" means, but in the "Manage Associations…" dialog the device is not present in the "Controlling device" drop-down list but is present in the "Device to add" drop-down list.
I tried the above twice.
The one thing I haven't tried is factory reset along with turning power to the module on and off.
Sun Jan 03, 2021 8:36 pm
Try selecting each device that is created (064 - Energy/Power Only and 064 - Outlet and Energy/Power) in the Main Window. Does the Device Details section have an Update and Reset button visible? If so, try pressing them both (for each device) and copy/paste the Event Log results into a reply for me.
Also turn on Indigo's Z-Wave Debug Logging checkbox, which you can access via the Interfaces->Z-Wave->Configure... menu item, then re-sync the device and copy/paste the results for me.
Tue Jan 05, 2021 8:14 pm
drbrain offline
Device Details doesn't have the Update or Reset buttons for the either device (
Controlled outlet
emerson 2021-01-05 17-52-38.png (411.18 KiB) Viewed 1422 times
Meter-only outlet
emerson 2021-01-05 17-53-38.png (348.74 KiB) Viewed 1422 times
I do see these buttons for other meter devices (like device 022, "Fireplace light strand" that emitted an update event while syncing device 064).
After switching to debug mode it seemed to enumerate all devices so I trimmed out all but my controller (in case that makes any difference) and the swidget device (node 064).
I didn't trim anything during the syncing
I clicked "Send status request" on the main sub device after syncing finished.
   Z-Wave Debug                    stopping node healing thread
   Z-Wave Debug                    stopping node status polling thread
   Z-Wave Debug                    stopped zwave packet parser thread
   Z-Wave                          connection reset requested
   Z-Wave Debug                    starting serial connection loop
   Z-Wave Debug                    starting zwave packet parser thread
   Z-Wave Debug                    SENT getVersion: 01 03 00 15 E9
   Z-Wave Debug                    RCVD getVersion: 01 10 01 15 5A 2D 57 61 76 65 20 34 2E 30 35 00 01 97 (no inbound callback)
   Z-Wave Debug                    . .  getVersion: Z-Wave 4.05 static controller
   Z-Wave Debug                    SENT getHomeID: 01 03 00 20 DC
   Z-Wave Debug                    RCVD getHomeID: 01 08 01 20 C2 24 68 36 01 6F (no inbound callback)
   Z-Wave Debug                    . .  getHomeID: C2246836, nodeID: 001
   Z-Wave Debug                    SENT getInterfaceFeatures: 01 03 00 05 F9
   Z-Wave Debug                    RCVD getInterfaceFeatures: 01 04 01 05 18 E7 (no inbound callback)
   Z-Wave Debug                    . .  getInterfaceFeatures: 18
   Z-Wave Debug                    SENT getInterfaceApiCapabilities: 01 03 00 07 FB
   Z-Wave Debug                    RCVD getInterfaceApiCapabilities: 01 2B 01 07 04 20 00 00 00 01 00 01 FE 81 FF 88 CF 1F 00 00 FB 9F 7D A0 67 00 80 80 00 80 86 00 00 00 E8 73 00 00 0E 00 00 60 00 00 03 (no inbound callback)
   Z-Wave Debug                    . .  getInterfaceApiCapabilities: supportedFuncIDs: 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 17 18 1C 20 21 22 23 24 27 28 29 2A 2B 2C 2D 41 42 44 45 46 47 48 49 4A 4B 4C 4D 50 51 53 54 55 56 57 5E 60 61 62 63 66 67 78 80 90 92 93 98 B4 B6 B7 B8 B9 BA BD BE BF D2 D3 D4 EE EF
   Z-Wave Debug                    . .  getInterfaceApiCapabilities: serialApi 4.32, manufactureId 0000, productType 0001, productId 0001
   Z-Wave                          connected to Generic Controller interface on /dev/cu.GoControl_zwave (firmware 4.32, SDK unknown)
   Z-Wave Debug                    SENT forceSUC: 01 05 00 54 01 01 AE
   Z-Wave Debug                    RCVD forceSUC: 01 04 01 54 01 AF (no inbound callback)
   Z-Wave Debug                    SENT getInitialNodeData: 01 03 00 02 FE
   Z-Wave Debug                    RCVD getInitialNodeData: 01 25 01 02 05 08 1D FF FF FE FF FF DF FF FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 ED (no inbound callback)
   Z-Wave Debug                    . .  getInitialNodeData: is static update controller
   Z-Wave Debug                    . .  getInitialNodeData: [1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64]
   Z-Wave Debug                    SENT getNodeProtocolInfo: 01 04 00 41 01 BB
   Z-Wave Debug                    RCVD getNodeProtocolInfo: 01 09 01 41 D3 16 01 02 02 01 73 (no inbound callback)
   Z-Wave Debug                    . .  getNodeProtocolInfo:       node 001, class name: Static Computer Controller
   Z-Wave Debug                    . .  getNodeProtocolInfo:            class hierarchy: Static Controller : Static Controller : Static Computer Controller (02 : 02 : 01)
   Z-Wave Debug                    . .  getNodeProtocolInfo:         base class command: 00
   Z-Wave Debug                    . .  getNodeProtocolInfo:   supported class commands: 20
   Z-Wave Debug                    . .  getNodeProtocolInfo:     encrypt class commands:
   Z-Wave Debug                    . .  getNodeProtocolInfo:                   features: beaming
[… what appears to be enumeration of all devices …]
   Z-Wave Debug                    SENT getNodeProtocolInfo: 01 04 00 41 40 FA
   Z-Wave Debug                    RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 01 04 10 01 ED (no inbound callback)
   Z-Wave Debug                    . .  getNodeProtocolInfo:       node 064, class name: Relay Power Switch
   Z-Wave Debug                    . .  getNodeProtocolInfo:            class hierarchy: Routing Slave : Relay Switch : Relay Power Switch (04 : 10 : 01)
   Z-Wave Debug                    . .  getNodeProtocolInfo:         base class command: 25
   Z-Wave Debug                    . .  getNodeProtocolInfo:   supported class commands: 20 25 27
   Z-Wave Debug                    . .  getNodeProtocolInfo:                   features: routing, beaming
   Z-Wave Debug                    starting node healing thread
   Z-Wave Debug                    starting node status polling thread
   Z-Wave Debug                    intiatingSyncUI (timeout in 1500 seconds)
   Z-Wave                          Syncing - started for "Garage fan"
   Z-Wave Debug                    SENT getNodeNeighbors: 01 06 00 80 40 01 01 39
   Z-Wave Debug                    RCVD getNodeNeighbors: 01 20 01 80 3E FF 20 B4 72 48 38 3B 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 32 (no inbound callback)
   Z-Wave Debug                    . .  getNodeNeighbors: nodeId 064, neighbors: 2, 3, 4, 5, 6, 9, 10, 11, 12, 13, 14, 15, 16, 22, 27, 29, 30, 32, 34, 37, 38, 39, 44, 47, 52, 53, 54, 57, 58, 60, 61, 62
   Z-Wave                          Syncing - assigning return route to "064 - Garage fan"
   Z-Wave Debug                    SENT assignReturnRoute: 01 05 00 46 40 01 FD
   Z-Wave Debug                    RCVD assignReturnRoute: 01 04 01 46 01 BD (no inbound callback)
   Z-Wave Debug                    RCVD requestMeterLevel: 01 14 00 04 00 16 0E 32 02 21 64 00 00 12 08 02 58 00 00 12 07 D7
   Z-Wave Debug                    . .  requestMeterLevel: node 022, endpoint None, meterType 01, raw value 6400...
   Z-Wave Debug                    . .  requestMeterLevel: 4.616 kWh (float: 4.616000)
   Z-Wave                          received "Fireplace light strand" energy total to 4.616 kWh
   Z-Wave Debug                    RCVD requestMeterLevel: 01 10 00 04 00 16 0A 32 02 21 74 00 00 1E DF 00 00 53
   Z-Wave Debug                    . .  requestMeterLevel: node 022, endpoint None, meterType 01, raw value 7400...
   Z-Wave Debug                    . .  requestMeterLevel: 7.903 W (float: 7.903000)
   Z-Wave                          received "Fireplace light strand" power load to 7.903 W
   Z-Wave Debug                    RCVD assignReturnRoute: 01 05 00 46 01 00 BD
   Z-Wave Debug                    . .  assignReturnRoute: node 064, success 1
   Z-Wave Debug                    SENT requestNodeInfo: 01 06 00 60 40 24 36 CB
   Z-Wave Debug                    RCVD nodeInfoFrame: 01 19 00 49 84 40 13 04 10 01 5E 86 85 59 72 25 73 32 9F 55 6C 56 22 5A 60 8E 19
   Z-Wave Debug                    . .  nodeInfoFrame: node 064, combined class list: 20v1 60v1 22v1 25v1 86v1 27v1 6Cv1 72v1 8Ev1 32v1 73v1 55v1 56v1 59v1 5Av1 85v1 5Ev1 9Fv1
   Z-Wave Debug                    SENT requestManufactureInfo: 01 09 00 13 40 02 72 04 25 37 C3
   Z-Wave Debug                    RCVD requestManufactureInfo: 01 05 00 13 37 00 DE (node ACK)
   Z-Wave Debug                    RCVD requestManufactureInfo: 01 0E 00 04 00 40 08 72 05 03 45 00 01 00 01 8C
   Z-Wave Debug                    . .  requestManufactureInfo: node 064, manufacturerId 0345, productId 00010001
   Z-Wave Debug                    . .  requestManufactureInfo: Swidget, Smart Outlet (R1015S)
   Z-Wave Debug                    SENT requestVersInfoGen: 01 09 00 13 40 02 86 11 25 38 2D
   Z-Wave Debug                    RCVD requestVersInfoGen: 01 05 00 13 38 00 D1 (node ACK)
   Z-Wave Debug                    RCVD requestVersInfoGen: 01 11 00 04 00 40 0B 86 12 06 06 02 06 01 02 01 01 02 30
   Z-Wave Debug                    . .  requestVersInfoGen: node 064, protoVers 6.02, appVers 6.01
   Z-Wave Debug                    SENT requestVersInfoCmdClass: 01 0A 00 13 40 03 86 13 60 25 39 4C
   Z-Wave Debug                    RCVD requestVersInfoCmdClass: 01 05 00 13 39 00 D0 (node ACK)
   Z-Wave Debug                    RCVD requestVersInfoCmdClass: 01 0A 00 04 00 40 04 86 14 60 04 43
   Z-Wave Debug                    . .  requestVersInfoCmdClass: node 064, class command 60 using version 4
   Z-Wave Debug                    . .  requestVersInfoCmdClass: node 064, combined class list: 20v1 60v4 22v1 25v1 86v1 27v1 6Cv1 72v1 8Ev1 32v1 73v1 55v1 56v1 59v1 5Av1 85v1 5Ev1 9Fv1
   Z-Wave Debug                    SENT requestVersInfoCmdClass: 01 0A 00 13 40 03 86 13 32 25 3A 1D
   Z-Wave Debug                    RCVD requestVersInfoCmdClass: 01 05 00 13 3A 00 D3 (node ACK)
   Z-Wave Debug                    RCVD requestVersInfoCmdClass: 01 0A 00 04 00 40 04 86 14 32 02 17
   Z-Wave Debug                    . .  requestVersInfoCmdClass: node 064, class command 32 using version 2
   Z-Wave Debug                    . .  requestVersInfoCmdClass: node 064, combined class list: 20v1 60v4 22v1 25v1 86v1 27v1 6Cv1 72v1 8Ev1 32v2 73v1 55v1 56v1 59v1 5Av1 85v1 5Ev1 9Fv1
   Z-Wave                          Syncing - retrieved command classes: 20v1 60v4 22v1 25v1 86v1 27v1 6Cv1 72v1 8Ev1 32v2 73v1 55v1 56v1 59v1 5Av1 85v1 5Ev1 9Fv1
   Z-Wave Debug                    SENT requestMultiEndPointInfo: 01 09 00 13 40 02 60 07 25 3B DE
   Z-Wave Debug                    RCVD requestMultiEndPointInfo: 01 05 00 13 3B 00 D2 (node ACK)
   Z-Wave Debug                    RCVD requestMultiEndPointInfo: 01 0B 00 04 00 40 05 60 08 00 02 00 DF
   Z-Wave Debug                    . .  requestMultiEndPointInfo: node 064, numEndPoints 2, sameClass False, notStatic False
   Z-Wave Debug                    SENT requestMultiEndPointDetails: 01 0A 00 13 40 03 60 09 01 25 3C D4
   Z-Wave Debug                    RCVD requestMultiEndPointDetails: 01 05 00 13 3C 00 D5 (node ACK)
   Z-Wave Debug                    RCVD requestMultiEndPointDetails: 01 13 00 04 00 40 0D 60 0A 01 10 01 5E 85 59 8E 25 32 9F 6C 37
   Z-Wave Debug                    . .  requestMultiEndPointDetails: node 064, endPoint 1, notStatic False, class hierarchy 10 : 01
   Z-Wave Debug                    . .  requestMultiEndPointDetails: node 064, combined multi-endpoint types: 1:(10 : 01)
   Z-Wave Debug                    . .  requestMultiEndPointDetails: node 064, combined multi-endpoint classes: 1:[5E 85 59 8E 25 32 9F 6C]
   Z-Wave Debug                    SENT requestMultiEndPointDetails: 01 0A 00 13 40 03 60 09 02 25 3D D6
   Z-Wave Debug                    RCVD requestMultiEndPointDetails: 01 05 00 13 3D 00 D4 (node ACK)
   Z-Wave Debug                    RCVD requestMultiEndPointDetails: 01 12 00 04 00 40 0C 60 0A 02 31 01 5E 85 59 8E 32 9F 6C 30
   Z-Wave Debug                    . .  requestMultiEndPointDetails: node 064, endPoint 2, notStatic False, class hierarchy 31 : 01
   Z-Wave Debug                    . .  requestMultiEndPointDetails: node 064, combined multi-endpoint types: 1:(10 : 01), 2:(31 : 01)
   Z-Wave Debug                    . .  requestMultiEndPointDetails: node 064, combined multi-endpoint classes: 1:[5E 85 59 8E 25 32 9F 6C], 2:[5E 85 59 8E 32 9F 6C]
   Z-Wave Debug                    SENT requestAssociationGroupCount: 01 09 00 13 40 02 85 05 25 3E 3C
   Z-Wave Debug                    RCVD requestAssociationGroupCount: 01 05 00 13 3E 00 D7 (node ACK)
   Z-Wave Debug                    RCVD requestAssociationGroupCount: 01 09 00 04 00 40 03 85 06 01 33
   Z-Wave Debug                    . .  requestAssociationGroupCount: node 064, group count: 1
   Z-Wave Debug                    SENT requestAssociations: 01 0A 00 13 40 03 85 02 01 25 3F 39
   Z-Wave Debug                    RCVD requestAssociations: 01 05 00 13 3F 00 D6 (node ACK)
   Z-Wave Debug                    RCVD requestAssociations: 01 0B 00 04 00 40 05 85 03 01 00 00 32
   Z-Wave Debug                    . .  requestAssociations: node 064, group: 1, num associations: 0, max associations: 0, replies left: 0
   Z-Wave Debug                    SENT requestMeterInfo: 01 09 00 13 40 02 32 03 25 40 F3
   Z-Wave Debug                    RCVD requestMeterInfo: 01 05 00 13 40 00 A9 (node ACK)
   Z-Wave Debug                    RCVD requestMeterInfo: 01 0A 00 04 00 40 04 32 04 01 04 86
   Z-Wave Debug                    . .  requestMeterInfo: node 064, meterType 01, subTypeFlags 04, supportsReset False
   Z-Wave Debug                    SENT requestMeterInfo: 01 0D 00 13 40 06 60 0D 01 01 32 03 25 41 9F
   Z-Wave Debug                    RCVD requestMeterInfo: 01 05 00 13 41 00 A8 (node ACK)
   Z-Wave Debug                    RCVD multiEndPointPacket: 01 0E 00 04 00 40 08 60 0D 01 01 32 04 01 04 E3
   Z-Wave Debug                    . .  multiEndPointPacket: node 064, endPoint 1
   Z-Wave Debug                    RCVD requestMeterInfo: 01 0A 00 04 00 40 04 32 04 01 04 FF
   Z-Wave Debug                    SENT requestMeterInfo: 01 0D 00 13 40 06 60 0D 01 02 32 03 25 42 9F
   Z-Wave Debug                    RCVD requestMeterInfo: 01 05 00 13 42 00 AB (node ACK)
   Z-Wave Debug                    RCVD multiEndPointPacket: 01 0E 00 04 00 40 08 60 0D 02 01 32 04 01 04 E0
   Z-Wave Debug                    . .  multiEndPointPacket: node 064, endPoint 2
   Z-Wave Debug                    SENT requestRelayStatus: 01 0D 00 13 40 06 60 0D 01 01 25 02 25 43 8B
   Z-Wave Debug                    RCVD requestRelayStatus: 01 05 00 13 43 00 AA (node ACK)
   Z-Wave Debug                    waiting up to 3.0 seconds for module reply after sending request
   Z-Wave Debug                    terminatingSyncUI
   Z-Wave                          sent "Garage fan" status request
   Z-Wave Debug                    RCVD multiEndPointPacket: 01 0D 00 04 00 40 07 60 0D 01 01 25 03 FF 05
   Z-Wave Debug                    RCVD requestRelayStatus: 01 09 00 04 00 40 03 25 03 FF FF
   Z-Wave Debug                    . .  requestRelayStatus: node 064, endpoint 1, value 255
   Z-Wave Debug                    SENT requestRelayStatus: 01 0D 00 13 40 06 60 0D 01 01 25 02 25 44 8C
   Z-Wave Debug                    RCVD requestRelayStatus: 01 05 00 13 44 00 AD (node ACK)
Thu Jan 07, 2021 5:55 pm
It looks like this particular module supports power (watts) but not energy (kWh) which is confusing Indigo somewhat. I'll work off the forum directly with you on a fix for this in a bit.
Fri Jun 18, 2021 2:58 pm
Indigo 2021.1.0 is now available and should fix the energy / power reporting issue discussed above.
