Inclusion to Indigo 7.4.1 somehow worked but for some reason it is included as an Fibaro Wall Plug Relay with Heating control but no wall plug on/off.
Debug log during inclusion:
- Code: Select all
Z-Wave Debug RCVD inclusionMode node found: 01 07 00 4A 03 02 00 00 B3
Z-Wave Debug RCVD inclusionMode adding slave node: 01 1D 00 4A 03 03 38 16 04 10 01 5E 7A 86 72 60 5A 70 73 77 71 85 8E 59 25 2B 2C 27 22 31 38
Z-Wave Debug RCVD inclusionMode node respondCmds: 5E 7A 86 72 60 5A 70 73 77 71 85 8E 59 25 2B 2C 27 22 31
Z-Wave Debug RCVD inclusionMode node added: 01 07 00 4A 03 05 38 00 8C
Z-Wave Debug SENT exitInclusionMode: 01 04 00 4A 05 B4
Z-Wave Debug RCVD exitInclusionMode: 06 (ACK)
Z-Wave Debug RCVD inclusionMode finished: 01 07 00 4A 03 06 38 00 8F
Debug log during sync:
- Code: Select all
Z-Wave Syncing - started for "054 - General Thermostat (v2)"
Z-Wave Debug SENT getNodeNeighbors: 01 06 00 80 36 01 01 4F
Z-Wave Debug RCVD getNodeNeighbors: 01 20 01 80 00 82 03 10 0C 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 43 (no inbound callback)
Z-Wave Debug . . getNodeNeighbors: nodeId 054, neighbors: 10, 16, 17, 18, 29, 35, 36, 56
Z-Wave Syncing - retrieved module neighbors list: 10, 16, 17, 18, 29, 35, 36, 56
Z-Wave Syncing - assigning return route to "054 - General Thermostat (v2)"
Z-Wave Debug SENT assignReturnRoute: 01 05 00 46 36 01 8B
Z-Wave Debug RCVD assignReturnRoute: 01 04 01 46 01 BD (no inbound callback)
Z-Wave Debug RCVD assignReturnRoute: 01 05 00 46 01 00 BD
Z-Wave Debug . . assignReturnRoute: node 054, success 1
Z-Wave Debug SENT requestNodeInfo: 01 06 00 60 36 24 68 E3
Z-Wave Debug RCVD nodeInfoFrame: 01 1A 00 49 84 36 14 04 10 01 5E 22 85 59 70 56 5A 7A 72 32 8E 71 73 98 31 25 86 7F
Z-Wave Debug . . nodeInfoFrame: node 054, combined class list: 20v1 40v1 22v1 43v1 85v1 86v1 71v1 32v1 8Ev1 70v1 31v1 72v1 73v1 56v1 98v1 59v1 5Av1 7Av1 5Ev1 25v1
Z-Wave Debug SENT requestManufactureInfo: 01 09 00 13 36 02 72 04 25 69 EB
Z-Wave Debug RCVD requestManufactureInfo: 01 07 00 13 69 00 00 08 8A (node ACK)
Z-Wave Debug RCVD requestManufactureInfo: 01 0E 00 04 00 36 08 72 05 01 0F 06 02 10 01 A7
Z-Wave Debug . . requestManufactureInfo: node 054, manufacturerId 010F, productId 06021001
Z-Wave Debug . . requestManufactureInfo: Fibaro System, Wall Plug Relay (FGWP102)
Z-Wave Syncing - retrieved manufacture and model names: Fibaro System - 010F, Wall Plug Relay (FGWP102) - 06021001
Z-Wave Debug SENT requestVersInfoGen: 01 09 00 13 36 02 86 11 25 6A 09
Z-Wave Debug RCVD requestVersInfoGen: 01 07 00 13 6A 00 00 06 87 (node ACK)
Z-Wave Debug RCVD requestVersInfoGen: 01 11 00 04 00 36 0B 86 12 03 04 05 03 02 02 01 03 02 42
Z-Wave Debug . . requestVersInfoGen: node 054, protoVers 4.05, appVers 3.02
Z-Wave Syncing - retrieved protocol version 4.05, app version 3.02
Z-Wave Debug SENT requestVersInfoCmdClass: 01 0A 00 13 36 03 86 13 32 25 6B 3A
Z-Wave Debug RCVD requestVersInfoCmdClass: 01 07 00 13 6B 00 00 06 86 (node ACK)
Z-Wave Debug RCVD requestVersInfoCmdClass: 01 0A 00 04 00 36 04 86 14 32 02 61
Z-Wave Debug . . requestVersInfoCmdClass: node 054, class command 32 using version 2
Z-Wave Debug . . requestVersInfoCmdClass: node 054, combined class list: 20v1 40v1 22v1 43v1 85v1 86v1 71v1 32v2 8Ev1 70v1 31v1 72v1 73v1 56v1 98v1 59v1 5Av1 7Av1 5Ev1 25v1
Z-Wave Debug SENT requestVersInfoCmdClass: 01 0A 00 13 36 03 86 13 31 25 6C 3E
Z-Wave Debug RCVD requestVersInfoCmdClass: 01 07 00 13 6C 00 00 06 81 (node ACK)
Z-Wave Debug RCVD requestVersInfoCmdClass: 01 0A 00 04 00 36 04 86 14 31 05 65
Z-Wave Debug . . requestVersInfoCmdClass: node 054, class command 31 using version 5
Z-Wave Debug . . requestVersInfoCmdClass: node 054, combined class list: 20v1 40v1 22v1 43v1 85v1 86v1 71v1 32v2 8Ev1 70v1 31v5 72v1 73v1 56v1 98v1 59v1 5Av1 7Av1 5Ev1 25v1
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Thermostat : General Thermostat (v2) (04 : 08 : 06, base 40)
Z-Wave Syncing - retrieved command classes: 20v1 40v1 22v1 43v1 85v1 86v1 71v1 32v2 8Ev1 70v1 31v5 72v1 73v1 56v1 98v1 59v1 5Av1 7Av1 5Ev1 25v1
Z-Wave Syncing - retrieved capabilities: routing, beaming, security, frequentWaking
Z-Wave Debug SENT requestAssociationGroupCount: 01 09 00 13 36 02 85 05 25 6D 19
Z-Wave Debug RCVD requestAssociationGroupCount: 01 07 00 13 6D 00 00 06 80 (node ACK)
Z-Wave Debug RCVD requestAssociationGroupCount: 01 09 00 04 00 36 03 85 06 03 47
Z-Wave Debug . . requestAssociationGroupCount: node 054, group count: 3
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 36 03 85 02 01 25 6E 1E
Z-Wave Debug RCVD requestAssociations: 01 07 00 13 6E 00 00 06 83 (node ACK)
Z-Wave Debug RCVD requestAssociations: 01 0C 00 04 00 36 06 85 03 01 01 00 01 40
Z-Wave Debug . . requestAssociations: node 054, group: 1, num associations: 1, max associations: 1, replies left: 0
Z-Wave Debug . . requestAssociations: node 054, group: 1, associations: [1]
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 36 03 85 02 02 25 6F 1C
Z-Wave Debug RCVD requestAssociations: 01 07 00 13 6F 00 00 06 82 (node ACK)
Z-Wave Debug RCVD requestAssociations: 01 0B 00 04 00 36 05 85 03 02 0A 00 4D
Z-Wave Debug . . requestAssociations: node 054, group: 2, num associations: 0, max associations: 10, replies left: 0
Z-Wave Debug . . requestAssociations: node 054, group: 2, associations: []
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 36 03 85 02 03 25 70 02
Z-Wave Debug RCVD requestAssociations: 01 07 00 13 70 00 00 06 9D (node ACK)
Z-Wave Debug RCVD requestAssociations: 01 0B 00 04 00 36 05 85 03 03 0A 00 4C
Z-Wave Debug . . requestAssociations: node 054, group: 3, num associations: 0, max associations: 10, replies left: 0
Z-Wave Debug . . requestAssociations: node 054, group: 3, associations: []
Z-Wave Syncing - retrieved group 3 associations: []
Z-Wave Debug SENT requestMeterInfo: 01 09 00 13 36 02 32 03 25 71 B4
Z-Wave Debug RCVD requestMeterInfo: 01 07 00 13 71 00 00 06 9C (node ACK)
Z-Wave Debug RCVD requestMeterInfo: 01 0A 00 04 00 36 04 32 04 81 05 71
Z-Wave Debug . . requestMeterInfo: node 054, meterType 01, subTypeFlags 05, supportsReset True
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 36 03 70 05 01 25 72 F0
Z-Wave Debug RCVD requestConfigVal: 01 07 00 13 72 00 00 06 9F (node ACK)
Z-Wave Debug RCVD requestConfigVal: 01 0B 00 04 00 36 05 70 06 01 01 00 B5
Z-Wave Debug . . requestConfigVal: node 054, parm index 1, value 0 (size 1)
Z-Wave Syncing - retrieved parameter 1 "Force module to always ON (disable OFF)" is false
Z-Wave Debug . . requestConfigVal: node 054, combined config vals: 1:0
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 36 03 70 05 02 25 73 F2
Z-Wave Debug RCVD requestConfigVal: 01 07 00 13 73 00 00 06 9E (node ACK)
Z-Wave Debug RCVD requestConfigVal: 01 0B 00 04 00 36 05 70 06 02 01 01 B7
Z-Wave Debug . . requestConfigVal: node 054, parm index 2, value 1 (size 1)
Z-Wave Syncing - retrieved parameter 2 "Power up to last known state" is true
Z-Wave Debug . . requestConfigVal: node 054, combined config vals: 1:0 2:1
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 36 03 70 05 28 25 74 DF
Z-Wave Debug RCVD requestConfigVal: 01 07 00 13 74 00 00 06 99 (node ACK)
Z-Wave Debug RCVD requestConfigVal: 01 0C 00 04 00 36 06 70 06 28 02 61 A8 52
Z-Wave Debug . . requestConfigVal: node 054, parm index 40, value 25000 (size 2)
Z-Wave Syncing - retrieved parameter 40 "Power exceeded threshold" is 25000 * 0.1 watts
Z-Wave Debug . . requestConfigVal: node 054, combined config vals: 40:25000 1:0 2:1
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 36 03 70 05 03 25 75 F5
Z-Wave Debug RCVD requestConfigVal: 01 07 00 13 75 00 00 06 98 (node ACK)
Z-Wave Debug RCVD requestConfigVal: 01 0C 00 04 00 36 06 70 06 03 02 00 00 B0
Z-Wave Debug . . requestConfigVal: node 054, parm index 3, value 0 (size 2)
Z-Wave Syncing - retrieved parameter 3 "Power overloaded threshold" is 0 * 0.1 watts
Z-Wave Debug . . requestConfigVal: node 054, combined config vals: 40:25000 1:0 2:1 3:0
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 36 03 70 05 0A 25 76 FF
Z-Wave Debug RCVD requestConfigVal: 01 07 00 13 76 00 00 06 9B (node ACK)
Z-Wave Debug RCVD requestConfigVal: 01 0B 00 04 00 36 05 70 06 0A 01 50 EE
Z-Wave Debug . . requestConfigVal: node 054, parm index 10, value 80 (size 1)
Z-Wave Syncing - retrieved parameter 10 "Immediate power threshold" is 80 %
Z-Wave Debug . . requestConfigVal: node 054, combined config vals: 40:25000 1:0 2:1 3:0 10:80
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 36 03 70 05 0B 25 77 FF
Z-Wave Debug RCVD requestConfigVal: 01 07 00 13 77 00 00 06 9A (node ACK)
Z-Wave Debug RCVD requestConfigVal: 01 0B 00 04 00 36 05 70 06 0B 01 0F B0
Z-Wave Debug . . requestConfigVal: node 054, parm index 11, value 15 (size 1)
Z-Wave Syncing - retrieved parameter 11 "Interval power threshold" is 15 %
Z-Wave Debug . . requestConfigVal: node 054, combined config vals: 1:0 2:1 3:0 40:25000 10:80 11:15
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 36 03 70 05 0C 25 78 F7
Z-Wave Debug RCVD requestConfigVal: 01 07 00 13 78 00 00 06 95 (node ACK)
Z-Wave Debug RCVD requestConfigVal: 01 0C 00 04 00 36 06 70 06 0C 02 00 1E A1
Z-Wave Debug . . requestConfigVal: node 054, parm index 12, value 30 (size 2)
Z-Wave Syncing - retrieved parameter 12 "Interval report delay" is 30 seconds
Z-Wave Debug . . requestConfigVal: node 054, combined config vals: 1:0 2:1 3:0 40:25000 10:80 11:15 12:30
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 36 03 70 05 0D 25 79 F7
Z-Wave Debug RCVD requestConfigVal: 01 07 00 13 79 00 00 06 94 (node ACK)
Z-Wave Debug RCVD requestConfigVal: 01 0C 00 04 00 36 06 70 06 0D 02 00 0A B4
Z-Wave Debug . . requestConfigVal: node 054, parm index 13, value 10 (size 2)
Z-Wave Syncing - retrieved parameter 13 "Energy report threshold" is 10 * 0.1 kWh
Z-Wave Debug . . requestConfigVal: node 054, combined config vals: 1:0 2:1 3:0 40:25000 10:80 11:15 12:30 13:10
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 36 03 70 05 0E 25 7A F7
Z-Wave Debug RCVD requestConfigVal: 01 07 00 13 7A 00 00 05 94 (node ACK)
Z-Wave Debug RCVD requestConfigVal: 01 0C 00 04 00 36 06 70 06 0E 02 0E 10 A3
Z-Wave Debug . . requestConfigVal: node 054, parm index 14, value 3600 (size 2)
Z-Wave Syncing - retrieved parameter 14 "Periodic power reports" is 3600 seconds
Z-Wave Debug . . requestConfigVal: node 054, combined config vals: 1:0 2:1 3:0 40:25000 10:80 11:15 12:30 13:10 14:3600
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 36 03 70 05 0F 25 7B F7
Z-Wave Debug RCVD requestConfigVal: 01 07 00 13 7B 00 00 06 96 (node ACK)
Z-Wave Debug RCVD requestConfigVal: 01 0B 00 04 00 36 05 70 06 0F 01 01 BA
Z-Wave Debug . . requestConfigVal: node 054, parm index 15, value 1 (size 1)
Z-Wave Syncing - retrieved parameter 15 "Include Wall Plug energy usage in reports" is true
Z-Wave Debug . . requestConfigVal: node 054, combined config vals: 1:0 2:1 3:0 40:25000 10:80 11:15 12:30 13:10 14:3600 15:1
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 36 03 70 05 29 25 7C D6
Z-Wave Debug RCVD requestConfigVal: 01 07 00 13 7C 00 00 06 91 (node ACK)
Z-Wave Debug RCVD requestConfigVal: 01 0B 00 04 00 36 05 70 06 29 01 01 9C
Z-Wave Debug . . requestConfigVal: node 054, parm index 41, value 1 (size 1)
Z-Wave Syncing - retrieved parameter 41 "LED ring color when ON" is 1 "Smooth Color Change from Power"
Z-Wave Debug . . requestConfigVal: node 054, combined config vals: 1:0 2:1 3:0 40:25000 41:1 10:80 11:15 12:30 13:10 14:3600 15:1
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 36 03 70 05 2A 25 7D D4
Z-Wave Debug RCVD requestConfigVal: 01 07 00 13 7D 00 00 06 90 (node ACK)
Z-Wave Debug RCVD requestConfigVal: 01 0B 00 04 00 36 05 70 06 2A 01 00 9E
Z-Wave Debug . . requestConfigVal: node 054, parm index 42, value 0 (size 1)
Z-Wave Syncing - retrieved parameter 42 "LED ring color when OFF" is 0 "Off"
Z-Wave Debug . . requestConfigVal: node 054, combined config vals: 1:0 2:1 3:0 40:25000 41:1 10:80 11:15 12:30 13:10 14:3600 15:1 42:0
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 09 06 31 05 04 22 00 11 FB
Z-Wave Debug . . requestVarSensorStatus: node 009, endpoint None, type 4, raw value 2200...
Z-Wave Debug . . requestVarSensorStatus: 1.7 W (float: 1.700000)
Z-Wave Syncing - created device "054 - Wall Plug Relay (FGWP102)"
Z-Wave Syncing - complete
Z-Wave Debug SENT requestHvacMode: 01 09 00 13 36 02 40 02 25 7E C8
Z-Wave Debug RCVD requestHvacMode: 01 07 00 13 7E 00 00 06 93 (node ACK)
Z-Wave Debug terminatingSyncUI
Z-Wave sent "054 - Wall Plug Relay (FGWP102)" mode status request
Z-Wave Debug SENT requestTempStatus: 01 09 00 13 36 02 31 04 25 7F BE
Z-Wave Debug RCVD requestTempStatus: 01 07 00 13 7F 00 00 05 91 (node ACK)
Z-Wave sent "054 - Wall Plug Relay (FGWP102)" temperature status request
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 36 06 31 05 04 22 00 3E EB
Z-Wave Debug . . requestVarSensorStatus: node 054, endpoint None, type 4, raw value 2200...
Z-Wave Debug . . requestVarSensorStatus: 6.2 W (float: 6.200000)
Z-Wave Debug received "054 - Wall Plug Relay (FGWP102)" power load to 6.2 W
Z-Wave Debug SENT requestSetpointVal: 01 0A 00 13 36 03 43 02 01 25 80 36
Z-Wave Debug RCVD requestSetpointVal: 01 07 00 13 80 00 00 06 6D (node ACK)
Z-Wave sent "054 - Wall Plug Relay (FGWP102)" heat setpoint status request
Z-Wave Debug SENT requestSetpointVal: 01 0A 00 13 36 03 43 02 02 25 81 34
Z-Wave Debug RCVD requestSetpointVal: 01 07 00 13 81 00 00 12 78 (node ACK)
Z-Wave sent "054 - Wall Plug Relay (FGWP102)" cool setpoint status request
Not sure why this is reported as a Fibaro device as I thought that thoses identifiers are somehow registered and no company can use another companies identifier. Or maybe Steinel used a modified wall plug produced by Fibaro?
I found this manual online with all the settings listed for this device:
http://manuals-backend.z-wave.info/make.php?lang=EN&sku=STEEXLEDSW&cert=ZC10-17045541
Is it possible to add support for this light as I planned to buy more of these as it would be great to have a 'normal' outdoor light with motion sensor that reports back to Indigo any motion and can be turned on/off from Indigo.
