I have a quite complicated problem:
1. what I changed:
I had to exchange an old FGS221 switch with a new FGS223 Switch because the old one had a hardware defect.
2. What the function should be
On the Fibaros, the first switch (S1) is and was used to control a direct load and trigger an action in Indigo to switch some slave Hue devices as well.
The second (S2) switch was used just to trigger an action group to switch some lamps in another room.
Unfortunately the new FGS223 has different association groups for S1 and S2 and lifeline. The lifeline group is the only one automatically set to device1 (Indigo)
But the second switch (s2) doesn't send anything to the lifeline.
So I set association group 4 which is the on/off group for S2 to device 1 (indigo) as well. Now I get on off commands when I switch S2 but unfortunately Indigo doesn't distinguisch between S1 und S2 and always behaves as if I would have switched S1.
I hope I could explain the problem properly so that anyone else can understand my problem.
Am I doing something wrong or is indigo just misinterpreting the commands?
Any help would be appreciated.
Cheers
Wilhelm
