Qubino 3-Phase Smart Meter
Tue Sep 01, 2020 6:12 am
Sevilsivle offline
I have just installed this smart meter to monitor usage of a kiln.
There doesn't appear to be a dedicated definition for this but there was no option to upload the details from the device window which is usually the case for unknown devices.
4 devices have been created
Meter - which shows Current Load in Watts and Total Usage in kWh
Meter 2, Meter 3, Meter 4 have no content.
Is there any possibility to show other outputs or does that require a dedicated device definition?
Full manual available here. https://qubino.com/manuals/3-Phase_Smart_Meter.pdf
Tim
Indigo Z-Wave Version: 7.4.1
Node ID: 99
Model: Smart Meter Din Rail (ZMNHXD1)
Model ID: 00070054
Manufacturer: Qubino
Manufacturer ID: 0159
Protocol Version: 4.61
Application Version: 1.00
Model Definition Version: 0
Library Type: 3
Class Name: Whole Home Meter
Class Hierarchy: 04 : 31 : 03
Command Class Base: 00
Command Versions: 20v1 85v1 86v1 8Ev1 55v1 56v1 98v1 59v1 5Av1 5Ev1 9Fv1 60v4 6Cv1 72v1 70v1 32v4 73v1 7Av1
Multi-Endpoint Types: 1:(31 : 03), 2:(31 : 03), 3:(31 : 03), 4:(31 : 03)
Multi-Endpoint Classes: 1:[5E 98 9F 6C 85 8E 59 32 6C], 2:[5E 98 9F 6C 85 8E 59 32 6C], 3:[5E 98 9F 6C 85 8E 59 32 6C], 4:[5E 98 9F 6C 85 8E 59 32 6C]
Features: routing, beaming, security, energyMeter
Neighbors: 8, 78, 81
Associations: 1:[1]
Config Values: - none -
Thu Sep 03, 2020 3:55 pm
Re: Qubino 3-Phase Smart Meter
Hi Tim,
Thanks for the sync log snipped and PDF link. It looks like we'll need to create a definition for this one. I'll add it to the list.
Wed Dec 23, 2020 4:53 pm
Indigo 7.5 is now available and includes preliminary (untested) support for the Qubino Smart Meter Din Rail (ZMNHXD).
Mon Jan 04, 2021 3:44 pm
Bijenkorf offline
I have a problem with the qubino 3-phase smart meter, this unit is included(preliminary) in Indigo 7.5.
The unit is included in my z-wave network but only the 009 - Meter Total indicates a value. please check the attachment.
I used the option, send raw z-wave command from the z-wave interface and noticed that send 009 - Meter Total works fine , but when I select 009 - Meter L1 a command is send to 009 - Relay 1
the same with Meter L2 (command to Relay 2) and Meter L3(command to Relay 3). It seems there is a mistake and there is no communication with L1 - L3 , only the relais.
Please advise, thanks in advance.
Eric
jan. 2021 22:23:31
- Within the z-wave interface, option: send raw z-wave command
select 009 - Meter Total and send RAW command:
Z-Wave sent "009 - Meter Total" raw command [32 01 10]
Z-Wave received "009 - Meter Total" power load to 1883.7
select 009 - Meter L1 and send RAW command:
Z-Wave sent "009 - Relay 1" raw command [32 01 10]
- Within the z-wave interface, option: send raw z-wave command select 009 - Relay 1 and send RAW command:
Sat Jan 09, 2021 4:32 pm
Bijenkorf offline
Hi Matt,
any news about this subject.
Sat Jan 09, 2021 4:42 pm
I hope to have time to investigate it tomorrow.
Sun Jan 10, 2021 12:54 pm
Hi Eric,
I've sent you an email off the forum so we can troubleshoot into this further. Thanks.
Sun Jan 10, 2021 1:41 pm
Bijenkorf offline
Hi Matt,
Thanks for your reply and email. I will start testing this evening.
Fri May 07, 2021 7:04 am
Gusten offline
Hi
It seems I have the same issue, did you found anything fixable?
Thanx
//Martin
Sat May 08, 2021 2:55 pm
Hi Martin – I just sent you an off-forum email.
Sun May 09, 2021 10:42 am
Gusten offline
Thanx, i will try it. But my meter blow up, so I will get a new one first
Fri Jun 18, 2021 2:53 pm
Indigo 2021.1.0 is now available and will hopefully fix the problems with the Qubino Smart Meter definition.
