Zwav Interface error
Fri Aug 07, 2020 9:55 am
captcurrent offline
I have a Aeotec USD Stick 2 running under Indigo 7.3. in Mac OS 10.13.6. and I am getting the following error which I think is telling me communication with the Z Wave stick is being dropped waging I further imagine has to do with my old software Good guess??
ug 7, 2020 at 11:28:20 AM
Z-Wave received "005 - Ultraviolet" sensor update to 1
Z-Wave Error Error in plugin execution:
File "/Library/Application Support/Perceptive Automation/Indigo 7.3/IndigoPluginHost.app/Contents/Resources/PlugIns/serialinterface.py", line 513, in startCommThread
self.processCommThread()
File "/Library/Application Support/Perceptive Automation/Indigo 7.3/IndigoPluginHost.app/Contents/Resources/PlugIns/serialinterface.py", line 687, in processCommThread
self.processQueueInPacket(packet) # Subclass is required to define.
File "zwaveinterface.py", line 2316, in processQueueInPacket
File "zwaveinterface.py", line 2290, in _processFuncCall
File "zwaveinterface.py", line 2351, in _processCommandReply
File "zwaveinterface.py", line 2335, in _processFuncTriggersAndBroadcast
File "zwaveinterface.py", line 2288, in _processFuncCall
File "actionsensor.py", line 342, in _processVarSensorStatusReply
File "actionsensor.py", line 215, in _processSensorNumVal
StandardError: ServerCommunicationError -- timeout waiting for response
Z-Wave Error exc type is <type 'exceptions.StandardError'>
Z-Wave Error restarting serial connection in 5.0 seconds
Script not good
Updated "Security" on
Z-Wave connected to Z-Stick S2 interface on /dev/cu.SLAB_USBtoUART (firmware 3.07)
Fri Aug 07, 2020 7:15 pm
Re: Zwav Interface error
This actually looks like your Indigo Server is getting hung up and not responding (or responding very slowly). Th e Z-Wave plugin is trying to communicate back to the Indigo Server but it is timing out.
How often are you getting this error? Are you noticing unresponsiveness from the Indigo Client (UI) app? I suspect if you had it open when this error occurred it would also be showing problems.
Sat Aug 08, 2020 2:05 am
captcurrent offline
only apparently when I was trying to resynch my Aeotc Zw100 s.. after changing batteries... One died the other finally re-synched Message has not repeated in 12 hours. so just a 'glitch". Thanks
