I just wanted to include a new fibaro smart implant with encryption, because I want to open my Entrance with it for security reasons.
At first, I got it included and synced, but it didn't perform as I expected. The Relais couldn't be switched by indigo resulting in an error message:
Z-Wave Error device "166 - Relay 1" does not support on command
which seemed to be odd.
So I removed the node and reincluded it without encryption and now I could switch the relays as expected. (now node 167) ?!?
Normally I would now give up and leave the device unencrypted but in this case I just wanted to get on the bottom of this.
So I removed the node and reincluded again. (now 168)
This worked, but noiw I could not sync. The errormessages in the userinterface were erratic, So I tried to reinclude agin, but got the errormessge the node is already included.
After that the sync succeeded, but in fact I don't know if it's now running encrypted or not.
What do you make of that log?
- Code: Select all
Z-Wave Started controller inclusion mode with encryption
26.07.2020 14:27:48
Z-Wave received "Temperatur Küche " sensor update to 24.9 °C
Schedule Now
Z-Wave controller included module: 168 - Notification Sensor
Z-Wave querying module for encryption support
Z-Wave received "Thermostat Studio links" temperature update to 23.72 °C
Z-Wave starting encryption key exchange with module
Z-Wave Error missing expected node callback ack (168) for nonceRequest (will re-send)
Z-Wave Error controller failed to exit inclusion mode
Z-Wave Syncing - started for "168 - Notification Sensor"
Z-Wave Error Syncing - failed
Z-Wave Error Timeout waiting for "168 - Notification Sensor". Module might be asleep, or is unreachable.
Z-Wave Error controller failed to enter inclusion mode
26.07.2020 14:28:56
Schedule Now
Z-Wave Error no ack/nak/busy reply (168) for nonceRequest (re-sending)
Z-Wave retrieved module neighbors list: 12, 27, 28, 39, 50, 54, 56, 57, 58, 59, 60, 61, 62, 76, 78, 86, 97, 122, 131, 153, 154, 155, 162
Z-Wave started controller inclusion mode with encryption
Z-Wave stopped controller inclusion mode
Z-Wave Error the node included has the same ID as a node already in use by Indigo
Z-Wave Error to change the encryption state of the device you must exclude it before re-including it
Z-Wave Syncing - retrieved module neighbors list: 12, 27, 28, 39, 50, 54, 56, 57, 58, 59, 60, 61, 62, 76, 78, 86, 97, 122, 131, 153, 154, 155, 162
Z-Wave Syncing - assigning return route to "168 - Notification Sensor"
Z-Wave Syncing - retrieved manufacture and model names: Fibaro System - 010F, Smart Implant (FGBS222) - 05021000
Z-Wave Syncing - retrieved protocol version 6.02, app version 5.01
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Notification Sensor : Notification Sensor (04 : 07 : 01, base 00)
Z-Wave Syncing - retrieved command classes: 20v1 85v1 86v1 8Ev1 55v1 56v1 98v1 59v1 5Av1 5Bv1 5Ev1 9Fv1 60v4 22v1 25v1 31v11 6Cv1 70v1 71v1 72v1 73v1 75v1 7Av1
Z-Wave Syncing - retrieved capabilities: routing, beaming, security
Z-Wave Syncing - retrieved multi-endpoint types: 1:(07 : 01), 2:(07 : 01), 3:(21 : 01), 4:(21 : 01), 5:(10 : 01), 6:(10 : 01), 7:(21 : 01)
Z-Wave Syncing - retrieved multi-endpoint classes: 1:[5E 85 8E 59 71 6C 22 98 9F], 2:[5E 85 8E 59 71 6C 22 98 9F], 3:[5E 85 8E 59 31 6C 22 98 9F], 4:[5E 85 8E 59 31 6C 22 98 9F], 5:[5E 25 85 8E 59 75 6C 22 98 9F], 6:[5E 25 85 8E 59 75 6C 22 98 9F], 7:[5E 85 8E 59 31 71 6C 22 98 9F]
Z-Wave Syncing - retrieved group 1 associations: []
Z-Wave Syncing - retrieved group 3 associations: []
Z-Wave Syncing - added group 1 multi association to interface
Z-Wave Syncing - retrieved parameter 20 "Input 1 type" is 2 "Push Button (Enables Scenes)"
Z-Wave Syncing - retrieved parameter 40 "Input 1 scene sending" is 0 "None"
Z-Wave Syncing - retrieved parameter 21 "Input 2 type" is 2 "Push Button (Enables Scenes)"
Z-Wave Syncing - retrieved parameter 41 "Input 2 scene sending" is 0 "None"
Z-Wave Syncing - retrieved parameter 24 "Swap inputs (IN1 and IN2)" is false
Z-Wave Syncing - retrieved parameter 154 "Output 1 type" is 0 "Normally Open"
Z-Wave Syncing - retrieved parameter 156 "Output 1 delayed off" is 0 * 0.1 seconds
Z-Wave Syncing - retrieved parameter 155 "Output 2 type" is 0 "Normally Open"
Z-Wave Syncing - retrieved parameter 157 "Output 2 delayed off" is 0 * 0.1 seconds
Z-Wave Syncing - retrieved parameter 25 "Swap outputs (OUT1 and OUT2)" is false
Z-Wave Syncing - retrieved parameter 66 "Internal temperature interval" is 0 seconds
Z-Wave Syncing - retrieved parameter 65 "Internal temperature sensitivity" is 5 * 0.1°C
Z-Wave Syncing - retrieved parameter 64 "Analog input interval" is 0 seconds
Z-Wave Syncing - retrieved parameter 63 "Analog input sensitivity" is 5 * 0.1 V
Z-Wave Syncing - retrieved parameter 150 "Analog IN1 debounce" is 10 milliseconds
Z-Wave Syncing - retrieved parameter 151 "Analog IN2 debounce" is 10 milliseconds
Z-Wave Syncing - retrieved parameter 68 "External sensor interval" is 0 seconds
Z-Wave Syncing - retrieved parameter 67 "External sensor sensitivity" is 5 * 0.1
Z-Wave Syncing - changed device "166 - Binary IN1" address from undefined to 168
Z-Wave Syncing - changed device "166 - Analog IN1" address from undefined to 168
Z-Wave Syncing - changed device "166 - Binary IN2" address from undefined to 168
Z-Wave Syncing - changed device "166 - Analog IN2" address from undefined to 168
Z-Wave Syncing - changed device "166 - Relay 1" address from undefined to 168
Z-Wave Syncing - changed device "166 - Relay 2" address from undefined to 168
Z-Wave Syncing - changed device "166 - Temperature" address from undefined to 168
Z-Wave Syncing - complete
Z-Wave device "168 - 166 - Binary IN1" parameter 156 "Output 1 delayed off" changed to 20 * 0.1 seconds
Z-Wave device "168 - 166 - Binary IN1" parameter 157 "Output 2 delayed off" changed to 20 * 0.1 seconds
Z-Wave sent "166 - Relay 1" on
Z-Wave received "166 - Relay 1" status update is off
Is it in encryption mode now? How could I verify this?
If not, why is it included unencrypted although I included it using encryption?
The basic question here seems to be, has anyone included that device properly using encryption?
Thanks in advance
Wilhelm
