I have a spooky problem with the following two devices :
a Aeon Smart Switch (ZW075) and a Aeon Multi Sensor (ZW074)
The Multi sensor is battery powered, if that matters.
These two devices are completely unrelated, they don't trigger eachother, and they are in different places
The Smart Switch is inside, turns on a light, the Multi Sensor is outside under a small roof and is used to trigger our outside lights.
Since last week, all of a sudden, when the Multi Sensor is triggered outside, it turns on the Smart Switch inside.
Inside Indigo (which I haven't touched in months) there is no trigger defined at all that turns on the Smart Switch.
Looking at the Zwave associations for both, they only mention 1:1, so it doesn't seem that there is any direct connection between the two outside of Indigo.
In the event log I see only this ;
Z-Wave received "Terras Beweging" status update is on
Z-Wave received "Living Stekker lamp schilderij" status update is on
The first line is the Multi sensor, the second line is the Smart switch.
Does anybody know what might be causing this ?
Ghosts ?
