Z-Wave LED Floodlight with PIR Motion Detector (EH403)
Fri Jul 17, 2020 11:28 am
Bildhauer offline
Please could you add this device to the next release? Currently it syncs OK but just shows as a Notification Sensor.
Indigo Z-Wave Version: 7.4.1
Node ID: 162
Model: Notification Sensor
Model ID: 00120001
Manufacturer: Everspring
Manufacturer ID: 0060
Protocol Version: 4.61
Application Version: 1.01
Model Definition Version: 0
Library Type: 3
Class Name: Notification Sensor
Class Hierarchy: 04 : 07 : 01
Command Class Base: 00
Command Versions: 20v1 85v1 86v1 71v1 6Cv1 70v1 31v5 72v1 73v1 55v1 98v1 59v1 5Av1 25v1 7Av1 5Ev1 9Fv1
Encryption Status: Enabled for Commands 85 86 71 6C 70 31 72 73 59 5A 7A 25
Features: routing, beaming, security
Neighbors: 54, 57, 64, 126, 127, 155
Associations: 1:[1] 2:[]
Config Values: - none -
Fri Jul 17, 2020 3:54 pm
Re: Z-Wave LED Floodlight with PIR Motion Detector (EH403)
Yes, from the documentation I found online this looks like it has the same firmware as the HomeSeer HS-FLS100+ which Indigo currently supports. So we'll point this model ID to use that device definition in the next release.
In the mean time, follow the instructions on this forum post to create a Trigger on the raw Z-Wave command if you are just interested in capturing when the motion sensor is tripped.
Sun Jul 19, 2020 1:28 pm
Bildhauer offline
I tried to use "* 0x71 0x05 0x00 0x00 0x00 0xFF 0x07 0x08 *" but without success!
Sun Jul 19, 2020 1:50 pm
Can you take and post in a reply a screen capture showing how you have the Trigger settings defined?
Also turn on Indigo's Z-Wave Debug logging checkbox (via the Interfaces->Z-Wave->Configure... menu item), then trip the motion detector a couple of times and copy/paste the Event Log window results into a reply.
Mon Jul 20, 2020 12:53 pm
Bildhauer offline
Doing what you told me (flood alight was switched on by motion sensor three times) brought the following results:
20. Jul 2020 at 20:49:42
Z-Wave Debug stopping node healing thread
Z-Wave Debug stopping node status polling thread
Z-Wave Debug stopped zwave packet parser thread
Z-Wave connection reset requested
Z-Wave Debug starting serial connection loop
Z-Wave Debug starting zwave packet parser thread
Z-Wave Debug SENT getVersion: 01 03 00 15 E9
Z-Wave Debug RCVD getVersion: 01 10 01 15 5A 2D 57 61 76 65 20 34 2E 35 34 00 01 93 (no inbound callback)
Z-Wave Debug . . getVersion: Z-Wave 4.54 static controller
Z-Wave Debug SENT getHomeID: 01 03 00 20 DC
Z-Wave Debug RCVD getHomeID: 01 08 01 20 EF 21 42 D2 01 89 (no inbound callback)
Z-Wave Debug . . getHomeID: EF2142D2, nodeID: 001
Z-Wave Debug SENT getInterfaceFeatures: 01 03 00 05 F9
Z-Wave Debug RCVD getInterfaceFeatures: 01 04 01 05 18 E7 (no inbound callback)
Z-Wave Debug . . getInterfaceFeatures: 18
Z-Wave Debug SENT getInterfaceApiCapabilities: 01 03 00 07 FB
Z-Wave Debug RCVD getInterfaceApiCapabilities: 01 2B 01 07 01 01 00 86 00 01 00 5A FE 81 FF 88 4F 1F 00 00 FB 9F 7D A0 67 00 00 80 00 80 86 00 00 00 E8 73 00 00 0E 00 00 60 00 00 FA (no inbound callback)
Z-Wave Debug . . getInterfaceApiCapabilities: supportedFuncIDs: 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 17 18 1C 20 21 22 23 24 27 29 2A 2B 2C 2D 41 42 44 45 46 47 48 49 4A 4B 4C 4D 50 51 53 54 55 56 57 5E 60 61 62 63 66 67 80 90 92 93 98 B4 B6 B7 B8 B9 BA BD BE BF D2 D3 D4 EE EF
Z-Wave Debug . . getInterfaceApiCapabilities: serialApi 1.01, manufactureId 0086, productType 0001, productId 005A
Z-Wave connected to Z-Stick interface on /dev/cu.usbmodem14101 (firmware 1.01)
Z-Wave Debug SENT forceSUC: 01 05 00 54 01 01 AE
Z-Wave Debug RCVD forceSUC: 01 04 01 54 01 AF (no inbound callback)
Z-Wave Debug SENT getInitialNodeData: 01 03 00 02 FE
Z-Wave Debug RCVD getInitialNodeData: 01 25 01 02 05 08 1D 31 07 00 00 C0 00 3C 83 15 D0 C6 00 DC 00 00 60 C1 9B 00 06 0B 00 00 00 00 00 00 00 00 05 00 6D (no inbound callback)
Z-Wave Debug . . getInitialNodeData: is static update controller
Z-Wave Debug . . getInitialNodeData: [1, 5, 6, 9, 10, 11, 39, 40, 51, 52, 53, 54, 57, 58, 64, 65, 67, 69, 77, 79, 80, 82, 83, 87, 88, 99, 100, 101, 103, 104, 126, 127, 129, 135, 136, 137, 138, 140, 141, 144, 154, 155, 161, 162, 164]
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 01 BB
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 93 16 01 02 02 01 33 (no inbound callback)
Z-Wave Debug . . getNodeProtocolInfo: node 001, class name: Static Computer Controller
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Static Controller : Static Controller : Static Computer Controller (02 : 02 : 01)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 00
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20
Z-Wave Debug . . getNodeProtocolInfo: encrypt class commands:
Z-Wave Debug . . getNodeProtocolInfo: features: beaming
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 05 BF
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 01 04 10 01 ED (no inbound callback)
Z-Wave Debug . . getNodeProtocolInfo: node 005, class name: Relay Power Switch
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Relay Switch : Relay Power Switch (04 : 10 : 01)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 25
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 25 27
Z-Wave Debug . . getNodeProtocolInfo: features: routing, beaming
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 06 BC
Z-Wave Debug . . getNodeProtocolInfo: node 006, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 09 B3
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 00 04 10 01 EC (no inbound callback)
Z-Wave Debug . . getNodeProtocolInfo: node 009, class name: Relay Power Switch
Z-Wave Debug stopped polling of "009 - Zwischenstecker Keller (Ladegerät Trolley-Akku)"
Z-Wave Debug started polling of "009 - Zwischenstecker Keller (Ladegerät Trolley-Akku)" approx every 3600 seconds
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 0A B0
Z-Wave Debug . . getNodeProtocolInfo: node 010, class name: Relay Power Switch
Z-Wave Debug stopped polling of "010 - Zwischenstecker IT alles"
Z-Wave Debug started polling of "010 - Zwischenstecker IT alles" approx every 3600 seconds
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 0B B1
Z-Wave Debug . . getNodeProtocolInfo: node 011, class name: Relay Power Switch
Z-Wave Debug stopped polling of "011 - Zwischenstecker AGFEO-Anlage"
Z-Wave Debug started polling of "011 - Zwischenstecker AGFEO-Anlage" approx every 3600 seconds
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 27 9D
Z-Wave Debug . . getNodeProtocolInfo: node 039, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 28 92
Z-Wave Debug . . getNodeProtocolInfo: node 040, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 33 89
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 01 04 11 01 EC (no inbound callback)
Z-Wave Debug . . getNodeProtocolInfo: node 051, class name: Dimmable Power Switch
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Mulitlevel Switch : Dimmable Power Switch (04 : 11 : 01)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 26
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 26 27
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 34 8E
Z-Wave Debug . . getNodeProtocolInfo: node 052, class name: Dimmable Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 35 8F
Z-Wave Debug . . getNodeProtocolInfo: node 053, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 36 8C
Z-Wave Debug . . getNodeProtocolInfo: node 054, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 39 83
Z-Wave Debug . . getNodeProtocolInfo: node 057, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 3A 80
Z-Wave Debug . . getNodeProtocolInfo: node 058, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 40 FA
Z-Wave Debug . . getNodeProtocolInfo: node 064, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 41 FB
Z-Wave Debug . . getNodeProtocolInfo: node 065, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 43 F9
Z-Wave Debug . . getNodeProtocolInfo: node 067, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 45 FF
Z-Wave Debug . . getNodeProtocolInfo: node 069, class name: Dimmable Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 4D F7
Z-Wave Debug . . getNodeProtocolInfo: node 077, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 4F F5
Z-Wave Debug . . getNodeProtocolInfo: node 079, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 50 EA
Z-Wave Debug . . getNodeProtocolInfo: node 080, class name: Dimmable Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 52 E8
Z-Wave Debug . . getNodeProtocolInfo: node 082, class name: Dimmable Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 53 E9
Z-Wave Debug . . getNodeProtocolInfo: node 083, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 57 ED
Z-Wave Debug . . getNodeProtocolInfo: node 087, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 58 E2
Z-Wave Debug . . getNodeProtocolInfo: node 088, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 63 D9
Z-Wave Debug . . getNodeProtocolInfo: node 099, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 64 DE
Z-Wave Debug . . getNodeProtocolInfo: node 100, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 65 DF
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 01 04 11 07 EA (no inbound callback)
Z-Wave Debug . . getNodeProtocolInfo: node 101, class name: Motor Control Class C
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Mulitlevel Switch : Motor Control Class C (04 : 11 : 07)
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 72 25 26 86
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 67 DD
Z-Wave Debug . . getNodeProtocolInfo: node 103, class name: Motor Control Class C
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 68 D2
Z-Wave Debug . . getNodeProtocolInfo: node 104, class name: Motor Control Class C
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 7E C4
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 00 04 0F 01 F3 (no inbound callback)
Z-Wave Debug . . getNodeProtocolInfo: node 126, class name: Basic Repeater Slave
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Repeater Slave : Basic Repeater Slave (04 : 0F : 01)
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 7F C5
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 01 04 0F 01 F2 (no inbound callback)
Z-Wave Debug . . getNodeProtocolInfo: node 127, class name: Basic Repeater Slave
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 81 3B
Z-Wave Debug . . getNodeProtocolInfo: node 129, class name: Basic Repeater Slave
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 87 3D
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 53 9C 01 04 18 01 65 (no inbound callback)
Z-Wave Debug . . getNodeProtocolInfo: node 135, class name: Basic Wall Controller
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Wall Controller : Basic Wall Controller (04 : 18 : 01)
Z-Wave Debug overriding node 135 type from zwCustomType to zwDimmerType
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 88 32
Z-Wave Debug . . getNodeProtocolInfo: node 136, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 89 33
Z-Wave Debug . . getNodeProtocolInfo: node 137, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 8A 30
Z-Wave Debug . . getNodeProtocolInfo: node 138, class name: Relay Power Switch
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 8C 36
Z-Wave Debug . . getNodeProtocolInfo: node 140, class name: Basic Repeater Slave
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 8D 37
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 53 9C 00 04 08 04 71 (no inbound callback)
Z-Wave Debug . . getNodeProtocolInfo: node 141, class name: Setpoint Thermostat
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Thermostat : Setpoint Thermostat (04 : 08 : 04)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 43
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 72 43 86 8F
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 90 2A
Z-Wave Debug . . getNodeProtocolInfo: node 144, class name: Motor Control Class C
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 9A 20
Z-Wave Debug . . getNodeProtocolInfo: node 154, class name: Motor Control Class C
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 9B 21
Z-Wave Debug . . getNodeProtocolInfo: node 155, class name: Motor Control Class C
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 A1 1B
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 01 04 07 01 FA (no inbound callback)
Z-Wave Debug . . getNodeProtocolInfo: node 161, class name: Notification Sensor
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Notification Sensor : Notification Sensor (04 : 07 : 01)
Z-Wave found module included in controller with no matching device (missing or disabled): 161 - Notification Sensor
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 A2 18
Z-Wave Debug . . getNodeProtocolInfo: node 162, class name: Notification Sensor
Z-Wave Debug stopped polling of "162 - Bewegungsmelder Carport"
Z-Wave Debug started polling of "162 - Bewegungsmelder Carport" approx every 300 seconds
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 A4 1E
Z-Wave Debug . . getNodeProtocolInfo: node 164, class name: Basic Wall Controller
Z-Wave Debug overriding node 164 type from zwCustomType to zwDimmerType
Z-Wave Debug starting node healing thread
Z-Wave Debug starting node status polling thread
Z-Wave Debug SENT setConfigVal: 01 0C 00 13 87 05 70 04 18 01 01 25 9F B4
Z-Wave Debug RCVD setConfigVal: 01 07 00 13 9F 01 04 BC CD (node NAK)
Z-Wave Debug . . setConfigVal: requeuing 14 unsolicited packets
Z-Wave Error device "Taster Wohnzimmer" may be asleep. configuration changes will be set during the next wake interval.
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 63 0E 32 02 21 44 00 00 88 B9 00 15 00 00 88 B9 C2
Z-Wave Debug . . requestMeterLevel: node 099, endpoint None, meterType 01, raw value 4400...
Z-Wave Debug . . requestMeterLevel: 350.01 kWh (float: 350.010000)
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 63 0A 32 02 A1 4A 00 23 00 15 00 25 4A
Z-Wave Debug . . requestMeterLevel: node 099, endpoint None, meterType 01, raw value 4A00...
Z-Wave Debug . . requestMeterLevel: 0.35 A (float: 0.350000)
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 10 63 0A 32 02 A1 4A 00 23 00 15 00 25 5A
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 63 0E 32 02 21 44 00 00 88 B9 00 0D 00 00 88 B9 DA
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 63 0E 32 02 21 54 00 00 1A FD 00 0D 00 00 1C 7F 4E
Z-Wave Debug . . requestMeterLevel: node 099, endpoint None, meterType 01, raw value 5400...
Z-Wave Debug . . requestMeterLevel: 69.09 W (float: 69.090000)
Z-Wave received "Zwischenstecker Thunderbolt-Monitor 2 (rechts)" power load to 69.09 W
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 63 0A 32 02 A1 42 5C 40 00 0D 5C 50 4C
Z-Wave Debug . . requestMeterLevel: node 099, endpoint None, meterType 01, raw value 425C...
Z-Wave Debug . . requestMeterLevel: 236.16 V (float: 236.160000)
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 63 0A 32 02 A1 4A 00 21 00 0D 00 23 56
Z-Wave Debug . . requestMeterLevel: 0.33 A (float: 0.330000)
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 9B 0A 32 02 21 34 00 00 0A 73 00 00 26
Z-Wave Debug . . requestMeterLevel: node 155, endpoint None, meterType 01, raw value 3400...
Z-Wave Debug . . requestMeterLevel: 267.5 W (float: 267.500000)
Z-Wave received "Qubino FS Rollo Esszimmer Erker mitte/ rechts" power load to 267.5 W
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 9B 0A 32 02 21 34 00 00 01 AB 00 00 F5
Z-Wave Debug . . requestMeterLevel: 42.7 W (float: 42.700000)
Z-Wave received "Qubino FS Rollo Esszimmer Erker mitte/ rechts" power load to 42.7 W
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 63 0E 32 02 21 44 00 00 88 B9 00 09 00 00 88 B9 DE
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 63 0E 32 02 21 54 00 00 1C 34 00 09 00 00 1A FD 01
Z-Wave Debug . . requestMeterLevel: 72.20 W (float: 72.200000)
Z-Wave received "Zwischenstecker Thunderbolt-Monitor 2 (rechts)" power load to 72.20 W
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 8A 0E 32 02 21 44 00 00 4C 73 01 2D 00 00 4C 73 12
Z-Wave Debug . . requestMeterLevel: node 138, endpoint None, meterType 01, raw value 4400...
Z-Wave Debug . . requestMeterLevel: 195.71 kWh (float: 195.710000)
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 8A 0E 32 02 21 54 00 00 01 7C 01 2D 00 00 01 7B 05
Z-Wave Debug . . requestMeterLevel: node 138, endpoint None, meterType 01, raw value 5400...
Z-Wave Debug . . requestMeterLevel: 3.80 W (float: 3.800000)
Z-Wave received "Zwischenstecker Küche Spülmaschine" power load to 3.80 W
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 8A 0A 32 02 A1 42 5B 8E 01 2D 5B 71 6B
Z-Wave Debug . . requestMeterLevel: node 138, endpoint None, meterType 01, raw value 425B...
Z-Wave Debug . . requestMeterLevel: 234.38 V (float: 234.380000)
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 8A 0A 32 02 A1 4A 00 05 01 2D 00 05 9C
Z-Wave Debug . . requestMeterLevel: node 138, endpoint None, meterType 01, raw value 4A00...
Z-Wave Debug . . requestMeterLevel: 0.05 A (float: 0.050000)
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 57 0E 32 02 21 44 00 00 6D E7 01 2D 00 00 6D E7 CF
Z-Wave Debug . . requestMeterLevel: node 087, endpoint None, meterType 01, raw value 4400...
Z-Wave Debug . . requestMeterLevel: 281.35 kWh (float: 281.350000)
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 63 0A 32 02 A1 42 5C 47 00 09 5C 40 5F
Z-Wave Debug . . requestMeterLevel: 236.23 V (float: 236.230000)
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 57 0E 32 02 21 54 00 00 00 00 01 2D 00 00 00 00 DF
Z-Wave Debug . . requestMeterLevel: node 087, endpoint None, meterType 01, raw value 5400...
Z-Wave Debug . . requestMeterLevel: 0.00 W (float: 0.000000)
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 63 0A 32 02 A1 4A 00 23 00 09 00 21 52
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 57 0A 32 02 A1 42 5A 74 01 2D 5A D4 E9
Z-Wave Debug . . requestMeterLevel: node 087, endpoint None, meterType 01, raw value 425A...
Z-Wave Debug . . requestMeterLevel: 231.56 V (float: 231.560000)
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 57 0A 32 02 A1 4A 00 00 01 2D 00 00 41
Z-Wave Debug . . requestMeterLevel: node 087, endpoint None, meterType 01, raw value 4A00...
Z-Wave Debug . . requestMeterLevel: 0.00 A (float: 0.000000)
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 4D 0E 32 02 21 44 00 00 0D FA 01 2D 00 00 0D FA D5
Z-Wave Debug . . requestMeterLevel: node 077, endpoint None, meterType 01, raw value 4400...
Z-Wave Debug . . requestMeterLevel: 35.78 kWh (float: 35.780000)
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 4D 0E 32 02 21 54 00 00 00 00 01 2D 00 00 00 00 C5
Z-Wave Debug . . requestMeterLevel: node 077, endpoint None, meterType 01, raw value 5400...
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 4D 0A 32 02 A1 42 5D 65 01 2D 5D AB 9D
Z-Wave Debug . . requestMeterLevel: node 077, endpoint None, meterType 01, raw value 425D...
Z-Wave Debug . . requestMeterLevel: 239.09 V (float: 239.090000)
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 4D 0A 32 02 A1 4A 00 00 01 2D 00 00 5B
Z-Wave Debug . . requestMeterLevel: node 077, endpoint None, meterType 01, raw value 4A00...
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 63 0E 32 02 21 54 00 00 1A FB 00 15 00 00 1C 34 1B
Z-Wave Debug . . requestMeterLevel: 69.07 W (float: 69.070000)
Z-Wave received "Zwischenstecker Thunderbolt-Monitor 2 (rechts)" power load to 69.07 W
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 63 0A 32 02 A1 42 5C 41 00 15 5C 47 42
Z-Wave Debug . . requestMeterLevel: 236.17 V (float: 236.170000)
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 63 0A 32 02 A1 4A 00 21 00 15 00 23 4E
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 64 0A 32 02 21 34 00 00 00 00 00 00 A0
Z-Wave Debug . . requestMeterLevel: node 100, endpoint None, meterType 01, raw value 3400...
Z-Wave Debug . . requestMeterLevel: 0.0 W (float: 0.000000)
20. Jul 2020 at 20:51:02
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 63 0E 32 02 21 44 00 00 88 B9 00 23 00 00 88 B9 F4
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 63 0E 32 02 21 54 00 00 1E 5A 00 23 00 00 1A FB 41
Z-Wave Debug . . requestMeterLevel: 77.70 W (float: 77.700000)
Z-Wave received "Zwischenstecker Thunderbolt-Monitor 2 (rechts)" power load to 77.70 W
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 63 0A 32 02 A1 42 5C 53 00 23 5C 41 60
Z-Wave Debug . . requestMeterLevel: 236.35 V (float: 236.350000)
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 63 0A 32 02 A1 4A 00 25 00 23 00 21 7E
Z-Wave Debug . . requestMeterLevel: 0.37 A (float: 0.370000)
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 63 0E 32 02 21 44 00 00 88 B9 00 0B 00 00 88 B9 DC
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 63 0E 32 02 21 54 00 00 1A 76 00 0B 00 00 1E 5A E4
Z-Wave Debug . . requestMeterLevel: 67.74 W (float: 67.740000)
Z-Wave received "Zwischenstecker Thunderbolt-Monitor 2 (rechts)" power load to 67.74 W
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 63 0A 32 02 A1 42 5C 69 00 0B 5C 53 60
Z-Wave Debug . . requestMeterLevel: 236.57 V (float: 236.570000)
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 63 0A 32 02 A1 4A 00 21 00 0B 00 25 56
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 63 0E 32 02 21 54 00 00 1E 74 00 0B 00 00 1A 76 CA
Z-Wave Debug . . requestMeterLevel: 77.96 W (float: 77.960000)
Z-Wave received "Zwischenstecker Thunderbolt-Monitor 2 (rechts)" power load to 77.96 W
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 28 0E 32 02 21 44 00 01 87 08 01 2D 00 01 87 08 B0
Z-Wave Debug . . requestMeterLevel: node 040, endpoint None, meterType 01, raw value 4400...
Z-Wave Debug . . requestMeterLevel: 1001.04 kWh (float: 1001.040000)
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 63 0A 32 02 A1 42 5C 4D 00 0B 5C 69 7E
Z-Wave Debug . . requestMeterLevel: 236.29 V (float: 236.290000)
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 28 0E 32 02 21 54 00 00 21 9D 01 2D 00 00 21 9D A0
Z-Wave Debug . . requestMeterLevel: node 040, endpoint None, meterType 01, raw value 5400...
Z-Wave Debug . . requestMeterLevel: 86.05 W (float: 86.050000)
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 63 0A 32 02 A1 4A 00 25 00 0B 00 21 56
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 28 0A 32 02 A1 42 5A E7 01 2D 5B 03 D3
Z-Wave Debug . . requestMeterLevel: node 040, endpoint None, meterType 01, raw value 425A...
Z-Wave Debug . . requestMeterLevel: 232.71 V (float: 232.710000)
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 28 0A 32 02 A1 4A 00 25 01 2D 00 25 3E
Z-Wave Debug . . requestMeterLevel: node 040, endpoint None, meterType 01, raw value 4A00...
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 63 0E 32 02 21 54 00 00 1A 93 00 09 00 00 1E 74 2D
Z-Wave Debug . . requestMeterLevel: 68.03 W (float: 68.030000)
Z-Wave received "Zwischenstecker Thunderbolt-Monitor 2 (rechts)" power load to 68.03 W
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 63 0A 32 02 A1 42 5C 4F 00 09 5C 4D 5A
Z-Wave Debug . . requestMeterLevel: 236.31 V (float: 236.310000)
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 63 0A 32 02 A1 4A 00 21 00 09 00 25 54
Mon Jul 20, 2020 2:34 pm
Is the 162 - Bewegungsmelder Carport device the LED floodlight? It isn't showing any commands coming from that module at all, which sounds like it isn't configured correctly to send motion sensing. Do you know if your attempts to trip/trigger it worked? Dd the LED floodlight turn on or some LED flash indicating it detected your motion?
Also re-sync it in Indigo and copy/paste the Event Log results of that.
Lastly, if you included it with encryption enabled you might try excluding it and then re-including it without encryption (then re-syncing it). That might get it to send the command correctly.
Mon Jul 20, 2020 3:21 pm
Bildhauer offline
Yes it's node 162.
I'll re-include it without encryption and will come back to you!
Thx. in advance!
Best regards
Stephan O. Merckens
Sun Dec 13, 2020 9:55 am
Bildhauer offline
Now I managed it to pout it include it into weave without encryption and it looks as it would work now!
Thx for your support!
Best regards
Bildhauer
Wed Dec 23, 2020 3:17 pm
Indigo 7.5 is now available and includes support for the Everspring Floodlight Sensor (EH403).
Users browsing this forum: No registered users and 20 guests
