Fibaro FGS-214
Tue Jun 23, 2020 10:50 am
McJohn offline
Fibaro FGS-214
Pleas could you add the Fibaro FGS-214 to the Indigo supported device list.
(And also for the FGS-224)
https://manuals.fibaro.com/content/manu ... EN-1.0.pdf
It's working, but only On and Off. Nothing more.
We are missing for example the Relay off delay function.
Below the Device details.
Thanks for all your work.
Indigo Device "117 - Relay Power Switch" Z-Wave Properties:
Indigo Z-Wave Version: 7.4.1
Node ID: 117
Model: Relay Power Switch
Model ID: 04041000
Manufacturer: Fibaro System
Manufacturer ID: 010F
Protocol Version: 6.04
Application Version: 5.00
Model Definition Version: 0
Library Type: 3
Class Name: Relay Power Switch
Class Hierarchy: 04 : 10 : 01
Command Class Base: 25
Command Versions: 85v1 86v1 8Ev1 98v1 9Fv1 20v1 22v1 25v1 27v1 55v1 56v1 59v1 5Av1 5Bv1 5Ev1 6Cv1 70v1 71v1 72v1 73v1 75v1 7Av1
Features: routing, beaming, security
Neighbors: 3, 5, 9, 10, 12, 13, 14, 15, 22, 23, 24, 25, 26, 27, 30, 35, 91, 100, 106, 111, 116
Associations: 1:[1] 2:[]
Config Values: - none -
Tue Jun 23, 2020 11:04 am
McJohn offline
Re: Fibaro FGS-214
PS:
For the beta users:
Parameter 150 value 2 = auto off.
Tue Jun 23, 2020 7:19 pm
Re: Fibaro FGS-214
Thanks for the details and PDF link. I'll definitely add it to the list.
Wed Nov 11, 2020 4:52 pm
siclark offline
Re: Fibaro FGS-214
Hi. Is this still waiting? Need a new double module and would like to buy the latest but might stick with the old one if it doesn't work properly yet.
Thu Nov 12, 2020 4:27 pm
Re: Fibaro FGS-214
We hope to have these supported in the next feature release.
Thu Nov 12, 2020 4:28 pm
siclark offline
Re: Fibaro FGS-214
Cheers Matt. Not sure what the new features are so went with the old double relay instead.
Wed Dec 23, 2020 5:32 pm
Re: Fibaro FGS-214
Indigo 7.5 is now available and includes support for the Fibaro Smart Module/Switch (FGS214).
