matt (support) wrote:See what Z-Wave commands it is sending when you locally control it (at the switch). Turn on the Z-Wave Debug Logging checkbox (via the Interfaces->Z-Wave->Configure... menu item) first, then copy/paste the Event Log results into a reply for me. Also after locally controlling it, after say 10 seconds, send it a status request so I can see how it responds to that.
Z-Wave Indigo Device "064 - Dimmer Switch (LZW31-SN)" Z-Wave Properties:
Indigo Z-Wave Version: 7.4.1
Node ID: 64
Model: Dimmer Switch (LZW31-SN)
Model ID: 00010001
Manufacturer: Inovelli
Manufacturer ID: 031E
Protocol Version: 6.04
Application Version: 1.35
Model Definition Version: 3
Library Type: 3
Class Name: Dimmable Power Switch
Class Hierarchy: 04 : 11 : 01
Command Class Base: 26
Command Versions: 85v1 86v1 55v1 98v1 59v1 5Av1 5Bv1 5Ev1 9Fv1 20v1 22v1 26v2 27v1 6Cv1 72v1 70v1 32v3 73v1 75v1 7Av1
Features: routing, beaming, security, energyMeter
Neighbors: 5, 16, 17, 20, 34, 48
Associations: 1:[1] 2:[] 3:[] 4:[]
Config Values: 1:0 2:3 3:0 4:0 5:1 6:99 7:0 11:0 13:170 14:5 15:1 18:10 19:3600 20:10
Z-Wave Debug stopping node healing thread
Z-Wave Debug stopping node status polling thread
Z-Wave Debug stopped zwave packet parser thread
Z-Wave connection reset requested
Z-Wave Debug starting serial connection loop
Z-Wave Debug starting zwave packet parser thread
Z-Wave Debug SENT getVersion: 01 03 00 15 E9
Z-Wave Debug RCVD getVersion: 01 10 01 15 5A 2D 57 61 76 65 20 33 2E 39 35 00 01 99 (no inbound callback)
Z-Wave Debug . . getVersion: Z-Wave 3.95 static controller
Z-Wave Debug SENT getHomeID: 01 03 00 20 DC
Z-Wave Debug RCVD getHomeID: 01 08 01 20 F7 83 E3 1A 01 5A (no inbound callback)
Z-Wave Debug . . getHomeID: F783E31A, nodeID: 001
Z-Wave Debug SENT getInterfaceFeatures: 01 03 00 05 F9
Z-Wave Debug RCVD getInterfaceFeatures: 01 04 01 05 1C E3 (no inbound callback)
Z-Wave Debug . . getInterfaceFeatures: 1C
Z-Wave Debug SENT getInterfaceApiCapabilities: 01 03 00 07 FB
Z-Wave Debug RCVD getInterfaceApiCapabilities: 01 2B 01 07 01 00 00 86 01 01 00 5A FE 81 FF 88 4F 1F 00 00 FB 9F 7D A0 67 00 00 80 00 80 86 00 00 00 E8 73 00 00 0E 00 00 60 00 00 FA (no inbound callback)
Z-Wave Debug . . getInterfaceApiCapabilities: supportedFuncIDs: 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 17 18 1C 20 21 22 23 24 27 29 2A 2B 2C 2D 41 42 44 45 46 47 48 49 4A 4B 4C 4D 50 51 53 54 55 56 57 5E 60 61 62 63 66 67 80 90 92 93 98 B4 B6 B7 B8 B9 BA BD BE BF D2 D3 D4 EE EF
Z-Wave Debug . . getInterfaceApiCapabilities: serialApi 1.00, manufactureId 0086, productType 0101, productId 005A
Z-Wave connected to Z-Stick Plus (ZW090) interface on /dev/cu.usbmodem411 (firmware 1.00)
Z-Wave Debug SENT forceSUC: 01 05 00 54 01 01 AE
Z-Wave Debug RCVD forceSUC: 01 04 01 54 01 AF (no inbound callback)
Z-Wave Debug SENT getInitialNodeData: 01 03 00 02 FE
Z-Wave Debug RCVD getInitialNodeData: 01 25 01 02 05 08 1D BB 8A DF 08 A2 F7 3D 9F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 DD (no inbound callback)
Z-Wave Debug . . getInitialNodeData: is static update controller
Z-Wave Debug . . getInitialNodeData: [1, 2, 4, 5, 6, 8, 10, 12, 16, 17, 18, 19, 20, 21, 23, 24, 28, 34, 38, 40, 41, 42, 43, 45, 46, 47, 48, 49, 51, 52, 53, 54, 57, 58, 59, 60, 61, 64]
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 01 BB
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 93 16 01 02 02 01 33 (no inbound callback)
Z-Wave Debug . . getNodeProtocolInfo: node 001, class name: Static Computer Controller
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Static Controller : Static Controller : Static Computer Controller (02 : 02 : 01)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 00
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20
Z-Wave Debug . . getNodeProtocolInfo: encrypt class commands:
Z-Wave Debug . . getNodeProtocolInfo: features: beaming
<Cut out a bunch of noise on other devices that didn't seem relevant>
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 40 FA
Z-Wave Debug RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 01 04 11 01 EC (no inbound callback)
Z-Wave Debug . . getNodeProtocolInfo: node 064, class name: Dimmable Power Switch
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Mulitlevel Switch : Dimmable Power Switch (04 : 11 : 01)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 26
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 26 27
Z-Wave Debug . . getNodeProtocolInfo: features: routing, beaming
Z-Wave Debug starting node healing thread
Z-Wave Debug starting node status polling thread
Z-Wave Debug RCVD sensorSetLevel: 01 09 00 04 00 26 03 20 01 FF 09
Z-Wave Debug . . sensorSetLevel: node 038, endpoint None, cmdClass 20, value 255
Z-Wave received "Master Bedroom (Motion)" status update is on
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 10 00 04 00 26 0A 71 05 00 00 00 FF 07 08 00 00 43
Z-Wave Debug . . requestAlarmSensorStatus: node 038, endpoint None, cmdClass 71, type 0, value 0, classSubKey 710000
Z-Wave Debug . . requestAlarmSensorStatus: typeExt 7, valueExt 8, classSubKeyExt 7100000708
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 04 0E 32 02 21 64 00 00 22 EC 00 C3 00 00 22 EC 53
Z-Wave Debug . . requestMeterLevel: node 004, endpoint None, meterType 01, raw value 6400...
Z-Wave Debug . . requestMeterLevel: 8.940 kWh (float: 8.940000)
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 04 0E 32 02 21 74 00 00 00 00 00 C3 00 00 22 EC 8D
Z-Wave Debug . . requestMeterLevel: node 004, endpoint None, meterType 01, raw value 7400...
Z-Wave Debug . . requestMeterLevel: 0.000 W (float: 0.000000)
Z-Wave Debug RCVD dimmerSetLevel: 01 09 00 04 00 40 03 20 03 63 F1
Z-Wave Debug . . dimmerSetLevel: node 064, endpoint None, value 99
Z-Wave received "064 - Dimmer Switch (LZW31-SN)" status update brightness 100
Z-Wave Debug queueing energy request of "064 - Dimmer Switch (LZW31-SN)" (activity detected)
Z-Wave Debug RCVD sceneActivateCmd2: 01 0B 00 04 00 40 05 5B 03 CA 80 02 A5
Z-Wave Debug . . sceneActivateCmd2: node 064, type: 0, scene: 2
Z-Wave received "064 - Dimmer Switch (LZW31-SN)" up button pressed
Z-Wave received "064 - Dimmer Switch (LZW31-SN)" status update is off
Z-Wave Debug ignoring duplicate energy request of "064 - Dimmer Switch (LZW31-SN)" (activity detected)
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 40 0A 32 02 21 34 00 00 00 75 00 00 F1
Z-Wave Debug . . requestMeterLevel: node 064, endpoint None, meterType 01, raw value 3400...
Z-Wave Debug . . requestMeterLevel: 11.7 W (float: 11.700000)
Z-Wave received "064 - Dimmer Switch (LZW31-SN)" power load to 11.7 W
Z-Wave Debug RCVD dimmerSetLevel: 01 09 00 04 00 40 03 20 03 00 92
Z-Wave Debug . . dimmerSetLevel: node 064, endpoint None, value 0
Z-Wave Debug RCVD sceneActivateCmd2: 01 0B 00 04 00 40 05 5B 03 CB 80 01 A7
Z-Wave Debug . . sceneActivateCmd2: node 064, type: 0, scene: 1
Z-Wave received "064 - Dimmer Switch (LZW31-SN)" down button pressed
Z-Wave received "064 - Dimmer Switch (LZW31-SN)" status update is on
Z-Wave Debug RCVD requestMeterLevel: 01 18 00 04 00 30 12 32 02 21 64 00 01 FD BB 00 3C 00 01 FD BB 00 00 00 00 88
Z-Wave Debug . . requestMeterLevel: node 048, endpoint None, meterType 01, raw value 6400...
Z-Wave Debug . . requestMeterLevel: 130.491 kWh (float: 130.491000)
Z-Wave Debug RCVD requestMeterLevel: 01 18 00 04 00 30 12 32 02 21 74 00 00 08 0A 00 00 00 00 00 00 00 00 00 00 A6
Z-Wave Debug . . requestMeterLevel: node 048, endpoint None, meterType 01, raw value 7400...
Z-Wave Debug . . requestMeterLevel: 2.058 W (float: 2.058000)
Z-Wave received "Washer (Switch)" power load to 2.058 W
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 40 0A 32 02 21 34 00 00 00 00 00 00 84
Z-Wave Debug . . requestMeterLevel: 0.0 W (float: 0.000000)
Z-Wave received "064 - Dimmer Switch (LZW31-SN)" power load to 0.0 W
Z-Wave Debug RCVD sceneActivateCmd2: 01 0B 00 04 00 40 05 5B 03 CC 80 02 A3
Z-Wave Debug RCVD sceneActivateCmd2: 01 0B 00 04 00 40 05 5B 03 CD 80 01 A1
Z-Wave Debug polling status of node "064 - Dimmer Switch (LZW31-SN)" (post-activity energy request)
Z-Wave Debug SENT requestMeterLevel: 01 0A 00 13 40 03 32 01 00 25 AD 1E
Z-Wave Debug RCVD requestMeterLevel: 01 07 00 13 AD 00 00 0C 4A (node ACK)
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 40 0E 32 02 21 64 00 00 02 8B 66 D1 00 00 02 76 9E
Z-Wave Debug . . requestMeterLevel: node 064, endpoint None, meterType 01, raw value 6400...
Z-Wave Debug . . requestMeterLevel: 0.651 kWh (float: 0.651000)
Z-Wave received "064 - Dimmer Switch (LZW31-SN)" energy total to 0.651 kWh
Z-Wave Debug SENT requestMeterLevel: 01 0A 00 13 40 03 32 01 10 25 AE 0D
Z-Wave Debug RCVD requestMeterLevel: 01 07 00 13 AE 00 00 0C 49 (node ACK)
Z-Wave Debug RCVD sensorSetLevel: 01 09 00 04 00 36 03 20 01 00 E6
Z-Wave Debug . . sensorSetLevel: node 054, endpoint None, cmdClass 20, value 0
Z-Wave received "M's Room (Motion)" status update is off
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 10 00 04 00 36 0A 71 05 00 00 00 FF 07 00 00 00 5B
Z-Wave Debug . . requestAlarmSensorStatus: node 054, endpoint None, cmdClass 71, type 0, value 0, classSubKey 710000
Z-Wave Debug . . requestAlarmSensorStatus: typeExt 7, valueExt 0, classSubKeyExt 7100000700
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 3D 0E 32 02 21 44 00 00 00 00 01 2D 00 00 00 00 A5
Z-Wave Debug . . requestMeterLevel: node 061, endpoint None, meterType 01, raw value 4400...
Z-Wave Debug . . requestMeterLevel: 0.00 kWh (float: 0.000000)
Z-Wave Debug SENT requestDimmerStatus: 01 09 00 13 40 02 26 02 25 AF 09
Z-Wave Debug RCVD requestDimmerStatus: 01 07 00 13 AF 00 00 06 42 (node ACK)
Z-Wave sent "064 - Dimmer Switch (LZW31-SN)" status request
Z-Wave sent "064 - Dimmer Switch (LZW31-SN)" energy status request
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 3D 0E 32 02 21 54 00 00 00 00 01 2D 00 00 00 00 B5
Z-Wave Debug . . requestMeterLevel: node 061, endpoint None, meterType 01, raw value 5400...
Z-Wave Debug . . requestMeterLevel: 0.00 W (float: 0.000000)
Z-Wave Debug RCVD sensorSetLevel: 01 09 00 04 00 36 03 20 01 FF 19
Z-Wave Debug . . sensorSetLevel: node 054, endpoint None, cmdClass 20, value 255
Z-Wave received "M's Room (Motion)" status update is on
Z-Wave Debug RCVD requestDimmerStatus: 01 09 00 04 00 40 03 26 03 00 94
Z-Wave Debug . . requestDimmerStatus: node 064, endpoint None, value 0
Z-Wave Debug SENT requestMeterLevel: 01 0A 00 13 40 03 32 01 00 25 B0 03
Z-Wave Debug RCVD requestMeterLevel: 01 07 00 13 B0 00 00 10 4B (node ACK)
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 10 00 04 00 36 0A 71 05 00 00 00 FF 07 08 00 00 53
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 40 0E 32 02 21 64 00 00 02 8B 00 04 00 00 02 8B D0
Z-Wave Debug SENT requestMeterLevel: 01 0A 00 13 40 03 32 01 10 25 B1 12
Z-Wave Debug RCVD sceneActivateCmd2: 01 0B 00 04 00 15 05 5B 03 06 80 01 3F
Z-Wave Debug . . sceneActivateCmd2: node 021, type: 0, scene: 1
Z-Wave received "021 - Dimmer Switch (LZW31-SN)" down button pressed
Z-Wave Debug RCVD dimmerSetLevel: 01 09 00 04 00 15 03 20 03 00 C7
Z-Wave Debug . . dimmerSetLevel: node 021, endpoint None, value 0
Z-Wave received "021 - Dimmer Switch (LZW31-SN)" status update is off
Z-Wave Debug queueing energy request of "021 - Dimmer Switch (LZW31-SN)" (activity detected)
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 15 0A 32 02 21 34 00 00 00 00 00 00 D1
Z-Wave Debug . . requestMeterLevel: node 021, endpoint None, meterType 01, raw value 3400...
Z-Wave received "021 - Dimmer Switch (LZW31-SN)" power load to 0.0 W
Z-Wave Debug polling status of node "021 - Dimmer Switch (LZW31-SN)" (post-activity energy request)
Z-Wave Debug SENT requestMeterLevel: 01 0A 00 13 15 03 32 01 00 25 13 F5
Z-Wave Debug RCVD requestMeterLevel: 01 07 00 13 13 00 00 02 FA (node ACK)
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 15 0E 32 02 21 64 00 00 00 0B 00 0D 00 00 00 0B 8C
Z-Wave Debug . . requestMeterLevel: node 021, endpoint None, meterType 01, raw value 6400...
Z-Wave Debug . . requestMeterLevel: 0.011 kWh (float: 0.011000)
Z-Wave Debug SENT requestMeterLevel: 01 0A 00 13 15 03 32 01 10 25 14 E2
Z-Wave Debug RCVD requestMeterLevel: 01 07 00 13 14 00 00 03 FC (node ACK)
Z-Wave Debug RCVD sceneActivateCmd2: 01 0B 00 04 00 15 05 5B 03 07 80 01 3E
Z-Wave received "021 - Dimmer Switch (LZW31-SN)" status update is on
Z-Wave Debug SENT requestMeterLevel: 01 0A 00 13 15 03 32 01 00 25 15 F3
Z-Wave Debug RCVD requestMeterLevel: 01 07 00 13 15 00 00 02 FC (node ACK)
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 15 0E 32 02 21 64 00 00 00 0B 00 0B 00 00 00 0B 8A
Z-Wave Debug SENT requestMeterLevel: 01 0A 00 13 15 03 32 01 10 25 16 E0
Z-Wave Debug RCVD requestMeterLevel: 01 07 00 13 16 00 00 02 FF (node ACK)
/code]
pressed the up button while the light was off. Then pressed the up button again (status shows off - lite is on)
[code]
Z-Wave Debug RCVD sceneActivateCmd2: 01 0B 00 04 00 15 05 5B 03 08 80 02 32
Z-Wave Debug . . sceneActivateCmd2: node 021, type: 0, scene: 2
Z-Wave received "021 - Dimmer Switch (LZW31-SN)" up button pressed
Z-Wave Debug RCVD dimmerSetLevel: 01 09 00 04 00 15 03 20 03 46 81
Z-Wave Debug . . dimmerSetLevel: node 021, endpoint None, value 70
Z-Wave received "021 - Dimmer Switch (LZW31-SN)" status update brightness 71
Z-Wave Debug ignoring duplicate energy request of "021 - Dimmer Switch (LZW31-SN)" (activity detected)
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 15 0A 32 02 21 34 00 00 00 37 00 00 E6
Z-Wave Debug . . requestMeterLevel: 5.5 W (float: 5.500000)
Z-Wave received "021 - Dimmer Switch (LZW31-SN)" power load to 5.5 W
Z-Wave Debug SENT requestMeterLevel: 01 0A 00 13 15 03 32 01 00 25 19 FF
Z-Wave Debug RCVD requestMeterLevel: 01 07 00 13 19 00 00 02 F0 (node ACK)
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 15 0E 32 02 21 64 00 00 00 0B 00 7E 00 00 00 0B FF
Z-Wave Debug SENT requestMeterLevel: 01 0A 00 13 15 03 32 01 10 25 1A EC
Z-Wave Debug RCVD requestMeterLevel: 01 07 00 13 1A 00 00 02 F3 (node ACK)
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 15 0A 32 02 21 34 00 00 00 3E 00 00 EF
Z-Wave Debug . . requestMeterLevel: 6.2 W (float: 6.200000)
Z-Wave received "021 - Dimmer Switch (LZW31-SN)" power load to 6.2 W
Z-Wave Debug RCVD sceneActivateCmd2: 01 0B 00 04 00 15 05 5B 03 09 80 02 33
Z-Wave Debug SENT requestMeterLevel: 01 0A 00 13 15 03 32 01 00 25 1B FD
Z-Wave Debug RCVD requestMeterLevel: 01 07 00 13 1B 00 00 02 F2 (node ACK)
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 15 0E 32 02 21 64 00 00 00 0B 00 08 00 00 00 0B 89
Z-Wave Debug SENT requestMeterLevel: 01 0A 00 13 15 03 32 01 10 25 1C EA
Z-Wave Debug RCVD requestMeterLevel: 01 07 00 13 1C 00 00 03 F4 (node ACK)
Users browsing this forum: No registered users and 19 guests
