I was curious about this device so I went ahead and picked one up. I threw together a quick prototype to understand what others have reported. I plan to use this one to control our HVAC humidifier (especially since this will run off 12v DC). I will probably pick up another to control our attic exhaust fan (which is embarrassingly using a corded appliance module now).
Knowing this will work perfectly well with the next release of Indigo, you can still use it now as a 2 relay device (relays 2 and 3) using the standard relay profile that Indigo selects. By capturing Z-Wave packets, it should be easy to use all 3 relays. It has some nice parameters including support for different kinds of switches, garage door mode, etc.
My only complaint so far is that the screw terminals are inaccessible once the device is mounted (which isn't a deal breaker for me).
- Screen Shot 2020-09-13 at 9.12.38 AM.png (29.22 KiB) Viewed 1634 times
- All Off
- IMG_3714.JPG (472.08 KiB) Viewed 1634 times
- Button 2 Pressed
- IMG_1205.JPG (470.4 KiB) Viewed 1634 times
