ok I've got this wired to a doorbell.
It works; when doorbell pressed in1 state changes.
What I don't understand is how I change the 'output'.
Essentially I want doorbell pressed to trigger in2 (or out2 I suppose). ( to unlock a door lock)
I can't see in Indigo how the device is changed i.e. how you can cause an output to alter via a z wave trigger.
The door lock has 2 wires when shorted together it unlocks. I assumed I could use the sensor 'z wave function' to remotely short these 2 wires
I'm undoubtedly misunderstanding something obvious!
