Fibaro smoke sensor FGSD002 doesn't update battery status
Thu May 21, 2020 1:41 pm
yassi offline
I had to replace the battery in this device (the 3rd time since I have it) and and now (even after a resync) the sensor doesn't show the actual (new) battery level.
The battery is new, but the device still shows the level of the "old" battery.
Never had teh issue before,
What to do? A resync didn't helped. Delete the device?
Yassi
Bildschirmfoto 2020-05-21 um 21.29.02.png (25.01 KiB) Viewed 2245 times
Thu May 21, 2020 1:53 pm
Re: Fibaro smoke sensor FGSD002 doesn't update battery statu
Give it 24 hours and it should update.
Thu May 21, 2020 11:20 pm
yassi offline
It didn‘t, Matt. The new battery is since a few days in.
Gesendet von iPhone mit Tapatalk
Fri May 22, 2020 12:35 pm
In the settings dialog what is the Wake Interval set to?
Fri May 22, 2020 12:56 pm
yassi offline
At the moment I think 30 minutes. To test it I’ve also lowered the interval to 5 mins too, but it did’ t make any difference.
Fri May 22, 2020 1:03 pm
Enable Indigo's Z-Wave Debug Logging checkbox (via the Interfaces->Z-Wave->Configure... menu item), change the wake interval to 5 minutes, then restart the Z-Wave interfaces (via the menu). Let that run for 30 minutes or so (several wake intervals), then copy/paste the Event Log results (or email them to us) and we'll see what is occurring when the module wakes. It is important you restart the Z-Wave interface as that will reset Indigo's built-in battery level checking throttle so it should poll out the battery level the next time the module wakes (and now wait until 12 hours have past).
Fri May 22, 2020 1:34 pm
yassi offline
Ok, thanks, Matt, I will try this tomorrow and post/send the logs.
Sat May 23, 2020 12:44 pm
yassi offline
Hi Matt, here we go.
Debug was on for about a half hour, afterwards, I've switched it off and reloaded the interface, hope that's fine so.
23. May 2020 at 19:54:51
   Z-Wave Debug                    stopping node healing thread
   Z-Wave Debug                    stopping node status polling thread
   Z-Wave Debug                    stopped zwave packet parser thread
   Z-Wave                          connection reset requested
   Z-Wave Debug                    starting serial connection loop
   Z-Wave Debug                    starting zwave packet parser thread
   Z-Wave Debug                    SENT getVersion: 01 03 00 15 E9
   Z-Wave Debug                    RCVD getVersion: 01 10 01 15 5A 2D 57 61 76 65 20 33 2E 39 35 00 01 99 (no inbound callback)
   Z-Wave Debug                    . .  getVersion: Z-Wave 3.95 static controller
   Z-Wave Debug                    SENT getHomeID: 01 03 00 20 DC
   Z-Wave Debug                    RCVD getHomeID: 01 08 01 20 C6 10 9A 67 01 FC (no inbound callback)
   Z-Wave Debug                    . .  getHomeID: C6109A67, nodeID: 001
   Z-Wave Debug                    SENT getInterfaceFeatures: 01 03 00 05 F9
   Z-Wave Debug                    RCVD getInterfaceFeatures: 01 04 01 05 18 E7 (no inbound callback)
   Z-Wave Debug                    . .  getInterfaceFeatures: 18
   Z-Wave Debug                    SENT getInterfaceApiCapabilities: 01 03 00 07 FB
   Z-Wave Debug                    RCVD getInterfaceApiCapabilities: 01 2B 01 07 01 00 00 86 00 01 00 5A FE 81 FF 88 4F 1F 00 00 FB 9F 7D A0 67 00 00 80 00 80 86 00 00 00 E8 73 00 00 0E 00 00 60 00 00 FB (no inbound callback)
   Z-Wave Debug                    . .  getInterfaceApiCapabilities: supportedFuncIDs: 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 17 18 1C 20 21 22 23 24 27 29 2A 2B 2C 2D 41 42 44 45 46 47 48 49 4A 4B 4C 4D 50 51 53 54 55 56 57 5E 60 61 62 63 66 67 80 90 92 93 98 B4 B6 B7 B8 B9 BA BD BE BF D2 D3 D4 EE EF
   Z-Wave Debug                    . .  getInterfaceApiCapabilities: serialApi 1.00, manufactureId 0086, productType 0001, productId 005A
   Z-Wave                          connected to Z-Stick interface on /dev/cu.usbmodem471 (firmware 1.00)
   Z-Wave Debug                    SENT forceSUC: 01 05 00 54 01 01 AE
   Z-Wave Debug                    RCVD forceSUC: 01 04 01 54 01 AF (no inbound callback)
   Z-Wave Debug                    SENT getInitialNodeData: 01 03 00 02 FE
   Z-Wave Debug                    RCVD getInitialNodeData: 01 25 01 02 05 08 1D FF 0F 39 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 05 (no inbound callback)
   Z-Wave Debug                    . .  getInitialNodeData: is static update controller
   Z-Wave Debug                    . .  getInitialNodeData: [1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 17, 20, 21, 22]
   Z-Wave Debug                    SENT getNodeProtocolInfo: 01 04 00 41 01 BB
   Z-Wave Debug                    RCVD getNodeProtocolInfo: 01 09 01 41 93 16 01 02 02 01 33 (no inbound callback)
   Z-Wave Debug                    . .  getNodeProtocolInfo:       node 001, class name: Static Computer Controller
   Z-Wave Debug                    . .  getNodeProtocolInfo:            class hierarchy: Static Controller : Static Controller : Static Computer Controller (02 : 02 : 01)
   Z-Wave Debug                    . .  getNodeProtocolInfo:         base class command: 00
   Z-Wave Debug                    . .  getNodeProtocolInfo:   supported class commands: 20
   Z-Wave Debug                    . .  getNodeProtocolInfo:     encrypt class commands:
   Z-Wave Debug                    . .  getNodeProtocolInfo:                   features: beaming
   Z-Wave Debug                    SENT getNodeProtocolInfo: 01 04 00 41 02 B8
   Z-Wave Debug                    RCVD getNodeProtocolInfo: 01 09 01 41 53 9C 00 04 20 01 5C (no inbound callback)
   Z-Wave Debug                    . .  getNodeProtocolInfo:       node 002, class name: Binary Sensor (routing)
   Z-Wave Debug                    . .  getNodeProtocolInfo:            class hierarchy: Routing Slave : Binary Sensor : Binary Sensor (routing) (04 : 20 : 01)
   Z-Wave Debug                    . .  getNodeProtocolInfo:         base class command: 30
   Z-Wave Debug                    . .  getNodeProtocolInfo:   supported class commands: 20 30
   Z-Wave Debug                    . .  getNodeProtocolInfo:                   features: routing, beaming
   Z-Wave Debug                    SENT getNodeProtocolInfo: 01 04 00 41 03 B9
   Z-Wave Debug                    RCVD getNodeProtocolInfo: 01 09 01 41 53 9C 01 04 07 01 7A (no inbound callback)
   Z-Wave Debug                    . .  getNodeProtocolInfo:       node 003, class name: Notification Sensor
   Z-Wave Debug                    . .  getNodeProtocolInfo:            class hierarchy: Routing Slave : Notification Sensor : Notification Sensor (04 : 07 : 01)
   Z-Wave Debug                    SENT getNodeProtocolInfo: 01 04 00 41 04 BE
   Z-Wave Debug                    RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 00 04 11 01 ED (no inbound callback)
   Z-Wave Debug                    . .  getNodeProtocolInfo:       node 004, class name: Dimmable Power Switch
   Z-Wave Debug                    . .  getNodeProtocolInfo:            class hierarchy: Routing Slave : Mulitlevel Switch : Dimmable Power Switch (04 : 11 : 01)
   Z-Wave Debug                    . .  getNodeProtocolInfo:         base class command: 26
   Z-Wave Debug                    . .  getNodeProtocolInfo:   supported class commands: 20 26 27
   Z-Wave Debug                    overriding node 004 type from zwDimmerType to zwColorDimmerType
   Z-Wave Debug                    SENT getNodeProtocolInfo: 01 04 00 41 05 BF
   Z-Wave Debug                    RCVD getNodeProtocolInfo: 01 09 01 41 53 9C 00 04 A1 02 DE (no inbound callback)
   Z-Wave Debug                    . .  getNodeProtocolInfo:       node 005, class name: Alarm Sensor (routing)
   Z-Wave Debug                    . .  getNodeProtocolInfo:            class hierarchy: Routing Slave : Sensor Alarm : Alarm Sensor (routing) (04 : A1 : 02)
   Z-Wave Debug                    . .  getNodeProtocolInfo:         base class command: 71
   Z-Wave Debug                    . .  getNodeProtocolInfo:   supported class commands: 20 80 85 86 71 72
   Z-Wave Debug                    . .  getNodeProtocolInfo:                   features: routing, battery, beaming
   Z-Wave Debug                    overriding node 005 type from zwCustomType to zwOnOffSensorType
   Z-Wave Debug                    SENT getNodeProtocolInfo: 01 04 00 41 06 BC
   Z-Wave Debug                    RCVD getNodeProtocolInfo: 01 09 01 41 53 5C 00 04 10 00 AD (no inbound callback)
   Z-Wave Debug                    . .  getNodeProtocolInfo:       node 006, class name: Relay Switch
   Z-Wave Debug                    . .  getNodeProtocolInfo:            class hierarchy: Routing Slave : Relay Switch : -- (04 : 10 : 00)
   Z-Wave Debug                    . .  getNodeProtocolInfo:         base class command: 25
   Z-Wave Debug                    . .  getNodeProtocolInfo:   supported class commands: 20 25
   Z-Wave Debug                    . .  getNodeProtocolInfo:                   features: routing, beaming, frequentWaking
   Z-Wave Debug                    stopped polling of "006 - Sirene"
   Z-Wave Debug                    started polling of "006 - Sirene" approx every 3600 seconds
   Z-Wave Debug                    SENT getNodeProtocolInfo: 01 04 00 41 07 BD
   Z-Wave Debug                    RCVD getNodeProtocolInfo: 01 09 01 41 13 96 01 01 01 01 33 (no inbound callback)
   Z-Wave Debug                    . .  getNodeProtocolInfo:       node 007, class name: Portable Remote Controller
   Z-Wave Debug                    . .  getNodeProtocolInfo:            class hierarchy: Controller : Portable Controller : Portable Remote Controller (01 : 01 : 01)
   Z-Wave Debug                    SENT getNodeProtocolInfo: 01 04 00 41 08 B2
   Z-Wave Debug                    RCVD getNodeProtocolInfo: 01 09 01 41 52 9C 00 04 A1 07 DA (no inbound callback)
   Z-Wave Debug                    . .  getNodeProtocolInfo:       node 008, class name: Smoke Sensor (routing)
   Z-Wave Debug                    . .  getNodeProtocolInfo:            class hierarchy: Routing Slave : Sensor Alarm : Smoke Sensor (routing) (04 : A1 : 07)
   Z-Wave Debug                    overriding node 008 type from zwCustomType to zwOnOffSensorType
   Z-Wave Debug                    SENT getNodeProtocolInfo: 01 04 00 41 09 B3
   Z-Wave Debug                    . .  getNodeProtocolInfo:       node 009, class name: Smoke Sensor (routing)
   Z-Wave Debug                    overriding node 009 type from zwCustomType to zwOnOffSensorType
   Z-Wave Debug                    SENT getNodeProtocolInfo: 01 04 00 41 0A B0
   Z-Wave Debug                    RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 00 04 10 01 EC (no inbound callback)
   Z-Wave Debug                    . .  getNodeProtocolInfo:       node 010, class name: Relay Power Switch
   Z-Wave Debug                    . .  getNodeProtocolInfo:            class hierarchy: Routing Slave : Relay Switch : Relay Power Switch (04 : 10 : 01)
   Z-Wave Debug                    . .  getNodeProtocolInfo:   supported class commands: 20 25 27
   Z-Wave Debug                    stopped polling of "010 - HiFi-Anlage"
   Z-Wave Debug                    started polling of "010 - HiFi-Anlage" approx every 3600 seconds
   Z-Wave Debug                    SENT getNodeProtocolInfo: 01 04 00 41 0B B1
   Z-Wave Debug                    RCVD getNodeProtocolInfo: 01 09 01 41 D3 9C 01 04 10 01 ED (no inbound callback)
   Z-Wave Debug                    . .  getNodeProtocolInfo:       node 011, class name: Relay Power Switch
   Z-Wave Debug                    stopped polling of "011 - Router"
   Z-Wave Debug                    started polling of "011 - Router" approx every 3600 seconds
   Z-Wave Debug                    SENT getNodeProtocolInfo: 01 04 00 41 0C B6
   Z-Wave Debug                    RCVD getNodeProtocolInfo: 01 09 01 41 53 9C 00 04 08 06 73 (no inbound callback)
   Z-Wave Debug                    . .  getNodeProtocolInfo:       node 012, class name: General Thermostat (v2)
   Z-Wave Debug                    . .  getNodeProtocolInfo:            class hierarchy: Routing Slave : Thermostat : General Thermostat (v2) (04 : 08 : 06)
   Z-Wave Debug                    . .  getNodeProtocolInfo:         base class command: 40
   Z-Wave Debug                    . .  getNodeProtocolInfo:   supported class commands: 20 40 72 43 86
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 012 - General Thermostat (v2)
   Z-Wave Debug                    SENT getNodeProtocolInfo: 01 04 00 41 11 AB
   Z-Wave Debug                    . .  getNodeProtocolInfo:       node 017, class name: General Thermostat (v2)
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 017 - General Thermostat (v2)
   Z-Wave Debug                    SENT getNodeProtocolInfo: 01 04 00 41 14 AE
   Z-Wave Debug                    RCVD getNodeProtocolInfo: 01 09 01 41 13 96 01 01 01 06 34 (no inbound callback)
   Z-Wave Debug                    . .  getNodeProtocolInfo:       node 020, class name: Remote Control Simple
   Z-Wave Debug                    . .  getNodeProtocolInfo:            class hierarchy: Controller : Portable Controller : Remote Control Simple (01 : 01 : 06)
   Z-Wave Debug                    SENT getNodeProtocolInfo: 01 04 00 41 15 AF
   Z-Wave Debug                    . .  getNodeProtocolInfo:       node 021, class name: Relay Power Switch
   Z-Wave Debug                    SENT getNodeProtocolInfo: 01 04 00 41 16 AC
   Z-Wave Debug                    . .  getNodeProtocolInfo:       node 022, class name: Notification Sensor
   Z-Wave Debug                    starting node healing thread
   Z-Wave Debug                    starting node status polling thread
   Z-Wave Debug                    validating parm 001, userVal 2, curVal 2, stateless False, writeonly False
   Z-Wave Debug                    validating parm 003, userVal 7, curVal 7, stateless False, writeonly False
   Z-Wave Debug                    validating parm 004, userVal 7, curVal 7, stateless False, writeonly False
   Z-Wave Debug                    validating parm 020, userVal 1, curVal 1, stateless False, writeonly False
   Z-Wave Debug                    validating parm 021, userVal 10, curVal 10, stateless False, writeonly False
   Z-Wave Debug                    validating parm 030, userVal 55, curVal 55, stateless False, writeonly False
   Z-Wave Debug                    validating parm 031, userVal 1, curVal 1, stateless False, writeonly False
   Z-Wave Debug                    SENT setWakeInterval: 01 0D 00 13 16 06 84 04 00 01 2C 01 25 E1 99
   Online Sensor                   "Public IP-address" new IP Address: X.X.X.X
   Reloading interface "Z-Wave 7.4.1"
   Stopping interface "Z-Wave 7.4.1" (pid 7058)
   Z-Wave                          closed connection to Z-Stick
   Stopped interface "Z-Wave 7.4.1"
   Starting interface "Z-Wave 7.4.1" (pid 79146)
   Started interface "Z-Wave 7.4.1"
   Z-Wave Debug                    . .  getNodeProtocolInfo: requeuing 1 unsolicited packets
   Z-Wave Debug                    RCVD packet: 01 07 00 13 E1 01 03 99 91 (hex)
   Z-Wave Debug                    SENT setWakeInterval: 01 0D 00 13 16 06 84 04 00 01 2C 01 25 F1 89
   Z-Wave Debug                    RCVD setWakeInterval: 01 07 00 13 F1 01 03 85 9D (node NAK)
   Z-Wave Debug                    . .  setWakeInterval: requeuing 1 unsolicited packets
   Z-Wave Error                    device "Rauchmelder Wohnzimmer" may be asleep. configuration changes will be set during the next wake interval.
   Z-Wave Debug                    RCVD requestVarSensorStatus: 01 0C 00 04 00 02 06 31 05 01 22 00 DF 3B
   Z-Wave Debug                    . .  requestVarSensorStatus: node 002, endpoint None, type 1, raw value 2200...
   Z-Wave Debug                    . .  requestVarSensorStatus: 22.3 °C (float: 22.300000)
   Z-Wave Debug                    received "Temperatursensor Flur" sensor update to 22.3 °C
23. May 2020 at 19:55:42
   Z-Wave Debug                    RCVD requestVarSensorStatus: 01 0C 00 04 00 02 06 31 05 03 0A 00 02 CC
   Z-Wave Debug                    . .  requestVarSensorStatus: node 002, endpoint None, type 3, raw value 0A00...
   Z-Wave Debug                    . .  requestVarSensorStatus: 2 lux (float: 2.000000)
   Z-Wave Debug                    received "Helligkeitssensor Flur" sensor update to 2 lux
23. May 2020 at 19:56:16
   Z-Wave Debug                    RCVD requestVarSensorStatus: 01 0C 00 04 00 02 06 31 05 01 22 00 E0 04
   Z-Wave Debug                    . .  requestVarSensorStatus: 22.4 °C (float: 22.400000)
   Z-Wave Debug                    received "Temperatursensor Flur" sensor update to 22.4 °C
23. May 2020 at 19:56:41
23. May 2020 at 19:56:58
   Online Sensor                   "Internet connectivity sensor" on
23. May 2020 at 19:57:15
23. May 2020 at 19:57:41
   Z-Wave Debug                    RCVD nonceFetch: node 021
   Z-Wave Debug                    SENT nonceReport: 01 11 00 13 15 0A 98 80 65 CF 4A 06 70 36 04 38 25 F2 B1
   Z-Wave Debug                    RCVD nonceReport: 01 07 00 13 F2 00 00 19 00 (node ACK)
   Z-Wave Debug                    RCVD encryptedPacket: 00 32 02 21 64 00 00 71 A2 02 58 00 00 71 A2 (decrypted)
   Z-Wave Debug                    RCVD requestMeterLevel: 01 14 00 04 00 15 0E 32 02 21 64 00 00 71 A2 02 58 00 00 71 A2 FF
   Z-Wave Debug                    . .  requestMeterLevel: node 021, endpoint None, meterType 01, raw value 6400...
   Z-Wave Debug                    . .  requestMeterLevel: 29.090 kWh (float: 29.090000)
23. May 2020 at 19:58:15
23. May 2020 at 19:58:41
23. May 2020 at 19:59:15
23. May 2020 at 19:59:41
23. May 2020 at 20:00:14
   Z-Wave Debug                    RCVD nodeAwake: 01 08 00 04 00 03 02 84 07 71
   Z-Wave Debug                    . .  nodeAwake: node 003
   Z-Wave Debug                    SENT requestBatteryLevel: 01 09 00 13 03 02 80 02 25 F3 B0
   Z-Wave Debug                    RCVD requestBatteryLevel: 01 07 00 13 F3 00 00 15 0D (node ACK)
   Z-Wave Debug                    . .  nodeAwake: inhibit count++ to 1
   Z-Wave Debug                    . .  nodeAwake: started inhibit sleep timer
   Z-Wave Debug                    RCVD requestBatteryLevel: 01 09 00 04 00 03 03 80 03 5A 2B
   Z-Wave Debug                    . .  requestBatteryLevel: node 003, level 90
   Z-Wave                          received "003 - Türsensor Eingangstür" status update battery level 90%
   Z-Wave Debug                    . .  nodeAwake: inhibit count-- to 0
   Z-Wave Debug                    . .  nodeAwake: stopping inhibit sleep timer
   Z-Wave Debug                    SENT goToSleep: 01 09 00 13 03 02 84 08 24 F4 B8
   Z-Wave Debug                    RCVD packet: 01 07 00 13 F4 00 00 04 1B (hex)
23. May 2020 at 20:00:40
23. May 2020 at 20:01:14
23. May 2020 at 20:01:40
23. May 2020 at 20:02:14
23. May 2020 at 20:02:39
   Z-Wave Debug                    RCVD nodeAwake: 01 08 00 04 00 11 02 84 07 63
   Z-Wave Debug                    . .  nodeAwake: node 017
   Z-Wave Debug                    SENT goToSleep: 01 09 00 13 11 02 84 08 24 F5 AB
   Z-Wave Debug                    RCVD packet: 01 07 00 13 F5 00 00 01 1F (hex)
23. May 2020 at 20:03:13
23. May 2020 at 20:03:39
23. May 2020 at 20:04:13
   Z-Wave Debug                    RCVD nodeAwake: 01 08 00 04 00 0C 02 84 07 7E
   Z-Wave Debug                    . .  nodeAwake: node 012
   Z-Wave Debug                    SENT goToSleep: 01 09 00 13 0C 02 84 08 24 F6 B5
   Z-Wave Debug                    RCVD packet: 01 07 00 13 F6 00 00 0A 17 (hex)
23. May 2020 at 20:04:39
23. May 2020 at 20:05:13
23. May 2020 at 20:05:39
23. May 2020 at 20:06:13
23. May 2020 at 20:06:38
23. May 2020 at 20:07:12
23. May 2020 at 20:07:38
   Z-Wave Debug                    SENT nonceReport: 01 11 00 13 15 0A 98 80 FE D7 3F D3 EC 1A 69 0F 25 F7 7D
   Z-Wave Debug                    RCVD nonceReport: 01 07 00 13 F7 00 00 15 09 (node ACK)
23. May 2020 at 20:08:12
23. May 2020 at 20:08:38
23. May 2020 at 20:09:12
23. May 2020 at 20:09:38
23. May 2020 at 20:10:11
23. May 2020 at 20:10:37
23. May 2020 at 20:11:11
23. May 2020 at 20:11:37
23. May 2020 at 20:12:11
23. May 2020 at 20:12:37
23. May 2020 at 20:13:10
23. May 2020 at 20:13:36
23. May 2020 at 20:14:11
23. May 2020 at 20:14:36
23. May 2020 at 20:15:10
23. May 2020 at 20:15:36
23. May 2020 at 20:16:10
   Z-Wave Debug                    RCVD nodeAwake: 01 08 00 04 00 05 02 84 07 77
   Z-Wave Debug                    . .  nodeAwake: node 005
   Z-Wave Debug                    SENT requestBatteryLevel: 01 09 00 13 05 02 80 02 25 F8 BD
   Z-Wave Debug                    RCVD requestBatteryLevel: 01 07 00 13 F8 00 00 03 10 (node ACK)
   Z-Wave Debug                    RCVD requestBatteryLevel: 01 09 00 04 00 05 03 80 03 41 36
   Z-Wave Debug                    . .  requestBatteryLevel: node 005, level 65
   Z-Wave                          received "005 - Wassermelder Bad" status update battery level 65%
   Z-Wave Debug                    SENT goToSleep: 01 09 00 13 05 02 84 08 24 F9 B3
   Z-Wave Debug                    RCVD packet: 01 07 00 13 F9 00 00 02 10 (hex)
23. May 2020 at 20:16:36
   Z-Wave Debug                    RCVD nodeAwake: 01 08 00 04 00 02 02 84 07 70
   Z-Wave Debug                    . .  nodeAwake: node 002
   Z-Wave Debug                    SENT requestBatteryLevel: 01 09 00 13 02 02 80 02 25 FA B8
   Z-Wave Debug                    RCVD requestBatteryLevel: 01 07 00 13 FA 00 00 06 17 (node ACK)
   Z-Wave Debug                    RCVD requestBatteryLevel: 01 09 00 04 00 02 03 80 03 64 14
   Z-Wave Debug                    . .  requestBatteryLevel: node 002, level 100
   Z-Wave Debug                    received "002 - Bewegungsmelder Flur" status update battery level 100%
   Z-Wave Debug                    SENT goToSleep: 01 09 00 13 02 02 84 08 24 FB B6
   Z-Wave Debug                    RCVD packet: 01 07 00 13 FB 00 00 02 12 (hex)
23. May 2020 at 20:17:09
23. May 2020 at 20:17:35
   Z-Wave Debug                    SENT nonceReport: 01 11 00 13 15 0A 98 80 59 AE 28 90 44 4B E9 0F 25 FC 85
   Z-Wave Debug                    RCVD nonceReport: 01 07 00 13 FC 00 00 19 0E (node ACK)
   Z-Wave Debug                    . .  nonceReport: requeuing 1 unsolicited packets
   Z-Wave Debug                    SENT goToSleep: 01 09 00 13 11 02 84 08 24 FD A3
   Z-Wave Debug                    RCVD packet: 01 07 00 13 FD 00 00 01 17 (hex)
23. May 2020 at 20:18:09
23. May 2020 at 20:18:35
23. May 2020 at 20:19:09
23. May 2020 at 20:19:25
   Z-Wave Debug                    SENT goToSleep: 01 09 00 13 0C 02 84 08 24 FE BD
   Z-Wave Debug                    RCVD packet: 01 07 00 13 FE 00 00 0D 18 (hex)
23. May 2020 at 20:20:09
23. May 2020 at 20:20:34
23. May 2020 at 20:21:08
23. May 2020 at 20:21:34
23. May 2020 at 20:22:08
23. May 2020 at 20:22:34
23. May 2020 at 20:23:08
23. May 2020 at 20:23:33
   Z-Wave Debug                    RCVD requestVarSensorStatus: 01 0C 00 04 00 02 06 31 05 03 0A 00 01 CF
   Z-Wave Debug                    . .  requestVarSensorStatus: 1 lux (float: 1.000000)
   Z-Wave Debug                    received "Helligkeitssensor Flur" sensor update to 1 lux
23. May 2020 at 20:24:08
23. May 2020 at 20:24:33
23. May 2020 at 20:25:07
23. May 2020 at 20:25:33
23. May 2020 at 20:26:07
23. May 2020 at 20:26:32
23. May 2020 at 20:27:06
23. May 2020 at 20:27:32
   Z-Wave Debug                    SENT nonceReport: 01 11 00 13 15 0A 98 80 45 58 40 A3 F9 60 1F 34 25 FF 6C
   Z-Wave Debug                    RCVD nonceReport: 01 07 00 13 FF 00 00 17 03 (node ACK)
23. May 2020 at 20:28:06
23. May 2020 at 20:28:32
23. May 2020 at 20:29:05
23. May 2020 at 20:29:32
23. May 2020 at 20:30:05
23. May 2020 at 20:30:20
   Z-Wave Debug                    . . . . . . . : skipping battery check (next check in 687 mins)
   Z-Wave Debug                    SENT goToSleep: 01 09 00 13 03 02 84 08 24 01 4D
   Z-Wave Debug                    RCVD packet: 01 07 00 13 01 00 00 08 E2 (hex)
23. May 2020 at 20:31:05
23. May 2020 at 20:31:31
23. May 2020 at 20:32:05
P.S. I've removed my public IP-adress in the log.
Thanks in advance!
Yassi
Mon May 25, 2020 12:46 pm
So it looks like that module is not waking up frequently. Here is Indigo trying to change the wake interval at the beginning:
But then the module never wakes up for Indigo to push that change to it. Kind-of a chicken/egg problem in that you have to wait for the original wake interval duration to pass before a module will wake up and can accept be changed to a shorter duration.
I'm not sure how the FGSD002 works, but you might want to try forcing it awake. If that isn't possible or doesn't work, then I would recommend excluding, re-including, and re-syncing it.
Fri May 29, 2020 10:11 am
yassi offline
Hi Matt,
ok, thanks.
I've tried twice (last time today in the morning) but I didn't succeeded, it still shows 5% battery.
Here are the logs from the exclusion/inclusion.
29. May 2020 at 10:56:22
   Z-Wave                          started controller exclusion mode
   Z-Wave                          controller excluded module: 023 - Rauchmelder Wohnzimmer
   Z-Wave Error                    device "Rauchmelder Wohnzimmer" no longer has a matching module 023 in the controller
   Z-Wave Error                    device "Vandalismussensor Rauchmelder Wohnzimmer" no longer has a matching module 023 in the controller
   Z-Wave Error                    device "Temperatursensor Wohnzimmer" no longer has a matching module 023 in the controller
   Z-Wave Error                    to re-enable the device with a new z-wave module, press the "Define and Sync..." button in the device dialog
   Z-Wave                          stopped controller exclusion mode
29. May 2020 at 10:57:26
   Z-Wave                          started controller inclusion mode with encryption
   Z-Wave                          controller included module: 024 - Notification Sensor
   Z-Wave                          querying module for encryption support
   Z-Wave                          starting encryption key exchange with module
   Z-Wave                          completed encryption key exchange with module
   Z-Wave                          stopped controller inclusion mode
29. May 2020 at 10:58:13
   Z-Wave                          Syncing - started for "024 - Notification Sensor"
   Z-Wave                          Syncing - retrieved module neighbors list: 4, 10
   Z-Wave                          Syncing - assigning return route to "024 - Notification Sensor"
   Z-Wave                          Syncing - retrieved manufacture and model names: Fibaro System - 010F, Smoke Sensor (FGSD002) - 0C021002
   Z-Wave                          Syncing - retrieved protocol version 4.05, app version 3.03
   Z-Wave                          Syncing - retrieved class hierarchy: Routing Slave : Notification Sensor : Notification Sensor (04 : 07 : 01, base 00)
   Z-Wave                          Syncing - retrieved command classes: 80v1 84v2 85v1 86v1 8Ev1 56v1 98v1 59v1 5Av1 9Cv1 5Ev1 20v1 22v1 71v1 70v1 31v8 72v1 73v1 7Av1
   Z-Wave                          Syncing - retrieved encrypt commands: 20 84 85 8E 70 71 5A 9C
   Z-Wave                          Syncing - retrieved capabilities: routing, battery, beaming, security, waking
   Z-Wave                          Syncing - retrieved wake interval of 360 minutes
   Z-Wave                          Syncing - device "024 - Notification Sensor" wake interval changed to 60 minutes
   Z-Wave                          Syncing - retrieved group 1 associations: []
   Z-Wave                          Syncing - retrieved group 2 associations: []
   Z-Wave                          Syncing - retrieved group 3 associations: []
   Z-Wave                          Syncing - retrieved group 4 associations: []
   Z-Wave                          Syncing - retrieved group 5 associations: []
   Z-Wave                          Syncing - added group 1 association to interface
   Z-Wave                          Syncing - added group 2 association to interface
   Z-Wave                          Syncing - added group 5 association to interface
   Z-Wave                          Syncing - retrieved parameter 2 "Notification flags" is 0
   Z-Wave                          Syncing - device "024 - Notification Sensor" parameter 2 "Notification flags" changed to 3
   Z-Wave                          Syncing - retrieved parameter 10 "Group 2 command type" is 0
   Z-Wave                          Syncing - retrieved parameter 11 "Group 2 command value" is 255
   Z-Wave                          Syncing - retrieved parameter 1 "Smoke sensitivity" is 2 "Medium"
   Z-Wave                          Syncing - retrieved parameter 3 "Visual alerts" is 0 "Disabled"
   Z-Wave                          Syncing - retrieved parameter 4 "Audible alerts" is 0 "Disabled"
   Z-Wave                          Syncing - retrieved parameter 20 "Temperature interval" is 1 * 10 seconds
   Z-Wave                          Syncing - retrieved parameter 21 "Temperature sensitivity" is 10 * 0.1°C
   Z-Wave                          Syncing - retrieved parameter 30 "Temperature threshold" is 55 °C
   Z-Wave                          Syncing - retrieved parameter 31 "Temperature alarm" is 1 "10 Seconds"
   Z-Wave                          Syncing - retrieved battery level of 5%
   Z-Wave                          Syncing - changed device "Rauchmelder Wohnzimmer" address from undefined to 024
   Z-Wave                          Syncing - changed device "Vandalismussensor Rauchmelder Wohnzimmer" address from undefined to 024
   Z-Wave                          Syncing - changed device "Temperatursensor Wohnzimmer" address from undefined to 024
I'm thinking to do it this way:
1. Exclude
2, Delete teh device from Indigo
3. Reset it (there is a procedure described in the manual).
4. Includ & create the device again
What do you think?
Yassi
Bildschirmfoto 2020-05-29 um 18.10.39.png (14.2 KiB) Viewed 2040 times
Fri May 29, 2020 10:24 am
That sounds good. The Indigo device delete shouldn't be needed but won't hurt. Note though it might delete dependent Triggers, Schedules, Action Groups.
Fri May 29, 2020 10:34 am
yassi offline
Yeah, that‘s the problem. Have triggers, actions, etc. Maybe I won‘t delete it.
Sun Jun 07, 2020 10:38 am
yassi offline
Hi Matt,
sorry for the delay, didn't had the time to take care about the smoke sensor.
Well, I've excluded, deleted and resetted it, now it's showing again the right battery level! :lol:
Yassi
Users browsing this forum: No registered users and 23 guests
