The first time I noticed it was when I was testing a Fibaro Button that I haven't used in a long time. Shortly after the errors appeared in connection with another device (a door sensor).
This is what the log looks like … (There are a couple of events at the beginning, two button presses and some RFXCOM reports, that I assume are unrelated …)
And yes, it's sort of repetitive:
2020-05-11 23:28:40.261 Z-Wave Error missing expected node callback ack (165) for nonceReport (will re-send)
2020-05-11 23:28:47.017 RFXCOM Error probably a LW Remote?
2020-05-11 23:28:47.019 Trigger Test button press
2020-05-11 23:28:53.540 RFXCOM Error probably a LW Remote?
2020-05-11 23:28:53.545 Trigger Test button press
2020-05-11 23:29:40.262 Z-Wave Error no ack/nak/busy reply (165) for nonceReport (re-sending)
2020-05-11 23:29:49.491 Z-Wave Error RCVD encryptedPacket: unexpected sequence byte 8C
2020-05-11 23:29:49.491 Z-Wave Error RCVD encryptedPacket: full raw packet 01 20 00 04 10 A5 1A 98 81 74 93 F7 23 59 76 CB 45 43 22 A1 C7 4D CD 57 7F 90 8E 43 E0 DE C0 A6 47 12
2020-05-11 23:29:49.492 Z-Wave Error RCVD encryptedPacket: encrypted packet 43 22 A1 C7 4D CD 57
2020-05-11 23:29:49.493 Z-Wave Error RCVD encryptedPacket: decrypted packet 8C FE FE CC B5 8C EF
2020-05-11 23:29:49.493 Z-Wave Error encrypted command received from node ID 165 has invalid CBC-MAC value (ignoring)
2020-05-11 23:29:49.494 Z-Wave Error RCVD encryptedPacket: unexpected sequence byte 8C
2020-05-11 23:29:49.494 Z-Wave Error RCVD encryptedPacket: full raw packet 01 20 00 04 10 A5 1A 98 81 74 93 F7 23 59 76 CB 45 43 22 A1 C7 4D CD 57 7F 90 8E 43 E0 DE C0 A6 47 12
2020-05-11 23:29:49.495 Z-Wave Error RCVD encryptedPacket: encrypted packet 43 22 A1 C7 4D CD 57
2020-05-11 23:29:49.495 Z-Wave Error RCVD encryptedPacket: decrypted packet 8C FE FE CC B5 8C EF
2020-05-11 23:29:49.496 Z-Wave Error encrypted command received from node ID 165 has invalid CBC-MAC value (ignoring)
2020-05-11 23:29:49.498 Z-Wave Error RCVD encryptedPacket: unexpected sequence byte 8C
2020-05-11 23:29:49.498 Z-Wave Error RCVD encryptedPacket: full raw packet 01 20 00 04 10 A5 1A 98 81 74 93 F7 23 59 76 CB 45 43 22 A1 C7 4D CD 57 7F 90 8E 43 E0 DE C0 A6 47 12
2020-05-11 23:29:49.499 Z-Wave Error RCVD encryptedPacket: encrypted packet 43 22 A1 C7 4D CD 57
2020-05-11 23:29:49.499 Z-Wave Error RCVD encryptedPacket: decrypted packet 8C FE FE CC B5 8C EF
2020-05-11 23:29:49.500 Z-Wave Error encrypted command received from node ID 165 has invalid CBC-MAC value (ignoring)
2020-05-11 23:29:49.501 Z-Wave Error RCVD encryptedPacket: unexpected sequence byte 8C
2020-05-11 23:29:49.502 Z-Wave Error RCVD encryptedPacket: full raw packet 01 20 00 04 10 A5 1A 98 81 74 93 F7 23 59 76 CB 45 43 22 A1 C7 4D CD 57 7F 90 8E 43 E0 DE C0 A6 47 12
2020-05-11 23:29:49.502 Z-Wave Error RCVD encryptedPacket: encrypted packet 43 22 A1 C7 4D CD 57
2020-05-11 23:29:49.503 Z-Wave Error RCVD encryptedPacket: decrypted packet 8C FE FE CC B5 8C EF
2020-05-11 23:29:49.505 Z-Wave Error encrypted command received from node ID 165 has invalid CBC-MAC value (ignoring)
2020-05-11 23:29:49.506 Z-Wave Error RCVD encryptedPacket: unexpected sequence byte 8C
2020-05-11 23:29:49.507 Z-Wave Error RCVD encryptedPacket: full raw packet 01 20 00 04 10 A5 1A 98 81 74 93 F7 23 59 76 CB 45 43 22 A1 C7 4D CD 57 7F 90 8E 43 E0 DE C0 A6 47 12
2020-05-11 23:29:49.507 Z-Wave Error RCVD encryptedPacket: encrypted packet 43 22 A1 C7 4D CD 57
2020-05-11 23:29:49.508 Z-Wave Error RCVD encryptedPacket: decrypted packet 8C FE FE CC B5 8C EF
2020-05-11 23:29:49.508 Z-Wave Error encrypted command received from node ID 165 has invalid CBC-MAC value (ignoring)
2020-05-11 23:29:49.510 Z-Wave Error RCVD encryptedPacket: unexpected sequence byte 8C
2020-05-11 23:29:49.510 Z-Wave Error RCVD encryptedPacket: full raw packet 01 20 00 04 10 A5 1A 98 81 74 93 F7 23 59 76 CB 45 43 22 A1 C7 4D CD 57 7F 90 8E 43 E0 DE C0 A6 47 12
2020-05-11 23:29:49.511 Z-Wave Error RCVD encryptedPacket: encrypted packet 43 22 A1 C7 4D CD 57
2020-05-11 23:29:49.511 Z-Wave Error RCVD encryptedPacket: decrypted packet 8C FE FE CC B5 8C EF
2020-05-11 23:29:49.512 Z-Wave Error encrypted command received from node ID 165 has invalid CBC-MAC value (ignoring)
2020-05-11 23:29:49.513 Z-Wave Error RCVD encryptedPacket: unexpected sequence byte 8C
2020-05-11 23:29:49.513 Z-Wave Error RCVD encryptedPacket: full raw packet 01 20 00 04 10 A5 1A 98 81 74 93 F7 23 59 76 CB 45 43 22 A1 C7 4D CD 57 7F 90 8E 43 E0 DE C0 A6 47 12
2020-05-11 23:29:49.514 Z-Wave Error RCVD encryptedPacket: encrypted packet 43 22 A1 C7 4D CD 57
2020-05-11 23:29:49.515 Z-Wave Error RCVD encryptedPacket: decrypted packet 8C FE FE CC B5 8C EF
2020-05-11 23:29:49.515 Z-Wave Error encrypted command received from node ID 165 has invalid CBC-MAC value (ignoring)
2020-05-11 23:29:49.517 Z-Wave Error RCVD encryptedPacket: unexpected sequence byte 8C
2020-05-11 23:29:49.517 Z-Wave Error RCVD encryptedPacket: full raw packet 01 20 00 04 10 A5 1A 98 81 74 93 F7 23 59 76 CB 45 43 22 A1 C7 4D CD 57 7F 90 8E 43 E0 DE C0 A6 47 12
2020-05-11 23:29:49.518 Z-Wave Error RCVD encryptedPacket: encrypted packet 43 22 A1 C7 4D CD 57
2020-05-11 23:29:49.518 Z-Wave Error RCVD encryptedPacket: decrypted packet 8C FE FE CC B5 8C EF
2020-05-11 23:29:49.519 Z-Wave Error encrypted command received from node ID 165 has invalid CBC-MAC value (ignoring)
2020-05-11 23:29:49.520 Z-Wave Error RCVD encryptedPacket: unexpected sequence byte 8C
2020-05-11 23:29:49.521 Z-Wave Error RCVD encryptedPacket: full raw packet 01 20 00 04 10 A5 1A 98 81 74 93 F7 23 59 76 CB 45 43 22 A1 C7 4D CD 57 7F 90 8E 43 E0 DE C0 A6 47 12
2020-05-11 23:29:49.522 Z-Wave Error RCVD encryptedPacket: encrypted packet 43 22 A1 C7 4D CD 57
2020-05-11 23:29:49.522 Z-Wave Error RCVD encryptedPacket: decrypted packet 8C FE FE CC B5 8C EF
2020-05-11 23:29:49.523 Z-Wave Error encrypted command received from node ID 165 has invalid CBC-MAC value (ignoring)
2020-05-11 23:29:49.524 Z-Wave Error RCVD encryptedPacket: unexpected sequence byte 8C
2020-05-11 23:29:49.524 Z-Wave Error RCVD encryptedPacket: full raw packet 01 20 00 04 10 A5 1A 98 81 74 93 F7 23 59 76 CB 45 43 22 A1 C7 4D CD 57 7F 90 8E 43 E0 DE C0 A6 47 12
2020-05-11 23:29:49.525 Z-Wave Error RCVD encryptedPacket: encrypted packet 43 22 A1 C7 4D CD 57
2020-05-11 23:29:49.525 Z-Wave Error RCVD encryptedPacket: decrypted packet 8C FE FE CC B5 8C EF
2020-05-11 23:29:49.526 Z-Wave Error encrypted command received from node ID 165 has invalid CBC-MAC value (ignoring)
2020-05-11 23:29:49.528 Z-Wave Error RCVD encryptedPacket: unexpected sequence byte 8C
2020-05-11 23:29:49.528 Z-Wave Error RCVD encryptedPacket: full raw packet 01 20 00 04 10 A5 1A 98 81 74 93 F7 23 59 76 CB 45 43 22 A1 C7 4D CD 57 7F 90 8E 43 E0 DE C0 A6 47 12
2020-05-11 23:29:49.529 Z-Wave Error RCVD encryptedPacket: encrypted packet 43 22 A1 C7 4D CD 57
2020-05-11 23:29:49.529 Z-Wave Error RCVD encryptedPacket: decrypted packet 8C FE FE CC B5 8C EF
2020-05-11 23:29:49.530 Z-Wave Error encrypted command received from node ID 165 has invalid CBC-MAC value (ignoring)
2020-05-11 23:29:49.531 Z-Wave Error RCVD encryptedPacket: unexpected sequence byte 8C
2020-05-11 23:29:49.531 Z-Wave Error RCVD encryptedPacket: full raw packet 01 20 00 04 10 A5 1A 98 81 74 93 F7 23 59 76 CB 45 43 22 A1 C7 4D CD 57 7F 90 8E 43 E0 DE C0 A6 47 12
2020-05-11 23:29:49.532 Z-Wave Error RCVD encryptedPacket: encrypted packet 43 22 A1 C7 4D CD 57
2020-05-11 23:29:49.533 Z-Wave Error RCVD encryptedPacket: decrypted packet 8C FE FE CC B5 8C EF
2020-05-11 23:29:49.535 Z-Wave Error encrypted command received from node ID 165 has invalid CBC-MAC value (ignoring)
2020-05-11 23:29:49.542 Z-Wave Error RCVD encryptedPacket: unexpected sequence byte 8C
2020-05-11 23:29:49.552 Z-Wave Error RCVD encryptedPacket: full raw packet 01 20 00 04 10 A5 1A 98 81 74 93 F7 23 59 76 CB 45 43 22 A1 C7 4D CD 57 7F 90 8E 43 E0 DE C0 A6 47 12
2020-05-11 23:29:49.554 Z-Wave Error RCVD encryptedPacket: encrypted packet 43 22 A1 C7 4D CD 57
2020-05-11 23:29:49.555 Z-Wave Error RCVD encryptedPacket: decrypted packet 8C FE FE CC B5 8C EF
2020-05-11 23:29:49.557 Z-Wave Error encrypted command received from node ID 165 has invalid CBC-MAC value (ignoring)
2020-05-11 23:29:49.560 Z-Wave Error RCVD encryptedPacket: unexpected sequence byte 8C
2020-05-11 23:29:49.560 Z-Wave Error RCVD encryptedPacket: full raw packet 01 20 00 04 10 A5 1A 98 81 74 93 F7 23 59 76 CB 45 43 22 A1 C7 4D CD 57 7F 90 8E 43 E0 DE C0 A6 47 12
2020-05-11 23:29:49.562 Z-Wave Error RCVD encryptedPacket: encrypted packet 43 22 A1 C7 4D CD 57
2020-05-11 23:29:49.562 Z-Wave Error RCVD encryptedPacket: decrypted packet 8C FE FE CC B5 8C EF
2020-05-11 23:29:49.564 Z-Wave Error encrypted command received from node ID 165 has invalid CBC-MAC value (ignoring)
2020-05-11 23:29:49.568 Z-Wave Error RCVD encryptedPacket: unexpected sequence byte 8C
2020-05-11 23:29:49.568 Z-Wave Error RCVD encryptedPacket: full raw packet 01 20 00 04 10 A5 1A 98 81 74 93 F7 23 59 76 CB 45 43 22 A1 C7 4D CD 57 7F 90 8E 43 E0 DE C0 A6 47 12
2020-05-11 23:29:49.570 Z-Wave Error RCVD encryptedPacket: encrypted packet 43 22 A1 C7 4D CD 57
2020-05-11 23:29:49.572 Z-Wave Error RCVD encryptedPacket: decrypted packet 8C FE FE CC B5 8C EF
2020-05-11 23:29:49.574 Z-Wave Error encrypted command received from node ID 165 has invalid CBC-MAC value (ignoring)
2020-05-11 23:29:49.578 Z-Wave Error RCVD encryptedPacket: unexpected sequence byte 8C
2020-05-11 23:29:49.579 Z-Wave Error RCVD encryptedPacket: full raw packet 01 20 00 04 10 A5 1A 98 81 74 93 F7 23 59 76 CB 45 43 22 A1 C7 4D CD 57 7F 90 8E 43 E0 DE C0 A6 47 12
2020-05-11 23:29:49.580 Z-Wave Error RCVD encryptedPacket: encrypted packet 43 22 A1 C7 4D CD 57
2020-05-11 23:29:49.594 Z-Wave Error RCVD encryptedPacket: decrypted packet 8C FE FE CC B5 8C EF
2020-05-11 23:29:49.596 Z-Wave Error encrypted command received from node ID 165 has invalid CBC-MAC value (ignoring)
2020-05-11 23:29:49.601 Z-Wave Error RCVD encryptedPacket: unexpected sequence byte 8C
2020-05-11 23:29:49.603 Z-Wave Error RCVD encryptedPacket: full raw packet 01 20 00 04 10 A5 1A 98 81 74 93 F7 23 59 76 CB 45 43 22 A1 C7 4D CD 57 7F 90 8E 43 E0 DE C0 A6 47 12
2020-05-11 23:29:49.605 Z-Wave Error RCVD encryptedPacket: encrypted packet 43 22 A1 C7 4D CD 57
2020-05-11 23:29:49.607 Z-Wave Error RCVD encryptedPacket: decrypted packet 8C FE FE CC B5 8C EF
2020-05-11 23:29:49.612 Z-Wave Error encrypted command received from node ID 165 has invalid CBC-MAC value (ignoring)
2020-05-11 23:29:49.659 Z-Wave Error error trying to parse value (valsize 4 too large for packetsize 3)
