Disable routing of device
Thu May 07, 2020 1:50 am
davinci offline
I have a device which changes position frequently. Now I want to avoid that it is used for routing signals or that it does routing to neighbors that aren't there. Especially the first point I need to make it stop since some other devices act strange if the device is nearby or not.
How can I do this?
Indigo Z-Wave Version: 7.4.1
Node ID: 102
Model: Multilevel Sensor (routing)
Model ID: 01100001
Manufacturer: Duwi
Manufacturer ID: 0115
Protocol Version: 4.38
Application Version: 2.13
Model Definition Version: 0
Library Type: 3
Class Name: Multilevel Sensor (routing)
Class Hierarchy: 04 : 21 : 01
Command Class Base: 31
Command Versions: 20v1 80v1 84v2 85v1 86v1 60v4 8Ev1 70v1 31v7 72v1 73v1 59v1 7Av1 5Av1 5Ev1 25v1
Multi-Endpoint Types: 1:(21 : 01), 2:(10 : 01)
Multi-Endpoint Classes: 1:[31], 2:[25]
Features: routing, battery, beaming, waking
Neighbors: 5, 71, 74
Associations: 1:[1]
Config Values: - none -
Thu May 07, 2020 4:37 pm
Re: Disable routing of device
The Z-Wave->Optimize Z-Wave Network... menu command is pretty much the only tool in the toolbox for this. You can just query the neighbor nodes around that particular module and it will hopefully clean-up the routing both for that node and all of its previous neighbors. The Z-Wave Controller API doesn't really provide control over how routing is setup outside of telling a module to try to re-discover what its neighbors are.
Fri May 08, 2020 8:51 am
davinci offline
I use the sensor on a robot. Can I disable routing over this sensor? Basically act like a battery powered device.
Fri May 08, 2020 10:02 am
I'm not aware of any Z-Wave command to enable/disable routing.
