How to set up Roller without Indigo UI
Sun Apr 12, 2020 1:19 am
davinci offline
I have this device:
viewtopic.php?f=132&t=23810
Z-Wave Indigo Device "112 - Mulitlevel Switch" Z-Wave Properties:
Indigo Z-Wave Version: 7.4.1
Node ID: 112
Model: Motor Control Class B
Model ID: 03031000
Manufacturer: Fibaro System
Manufacturer ID: 010F
Protocol Version: 6.02
Application Version: 5.01
Model Definition Version: 0
Library Type: 3
Class Name: Motor Control Class B
Class Hierarchy: 04 : 11 : 06
Command Class Base: 26
Command Versions: 20v1 85v1 86v1 8Ev1 55v1 56v1 98v1 59v1 5Av1 5Bv1 5Ev1 9Fv1 60v4 22v1 25v1 26v4 6Cv1 32v3 70v1 71v1 72v1 73v1 75v1 7Av1
Multi-Endpoint Types: 1:(11 : 06), 2:(11 : 06)
Multi-Endpoint Classes: 1:[5E 26 85 8E 59 98 9F 6C 32 71 22], 2:[5E 26 85 8E 59 98 9F 6C 22]
Features: routing, beaming, security, energyMeter
Neighbors: 4, 5, 6, 11, 12, 27, 29, 31, 32, 40, 57, 58, 59, 60, 61, 66, 67, 68, 69, 71, 73, 74
Associations: 1:[1] 2:[] 3:[]
Config Values: - none -
Since Indigo is not supporting this version, I need to find another way to make it work. How can I do this?
I need to calibrate and to set it to whatever percentage.
But sending this RAW command did nothing (log from other rollers that calibrated):
01 0C 00 13 39 05 70 04 1D 01 01 25 0D 9D
01 0C 00 13 3A 05 70 04 1D 01 01 25 28 BB
01 0C 00 13 3B 05 70 04 1D 01 01 25 29 BB
I have synced two multilevel switches instead of one Motor.
Sun Apr 12, 2020 1:45 am
Re: How to set up Roller without Indigo UI
I’ll look later, but based on that log, just send Raw from 70 04 and leave off the last byte, not the whole line.
Sun Apr 12, 2020 2:11 am
davinci offline
Thanks for helping
I sent 70 04 1D 01 01 25 but no success. The second last byte changes from device to device, so I am not sure what to do with it.
Sun Apr 12, 2020 3:59 am
davinci offline
Ok, I found the solution. I only had to set parameter 150 to "2". :D
Sun Apr 12, 2020 8:19 pm
sarahcat offline
OK, I'll show my ignorance. What is a 'roller', in the context of this post?
Sun Apr 12, 2020 8:22 pm
Roller shade.
Sun Apr 12, 2020 9:06 pm
sarahcat offline
Thanks, Joe. I found the link about 30 seconds ago. :oops:
