Notifications on Inovelli wall switch LZW31-sn
Sat Apr 17, 2021 12:09 pm
7rdr7 offline
Re: Notifications on Inovelli wall switch LZW31-sn
Thanks Matt!
Fri Jun 18, 2021 2:49 pm
Indigo 2021.1.0 is now available and should include a scene trigger for the config button being double-tapped.
Wed Nov 24, 2021 10:13 pm
Jeff Boyd offline
I recently installed an Inovelli LZW31-SN (Red Series Dimmer). It shipped in September 2021, arriving with Firmware Version 1.57. This firmware version does NOT support any scene notifications from the config button other than a single tap. I've discussed this with Matt and subsequently with Inovelli tech support. Inovelli advised that some earlier versions of the firmware did indeed support additional notifications from the config button, however that capability has been removed.
If you are currently relying on double-tap triggered scenes from the config button, you may wish to keep your LZW31-SN at whatever firmware version you have that does support that capability.
Regards
Jeff
