ZOOZ RGBW Dimmer Zen31... working-ish
Fri Jan 24, 2020 7:04 pm
whmoorejr offline
Not sure if my "Submit to Indigo" button / form did anything, so I'll post here too....
Got a RGBW Dimmer Zen31 by ZOOZ.
($33 on Amazon)https://www.amazon.com/Z-Wave-Dimmer-Strips-Lighting-Required/dp/B081VYNF27
I can make it work... but it's goofy.
It installs as 9 different devices.
1) Multilevel Switch 1 (On/Off Brightness)
2) Multilevel Switch 2 (Red)
3) Multilevel Switch 3 (Blue)
4) Multilevel Switch 4 (Green)
5) Multilevel Switch 5 (White)
Those 5 show up as dimable lightbulbs. By adjusting the brightness, you are adjusting the level of Red, Green or Blue to make whatever color you want.
The device has 4 inputs for 4 separate physical switches. Switch is activated by grounding out the terminal.
Those are represented by 4 Multilevel SensorsWhen turning on (grounding) then off each switch, nothing happens to the device state (that I can see), but I get this in the event log:
Z-Wave received "018 - Mulitlevel Switch" scene 513 (0201)
Z-Wave received "018 - Mulitlevel Switch" scene 257 (0101)
Z-Wave received "018 - Mulitlevel Switch" scene 514 (0202)
Z-Wave received "018 - Mulitlevel Switch" scene 258 (0102)
Z-Wave received "018 - Mulitlevel Switch" scene 515 (0203)
Z-Wave received "018 - Mulitlevel Switch" scene 259 (0103)
Z-Wave received "018 - Mulitlevel Switch" scene 516 (0204)
Z-Wave received "018 - Mulitlevel Switch" scene 260 (0104)
So I guess I could write triggers based on those received Z-Wave commands.
From the device log:
Indigo Z-Wave Version: 7.4.0
Node ID: 18
Model: Mulitlevel Switch
Model ID: 09022000
Manufacturer: Zooz
Manufacturer ID: 027A
Protocol Version: 6.04
Application Version: 5.00
Model Definition Version: 0
Library Type: 3
Class Name: Mulitlevel Switch
Class Hierarchy: 04 : 11 : 02
Command Class Base: 26
Command Versions: 20v1 85v1 86v1 8Ev1 55v1 56v1 98v1 59v1 5Av1 5Bv1 33v3 5Ev1 9Fv1 60v4 22v1 26v4 31v11 6Cv1 32v3 70v1 71v1 72v1 73v1 75v1 7Av1
Multi-Endpoint Types: 1:(11 : 02), 2:(11 : 01), 3:(11 : 01), 4:(11 : 01), 5:(11 : 01), 6:(21 : 01), 7:(21 : 01), 8:(21 : 01), 9:(21 : 01)
Multi-Endpoint Classes: 1:[5E 26 85 8E 59 98 9F 32 33 75 6C 22 71], 2:[5E 26 85 8E 59 98 9F 6C 22], 3:[5E 26 85 8E 59 98 9F 6C 22], 4:[5E 26 85 8E 59 98 9F 6C 22], 5:[5E 26 85 8E 59 98 9F 6C 22], 6:[5E 85 8E 59 98 9F 31 6C 22], 7:[5E 85 8E 59 98 9F 31 6C 22], 8:[5E 85 8E 59 98 9F 31 6C 22], 9:[5E 85 8E 59 98 9F 31 6C 22]
Features: routing, beaming, security, energyMeter
Neighbors: 4, 8, 13
Associations: 1:[1] 2:[] 3:[] 4:[] 5:[] 6:[] 7:[] 8:[] 9:[] 10:[]
Config Values: - none -
On top of the above, it's a little finicky. Like when you change one of the color values (Device 2, 3 or 4), you have to then turn the first device off then on for it to take.... sometimes.
Bill
My Plugin: My People
Sat Jan 25, 2020 1:02 pm
Re: ZOOZ RGBW Dimmer Zen31... working-ish
The next release of Indigo (7.4.1; not available yet but soonish) will have better support for this one.
Sat Jan 25, 2020 10:45 pm
whmoorejr offline
Thank you Matt. Y'all are the best.
Bill
Sat Feb 01, 2020 7:11 am
Espressomatic offline
*thumbsup* I have one of these arriving soon, so that's great news. More surely to follow if it works well. Though I also have my eye on the Shelly controllers. ;)
Sun Apr 19, 2020 8:22 pm
whmoorejr offline
I tinkered with this device again today.... tried to delete it then re-add it. But it still operates the way it was before. Did support for the device change in the last Indigo update? Did I re-add it incorrectly? Just checking.
Respectfully,
Bill
Bill
Sun Apr 19, 2020 8:41 pm
Copy/paste the Event Log results of the re-sync into a reply for me. And how is it behaving now? Any differently?
Sun Apr 19, 2020 8:53 pm
whmoorejr offline
  Z-Wave                          Syncing - started for "018 - Mulitlevel Switch"
   Z-Wave                          Syncing - retrieved module neighbors list: 4, 14, 19, 24
   Z-Wave                          Syncing - assigning return route to "018 - Mulitlevel Switch"
   Z-Wave                          Syncing - retrieved manufacture and model names: Zooz - 027A, Mulitlevel Switch - 09022000
   Z-Wave                          Syncing - retrieved protocol version 6.04, app version 5.00
   Z-Wave                          Syncing - retrieved class hierarchy: Routing Slave : Mulitlevel Switch : -- (04 : 11 : 02, base 26)
   Z-Wave                          Syncing - retrieved command classes: 85v1 86v1 8Ev1 98v1 9Fv1 20v1 22v1 26v4 31v11 32v3 33v3 55v1 56v1 59v1 5Av1 5Bv1 5Ev1 60v4 6Cv1 70v1 71v1 72v1 73v1 75v1 7Av1
   Z-Wave                          Syncing - retrieved encrypt commands: - none -
   Z-Wave                          Syncing - retrieved capabilities: routing, beaming, security
   Z-Wave                          Syncing - retrieved multi-endpoint types: 1:(11 : 02), 2:(11 : 01), 3:(11 : 01), 4:(11 : 01), 5:(11 : 01), 6:(21 : 01), 7:(21 : 01), 8:(21 : 01), 9:(21 : 01)
   Z-Wave                          Syncing - retrieved multi-endpoint classes: 1:[5E 26 85 8E 59 98 9F 32 33 75 6C 22 71], 2:[5E 26 85 8E 59 98 9F 6C 22], 3:[5E 26 85 8E 59 98 9F 6C 22], 4:[5E 26 85 8E 59 98 9F 6C 22], 5:[5E 26 85 8E 59 98 9F 6C 22], 6:[5E 85 8E 59 98 9F 31 6C 22], 7:[5E 85 8E 59 98 9F 31 6C 22], 8:[5E 85 8E 59 98 9F 31 6C 22], 9:[5E 85 8E 59 98 9F 31 6C 22]
   Z-Wave                          Syncing - retrieved group 1 associations: [1]
   Z-Wave                          Syncing - retrieved group 2 associations: []
   Z-Wave                          Syncing - retrieved group 3 associations: []
   Z-Wave                          Syncing - retrieved group 4 associations: []
   Z-Wave                          Syncing - retrieved group 5 associations: []
   Z-Wave                          Syncing - retrieved group 6 associations: []
   Z-Wave                          Syncing - retrieved group 7 associations: []
   Z-Wave                          Syncing - retrieved group 8 associations: []
   Z-Wave                          Syncing - retrieved group 9 associations: []
   Z-Wave                          Syncing - retrieved group 10 associations: []
   Z-Wave                          Syncing - group 1 association to interface already exists (skipping)
   Z-Wave                          sent "018 - Mulitlevel Switch" status request
   Z-Wave                          sent "018 - Mulitlevel Switch" energy status request
   Z-Wave                          sent "018 - Mulitlevel Switch 2" status request
   Z-Wave                          sent "018 - Mulitlevel Switch 3" status request
   Z-Wave                          received "018 - Mulitlevel Switch 3" status update brightness 100
   Z-Wave                          sent "018 - Mulitlevel Switch 4" status request
   Z-Wave                          sent "018 - Mulitlevel Switch 5" status request
   Z-Wave                          received "018 - Mulitlevel Switch 5" status update brightness 100
   Z-Wave                          sent "018 - Multilevel Sensor" status request
   Z-Wave                          received "018 - Multilevel Sensor" sensor update to 0.0 V
   Z-Wave                          sent "018 - Multilevel Sensor 2" status request
   Z-Wave                          received "018 - Multilevel Sensor 2" sensor update to 0.0 V
   Z-Wave                          sent "018 - Multilevel Sensor 3" status request
   Z-Wave                          received "018 - Multilevel Sensor 3" sensor update to 0.0 V
   Z-Wave                          sent "018 - Multilevel Sensor 4" status request
   Z-Wave                          received "018 - Multilevel Sensor 4" sensor update to 0.0 V
That's what it looks like if I re-define and sync the device. Operationally, it is about the same as before. 5 switches and 4 sensors. The sensors still don't turn on or off, but they provide a status change in the log file if you ground out a sensor. You can toggle switches 1-5 in various ways to adjust the color. Purple = (Switch 1 @ 100%, Switch 2 @ 100% (red), Switch 3 @ 100% (blue)).
After Indigo update: I think it's responding quicker after the update. Before, I think I had to adjust the colors, then switch the first switch off then back on for it to physically adjust. Now it adjusts as I toggle switches or adjust percentages of a switch.
Bill
Mon Apr 20, 2020 6:29 pm
Sorry, it looks like this one fell through the cracks and didn't make it into 7.4.1. I'll make sure it gets into 7.4.2.
Mon Apr 20, 2020 10:57 pm
whmoorejr offline
Thank you Matt.
Looking forward to 7.4.2
Bill
Wed Dec 23, 2020 3:09 pm
Indigo 7.5 is now available and includes support for the Zooz RGBW Dimmer (ZEN31).
Wed Dec 23, 2020 6:10 pm
whmoorejr offline
Thank you Matt! Works great and now I'm going to make my house crazy colorful. If I can figure out how to tie in the Airfoil plugin, I can open up Bill's Discoteca.
After updating to Indigo 7.5, it still installs as 9 different devices, but there is some coolness with that.
    1 ) Main device controls everything (on, off, color, etc.)
    2 ) White - Currently set at 0, hidden from remote display and put in a separate folder. (May change if I use a RGBW strand vs. an RGB strand... but it's what I have on hand at the moment.
    3 ) Red - Set at 100, hidden from remote, put in a separate folder.
    4 ) Green - Set at 100, hidden, separate folder.
    5 ) Blue - Set at 100, hidden, separate folder.
    6 ) Analog Input 1 (Button 1)*
    7 ) Analog Input 2 (Button 2)*
    8 ) Analog Input 3 (Button 3)*
    9 ) Analog Input 4 (Button 4)*
* Note on the Analog inputs.... pretty cool stuff. Each input has multiple responses? or scene options?, button settings?... not sure what word to use.
    Pressed
    Held-Release
    Double-Tap
3 button options x 4 buttons = 12 scene options.
With all these options my head is exploding. Do I just use the RGBW part to make my house pretty :D , or do I take advantage of all the wire-inputs to make some kind of 1980's mushroom button control panel thing that makes it look like I have nuclear launch abilities from my desk. :twisted:
Bill
Tue Jan 31, 2023 7:49 am
I'm getting ready to roll a couple of these out and I wanted to confirm what I'm seeing.
I'm using this device (x2) in order to control a single color white strips using just the W terminal. I'm finding that, In order to control turn the strip on, I need to have both the "composite" and "white" devices turned on for there to be light. I can then control the strip simply with the composite device.
Is it safe to leave the white device turned on 24/7 and just ignore it? It doesn't report any energy usage in this state.
Tue Jan 31, 2023 8:18 am
whmoorejr offline
Based on the date of my last post.... I've been running my lights this way for 2 years now without issue. Mine is just the opposite, I turn all the colors on, the white off and just use the composite to control the strip. Leaving all the others Red, Green and Blue set at 100% for the last 2 years, no problems. My 2nd set (which I put in about a month after my last post), I leave B and W at 100% all the time to give the RGBW strip a bluish white glow and just use the composite for on/off. Same thing with that one, no issues leaving the B and W at 100%.
Hope that helps.
Bill
Tue Jan 31, 2023 8:27 am
Thanks for confirming!
Wed Feb 01, 2023 9:49 am
One thing I've noticed about the Zooz units is that -- after a round of disconnecting/reconnecting the LED strips and restoring power -- I find I have to re-sync them in Indigo to get them to work. I'm curious to see how they recover after a power outage which, sadly, we are all too familiar with around these parts.
