I'm adding devices to my slowly-growing z-wave setup and I have some random questions about association/sync and optimization.
Recently, I bought a couple of Zooz multi-sensors. Sitting in my kitchen, I used network-association and added or sync'd them quickly/painlessly to Indigo. Then I carried one of the devices - let's call it D - over to the bathroom (farther away from my central controller) and deployed it. At that point, I found that if I tried to perform the z-wave "optimize" function, either just D itself or for my entire network (which takes a long time), that the optimization reported that it "failed" and that at the end of the process, D had no neighbors.
Indigo was still receiving messages from the device. I created some triggers for the device to turn on some lights and the triggers worked, but I noticed that they had a pretty long delay before Indigo would respond (perhaps 5s or more). I also noticed that Indigo seemed to log 2-3 copies of each message from D (such as a temperature update) within a short time of each other.
From within Indigo, I could do things like change device parameters and such. Indigo would first Indicate that the device was asleep, then later the device would send a wake-up message (or whatever) and the changes would get pushed out successfully. So there was definitely some working two-way communication between Indigo and D.
My questions:
What does it mean when optimization fails for D?
What actions do I need to take when D fails optimization?
- Do I need to move or add some nodes on my network to try to create some viable mid-points on the path from my server to D?
- Or does it simply mean that I need to re-do some part of the association or sync process with D located in its working location?
Is it "normal" for a device such as D to fail z-wave optimization, but then to still seemingly be able to communicate pretty well with Indigo?
How/why should it be that packets find their way across my network in both directions, but somehow the z-wave optimization keeps failing?
Does this indicate possibly that I have some "misbehaving" z-wave nodes on my network?
Should I be able to repeat define/sync for devices that are already included in Indigo?
I have Z-Wave Node Matrix plugin, which I think is supposed to tell me something about my network. Reading some of the documentation on that plugin, I came to realize that in addition to network optimization, that re-doing define-and-sync from Indigo is sometimes supposed to also be useful for working out certain Z-wave problems. I discovered that I have a few other problems and issues in that area..
I have an Aeotec ZW056 doorbell - the device is working, but as part of the z-wave network experimentation I tried repeating define-and-sync. It starts for this device, but always ends with an error saying "Module might be asleep, or is unreachable." I even moved it and plugged it in right next to my Z-Stick and I always get the same error. What does this mean? I checked and I think this device is supposed to be Indigo-supported. Do I need to force a reset somehow? Or is this another case, where I need to hit the "wake" button multiple times during the process to wake the device and keep it awake (this is a ac-powered device, by the way).
I also tried to do a define-and-sync operation with D, but couldn't get it to succeed in the planned location. Later, just to make sure I understood what was happening, I took D back closer to my server and tried again, and was able to get define-and-sync to work, but the process was made more difficult by my not having a clear understanding of the steps. The device instructions state that there is first an inclusion(pairing) step that involves clicking an internal button once. I think that step is working fine. Then after that, there is a step referred to in the device instructions as "finalize inclusion" for which it says you should hit the internal button on the sensor twice. I'm not clear whether clicking twice is something that wakes the device up so Indigo can talk to it vs. if clicking twice is supposed to tell the device to stop listening (and go back to "sleep") at the end of process. Anyway, I had a lot of trouble getting this to work. I could see that Indigo and the device were communicating, but I could not discern the correct sequence of pushing buttons on the device once/twice to get through the define-and-sync process. I eventually got it to work, but I think it was by hitting the button, then waiting a few seconds and hitting it again - perhaps the effect was to first wake the device and then the second click either re-wakened it during a second step of the process or possibly just acted as a "stay away" command. Anyway, though I did get it to work, it is definitely not easily repeatable. Anyone else know how this is SUPPOSED to work?
Also, in a direct line between where I'm trying to get multisensor D to work and my server, I have a recent-model HomeSeer brand wall switch, which I assumed should work as a repeater. The switch is working fine and seems to communicate fine with Indigo, however I'm a bit curious about why this switch doesn't seem to appear on the neighbor lists of D and/or why the existence of this switch does fix/prevent problems like the one I'm having trying to get D to work in the desired location. Is this a sign of something not functioning properly?
So that's a whole bag of messy topics/questions. I'm looking for any help/advice/experience I can tap to understand the z-wave inclusion/sync process better. Thanks in advance.
