RGBGenie Anyone been able to use this RGBW controller?
Sat Jan 04, 2020 12:04 pm
Butch2427 offline
I purchased this RGBW Led z-wave controller with hope to use it with Indigo 7.4. It was easy to include in my network but is seen by Indigo 7.4 as a dimmable power switch, not an RGBW controller. Has anyone been able to use one of these?
Amazon link:
https://www.amazon.com/gp/product/B07GG ... UTF8&psc=1
Sat Jan 04, 2020 1:16 pm
Re: RGBGenie Anyone been able to use this RGBW controller?
Re-sync it in Indigo then copy/paste the Event Log results into a forum reply. We'll look into adding a definition for it.
Sat Jan 04, 2020 1:30 pm
Butch2427 offline
Thanks Matt, here is the log:
Jan 4, 2020, 11:26:55 AM
Z-Wave Syncing - started for "GAME-RM-Strip light"
Z-Wave Syncing - retrieved module neighbors list: 7, 9, 11
Z-Wave Syncing - assigning return route to "012 - GAME-RM-Strip light"
Z-Wave Syncing - retrieved manufacture and model names: Unknown - 0330, Dimmable Power Switch - 0201D002
Z-Wave Syncing - retrieved protocol version 4.61, app version 1.05
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Mulitlevel Switch : Dimmable Power Switch (04 : 11 : 01, base 26)
Z-Wave Syncing - retrieved command classes: 20v1 33v3 26v4 86v1 27v1 2Cv1 2Bv1 6Cv1 70v1 71v1 72v1 73v1 55v1 98v1 59v1 5Av1 85v1 7Av1 5Ev1 9Fv1
Z-Wave Syncing - retrieved encrypt commands: - none -
Z-Wave Syncing - retrieved capabilities: routing, beaming, security
Z-Wave Syncing - retrieved group 1 associations: [1]
Z-Wave Syncing - group 1 association to interface already exists (skipping)
Z-Wave Syncing - complete
Z-Wave sent "GAME-RM-Strip light" status request
Fri Feb 07, 2020 2:42 pm
Indigo 7.4.1 is now available and includes preliminary support for the RGBgenie RGBW Controller (ZW1002).
Sat Feb 08, 2020 10:45 am
Butch2427 offline
Thanks Matt!
Mon Dec 05, 2022 10:01 pm
eightball offline
Is there anyway to setup these controllers to control the color channels separately? Rather than as a single controller of all three? (i.e. green 1-100; blue 1-100; red 1-100)?
Anthony
Fri Dec 09, 2022 3:08 pm
You can send raw Z-Wave commands to the module to control the color channels individually. Downside is Indigo won't update its UI to reflect the color change (unless the module happens to broadcast out the new state after it is changed; I'm not sure if it does that or not).
The raw Z-Wave command for changing the color levels is:
0x33 0x05 0x01 COLOR_INDEX COLOR_LEVEL
where COLOR_INDEX is 0x02 for RED, 0x03 for GREEN, 0x04 for BLUE, and if supported 0x00 for WARM WHITE and 0x01 for COOL WHITE. There is a UI action for sending raw Z-Wave commands you can use, but if you need to pass in dynamic levels you'll need to send the commands via a python script action. I can give you the basic format for a script if needed.
