Aeotec (Aeon Labs) Smart Switch 7 (ZW175)
Wed Dec 11, 2019 1:12 pm
DirkWe offline
Hey Matt,
hey Jay,
could you please add the device information for this new device ?
What it does...
* Can add it to my zwave network
* Device appears in indigo with on/off capabilities
* Led from the device is dark if switch is turned off
* When switch is turned on in indigo, led becomes green, but there is no power on the connected device ?!?!?!
* Switch off, led becomes dark again.
* Got three of them, all the same behaviour.... :cry:
Thx
Dirk from Germany
 Syncing - started for "Steckdose Aeo (125)"
   Z-Wave                          Syncing - retrieved module neighbors list:  (...)
   Z-Wave                          Syncing - assigning return route to "125 - Steckdose Aeo (125)"
   Z-Wave                          Syncing - retrieved manufacture and model names: Aeon Labs - 0371, Relay Power Switch - 000300AF
   Z-Wave                          Syncing - retrieved protocol version 6.04, app version 1.02
   Z-Wave                          Syncing - retrieved class hierarchy: Routing Slave : Relay Switch : Relay Power Switch (04 : 10 : 01, base 25)
   Z-Wave                          Syncing - retrieved command classes: 81v1 85v1 86v1 98v1 9Fv1 20v1 22v1 25v1 26v2 27v1 2Bv1 2Cv1 32v4 33v1 55v1 59v1 5Av1 5Ev1 6Cv1 70v1 71v1 72v1 73v1 75v1 7Av1
   Z-Wave                          Syncing - retrieved encrypt commands: - none -
   Z-Wave                          Syncing - retrieved capabilities: routing, beaming, security
   Z-Wave                          Syncing - retrieved group 1 associations: [1]
   Z-Wave                          Syncing - retrieved group 2 associations: []
   Z-Wave                          Syncing - group 1 association to interface already exists (skipping)
   Z-Wave                          Syncing - synced server clock to module (20:02, Wednesday)
model : Relay Power Switch
name : Steckdose Aeo (125)
onState : False
ownerProps : com.perceptiveautomation.indigoplugin.zwave : (dict)
     SupportsEnergyMeter : true (bool)
     SupportsEnergyMeterCurPower : true (bool)
     SupportsEnergyMeterReset : true (bool)
     SupportsGasMeterReset : true (bool)
     SupportsWaterMeterReset : true (bool)
     address : 125 (integer)
     indigoObjVersion : 8 (integer)
     modelNameAndFirmware : Relay Power Switch, firmware 1.02 (string)
     propsPushTickler : 1 (string)
     tempAlwaysFalse : false (bool)
     userPollAfterActivity : true (bool)
     userPollInterval : 0 (integer)
     userPollingEnabled : true (bool)
     userWakeInterval : 60 (integer)
     version : 1.02 (string)
     zwAppVersMajor : 1 (integer)
     zwAppVersMinor : 2 (integer)
     zwAssociationsMap : (dict)
          g1 : (list)
               Item : 1 (integer)
          g2 : (list)
     zwAssociationsMapStr : 1:[1] 2:[] (string)
     zwClassCmdBase : 37 (integer)
     zwClassCmdMap : (dict)
          c108 : 1 (integer)
          c112 : 1 (integer)
          c113 : 1 (integer)
          c114 : 1 (integer)
          c115 : 1 (integer)
          c117 : 1 (integer)
          c122 : 1 (integer)
          c129 : 1 (integer)
          c133 : 1 (integer)
          c134 : 1 (integer)
          c152 : 1 (integer)
          c159 : 1 (integer)
          c32 : 1 (integer)
          c34 : 1 (integer)
          c37 : 1 (integer)
          c38 : 2 (integer)
          c39 : 1 (integer)
          c43 : 1 (integer)
          c44 : 1 (integer)
          c50 : 4 (integer)
          c51 : 1 (integer)
          c85 : 1 (integer)
          c89 : 1 (integer)
          c90 : 1 (integer)
          c94 : 1 (integer)
     zwClassCmdMapStr : 81v1 85v1 86v1 98v1 9Fv1 20v1 22v1 25v1 26v2 27v1 2Bv1 2Cv1 32v4 33v1 55v1 59v1 5Av1 5Ev1 6Cv1 70v1 71v1 72v1 73v1 75v1 7Av1 (string)
     zwClassIds : (list)
          Item : 4 (integer)
          Item : 16 (integer)
          Item : 1 (integer)
     zwClassInstanceCountMap : (dict)
     zwClassInstanceCountMapStr : - none - (string)
     zwClassName : Relay Power Switch (string)
     zwConfigVals : (dict)
     zwConfigValsStr : - none - (string)
     zwDevSubIndex : 0 (integer)
     zwEncryptClassCmdMap : (dict)
     zwEncryptClassCmdMapStr : - none - (string)
     zwEncryptionStatusStr : Supported but not Enabled (string)
     zwEndpointClassMap : (dict)
     zwEndpointClassMapStr : - none - (string)
     zwEndpointDevTypeMap : (dict)
     zwEndpointDevTypeMapStr : - none - (string)
     zwFeatureListStr : routing, beaming, security, energyMeter (string)
     zwLibType : 3 (integer)
     zwManufactureId : 881 (integer)
     zwManufactureName : Aeon Labs (string)
     zwMeterSubTypeFlags : 53 (integer)
     zwMeterSupportsReset : true (bool)
     zwMeterType : 1 (integer)
     zwModelDefnVers : 0 (integer)
     zwModelId : 196783 (integer)
     zwModelName : Relay Power Switch (string)
     zwNodeNeighbors : (list)
          Item : 1 (integer)
          Item : 6 (integer)
          Item : 7 (integer)
          Item : 8 (integer)
          Item : 9 (integer)
          Item : 10 (integer)
          Item : 12 (integer)
          Item : 14 (integer)
          Item : 17 (integer)
          Item : 18 (integer)
          Item : 19 (integer)
          Item : 20 (integer)
          Item : 25 (integer)
          Item : 33 (integer)
          Item : 36 (integer)
          Item : 49 (integer)
          Item : 50 (integer)
          Item : 54 (integer)
          Item : 55 (integer)
          Item : 59 (integer)
          Item : 60 (integer)
          Item : 62 (integer)
          Item : 63 (integer)
          Item : 69 (integer)
          Item : 70 (integer)
          Item : 91 (integer)
          Item : 92 (integer)
          Item : 93 (integer)
          Item : 94 (integer)
          Item : 95 (integer)
          Item : 108 (integer)
          Item : 109 (integer)
          Item : 112 (integer)
          Item : 113 (integer)
          Item : 115 (integer)
          Item : 118 (integer)
     zwNodeNeighborsStr : 1, 6, 7, 8, 9, 10, 12, 14, 17, 18, 19, 20, 25, 33, 36, 49, 50, 54, 55, 59, 60, 62, 63, 69, 70, 91, 92, 93, 94, 95, 108, 109, 112, 113, 115, 118 (string)
     zwProtoVersMajor : 6 (integer)
     zwProtoVersMinor : 4 (integer)
     zwShowDumpDevToLog : false (bool)
     zwShowMainUI : true (bool)
     zwShowManualModifyConfigParmUI : true (bool)
     zwShowPollingUI : true (bool)
     zwShowSubmitModelInfoUI : true (bool)
     zwShowWakeIntervalUI : false (bool)
     zwWakeInterval : 0 (integer)
pluginId : com.perceptiveautomation.indigoplugin.zwave
protocol : ZWave
remoteDisplay : True
states : States : (dict)
     accumEnergyTimeDelta : 0 (integer)
     accumEnergyTimeDelta.ui : 0 seconds (string)
     accumEnergyTotal : 0 (real)
     accumEnergyTotal.ui : 0.0 kWh (string)
     curEnergyLevel : 0 (integer)
subModel :
supportsAllOff : False
supportsStatusRequest : True
version : 1.02
Wed Dec 11, 2019 1:49 pm
Re: Aeotec (Aeon Labs) Smart Switch 7 (ZW175)
Can you manually operate the switch (I don't know if it has an on/off button on the physical device) and if so does that cause the connected device to turn on/off?
Thu Dec 12, 2019 10:23 am
DirkWe offline
Hi Jay,
yes, i can operate the switch manualy. The LED on the top is also a manual switch which turns on the connected device.
Do you need any futher info´s?
Dirk
Thu Dec 12, 2019 6:03 pm
Hi Dirk,
Can you turn on Indigo's Z-Wave debug logging checkbox (via the Interfaces->Z-Wave->Configure... menu item), then use Indigo's UI to turn it ON and OFF a couple of times? Copy/paste the Event Log results into a reply for me.
Also, does Indigo show it in its UI the ZW175 as a switch (relay; ON and OFF only) or a dimmer (with brightness)?
Lastly, try the Interfaces->Z-Wave->Send Raw Z-Wave Command... menu item to send the following commands individually (first is ON, second is OFF):
0x25 0x01 0xFF
0x25 0x01 0x00
Does that work?
Sat Dec 14, 2019 4:07 am
DirkWe offline
Hi Jay,
thanks for your reply.
Easy things first:
Indigo shows the powerwall as an on off switch. The device details are update correct, espacialy the on state. If i switch it manualy on or if use the buttons in indigo: i can switch it on and off. But there is only power if i do this manualy using the ledswitch on the device.
Second: RAW commands
If i toggle on/off using buttons in indigo the led on the device will switch its state from on to off and reverse. But no power.
If i use your RAW commands, the led will shut down, but i can toggle the real power on and off. YEAH! :D
For me it seems like two devices or switches. One for the led an a different for power.
And here the debugging log:
   Z-Wave                          sent "Steckdose Aeo (124)" on
   Z-Wave Debug                    queueing energy request of "124 - Steckdose Aeo (124)" (activity detected)
   Z-Wave Debug                    RCVD requestDimmerStatus: 01 09 00 04 00 7C 03 26 03 0A A2
   Z-Wave Debug                    . .  requestDimmerStatus: node 124, endpoint None, value 10
   Z-Wave Debug                    SENT setMultiLevelValue: 01 0A 00 13 7C 03 26 01 00 25 1A 81
   Z-Wave                          sent "Steckdose Aeo (124)" off
   Z-Wave Debug                    ignoring duplicate energy request of "124 - Steckdose Aeo (124)" (activity detected)
   Z-Wave Debug                    SENT setMultiLevelValue: 01 0A 00 13 7C 03 26 01 00 25 1B 80
   Z-Wave Debug                    RCVD requestDimmerStatus: 01 09 00 04 00 7C 03 26 03 00 A8
   Z-Wave Debug                    . .  requestDimmerStatus: node 124, endpoint None, value 0
   Z-Wave Debug                    SENT setMultiLevelValue: 01 0A 00 13 7C 03 26 01 FF 25 1C 78
   Z-Wave Debug                    SENT setMultiLevelValue: 01 0A 00 13 7C 03 26 01 00 25 1D 86
   Z-Wave Debug                    RCVD multiEndPointPacket: 01 12 00 04 00 69 0C 60 0D 05 05 31 05 01 44 00 00 11 C6 47
   Z-Wave Debug                    . .  multiEndPointPacket: node 105, endPoint 5
   Z-Wave Debug                    RCVD requestVarSensorStatus: 01 0E 00 04 00 69 08 31 05 01 44 00 00 11 C6 FF
   Z-Wave Debug                    . .  requestVarSensorStatus: node 105, endpoint 5, type 1, raw value 4400...
   Z-Wave Debug                    . .  requestVarSensorStatus: 45.50 °C (float: 45.500000)
   Z-Wave Debug                    received "Heizungstemperatur - Heizkoerper (105)" sensor update to 45.50 °C
   Z-Wave Debug                    SENT setMultiLevelValue: 01 0A 00 13 7C 03 26 01 FF 25 1E 7A
   Z-Wave Debug                    SENT setRelayValue: 01 0E 00 13 45 07 60 0D 01 02 25 01 00 25 1F D0
Anything more i can do?
Dirk
Sat Dec 21, 2019 4:14 am
DirkWe offline
Hey Matt, hey Jay,
any ideas ?
Dirk
Sat Dec 21, 2019 2:32 pm
Hi Dirk,
We are looking at adding a device definition for it that will show 2 devices (LED and load).
In the mean time you can send the raw commands to control the load. You can also create a pair of Action Groups (one for each raw command) then define a Virtual Device in Indigo that executes the action groups when the virtual device is Turned On/Off (in the UI, Indigo Touch, by other actions, etc.).
Mon Dec 23, 2019 5:57 am
DirkWe offline
Ok.
I took me a while to find out, how to send these RAW commands correctly. Here is how it works...
cmdString = [0x25, 0x01, 0xFF]
indigo.zwave.sendRaw(device=indigo.devices[193818484], cmdBytes=cmdString, sendMode=1, waitUntilAck=False)
Thx again, i´m waiting for the next update. If i can do some testing for you...
Frohes Weihnachtsfest !
Gruß
Dirk
Mon Dec 23, 2019 10:55 am
There is an action with UI (on the actions panel) to send raw commands as well using the Type Z-Wave Actions->Send Raw Z-Wave Command.
Fri Feb 07, 2020 2:49 pm
Indigo 7.4.1 is now available and includes support for the Aeotec Radiator Thermostat (ZWA021), Range Extender 7 / Repeater (ZW189), Recessed Door Sensor 7 (ZW187), Smart Switch (ZW175).
Sat Oct 29, 2022 11:08 am
McJohn offline
The manual of the Aeotec Smart Switch 7 says about the LED:
(https://aeotec.freshdesk.com/support/so ... ser-guide-)
Parameter 81 - LED indicator mode:
0. LED Disabled.
1. Night Light Mode.
2. On/Off Mode.
ON = 50% white light
OFF = 10% green light
So, there is no Off mode without LED/light?
And further on the manual says about the LED:
Brightness can be controlled via Multilevel Switch CC.
Colour can be controlled via Color Switch CC.
Does anyone know what "Multilevel Switch CC" and "Color Switch CC" means here?
Sat Oct 29, 2022 11:52 am
I don't know the exact behavior. You'll have to just experiment with it.
Yes, when syncing that device Indigo should create 2 devices: one that controls the main load, and another "Nightlight" dimmable device for the LED indicator. You can try the dimming slider in the Main Window when that is selected to see if you can adjust the brightness. There should also be a color swatch you can select to change the color. Indigo uses the Color Switch CC commands for sending those color values to the module.
Sat Oct 29, 2022 12:53 pm
McJohn offline
Wow, thank you so much for the fast reply Matt. Super!
There is no dimmer slider for the Main switch. But..
With the settings of the LED mode to "Mirrors Load", the other "Nightlight" dimmable device has indeed the possibility to change the brightness and the color of the LED.
Once this is done, these settings also effect at the main device and now the LED goes off and becomes red (or green, or yellow) when it's on. Very nice feature.
Thanks again for the fast support!
