Zooz ZSE29 Outdoor Motion Sensor
Tue Nov 26, 2019 1:06 pm
Gman34798 offline
I have had this sensor for a couple days and am wrestling with getting rid of false triggers.
I have Parameter 1 set to 120 seconds.
Parameter 2 is set to 50.
It's nearly constantly "on". When it does go "off", it has been so far, only a few seconds before it triggers "on" again.
it's facing south, over my driveway and the sun is pretty bright.
The 2 parameters mentioned are shown in the attached shot of the paper instructions that came with the sensor. I could find no on-line downloadable manual that
has the advanced settings section.
Anyone that has any experience or opinions on this thing, I would greatly appreciate your input.
Screen Shot 2019-11-26 at 2.01.29 PM.png (240.99 KiB) Viewed 1054 times
Tue Nov 26, 2019 3:26 pm
Re: Zooz ZSE29 Outdoor Motion Sensor
Based on that screen shot it doesn't look like the motion sensor has any sensitivity setting. The lux/brightness (parm 2) is related to the luminosity sensor, which I think might be used to define a daylight/night trigger for when motion is sent? Parm 1 is just used to determine the frequencies the motion messages will be sent (not the sensitivity). The manual might have manual tips for modifying the sensitivity, such as how you position/point the sensor.
Wed Nov 27, 2019 7:43 pm
Gman34798 offline
Yes, there is no sensitivity setting that I can tell. I think I isolated the issue of the frequent triggers....it seems to have been triggering on the movement of a flag that was off our porch. I’ll make some adjustments and proceed with the settings as they are and update any new findings.
Wed Nov 27, 2019 9:19 pm
ELWOOD offline
Sounds like it's an infrared detector so if it is pointed south the sun is a great source for infrared. Try putting the detector on the other side of the driveway so it pointed north. It will work best if it is pointed at a stable back round, like your house.
Elwood
