Fibaro RGBW module 2 FGRGBW-442
Tue Nov 05, 2019 5:19 pm
siclark offline
Has anyone got one and tried to use it? I'm guessing I need to wait until the next release for full support. If I do need to wait does anyone know how indigo would treat this?
Wed Nov 06, 2019 11:11 am
siclark offline
Re: Fibaro RGBW module 2 FGRGBW-442
Alternatively, does anyone know the benefit of the new version? It's just to control a CCT strip so guessing the old version would work just as well and is cheaper.
Sat Nov 09, 2019 2:33 pm
While Indigo has a device definition for the older FGRGBWM, we don't yet have one for this newer version. It might work out-of-the-box with Indigo as an RGB controllable device, but we won't know until someone gets one and tries it. If you do then copy/paste the Event Log window results of the sync operation so we can see the details about how it reports its capabilities to Indigo.
Sat Nov 09, 2019 3:19 pm
siclark offline
Cheers Matt. Think I might go with the old one that I know works.
Tue Nov 12, 2019 3:15 am
siclark offline
Actually I decided to give a bit back to this fantastic community and to get the new version and get you the information you need to get it included sooner.
It should be arriving today.
Wed Nov 13, 2019 2:13 pm
siclark offline
It finally arrived today after Amazon couldnt be bothered to deliver it yesterday. Next day delivery *except if the delivery driver wants to go home early.
Its a great looking device, and a bit easier to use than their other first gen modules in wiring up.
It has setup as a generic multilevel switch, so has a master level switch device, then 4 more, one for each of R.G,B and W. Device details below. I am guessing there is no easy way to map a dummy RGB device to this as otherwise its going to be a pain to use. I might have to default the colour (I am actually just using this to control a CCT strip) and then setup the master in HKB.
ndigo Z-Wave Version: 7.4.0
Node ID: 106
Model: Mulitlevel Switch
Model ID: 09021000
Manufacturer: Fibaro System
Manufacturer ID: 010F
Protocol Version: 6.04
Application Version: 5.00
Model Definition Version: 0
Library Type: 3
Class Name: Mulitlevel Switch
Class Hierarchy: 04 : 11 : 02
Command Class Base: 26
Command Versions: 20v1 85v1 86v1 8Ev1 55v1 56v1 98v1 59v1 5Av1 5Bv1 33v3 5Ev1 9Fv1 60v4 22v1 26v4 31v11 6Cv1 32v3 70v1 71v1 72v1 73v1 75v1 7Av1
Multi-Endpoint Types: 1:(11 : 02), 2:(11 : 01), 3:(11 : 01), 4:(11 : 01), 5:(11 : 01), 6:(21 : 01), 7:(21 : 01), 8:(21 : 01), 9:(21 : 01)
Multi-Endpoint Classes: 1:[5E 26 85 8E 59 98 9F 32 33 75 6C 22 71], 2:[5E 26 85 8E 59 98 9F 6C 22], 3:[5E 26 85 8E 59 98 9F 6C 22], 4:[5E 26 85 8E 59 98 9F 6C 22], 5:[5E 26 85 8E 59 98 9F 6C 22], 6:[5E 85 8E 59 98 9F 31 6C 22], 7:[5E 85 8E 59 98 9F 31 6C 22], 8:[5E 85 8E 59 98 9F 31 6C 22], 9:[5E 85 8E 59 98 9F 31 6C 22]
Features: routing, beaming, security, energyMeter
Neighbors: 13, 28, 66, 90, 94, 95, 98, 102
Associations: 1:[1] 2:[] 3:[] 4:[] 5:[] 6:[] 7:[] 8:[] 9:[] 10:[]
Config Values: - none -
Wed Nov 13, 2019 8:23 pm
That helps. We'll look at adding preliminary support for this to the next version (7.4.1). It will make that first device an RGBW Device in Indigo that accepts the action to set the color.
Thu Nov 14, 2019 3:00 am
siclark offline
Thanks. Let me know if any other help or testing is needed.
For now I'm using groups to set the required white colour and brightness.
More generally on these devices, as well as RGB and RGBW, I and am sure others also use these for CCT strips on only 2 channels, to control white temperature.
Seeing the post in SDK dev about device colour attributes, would it be possible to have a config setting that would change them from being RGB and white simultaneously to supports 2 white channels simultaneously (either force it to use R and G say or gives a choice)
It would greatly enhance the fibrocartilage of these devices.
Would they then show up more correctly in indigo and other plugins/homekit?
Otherwise I have to explain to my wife how to use colour picker to get the right white.
Thanks.
Sat Nov 30, 2019 4:32 pm
shapa offline
Received one as well. Will be happy to test.
Fri Feb 07, 2020 2:12 pm
Indigo 7.4.1 is now available and includes support for the Fibaro RGBW Controller (FGRGBW442).
Wed Apr 29, 2020 4:45 am
pocster offline
I'm struggling with this.
Can only get Red to work. No obvious errors in the log. Trying a RGBW strip.
Cheers
Wed Apr 29, 2020 7:51 am
We'll need to see what the Event Log is showing, both when you try to change the color (also give a description of how you are changing the color) and of a re-sync of the device.
Thu Apr 30, 2020 2:23 am
pocster offline
Hi Matt
Here's the define and sync log output
Z-Wave Debug intiatingSyncUI (timeout in 1500 seconds)
Z-Wave Syncing - started for "Bathroom RGBW 1"
Z-Wave Debug SENT getNodeNeighbors: 01 06 00 80 08 01 01 71
Z-Wave Debug RCVD getNodeNeighbors: 01 20 01 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 5E (no inbound callback)
Z-Wave Debug . . getNodeNeighbors: nodeId 008, neighbors: - none -
Z-Wave Syncing - assigning return route to "008 - Bathroom RGBW 1"
Z-Wave Debug SENT assignReturnRoute: 01 05 00 46 08 01 B5
Z-Wave Debug RCVD assignReturnRoute: 01 04 01 46 01 BD (no inbound callback)
Z-Wave Debug RCVD assignReturnRoute: 01 05 00 46 01 00 BD
Z-Wave Debug . . assignReturnRoute: node 008, success 1
Z-Wave Debug SENT requestNodeInfo: 01 06 00 60 08 24 5D E8
Z-Wave Debug RCVD nodeInfoFrame: 01 21 00 49 84 08 1B 04 11 02 5E 26 85 8E 59 55 86 72 5A 73 98 9F 31 70 56 71 60 32 33 7A 75 5B 22 6C AF
Z-Wave Debug . . nodeInfoFrame: node 008, combined class list: 85v1 86v1 8Ev1 98v1 9Fv1 20v1 22v1 26v1 31v1 32v1 33v1 55v1 56v1 59v1 5Av1 5Bv1 5Ev1 60v1 6Cv1 70v1 71v1 72v1 73v1 75v1 7Av1
Z-Wave Debug SENT requestManufactureInfo: 01 09 00 13 08 02 72 04 25 5E E2
Z-Wave Debug RCVD requestManufactureInfo: 01 07 00 13 5E 00 00 02 B7 (node ACK)
Z-Wave Debug RCVD requestManufactureInfo: 01 0E 00 04 00 08 08 72 05 01 0F 09 02 10 00 97
Z-Wave Debug . . requestManufactureInfo: node 008, manufacturerId 010F, productId 09021000
Z-Wave Debug . . requestManufactureInfo: Fibaro System, RGBW Controller (FGRGBW442)
Z-Wave Syncing - retrieved manufacture and model names: Fibaro System - 010F, RGBW Controller (FGRGBW442) - 09021000
Z-Wave Debug SENT requestVersInfoGen: 01 09 00 13 08 02 86 11 25 5F 02
Z-Wave Debug RCVD requestVersInfoGen: 01 07 00 13 5F 00 00 02 B6 (node ACK)
Z-Wave Debug RCVD requestVersInfoGen: 01 13 00 04 00 08 0D 86 12 03 06 04 05 00 02 02 05 00 01 00 79
Z-Wave Debug . . requestVersInfoGen: node 008, protoVers 6.04, appVers 5.00
Z-Wave Syncing - retrieved protocol version 6.04, app version 5.00
Z-Wave Debug SENT requestVersInfoCmdClass: 01 0A 00 13 08 03 86 13 26 25 60 1B
Z-Wave Debug RCVD requestVersInfoCmdClass: 01 07 00 13 60 00 00 02 89 (node ACK)
Z-Wave Debug RCVD requestVersInfoCmdClass: 01 0A 00 04 00 08 04 86 14 26 04 4D
Z-Wave Debug . . requestVersInfoCmdClass: node 008, class command 26 using version 4
Z-Wave Debug . . requestVersInfoCmdClass: node 008, combined class list: 85v1 86v1 8Ev1 98v1 9Fv1 20v1 22v1 26v4 31v1 32v1 33v1 55v1 56v1 59v1 5Av1 5Bv1 5Ev1 60v1 6Cv1 70v1 71v1 72v1 73v1 75v1 7Av1
Z-Wave Debug SENT requestVersInfoCmdClass: 01 0A 00 13 08 03 86 13 31 25 61 0D
Z-Wave Debug RCVD requestVersInfoCmdClass: 01 07 00 13 61 00 00 02 88 (node ACK)
Z-Wave Debug RCVD requestVersInfoCmdClass: 01 0A 00 04 00 08 04 86 14 31 0B 55
Z-Wave Debug . . requestVersInfoCmdClass: node 008, class command 31 using version 11
Z-Wave Debug . . requestVersInfoCmdClass: node 008, combined class list: 85v1 86v1 8Ev1 98v1 9Fv1 20v1 22v1 26v4 31v11 32v1 33v1 55v1 56v1 59v1 5Av1 5Bv1 5Ev1 60v1 6Cv1 70v1 71v1 72v1 73v1 75v1 7Av1
Z-Wave Debug SENT requestVersInfoCmdClass: 01 0A 00 13 08 03 86 13 32 25 62 0D
Z-Wave Debug RCVD requestVersInfoCmdClass: 01 07 00 13 62 00 00 02 8B (node ACK)
Z-Wave Debug RCVD requestVersInfoCmdClass: 01 0A 00 04 00 08 04 86 14 32 03 5E
Z-Wave Debug . . requestVersInfoCmdClass: node 008, class command 32 using version 3
Z-Wave Debug . . requestVersInfoCmdClass: node 008, combined class list: 85v1 86v1 8Ev1 98v1 9Fv1 20v1 22v1 26v4 31v11 32v3 33v1 55v1 56v1 59v1 5Av1 5Bv1 5Ev1 60v1 6Cv1 70v1 71v1 72v1 73v1 75v1 7Av1
Z-Wave Debug SENT requestVersInfoCmdClass: 01 0A 00 13 08 03 86 13 33 25 63 0D
Z-Wave Debug RCVD requestVersInfoCmdClass: 01 07 00 13 63 00 00 03 8B (node ACK)
Z-Wave Debug RCVD requestVersInfoCmdClass: 01 0A 00 04 00 08 04 86 14 33 03 5F
Z-Wave Debug . . requestVersInfoCmdClass: node 008, class command 33 using version 3
Z-Wave Debug . . requestVersInfoCmdClass: node 008, combined class list: 85v1 86v1 8Ev1 98v1 9Fv1 20v1 22v1 26v4 31v11 32v3 33v3 55v1 56v1 59v1 5Av1 5Bv1 5Ev1 60v1 6Cv1 70v1 71v1 72v1 73v1 75v1 7Av1
Z-Wave Debug SENT requestVersInfoCmdClass: 01 0A 00 13 08 03 86 13 60 25 64 59
Z-Wave Debug RCVD requestVersInfoCmdClass: 01 07 00 13 64 00 00 02 8D (node ACK)
Z-Wave Debug RCVD requestVersInfoCmdClass: 01 0A 00 04 00 08 04 86 14 60 04 0B
Z-Wave Debug . . requestVersInfoCmdClass: node 008, class command 60 using version 4
Z-Wave Debug . . requestVersInfoCmdClass: node 008, combined class list: 85v1 86v1 8Ev1 98v1 9Fv1 20v1 22v1 26v4 31v11 32v3 33v3 55v1 56v1 59v1 5Av1 5Bv1 5Ev1 60v4 6Cv1 70v1 71v1 72v1 73v1 75v1 7Av1
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Mulitlevel Switch : -- (04 : 11 : 02, base 26)
Z-Wave Syncing - retrieved command classes: 85v1 86v1 8Ev1 98v1 9Fv1 20v1 22v1 26v4 31v11 32v3 33v3 55v1 56v1 59v1 5Av1 5Bv1 5Ev1 60v4 6Cv1 70v1 71v1 72v1 73v1 75v1 7Av1
Z-Wave Syncing - retrieved capabilities: routing, beaming, security
Z-Wave Debug SENT requestMultiEndPointInfo: 01 09 00 13 08 02 60 07 25 65 C8
Z-Wave Debug RCVD requestMultiEndPointInfo: 01 07 00 13 65 00 00 02 8C (node ACK)
Z-Wave Debug RCVD requestMultiEndPointInfo: 01 0B 00 04 00 08 05 60 08 00 09 00 9C
Z-Wave Debug . . requestMultiEndPointInfo: node 008, numEndPoints 9, sameClass False, notStatic False
Z-Wave Debug SENT requestMultiEndPointDetails: 01 0A 00 13 08 03 60 09 01 25 66 C6
Z-Wave Debug RCVD requestMultiEndPointDetails: 01 07 00 13 66 00 00 02 8F (node ACK)
Z-Wave Debug RCVD requestMultiEndPointDetails: 01 18 00 04 00 08 12 60 0A 01 11 02 5E 26 85 8E 59 98 9F 32 33 75 6C 22 71 E7
Z-Wave Debug . . requestMultiEndPointDetails: node 008, endPoint 1, notStatic False, class hierarchy 11 : 02
Z-Wave Debug . . requestMultiEndPointDetails: node 008, combined multi-endpoint types: 1:(11 : 02)
Z-Wave Debug . . requestMultiEndPointDetails: node 008, combined multi-endpoint classes: 1:[5E 26 85 8E 59 98 9F 32 33 75 6C 22 71]
Z-Wave Debug SENT requestMultiEndPointDetails: 01 0A 00 13 08 03 60 09 02 25 67 C4
Z-Wave Debug RCVD requestMultiEndPointDetails: 01 07 00 13 67 00 00 02 8E (node ACK)
Z-Wave Debug RCVD requestMultiEndPointDetails: 01 14 00 04 00 08 0E 60 0A 02 11 01 5E 26 85 8E 59 98 9F 6C 22 F2
Z-Wave Debug . . requestMultiEndPointDetails: node 008, endPoint 2, notStatic False, class hierarchy 11 : 01
Z-Wave Debug . . requestMultiEndPointDetails: node 008, combined multi-endpoint types: 1:(11 : 02), 2:(11 : 01)
Z-Wave Debug . . requestMultiEndPointDetails: node 008, combined multi-endpoint classes: 1:[5E 26 85 8E 59 98 9F 32 33 75 6C 22 71], 2:[5E 26 85 8E 59 98 9F 6C 22]
Z-Wave Debug SENT requestMultiEndPointDetails: 01 0A 00 13 08 03 60 09 03 25 68 CA
Z-Wave Debug RCVD requestMultiEndPointDetails: 01 07 00 13 68 00 00 02 81 (node ACK)
Z-Wave Debug RCVD requestMultiEndPointDetails: 01 14 00 04 00 08 0E 60 0A 03 11 01 5E 26 85 8E 59 98 9F 6C 22 F3
Z-Wave Debug . . requestMultiEndPointDetails: node 008, endPoint 3, notStatic False, class hierarchy 11 : 01
Z-Wave Debug . . requestMultiEndPointDetails: node 008, combined multi-endpoint types: 1:(11 : 02), 2:(11 : 01), 3:(11 : 01)
Z-Wave Debug . . requestMultiEndPointDetails: node 008, combined multi-endpoint classes: 1:[5E 26 85 8E 59 98 9F 32 33 75 6C 22 71], 2:[5E 26 85 8E 59 98 9F 6C 22], 3:[5E 26 85 8E 59 98 9F 6C 22]
Z-Wave Debug SENT requestMultiEndPointDetails: 01 0A 00 13 08 03 60 09 04 25 69 CC
Z-Wave Debug RCVD requestMultiEndPointDetails: 01 07 00 13 69 00 00 02 80 (node ACK)
Z-Wave Debug RCVD requestMultiEndPointDetails: 01 14 00 04 00 08 0E 60 0A 04 11 01 5E 26 85 8E 59 98 9F 6C 22 F4
Z-Wave Debug . . requestMultiEndPointDetails: node 008, endPoint 4, notStatic False, class hierarchy 11 : 01
Z-Wave Debug . . requestMultiEndPointDetails: node 008, combined multi-endpoint types: 1:(11 : 02), 2:(11 : 01), 3:(11 : 01), 4:(11 : 01)
Z-Wave Debug . . requestMultiEndPointDetails: node 008, combined multi-endpoint classes: 1:[5E 26 85 8E 59 98 9F 32 33 75 6C 22 71], 2:[5E 26 85 8E 59 98 9F 6C 22], 3:[5E 26 85 8E 59 98 9F 6C 22], 4:[5E 26 85 8E 59 98 9F 6C 22]
Z-Wave Debug SENT requestMultiEndPointDetails: 01 0A 00 13 08 03 60 09 05 25 6A CE
Z-Wave Debug RCVD requestMultiEndPointDetails: 01 07 00 13 6A 00 00 02 83 (node ACK)
Z-Wave Debug RCVD requestMultiEndPointDetails: 01 14 00 04 00 08 0E 60 0A 05 11 01 5E 26 85 8E 59 98 9F 6C 22 F5
Z-Wave Debug . . requestMultiEndPointDetails: node 008, endPoint 5, notStatic False, class hierarchy 11 : 01
Z-Wave Debug . . requestMultiEndPointDetails: node 008, combined multi-endpoint types: 1:(11 : 02), 2:(11 : 01), 3:(11 : 01), 4:(11 : 01), 5:(11 : 01)
Z-Wave Debug . . requestMultiEndPointDetails: node 008, combined multi-endpoint classes: 1:[5E 26 85 8E 59 98 9F 32 33 75 6C 22 71], 2:[5E 26 85 8E 59 98 9F 6C 22], 3:[5E 26 85 8E 59 98 9F 6C 22], 4:[5E 26 85 8E 59 98 9F 6C 22], 5:[5E 26 85 8E 59 98 9F 6C 22]
Z-Wave Debug SENT requestMultiEndPointDetails: 01 0A 00 13 08 03 60 09 06 25 6B CC
Z-Wave Debug RCVD requestMultiEndPointDetails: 01 07 00 13 6B 00 00 03 83 (node ACK)
Z-Wave Debug RCVD requestMultiEndPointDetails: 01 14 00 04 00 08 0E 60 0A 06 21 01 5E 85 8E 59 98 9F 31 6C 22 D1
Z-Wave Debug . . requestMultiEndPointDetails: node 008, endPoint 6, notStatic False, class hierarchy 21 : 01
Z-Wave Debug . . requestMultiEndPointDetails: node 008, combined multi-endpoint types: 1:(11 : 02), 2:(11 : 01), 3:(11 : 01), 4:(11 : 01), 5:(11 : 01), 6:(21 : 01)
Z-Wave Debug . . requestMultiEndPointDetails: node 008, combined multi-endpoint classes: 1:[5E 26 85 8E 59 98 9F 32 33 75 6C 22 71], 2:[5E 26 85 8E 59 98 9F 6C 22], 3:[5E 26 85 8E 59 98 9F 6C 22], 4:[5E 26 85 8E 59 98 9F 6C 22], 5:[5E 26 85 8E 59 98 9F 6C 22], 6:[5E 85 8E 59 98 9F 31 6C 22]
Z-Wave Debug SENT requestMultiEndPointDetails: 01 0A 00 13 08 03 60 09 07 25 6C CA
Z-Wave Debug RCVD requestMultiEndPointDetails: 01 07 00 13 6C 00 00 02 85 (node ACK)
Z-Wave Debug RCVD requestMultiEndPointDetails: 01 14 00 04 00 08 0E 60 0A 07 21 01 5E 85 8E 59 98 9F 31 6C 22 D0
Z-Wave Debug . . requestMultiEndPointDetails: node 008, endPoint 7, notStatic False, class hierarchy 21 : 01
Z-Wave Debug . . requestMultiEndPointDetails: node 008, combined multi-endpoint types: 1:(11 : 02), 2:(11 : 01), 3:(11 : 01), 4:(11 : 01), 5:(11 : 01), 6:(21 : 01), 7:(21 : 01)
Z-Wave Debug . . requestMultiEndPointDetails: node 008, combined multi-endpoint classes: 1:[5E 26 85 8E 59 98 9F 32 33 75 6C 22 71], 2:[5E 26 85 8E 59 98 9F 6C 22], 3:[5E 26 85 8E 59 98 9F 6C 22], 4:[5E 26 85 8E 59 98 9F 6C 22], 5:[5E 26 85 8E 59 98 9F 6C 22], 6:[5E 85 8E 59 98 9F 31 6C 22], 7:[5E 85 8E 59 98 9F 31 6C 22]
Z-Wave Debug SENT requestMultiEndPointDetails: 01 0A 00 13 08 03 60 09 08 25 6D C4
Z-Wave Debug RCVD requestMultiEndPointDetails: 01 07 00 13 6D 00 00 03 85 (node ACK)
Z-Wave Debug RCVD requestMultiEndPointDetails: 01 14 00 04 00 08 0E 60 0A 08 21 01 5E 85 8E 59 98 9F 31 6C 22 DF
Z-Wave Debug . . requestMultiEndPointDetails: node 008, endPoint 8, notStatic False, class hierarchy 21 : 01
Z-Wave Debug . . requestMultiEndPointDetails: node 008, combined multi-endpoint types: 1:(11 : 02), 2:(11 : 01), 3:(11 : 01), 4:(11 : 01), 5:(11 : 01), 6:(21 : 01), 7:(21 : 01), 8:(21 : 01)
Z-Wave Debug . . requestMultiEndPointDetails: node 008, combined multi-endpoint classes: 1:[5E 26 85 8E 59 98 9F 32 33 75 6C 22 71], 2:[5E 26 85 8E 59 98 9F 6C 22], 3:[5E 26 85 8E 59 98 9F 6C 22], 4:[5E 26 85 8E 59 98 9F 6C 22], 5:[5E 26 85 8E 59 98 9F 6C 22], 6:[5E 85 8E 59 98 9F 31 6C 22], 7:[5E 85 8E 59 98 9F 31 6C 22], 8:[5E 85 8E 59 98 9F 31 6C 22]
Z-Wave Debug SENT requestMultiEndPointDetails: 01 0A 00 13 08 03 60 09 09 25 6E C6
Z-Wave Debug RCVD requestMultiEndPointDetails: 01 07 00 13 6E 00 00 02 87 (node ACK)
Z-Wave Debug RCVD requestMultiEndPointDetails: 01 14 00 04 00 08 0E 60 0A 09 21 01 5E 85 8E 59 98 9F 31 6C 22 DE
Z-Wave Debug . . requestMultiEndPointDetails: node 008, endPoint 9, notStatic False, class hierarchy 21 : 01
Z-Wave Debug . . requestMultiEndPointDetails: node 008, combined multi-endpoint types: 1:(11 : 02), 2:(11 : 01), 3:(11 : 01), 4:(11 : 01), 5:(11 : 01), 6:(21 : 01), 7:(21 : 01), 8:(21 : 01), 9:(21 : 01)
Z-Wave Debug . . requestMultiEndPointDetails: node 008, combined multi-endpoint classes: 1:[5E 26 85 8E 59 98 9F 32 33 75 6C 22 71], 2:[5E 26 85 8E 59 98 9F 6C 22], 3:[5E 26 85 8E 59 98 9F 6C 22], 4:[5E 26 85 8E 59 98 9F 6C 22], 5:[5E 26 85 8E 59 98 9F 6C 22], 6:[5E 85 8E 59 98 9F 31 6C 22], 7:[5E 85 8E 59 98 9F 31 6C 22], 8:[5E 85 8E 59 98 9F 31 6C 22], 9:[5E 85 8E 59 98 9F 31 6C 22]
Z-Wave Syncing - retrieved multi-endpoint types: 1:(11 : 02), 2:(11 : 01), 3:(11 : 01), 4:(11 : 01), 5:(11 : 01), 6:(21 : 01), 7:(21 : 01), 8:(21 : 01), 9:(21 : 01)
Z-Wave Syncing - retrieved multi-endpoint classes: 1:[5E 26 85 8E 59 98 9F 32 33 75 6C 22 71], 2:[5E 26 85 8E 59 98 9F 6C 22], 3:[5E 26 85 8E 59 98 9F 6C 22], 4:[5E 26 85 8E 59 98 9F 6C 22], 5:[5E 26 85 8E 59 98 9F 6C 22], 6:[5E 85 8E 59 98 9F 31 6C 22], 7:[5E 85 8E 59 98 9F 31 6C 22], 8:[5E 85 8E 59 98 9F 31 6C 22], 9:[5E 85 8E 59 98 9F 31 6C 22]
Z-Wave Debug SENT requestAssociationGroupCount: 01 09 00 13 08 02 85 05 25 6F 25
Z-Wave Debug RCVD requestAssociationGroupCount: 01 07 00 13 6F 00 00 02 86 (node ACK)
Z-Wave Debug RCVD requestAssociationGroupCount: 01 09 00 04 00 08 03 85 06 0A 70
Z-Wave Debug . . requestAssociationGroupCount: node 008, group count: 10
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 08 03 85 02 01 25 70 3E
Z-Wave Debug RCVD requestAssociations: 01 07 00 13 70 00 00 02 99 (node ACK)
Z-Wave Debug RCVD requestAssociations: 01 0C 00 04 00 08 06 85 03 01 01 00 01 7E
Z-Wave Debug . . requestAssociations: node 008, group: 1, num associations: 1, max associations: 1, replies left: 0
Z-Wave Debug . . requestAssociations: node 008, group: 1, associations: [1]
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 08 03 85 02 02 25 71 3C
Z-Wave Debug RCVD requestAssociations: 01 07 00 13 71 00 00 02 98 (node ACK)
Z-Wave Debug RCVD requestAssociations: 01 0B 00 04 00 08 05 85 03 02 05 00 7C
Z-Wave Debug . . requestAssociations: node 008, group: 2, num associations: 0, max associations: 5, replies left: 0
Z-Wave Debug . . requestAssociations: node 008, group: 2, associations: []
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 08 03 85 02 03 25 72 3E
Z-Wave Debug RCVD requestAssociations: 01 07 00 13 72 00 00 02 9B (node ACK)
Z-Wave Debug RCVD requestAssociations: 01 0B 00 04 00 08 05 85 03 03 05 00 7D
Z-Wave Debug . . requestAssociations: node 008, group: 3, num associations: 0, max associations: 5, replies left: 0
Z-Wave Debug . . requestAssociations: node 008, group: 3, associations: []
Z-Wave Syncing - retrieved group 3 associations: []
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 08 03 85 02 04 25 73 38
Z-Wave Debug RCVD requestAssociations: 01 07 00 13 73 00 00 02 9A (node ACK)
Z-Wave Debug RCVD requestAssociations: 01 0B 00 04 00 08 05 85 03 04 05 00 7A
Z-Wave Debug . . requestAssociations: node 008, group: 4, num associations: 0, max associations: 5, replies left: 0
Z-Wave Debug . . requestAssociations: node 008, group: 4, associations: []
Z-Wave Syncing - retrieved group 4 associations: []
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 08 03 85 02 05 25 74 3E
Z-Wave Debug RCVD requestAssociations: 01 07 00 13 74 00 00 02 9D (node ACK)
Z-Wave Debug RCVD requestAssociations: 01 0B 00 04 00 08 05 85 03 05 05 00 7B
Z-Wave Debug . . requestAssociations: node 008, group: 5, num associations: 0, max associations: 5, replies left: 0
Z-Wave Debug . . requestAssociations: node 008, group: 5, associations: []
Z-Wave Syncing - retrieved group 5 associations: []
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 08 03 85 02 06 25 75 3C
Z-Wave Debug RCVD requestAssociations: 01 07 00 13 75 00 00 02 9C (node ACK)
Z-Wave Debug RCVD requestAssociations: 01 0B 00 04 00 08 05 85 03 06 05 00 78
Z-Wave Debug . . requestAssociations: node 008, group: 6, num associations: 0, max associations: 5, replies left: 0
Z-Wave Debug . . requestAssociations: node 008, group: 6, associations: []
Z-Wave Syncing - retrieved group 6 associations: []
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 08 03 85 02 07 25 76 3E
Z-Wave Debug RCVD requestAssociations: 01 07 00 13 76 00 00 03 9E (node ACK)
Z-Wave Debug RCVD requestAssociations: 01 0B 00 04 00 08 05 85 03 07 05 00 79
Z-Wave Debug . . requestAssociations: node 008, group: 7, num associations: 0, max associations: 5, replies left: 0
Z-Wave Debug . . requestAssociations: node 008, group: 7, associations: []
Z-Wave Syncing - retrieved group 7 associations: []
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 08 03 85 02 08 25 77 30
Z-Wave Debug RCVD requestAssociations: 01 07 00 13 77 00 00 02 9E (node ACK)
Z-Wave Debug RCVD requestAssociations: 01 0B 00 04 00 08 05 85 03 08 05 00 76
Z-Wave Debug . . requestAssociations: node 008, group: 8, num associations: 0, max associations: 5, replies left: 0
Z-Wave Debug . . requestAssociations: node 008, group: 8, associations: []
Z-Wave Syncing - retrieved group 8 associations: []
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 08 03 85 02 09 25 78 3E
Z-Wave Debug RCVD requestAssociations: 01 07 00 13 78 00 00 02 91 (node ACK)
Z-Wave Debug RCVD requestAssociations: 01 0B 00 04 00 08 05 85 03 09 05 00 77
Z-Wave Debug . . requestAssociations: node 008, group: 9, num associations: 0, max associations: 5, replies left: 0
Z-Wave Debug . . requestAssociations: node 008, group: 9, associations: []
Z-Wave Syncing - retrieved group 9 associations: []
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 08 03 85 02 0A 25 79 3C
Z-Wave Debug RCVD requestAssociations: 01 07 00 13 79 00 00 02 90 (node ACK)
Z-Wave Debug RCVD requestAssociations: 01 0B 00 04 00 08 05 85 03 0A 05 00 74
Z-Wave Debug . . requestAssociations: node 008, group: 10, num associations: 0, max associations: 5, replies left: 0
Z-Wave Debug . . requestAssociations: node 008, group: 10, associations: []
Z-Wave Syncing - retrieved group 10 associations: []
Z-Wave Debug SENT requestMeterInfo: 01 09 00 13 08 02 32 03 25 7A 81
Z-Wave Debug RCVD requestMeterInfo: 01 07 00 13 7A 00 00 02 93 (node ACK)
Z-Wave Debug RCVD requestMeterInfo: 01 0A 00 04 00 08 04 32 04 81 05 4F
Z-Wave Debug . . requestMeterInfo: node 008, meterType 01, subTypeFlags 05, supportsReset True
Z-Wave Debug SENT requestMeterInfo: 01 0D 00 13 08 06 60 0D 01 01 32 03 25 7B ED
Z-Wave Debug RCVD requestMeterInfo: 01 07 00 13 7B 00 00 02 92 (node ACK)
Z-Wave Debug RCVD multiEndPointPacket: 01 0E 00 04 00 08 08 60 0D 01 01 32 04 81 05 2A
Z-Wave Debug . . multiEndPointPacket: node 008, endPoint 1
Z-Wave Debug RCVD requestMeterInfo: 01 0A 00 04 00 08 04 32 04 81 05 FF
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 08 03 70 05 01 25 7C C0
Z-Wave Debug RCVD requestConfigVal: 01 07 00 13 7C 00 00 02 95 (node ACK)
Z-Wave Debug RCVD requestConfigVal: 01 0B 00 04 00 08 05 70 06 01 01 00 8B
Z-Wave Debug . . requestConfigVal: node 008, parm index 1, value 0 (size 1)
Z-Wave Syncing - retrieved parameter 1 "Power up to last known state" is false
Z-Wave Debug . . requestConfigVal: node 008, combined config vals: 1:0
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 08 03 70 05 14 25 7D D4
Z-Wave Debug RCVD requestConfigVal: 01 07 00 13 7D 00 00 02 94 (node ACK)
Z-Wave Debug RCVD requestConfigVal: 01 0B 00 04 00 08 05 70 06 14 01 02 9C
Z-Wave Debug . . requestConfigVal: node 008, parm index 20, value 2 (size 1)
Z-Wave Syncing - retrieved parameter 20 "Input 1 type" is 2 "Momentary (Enables Scenes)"
Z-Wave Debug . . requestConfigVal: node 008, combined config vals: 1:0 20:2
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 08 03 70 05 15 25 7E D6
Z-Wave Debug RCVD requestConfigVal: 01 07 00 13 7E 00 00 03 96 (node ACK)
Z-Wave Debug RCVD requestConfigVal: 01 0B 00 04 00 08 05 70 06 15 01 02 9D
Z-Wave Debug . . requestConfigVal: node 008, parm index 21, value 2 (size 1)
Z-Wave Syncing - retrieved parameter 21 "Input 2 type" is 2 "Momentary (Enables Scenes)"
Z-Wave Debug . . requestConfigVal: node 008, combined config vals: 1:0 20:2 21:2
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 08 03 70 05 16 25 7F D4
Z-Wave Debug RCVD requestConfigVal: 01 07 00 13 7F 00 00 02 96 (node ACK)
Z-Wave Debug RCVD requestConfigVal: 01 0B 00 04 00 08 05 70 06 16 01 02 9E
Z-Wave Debug . . requestConfigVal: node 008, parm index 22, value 2 (size 1)
Z-Wave Syncing - retrieved parameter 22 "Input 3 type" is 2 "Momentary (Enables Scenes)"
Z-Wave Debug . . requestConfigVal: node 008, combined config vals: 1:0 20:2 21:2 22:2
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 08 03 70 05 17 25 80 2A
Z-Wave Debug RCVD requestConfigVal: 01 07 00 13 80 00 00 02 69 (node ACK)
Z-Wave Debug RCVD requestConfigVal: 01 0B 00 04 00 08 05 70 06 17 01 02 9F
Z-Wave Debug . . requestConfigVal: node 008, parm index 23, value 2 (size 1)
Z-Wave Syncing - retrieved parameter 23 "Input 4 type" is 2 "Momentary (Enables Scenes)"
Z-Wave Debug . . requestConfigVal: node 008, combined config vals: 1:0 20:2 21:2 22:2 23:2
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 08 03 70 05 3F 25 81 03
Z-Wave Debug RCVD requestConfigVal: 01 07 00 13 81 00 00 03 69 (node ACK)
Z-Wave Debug RCVD requestConfigVal: 01 0C 00 04 00 08 06 70 06 3F 02 00 05 B7
Z-Wave Debug . . requestConfigVal: node 008, parm index 63, value 5 (size 2)
Z-Wave Syncing - retrieved parameter 63 "Analog input sensitivity" is 5 * 0.1 V
Z-Wave Debug SENT setConfigVal: 01 0C 00 13 08 05 70 04 3F 01 00 25 82 00
Z-Wave Debug RCVD setConfigVal: 01 07 00 13 82 00 00 03 6A (node ACK)
Z-Wave Syncing - device "008 - Bathroom RGBW 1" parameter 63 "Analog input sensitivity" changed to 0 * 0.1 V (was 5 * 0.1 V)
Z-Wave Debug . . pushNewValToNode: node 008, combined config vals: 1:0 20:2 21:2 22:2 23:2 63:0
Z-Wave Debug RCVD requestReply1: 01 09 00 04 00 08 03 22 02 00 D9 (hex)
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 08 03 70 05 40 25 83 7E
Z-Wave Debug RCVD requestConfigVal: 01 07 00 13 83 00 00 02 6A (node ACK)
Z-Wave Debug RCVD requestConfigVal: 01 0C 00 04 00 08 06 70 06 40 02 00 00 CD
Z-Wave Debug . . requestConfigVal: node 008, parm index 64, value 0 (size 2)
Z-Wave Syncing - retrieved parameter 64 "Analog input interval" is 0 seconds
Z-Wave Debug . . requestConfigVal: node 008, combined config vals: 64:0 1:0 20:2 21:2 22:2 23:2 63:0
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 08 03 70 05 3E 25 84 07
Z-Wave Debug RCVD requestConfigVal: 01 07 00 13 84 00 00 02 6D (node ACK)
Z-Wave Debug RCVD requestConfigVal: 01 0C 00 04 00 08 06 70 06 3E 02 0E 10 AD
Z-Wave Debug . . requestConfigVal: node 008, parm index 62, value 3600 (size 2)
Z-Wave Syncing - retrieved parameter 62 "Periodic power reports" is 3600 seconds
Z-Wave Debug . . requestConfigVal: node 008, combined config vals: 64:0 1:0 20:2 21:2 22:2 23:2 62:3600 63:0
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 08 03 70 05 41 25 85 79
Z-Wave Debug RCVD requestConfigVal: 01 07 00 13 85 00 00 02 6C (node ACK)
Z-Wave Debug RCVD requestConfigVal: 01 0C 00 04 00 08 06 70 06 41 02 00 0A C6
Z-Wave Debug . . requestConfigVal: node 008, parm index 65, value 10 (size 2)
Z-Wave Syncing - retrieved parameter 65 "Energy report threshold" is 10 * 0.1 kWh
Z-Wave Debug . . requestConfigVal: node 008, combined config vals: 64:0 1:0 20:2 21:2 22:2 23:2 65:10 62:3600 63:0
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 08 03 70 05 42 25 86 79
Z-Wave Debug RCVD requestConfigVal: 01 07 00 13 86 00 00 03 6E (node ACK)
Z-Wave Debug RCVD requestConfigVal: 01 0C 00 04 00 08 06 70 06 42 02 0E 10 D1
Z-Wave Debug . . requestConfigVal: node 008, parm index 66, value 3600 (size 2)
Z-Wave Syncing - retrieved parameter 66 "Periodic energy reports" is 3600 seconds
Z-Wave Debug . . requestConfigVal: node 008, combined config vals: 64:0 1:0 66:3600 20:2 21:2 22:2 23:2 65:10 62:3600 63:0
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 08 03 70 05 97 25 87 AD
Z-Wave Debug RCVD requestConfigVal: 01 07 00 13 87 00 00 02 6E (node ACK)
Z-Wave Debug RCVD requestConfigVal: 01 0C 00 04 00 08 06 70 06 97 02 00 03 19
Z-Wave Debug . . requestConfigVal: node 008, parm index 151, value 3 (size 2)
Z-Wave Syncing - retrieved parameter 151 "Local ramp rate" is 3 seconds
Z-Wave Debug . . requestConfigVal: node 008, combined config vals: 64:0 1:0 66:3600 65:10 151:3 20:2 21:2 22:2 23:2 62:3600 63:0
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 08 03 70 05 98 25 88 AD
Z-Wave Debug RCVD requestConfigVal: 01 07 00 13 88 00 00 03 60 (node ACK)
Z-Wave Debug RCVD requestConfigVal: 01 0C 00 04 00 08 06 70 06 98 02 00 03 16
Z-Wave Debug . . requestConfigVal: node 008, parm index 152, value 3 (size 2)
Z-Wave Syncing - retrieved parameter 152 "Remote ramp rate" is 3 seconds
Z-Wave Debug . . requestConfigVal: node 008, combined config vals: 64:0 1:0 66:3600 65:10 151:3 20:2 21:2 22:2 23:2 152:3 62:3600 63:0
Z-Wave Syncing - complete
Z-Wave Debug SENT requestDimmerStatus: 01 09 00 13 08 02 26 02 25 89 67
Z-Wave Debug RCVD requestDimmerStatus: 01 07 00 13 89 00 00 02 60 (node ACK)
Z-Wave Debug terminatingSyncUI
Z-Wave sent "Bathroom RGBW 1" status request
Z-Wave sent "Bathroom RGBW 1" energy status request
Z-Wave Debug RCVD requestDimmerStatus: 01 0B 00 04 00 08 05 26 03 63 63 00 D8
Z-Wave Debug . . requestDimmerStatus: node 008, endpoint None, value 99
Z-Wave Debug SENT requestDimmerStatus: 01 0D 00 13 08 06 60 0D 01 02 26 02 25 8A 0A
Z-Wave Debug RCVD requestDimmerStatus: 01 07 00 13 8A 00 00 02 63 (node ACK)
Z-Wave sent "008 - Red" status request
Z-Wave Debug RCVD multiEndPointPacket: 01 0F 00 04 00 08 09 60 0D 02 01 26 03 00 00 00 BE
Z-Wave Debug . . multiEndPointPacket: node 008, endPoint 2
Z-Wave Debug RCVD requestDimmerStatus: 01 0B 00 04 00 08 05 26 03 00 00 00 FF
Z-Wave Debug . . requestDimmerStatus: node 008, endpoint 2, value 0
Z-Wave received "008 - Red" status update is off
Z-Wave Debug queueing energy request of "008 - Bathroom RGBW 1" (activity detected)
Z-Wave Debug SENT requestDimmerStatus: 01 0D 00 13 08 06 60 0D 01 03 26 02 25 8B 0A
Z-Wave Debug RCVD requestDimmerStatus: 01 07 00 13 8B 00 00 03 63 (node ACK)
Z-Wave sent "008 - Green" status request
Z-Wave Debug RCVD multiEndPointPacket: 01 0F 00 04 00 08 09 60 0D 03 01 26 03 00 00 00 BF
Z-Wave Debug . . multiEndPointPacket: node 008, endPoint 3
Z-Wave Debug . . requestDimmerStatus: node 008, endpoint 3, value 0
Z-Wave received "008 - Green" status update is off
Z-Wave Debug ignoring duplicate energy request of "008 - Bathroom RGBW 1" (activity detected)
Z-Wave Debug SENT requestDimmerStatus: 01 0D 00 13 08 06 60 0D 01 04 26 02 25 8C 0A
Z-Wave Debug RCVD requestDimmerStatus: 01 07 00 13 8C 00 00 02 65 (node ACK)
Z-Wave sent "008 - Blue" status request
Z-Wave Debug RCVD multiEndPointPacket: 01 0F 00 04 00 08 09 60 0D 04 01 26 03 00 00 00 B8
Z-Wave Debug . . multiEndPointPacket: node 008, endPoint 4
Z-Wave Debug . . requestDimmerStatus: node 008, endpoint 4, value 0
Z-Wave received "008 - Blue" status update is off
Z-Wave Debug SENT requestDimmerStatus: 01 0D 00 13 08 06 60 0D 01 05 26 02 25 8D 0A
Z-Wave Debug RCVD requestDimmerStatus: 01 07 00 13 8D 00 00 02 64 (node ACK)
Z-Wave sent "008 - White" status request
Z-Wave Debug RCVD multiEndPointPacket: 01 0F 00 04 00 08 09 60 0D 05 01 26 03 00 00 00 B9
Z-Wave Debug . . multiEndPointPacket: node 008, endPoint 5
Z-Wave Debug . . requestDimmerStatus: node 008, endpoint 5, value 0
Z-Wave received "008 - White" status update is off
Z-Wave Debug SENT requestVarSensorStatus: 01 0D 00 13 08 06 60 0D 01 06 31 04 25 8E 1B
Z-Wave Debug RCVD requestVarSensorStatus: 01 07 00 13 8E 00 00 02 67 (node ACK)
Z-Wave sent "008 - Analog IN1" status request
Z-Wave Debug RCVD multiEndPointPacket: 01 10 00 04 00 08 0A 60 0D 06 01 31 05 0F 22 00 00 9A
Z-Wave Debug . . multiEndPointPacket: node 008, endPoint 6
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 08 06 31 05 0F 22 00 00 FF
Z-Wave Debug . . requestVarSensorStatus: node 008, endpoint 6, type 15, raw value 2200...
Z-Wave Debug . . requestVarSensorStatus: 0.0 V (float: 0.000000)
Z-Wave Debug . . requestVarSensorStatus: ignored (no device found for dispatch)
Z-Wave Debug SENT requestVarSensorStatus: 01 0D 00 13 08 06 60 0D 01 07 31 04 25 8F 1B
Z-Wave Debug RCVD requestVarSensorStatus: 01 07 00 13 8F 00 00 03 67 (node ACK)
Z-Wave sent "008 - Analog IN2" status request
Z-Wave Debug RCVD multiEndPointPacket: 01 10 00 04 00 08 0A 60 0D 07 01 31 05 0F 22 00 00 9B
Z-Wave Debug . . multiEndPointPacket: node 008, endPoint 7
Z-Wave Debug . . requestVarSensorStatus: node 008, endpoint 7, type 15, raw value 2200...
Z-Wave Debug SENT requestVarSensorStatus: 01 0D 00 13 08 06 60 0D 01 08 31 04 25 90 0B
Z-Wave Debug RCVD requestVarSensorStatus: 01 07 00 13 90 00 00 02 79 (node ACK)
Z-Wave sent "008 - Analog IN3" status request
Z-Wave Debug RCVD multiEndPointPacket: 01 10 00 04 00 08 0A 60 0D 08 01 31 05 0F 22 00 00 94
Z-Wave Debug . . multiEndPointPacket: node 008, endPoint 8
Z-Wave Debug . . requestVarSensorStatus: node 008, endpoint 8, type 15, raw value 2200...
Z-Wave Debug SENT requestVarSensorStatus: 01 0D 00 13 08 06 60 0D 01 09 31 04 25 91 0B
Z-Wave Debug RCVD requestVarSensorStatus: 01 07 00 13 91 00 00 02 78 (node ACK)
Z-Wave sent "008 - Analog IN4" status request
Z-Wave Debug RCVD multiEndPointPacket: 01 10 00 04 00 08 0A 60 0D 09 01 31 05 0F 22 00 00 95
Z-Wave Debug . . multiEndPointPacket: node 008, endPoint 9
Z-Wave Debug . . requestVarSensorStatus: node 008, endpoint 9, type 15, raw value 2200...
Z-Wave Debug SENT requestMeterLevel: 01 0A 00 13 08 03 32 01 00 25 92 69
Z-Wave Debug RCVD requestMeterLevel: 01 07 00 13 92 00 00 02 7B (node ACK)
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 08 0E 32 02 21 44 00 00 00 00 00 00 00 00 00 00 BC
Z-Wave Debug . . requestMeterLevel: node 008, endpoint None, meterType 01, raw value 4400...
Z-Wave Debug . . requestMeterLevel: 0.00 kWh (float: 0.000000)
Z-Wave Debug SENT requestMeterLevel: 01 0A 00 13 08 03 32 01 10 25 93 78
Z-Wave Debug RCVD requestMeterLevel: 01 07 00 13 93 00 00 02 7A (node ACK)
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 08 0A 32 02 21 32 00 00 00 00 00 00 CA
Z-Wave Debug . . requestMeterLevel: node 008, endpoint None, meterType 01, raw value 3200...
Z-Wave Debug . . requestMeterLevel: 0.0 W (float: 0.000000)
Z-Wave Debug polling status of node "008 - Bathroom RGBW 1" (post-activity energy request)
Z-Wave Debug SENT requestMeterLevel: 01 0A 00 13 08 03 32 01 00 25 94 6F
Z-Wave Debug RCVD requestMeterLevel: 01 07 00 13 94 00 00 03 7C (node ACK)
Z-Wave Debug SENT requestMeterLevel: 01 0A 00 13 08 03 32 01 10 25 95 7E
Z-Wave Debug RCVD requestMeterLevel: 01 07 00 13 95 00 00 03 7D (node ACK)
If I try and change say Red (only brightness works though; so by changing W )but via the parent object the actual 442 multi switch here's what I get
30 Apr 2020 at 09:18:18
Z-Wave Debug SENT setRgbColorValues: 01 0D 00 13 08 06 33 05 01 00 59 00 25 9C 38
Z-Wave Debug RCVD setRgbColorValues: 01 07 00 13 9C 00 00 02 75 (node ACK)
Z-Wave sent "Bathroom RGBW 1" set color to -- -- --, 35
Z-Wave Debug SENT requestMeterLevel: 01 0A 00 13 08 03 32 01 00 25 9D 66
Z-Wave Debug RCVD requestMeterLevel: 01 07 00 13 9D 00 00 03 75 (node ACK)
Z-Wave Debug SENT requestMeterLevel: 01 0A 00 13 08 03 32 01 10 25 9E 75
Z-Wave Debug RCVD requestMeterLevel: 01 07 00 13 9E 00 00 02 77 (node ACK)
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 08 0A 32 02 21 32 00 01 00 00 00 00 CB
Z-Wave Debug . . requestMeterLevel: 0.1 W (float: 0.100000)
Z-Wave received "Bathroom RGBW 1" power load to 0.1 W
Altering just the red component directly - but appears to have no effect
30 Apr 2020 at 09:19:26
Z-Wave Debug SENT setMultiLevelValue: 01 0E 00 13 08 07 60 0D 01 02 26 01 FF 25 9F E1
Z-Wave Debug RCVD setMultiLevelValue: 01 07 00 13 9F 00 00 02 76 (node ACK)
Z-Wave sent "008 - Red" on
Z-Wave Debug SENT setMultiLevelValue: 01 0E 00 13 08 07 60 0D 01 02 26 01 2E 25 A0 0F
Z-Wave Debug RCVD setMultiLevelValue: 01 07 00 13 A0 00 00 02 49 (node ACK)
Z-Wave sent "008 - Red" set brightness to 46
Z-Wave Debug SENT requestMeterLevel: 01 0A 00 13 08 03 32 01 00 25 A1 5A
Z-Wave Debug RCVD requestMeterLevel: 01 07 00 13 A1 00 00 02 48 (node ACK)
Z-Wave Debug SENT requestMeterLevel: 01 0A 00 13 08 03 32 01 10 25 A2 49
Z-Wave Debug RCVD requestMeterLevel: 01 07 00 13 A2 00 00 02 4B (node ACK)
Hope this helps!
Cheers
Tue May 05, 2020 2:26 am
pocster offline
Managed to get hold of another Fibaro RGBW 2 ; exactly the same problem. Red only.
Thu May 07, 2020 6:30 pm
Sorry for the delayed response.
I'm a bit confused. You said only red works but also said, "altering just the red component directly - but appears to have no effect", which sounds like even red didn't work?
Also what do you mean by this exactly:
Can you describe in more detail what occurs as you control each device: composite, red, green, blue, and white? Include log snippets of all of them. Also, when controlling the composite try choosing several different colors from the color picker. Do the LEDs change at all when choosing different colors from the picker (for the composite device)?
Lastly, try moving all of the brightness sliders for Red, Green, Blue, and White to 0%, then try controlling the composite device (via the color picker). Does that work? Next, try changing all of the R, G, B, W devices to 100% then try controlling the composite device (via color picker). Any different?
