Aeotc Multi Sensor 6. ZW100 Limited Settings available
Tue Nov 05, 2019 5:57 am
plaurent offline
I own a half dozen of the ZW100 sensors, and started acquiring a few of the Aeotec Trisensor (ZWA005) sensors. Beyond the physical differences, I noticed that the number of settings available within Indigo on the Trisensor are numerous compared to the Multi Sensor 6. Looking at the tech docs for the ZW100, I do see that there are lots more configuration options available for the ZW100 but aren't made available in the Indigo GUI.
The ZW100 devices that I have are all running firmware 1.10, whereas the latest release is 1.13 so perhaps this is the reason they aren't made available within Indigo's GUI?
Tue Nov 05, 2019 9:09 am
Re: Aeotc Multi Sensor 6. ZW100 Limited Settings available
Re-sync your ZW100 and copy/paste the Event Log window results into a reply post for me.
Tue Nov 05, 2019 7:19 pm
plaurent offline
As requested:
Nov 5, 2019 at 8:17:42 PM
Z-Wave Syncing - started for "Family Room - Motion Sensor"
Z-Wave Syncing - retrieved module neighbors list: 25
Z-Wave Syncing - assigning return route to "035 - Family Room - Motion Sensor"
Z-Wave Syncing - retrieved manufacture and model names: Aeon Labs - 0086, Multi Sensor 6 (ZW100) - 01020064
Z-Wave Syncing - retrieved protocol version 4.54, app version 1.10
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Multilevel Sensor : Multilevel Sensor (routing) (04 : 21 : 01, base 31)
Z-Wave Syncing - retrieved command classes: 20v1 80v1 84v2 85v1 86v1 30v1 70v1 31v5 72v1 73v1 71v1 59v1 7Av1 5Av1 5Ev1
Z-Wave Syncing - retrieved capabilities: routing, battery, beaming, waking
Z-Wave Syncing - retrieved wake interval of 60 minutes
Z-Wave Syncing - device "035 - Family Room - Motion Sensor" wake interval changed to 60 minutes
Z-Wave Syncing - retrieved parameter 252 "Lock configuration" is false
Z-Wave Syncing - retrieved parameter 2 "Wake for 10 minutes after battery change" is true
Z-Wave Syncing - retrieved parameter 4 "Motion sensing" is 5 "Sensitivity 5 - Maximum"
Z-Wave Syncing - retrieved parameter 3 "Off delay" is 10 seconds
Z-Wave Syncing - retrieved parameter 5 "Motion flags" is 1
Z-Wave Syncing - retrieved parameter 40 "Enable selective threshold reporting" is false
Z-Wave Syncing - retrieved parameter 64 "Temperature units" is 2 "Fahrenheit"
Z-Wave Syncing - retrieved parameter 111 "Reporting interval" is 60 seconds
Z-Wave Syncing - retrieved parameter 112 "Reporting interval2" is 1800 seconds
Z-Wave Syncing - retrieved parameter 113 "Reporting interval3" is 1800 seconds
Z-Wave Syncing - retrieved parameter 101 "Group 1 flags" is 240
Z-Wave Syncing - retrieved parameter 102 "Group 2 flags" is 0
Z-Wave Syncing - retrieved parameter 103 "Group 3 flags" is 0
Z-Wave Syncing - device "035 - Family Room - Motion Sensor" parameter 103 "Group 3 flags" changed to 0
Z-Wave received "Family Room - Temperature" sensor update to 73.5 °F
Z-Wave received "Family Room - Humidity" sensor update to 60%
Z-Wave received "Family Room - Luminance" sensor update to 3 lux
Z-Wave received "Family Room - Ultraviolet" sensor update to 0
Z-Wave Syncing - retrieved battery level of 50%
Z-Wave Syncing - complete
Sat Nov 09, 2019 2:29 pm
Okay, I wanted to make sure Indigo was matching its ZW100 definition for yours and it is.
What are the specific settings you are seeing for the ZW100 (in the docs) that you would think are useful? We tend not to add all of the settings available for modules to the UI, as some are infrequently used (or too complicated for us to define in Indigo's settings UI), but if there are some popular ones we missed we can look at adding them. I assume you know you can manually change any settings even if there isn't UI defined for them via the Interfaces->Z-Wave->Modify Configuration Parameter... menu item?
