Firmware Upgrade UZB
Sun Oct 27, 2019 2:54 am
davinci offline
I want to update the USB stick for two reasons.
- being able to make a backup
- disable the obnoxious blue LED
https://z-wave.me/support/uzbrazberry-firmwares/
As far as I understand I could use Z-Way without a license to make the backup and the firmware upgrade.
https://z-wave.me/z-way-v3-0-0/
Anyone here who did this on a Mac? Is it even possible to do this?
Sun Oct 27, 2019 1:05 pm
roquej offline
Re: Firmware Upgrade UZB
With Indigo, you should be using 5.07 as outlined here ( viewtopic.php?f=58&t=22120&p=174808&hilit=UZB+firmware#p174808 ) or your locks won't work.
For one, I am eagerly waiting to be able to use the latest firmware.
As for backup, I used the Z-Way.me Zway software, in both raspberry and the windows version to backup and restore the z-wave configuration after a UZB stick failed. it worked well. However, I did buy the license. Not sure if it would work without it.
JP
Mon Oct 28, 2019 3:50 pm
shapa offline
Do not try it. Anything higher than 5.07 will not work properly.
It is an Indigo issue - other SW works fine.
Made a comment in the Kwickset thread :)
shapa offline
BTW, backup will work just fine with 5.07
" I could use Z-Way without a license" - really, not. Will not restore multiple devices - only a few allowed.
But the price is negligible - you can buy it online for something like 20$
A lot of very useful tools in the razpberry software non-existent in Indigo - including advanced associations, network map and so on.
Mon Oct 28, 2019 4:11 pm
I've actually looked at this (UZB) recently. I need to spend some more time on it, but the more recent versions of the UZB definitely are doing some strange things. In particular, it adds 2 random bytes to association report commands. I've verified that it is definitely sending additional bytes in that case, and have worked around it to some extent but cannot catch all of the cases. I'm not sure about the lock/encryption issue yet.
Thu Dec 05, 2019 4:28 pm
shapa offline
Tested beta version of the zwave plugin. Upgraded UZB1 to 5.36 (SDK - 6.81.01 with smart start support). So far, works fine - including encryption (locks, etc).
Awesome news :)
Thu Dec 05, 2019 6:31 pm
roquej offline
Cool news! Any chance to try the beta plugin? Running into some issues, every works then stops until I resync devices. Hoping is the firmware.
JP
Thu Dec 05, 2019 9:08 pm
I'm not so sure it will help that problem, but I'll send you an email.
Tue Dec 10, 2019 9:27 am
roquej offline
Matt,
A quick update. Upgraded the UZB1 to 5.36 firmware and with the beta zwave plugin, everything seems to work well, including the locks.
As for my z-wave re-sync issue, all well so far. Will keep you posted.
Thank you!
JP
Fri Feb 07, 2020 2:10 pm
Indigo 7.4.1 is now available and includes support for the USB Stick (ZME UZB1).
Sat Jan 09, 2021 7:40 am
jaknudsen offline
According to release notes for 7.4.1, UZB1 firmware up to 5.32 is supported. Does Indigo 7.5 support the current UZB1 firmware 5.39?
Sat Jan 09, 2021 1:22 pm
We haven't tested against 5.39 but I suspect it will work fine.
Users browsing this forum: No registered users and 49 guests
