Lots of "no ack"
Thu Oct 24, 2019 2:19 am
MarcoGT offline
Lots of "no ack"
Hi all,
since a couple of hrs lots of Z-WAVE device (Roller shutter and wall switches) are in a "no ack" status; the Door sensors still work, but I think just because a status request has not been sent yet.
I restarted the Z-Wave interface, but not yet disconnected the Z Wave Stick (S2); I will try when at home (or ask the wife to do it :D ).
Furthermore, why do some roller shutter devices have as "last reset" few days ago even if I did not click "reset"?
Marco
Thu Oct 24, 2019 2:52 am
MarcoGT offline
Re: Lots of "no ack"
More details here:
- unplug / re-plug of the Stick did not help.
- when sending command to roller shutter, they actually work (blinds go up/down), but I do not get any feedback --> no ack.
What is going on?
Thu Oct 24, 2019 4:29 am
When I get the rare No Ack message, I've found that I've had to remove and restore power to the offending device in order to reset communication to it. With the wall switches, it may be enough to air gap them. I get a No Ack maybe once or twice a year for a single device. I have yet to figure out what causes the loss of communication to happen in the first place.
If you restore communication and then the messages come back again, it may be that your stick is failing.
Thu Oct 24, 2019 6:37 am
MarcoGT offline
So, went home, just touch the S2 Stick (not unplugged), and everything works fine :D
Let's see in the next days...
Thu Oct 24, 2019 6:41 am
MarcoGT offline
Well, they are failed again...Stick is dying? :? :? :?
Thu Oct 24, 2019 7:30 am
MarcoGT offline
Troubleshooting; if I move a Fibaro Wall Plug near the Stick, it gets recognised, if I move it back, "no ack"
Thu Oct 24, 2019 7:33 am
You might try a network heal to see if that helps. It could be that something in the communication path to the device (when it's installed in its intended location) is causing the messages to get lost.
Thu Oct 24, 2019 7:42 am
MarcoGT offline
Yes but why all devices?
How do I make a network heal?
You mean optimization? I have just started and I see lots of "ping failed", but at the moment for the battery powered devices
Thu Oct 24, 2019 7:47 am
Go to the Interfaces menu in Inidgo, select Z-Wave, and then Optimize Z-Wave Network. Depending on the number of devices you have, this make take a long time to complete. It also could get hung up on a failed device, so I'd suggest not running this step until a time where you are able to monitor progress. Just in case.
Thu Oct 24, 2019 1:59 pm
MarcoGT offline
Further investigation
So far I had just two hard disks connected to the MacMini.
Yesterday I connected another two, and since then I see the problem.
Removed those, everything fine, plugged again, lots of no ack
No idea what’s going on
Thu Oct 24, 2019 3:02 pm
Re: Lots of
Bad drive or USB cable is hogging the USB bus. Are these all plugged into a USB hub? What model mini? The latest ones have separate USB 2 and USB 3.1 busses. Put the Z-stick on the USB 2.0 bus and the drives on the 3.1 bus.
Thu Oct 24, 2019 10:35 pm
MarcoGT offline
I think drive is fine; it was connected to an iMac 27 (Late 2013, display died :( ) and everything was fine.
MacMini Late 2014 here
Fri Oct 25, 2019 6:04 am
It could be that everything is putting too much strain on the USB power bus. If you need to have all the drives attached, you might try hooking them up via a USB hub with a separate power supply. If the stick works well without the drives attached, I think you've isolated the cause of your trouble.
