Devolo Humidity Sensor
Mon Aug 26, 2019 8:44 am
Umtauscher offline
it seems to me the Philio Humitity Sensor PAT02-B is identical to the Devolo Humitity and Temperatur sensor.
Has anyone tried the devolo? I was hoping Indigo supported it but you'll never know.
As the Philio is more difficult to get here in Germany than the devolo I think I'd ask you guys.
Thanks in advance
Wilhelm
Mon Aug 26, 2019 3:33 pm
Re: Devolo Humidity Sensor
I'm not seeing user reports for the Devolo version but that may be because they are filed under the Philio version. If it uses identical firmware (same configuration parameters, etc.), then it should work in Indigo (we might still have to duplicate the device definition but that can make it into a bug-fix release). You might want to compare the PDF manuals to see if they really are identical. Sometimes in cases like this the hardware is the same but they modify the firmware with different functionality / features.
Wed Dec 23, 2020 4:52 pm
Indigo 7.5 is now available and includes preliminary (untested) support for the Devolo Humidity Sensor (MT02755).
Sat Oct 01, 2022 8:33 am
Bildhauer offline
Hello,
bring to modify the configuration parameters of an MT02755 end in:
  Z-Wave Error                    failed to read value -- device may not support parameter 5 or may be asleep
   Z-Wave Error                    send "Temperatursensor Gästehaus" readConfigValue command failed (module might be asleep, or is unreachable)
   Z-Wave Watcher Debug            Raw command sent (Node 192): 01 0A 00 13 C0 03 70 05 05 25 6C 1C (False)
The device is seen by Indigo app, delivering e. g. temperature values on a regular basis and parameter I'm trying to read is described in the manual of the device . Additionally
 Z-Wave                          received "Temperatursensor Gästehaus" sensor update to 61.51 °F
   Trigger                         Sende Nachricht Temperaturänderung Gästehaus
   Z-Wave Watcher Debug            Raw command received (Node 192): 01 0C 00 04 00 C0 06 31 05 01 4A 18 07 51
   Z-Wave Watcher Debug            Command class: 31v5
   Z-Wave Watcher Debug            Command not yet decoded: 31 05 v5
   Email+                          sending email 'Gästehaus: Änderung der Temperatur' to 'merckens@gmx.de' using Email+ SMTP Server
   Virtual Energy Meter Error      Error in plugin execution ServerReplacedElem:
  File "plugin.py", line 328, in deviceUpdated
KeyError: key id 201568232 not found in database
can be seen.
What can I do to read/ change parameters of it?
Best regards
Bildhauer
Sun Oct 02, 2022 1:45 pm
Is the module awake when you try to change (or read) that parameter? The manual might have steps for how to wake it. Often times pressing the button on it will wake it for a few seconds, although some modules require a particular number of button taps.
The other error is coming from the Virtual Energy Meter plugin. You probably have a virtual device defined that includes a device that you no longer have in your Indigo database. You might have to recreate that virtual device or remove the missing device.
Mon Oct 03, 2022 1:05 pm
Bildhauer offline
Thx, ehrt will be a hard job to find the "missing" device". IS there a way th get the list fitted to the window to make work much easier (see attached screenshot)?
Thanks a lot in advance!
Bildhauer
Configure_Virtual_Group_Energy_Meter_und_Edit_Device__Verbrauch_Büro_komplett__und_Grenzweg_und_Indigo_Domotics_•_Post_a_reply.jpg
Configure_Virtual_Group_Energy_Meter_und_Edit_Device__Verbrauch_Büro_komplett__und_Grenzweg_und_Indigo_Domotics_•_Post_a_reply.jpg (39.61 KiB) Viewed 1431 times
Mon Oct 03, 2022 4:38 pm
Try opening a copy (make a copy to be safe) of the Indigo database file, then open it in a raw text editor and search for the ID number 201568232. That might give you some context where to look. You can copy/paste the XML lines before and after that (a few dozen in either direction) into a reply and we can help, or you can email us your database file.
Tue Oct 11, 2022 11:22 am
Bildhauer offline
Hello,
as you see out of the screenshot the retrieved parameter value is not shown in den "modify configuration parameter …" window.
The log shows:
Z-Wave Watcher Debug            Raw command sent (Node 192): 01 0A 00 13 C0 03 70 05 0A 25 BF C0 (True)
   Z-Wave                          received "Manipulationssensor Gästehaus" status update is on
   Z-Wave Watcher Debug            Raw command received (Node 192): 01 0A 00 04 00 C0 04 30 03 FF 08 F1
   Z-Wave Watcher Debug            Command class: 30v1
   Z-Wave Watcher Debug            Command not yet decoded: 30 03 v1
   Z-Wave Watcher Debug            Raw command sent (Node 192): 01 0A 00 13 C0 03 70 05 0A 25 C0 BF (True)
   Z-Wave                          retrieved parameter 10 "Battery interval" is 12 * 30 minutes
   Z-Wave Watcher Debug            Raw command received (Node 192): 01 0B 00 04 00 C0 05 70 06 0A 01 0C 44
   Z-Wave Watcher Debug            Command class: 70v1
   Z-Wave Watcher Debug            Command not yet decoded: 70 06 v1
   Z-Wave Watcher Debug            Raw command sent (Node 192): 01 09 00 13 C0 02 84 08 24 C1 4E (True)
   Z-Wave Watcher Debug            Raw command received (Node 192): 01 08 00 04 00 C0 02 84 07 B2
   Z-Wave Watcher Debug            Command class: 84v2
   Z-Wave Watcher Debug            Command not yet decoded: 84 07 v2
   Z-Wave Watcher Debug            Raw command sent (Node 192): 01 09 00 13 C0 02 84 08 24 C2 4D (True)
What can I do?
I just sent you the database file per email.
Best regards
Bildhauer
Wed Oct 12, 2022 1:16 pm
Disable the Z-Wave Watcher plugin, then enable Indigo's built-in Z-Wave debug logging checkbox via the Interfaces->Z-Wave->Configure... menu item.
Next, use that Modify Configuration Parameter dialog to read parameter 10 (via Read Current Value button), then try to write/send a new value.
Lastly, copy/paste the Event Log window results of all the above into a reply for me. Also re-sync the module and copy/paste the results of that into a reply for me.
I'm not sure what is going on with the error on the device ID 201568232 being missing. Are you still seeing that error? That is a device in your database named Verbrauch komplett Wohnzimmer, so it should be found. Do you consistently get that error? Is that device enabled?
Thu Oct 13, 2022 12:56 pm
Bildhauer offline
In regards to the missing device I can assure that the device Verbrauch komplett Wohnzimmer ist enabled.
The other thing I will try next hours.
Best regsards
Bildhauer
Thu Oct 13, 2022 1:04 pm
Bildhauer offline
Command back: The device I saw is named "Verbrauch Wohnzimmer komplett" and has the device ID 1521006876. The device named Verbrauch komplett Wohnzimmer does not exist.
Thu Oct 13, 2022 1:51 pm
Bildhauer offline
It' s still the same in regards of reading the parameter ist very hard to get. I need at least 5 - 7 tries to see int in the l,ogfile but it is not seen in the "Modify Configuration Parameter …" window.
Here is the log:
13. Oct 2022 at 21:39:00
   Z-Wave                          received "Temperatursensor Gästehaus" sensor update to 78.74 °F
   Trigger                         Gästehaus Heizung AUS > 20ºC (Winter) copy
   Email+                          sending email 'Gästehaus Heizung AUS > 20ºC (Winter)' to 'merckens@gmx.de' using Email+ SMTP Server
13. Oct 2022 at 21:39:16
13. Oct 2022 at 21:39:32
13. Oct 2022 at 21:39:55
   Z-Wave                          sent "Zwischenstecker Gästehaus Luftreiniger" off
   Z-Wave                          sent "Zwischenstecker Gästehaus Steckdosenleiste IT" off
13. Oct 2022 at 21:40:17
   Z-Wave                          received "Temperatursensor Gästehaus" sensor update to 80.12 °F
   Z-Wave                          received "Feuchtigkeitsensor Gästehaus" sensor update to 68.96%
   Trigger                         Sende Nachricht Feuchtigkeitsänderung Gästehaus
   Z-Wave                          retrieved parameter 5 "Operation flags" is 33
   Email+                          sending email 'Gästehaus: Änderung der Luftfeuchtigkeit' to 'merckens@gmx.de' using Email+ SMTP Server
13. Oct 2022 at 21:41:19
   Z-Wave Error                    no ack/nak/busy reply (204) for setRelayValue (re-sending)
13. Oct 2022 at 21:42:02
   Z-Wave Error                    send "Zwischenstecker Gästehaus Luftreiniger" off failed
   Z-Wave                          received "Feuchtigkeitsensor Gästehaus" sensor update to 62.93%
   Z-Wave Error                    no ack/nak/busy reply (037) for nonceReport (re-sending)
   NetatmoWelcome                  Weather Station Data:
{'devices': [{'_id': '70:ee:50:7a:cd:0c', 'date_setup': 1627856691, 'last_setup': 1627856691, 'type': 'NAMain', 'last_status_store': 1665690147, 'module_name': 'Wetterstation Wohnzimmer', 'firmware': 181, 'wifi_status': 43, 'reachable': True, 'co2_calibrating': False, 'data_type': ['Temperature', 'CO2', 'Humidity', 'Noise', 'Pressure'], 'place': {'altitude': 22, 'city': 'Oststeinbek', 'country': 'DE', 'timezone': 'Europe/Berlin', 'location': [10.149527, 53.545794]}, 'station_name': 'Grenzweg 12a (Wetterstation Wohnzimmer)', 'home_id': '61071f331290da06ac60b64c', 'home_name': 'Grenzweg 12a', 'dashboard_data': {'time_utc': 1665690147, 'Temperature': 24.8, 'CO2': 1043, 'Humidity': 51, 'Noise': 36, 'Pressure': 1015.5, 'AbsolutePressure': 1012.9, 'min_temp': 20.8, 'max_temp': 24.9, 'date_max_temp': 1665689240, 'date_min_temp': 1665650145, 'temp_trend': 'up', 'pressure_trend': 'down'}, 'modules': [{'_id': '02:00:00:7b:02:ba', 'type': 'NAModule1', 'module_name': 'Wetterstation Aussenbereich', 'last_setup': 1627856691, 'data_type': ['Temperature', 'Humidity'], 'battery_percent': 61, 'reachable': True, 'firmware': 50, 'last_message': 1665690142, 'last_seen': 1665690129, 'rf_status': 83, 'battery_vp': 5304, 'dashboard_data': {'time_utc': 1665690129, 'Temperature': 13.3, 'Humidity': 92, 'min_temp': 6.5, 'max_temp': 15.5, 'date_max_temp': 1665667366, 'date_min_temp': 1665634398, 'temp_trend': 'down'}}, {'_id': '06:00:00:05:90:48', 'type': 'NAModule2', 'module_name': 'Windmesser', 'last_setup': 1627892286, 'data_type': ['Wind'], 'battery_percent': 83, 'reachable': True, 'firmware': 25, 'last_message': 1665690142, 'last_seen': 1665690142, 'rf_status': 120, 'battery_vp': 5654, 'dashboard_data': {'time_utc': 1665690142, 'WindStrength': 1, 'WindAngle': 90, 'GustStrength': 2, 'GustAngle': 90, 'max_wind_str': 7, 'max_wind_angle': 25, 'date_max_wind_str': 1665664046}}, {'_id': '05:00:00:08:fb:a0', 'type': 'NAModule3', 'module_name': 'Regenmesser', 'last_setup': 1627892507, 'data_type': ['Rain'], 'battery_percent': 82, 'reachable': True, 'firmware': 12, 'last_message': 1665690136, 'last_seen': 1665690129, 'rf_status': 93, 'battery_vp': 5610, 'dashboard_data': {'time_utc': 1665690129, 'Rain': 0, 'sum_rain_1': 0, 'sum_rain_24': 0}}]}], 'user': {'mail': 'merckens@gmx.de', 'administrative': {'lang': 'de-DE', 'reg_locale': 'de-DE', 'country': 'DE', 'unit': 0, 'windunit': 0, 'pressureunit': 0, 'feel_like_algo': 0}}}
   NetatmoWelcome                  Processing Weather Station 0
   NetatmoWelcome                  Processing Modules:
   NetatmoWelcome                  Processing Wetterstation Wohnzimmer NAMain
   NetatmoWelcome                   Processing Noise
   NetatmoWelcome                   Processing Temp
   NetatmoWelcome                   Processing Temp Trend
   NetatmoWelcome                   Processing Pressure
   NetatmoWelcome                   Processing Humidity
   NetatmoWelcome                   Processing CO2
   NetatmoWelcome                   Processing CO2 Cal
   NetatmoWelcome                   Processing Min/Max
   NetatmoWelcome                   Processing Timestamp
   NetatmoWelcome                   Finding weather device
   NetatmoWelcome                   - Updating Wetterstation Esszimmer Air Monitor
   NetatmoWelcome                    Processing device temperature update
   NetatmoWelcome                    Processing rest of device updates
   NetatmoWelcome                    Processing device state icon
   NetatmoWelcome                  Processing Wetterstation Aussenbereich NAModule1
   NetatmoWelcome                   - Updating Wetterstation Aussenbereich
   NetatmoWelcome                  Processing Windmesser NAModule2
   NetatmoWelcome                   - Updating Windmesser
   NetatmoWelcome                  Processing Regenmesser NAModule3
   NetatmoWelcome                   - Updating Regenmesser
13. Oct 2022 at 21:43:23
   Z-Wave Error                    send "Temperatursensor Gästehaus" setConfigVal command failed (module might be asleep, or is unreachable)
   Z-Wave Error                    device "Temperatursensor Gästehaus" may be asleep. configuration changes will be set during the next wake interval.
   Z-Wave                          received "Feuchtigkeitsensor Gästehaus" sensor update to 57.58%
13. Oct 2022 at 21:43:40
13. Oct 2022 at 21:44:02
   Z-Wave                          received "Temperatursensor Gästehaus" sensor update to 26.73 °C
   Z-Wave                          received "Temperatursensor Gästehaus" units changed to °C
13. Oct 2022 at 21:44:26
   Z-Wave                          device "192 - Temperatursensor Gästehaus" parameter 5 "Operation flags" changed to 41
13. Oct 2022 at 21:44:44
13. Oct 2022 at 21:45:03
13. Oct 2022 at 21:45:21
13. Oct 2022 at 21:45:40
   Z-Wave                          received "Feuchtigkeitsensor Gästehaus" sensor update to 62.65%
13. Oct 2022 at 21:46:44
   Z-Wave                          received "Feuchtigkeitsensor Gästehaus" sensor update to 57.62%
   Z-Wave Error                    no ack/nak/busy reply (192) for readConfigValue (re-sending)
   Z-Wave Error                    no ack/nak/busy reply (026) for nonceReport (re-sending)
Thu Oct 13, 2022 1:59 pm
Bildhauer offline
The change of parameters is as hard as to read the parameters. But at least it's working …
Thu Oct 13, 2022 3:59 pm
Device Verbrauch komplett Wohnzimmer exists in the database you emailed me. It is inside the folder Wohnzimmer. The device you have in your database, Verbrauch Wohnzimmer komplett, is not in the one I received via email.
Thu Oct 13, 2022 4:01 pm
You didn't turn on Indigo's Z-Wave debug logging and you didn't include a log of a re-sync of the device.
support wrote:
...then enable Indigo's built-in Z-Wave debug logging checkbox via the Interfaces->Z-Wave->Configure... menu item.
