Aeotc Multi Sensor 6. ZW100
Wed Aug 07, 2019 12:12 pm
captcurrent offline
I have been trying to deploy a couple of these devices at mt remote installation. I got them up and sort of working before I left
Three days ago I tried to update the setting using Inigo. Although I have had some slows success doing this, This time the devise is stuck with a red indicator and says Changing Pending.
I imagine I am going to have tp physically power cycle the device.
Any thoughts or prayers
thanks
Wed Aug 07, 2019 2:39 pm
Re: Aeotc Multi Sensor 6. ZW100
Indigo should push any config/settings changes to the device on its next wake interval (as defined by the popup near the top of the settings dialog). Manually waking it should also cause the settings to push. I don't recall the exact steps to manually wake an ZW100. Might be a single tap on the set button, might be 3 taps or a tap-and-hold.
Wed Aug 07, 2019 3:02 pm
captcurrent offline
thanks matt .. i will give that a try in a couple of months
Fri Oct 11, 2019 7:00 am
captcurrent offline
No joy.. power cable broke off removing doesn't respond under battery.. another roaring success
