peszko wrote:You could always use a pi zero as they have waterproof temperature probes and use pibeacon.I don't like being the first one, but really could use a temperature sensor with external probe. (Pool, sauna, hot tub, fridge). I might take a plunge so I can send you the device report. Are there any other z-wave devices that would have an external temperature probe and work with Indigo.
siclark wrote:You could always use a pi zero as they have waterproof temperature probes and use pibeacon.
Z-Wave sent "BY_Pool_In_TEMP" temperature status request
Z-Wave received "BY_Pool_In_TEMP" temperature update to 30.6 °C
Trigger BY_PoolTempChangeVar_TR
Z-Wave sent "BY_Pool_In_TEMP" heat setpoint status request
Z-Wave received "BY_Pool_In_TEMP" heat setpoint is 23.0 °C
Z-Wave sent "BY_Pool_In_TEMP" cool setpoint status request
Z-Wave Error rcvd incomplete interface packet: 01 0A 00 04 00 26 04 43 03 02 00 91 (missing 1 bytes)
matt (support) wrote:Which version of Indigo Server are you running?
Z-Wave sent "L4_Attic_TEMP_Z" heat setpoint status request
Z-Wave Error rcvd incomplete interface packet: 01 0A 00 04 00 25 04 43 03 01 00 91 (missing 1 bytes)
Z-Wave sent "L4_Attic_TEMP_Z" cool setpoint status request
Z-Wave received "L4_Attic_TEMP_Z" cool setpoint is 23.0 °C
SQL Logger adding column "setpointcool_ui" to table device_history_1789669507 ("L4_Attic_TEMP_Z")
