Polling uneccessary - unless...
Fri Jul 19, 2019 2:16 am
Umtauscher offline
I only have z-wave devices that properly report their status when switched by hand, so I disabled polling for those devices to reduce z-wave network traffic.
Unfortunately that means, if I restart the server, the state of devices is erratic, the more the longer the downtime is - because Indigo doesn't poll them after restart.
What I would need for such szenarios would be to set polling to something like "only after server start". Unfortunately this option doesn't exist.
So my question is - since I don't think a feature update to Indigo is likely to happen - Is there any workarround/plugin to accomplish that?
Any ideas welcome!
Cheers
Wilhelm
Fri Jul 19, 2019 6:24 am
Re: Polling uneccessary - unless...
Create a trigger for Indigo startup and put this in the action:
for dev in indigo.devices.iter("indigo.zwave"):
    indigo.device.statusRequest(dev)
viewtopic.php?f=78&t=20993
Fri Jul 19, 2019 9:43 am
Or, if you only want to update specific devices (which might be more efficient), create a startup trigger that requests a full status update to each of the those devices.
Fri Jul 19, 2019 9:58 am
Umtauscher offline
Thanks Joe for the script and the link.
Thanks Jay for trying to optimize it.
I still think, such things need to go into Indigo's user interface and device setting.
Just my 2 Ct.
Wilhelm
Fri Jul 19, 2019 10:13 am
Umtauscher offline
Still a problem:
When I do this, all battery powerd devices end up with a "no ack" state.
Is there a way to filter out battery powered devices in the loop that are not zwave plus?
(I understand polling on z-wave plus also works)
Fri Jul 19, 2019 11:49 am
racarter offline
This modification will avoid polling battery-powered devices, but I'm afraid that would include Z-Wave Plus ones:
    if dev.batteryLevel == None:
Fri Jul 19, 2019 2:45 pm
Umtauscher offline
Thanks, but that does only part of the job.
The primary battery powered devices are not polled any more, but the slave devices of those still fail.
Example:
Fibaro Door Window sensor (skipped)
it's temperature sensor (fails)
Fibaro Motion sensor (skipped)
it's temperatur sensor (fails)
it's tilt/temper sensor (fails)
I hope you get the picture.
Fri Jul 19, 2019 2:48 pm
Sound like using Jay's method to build a list would be easier.
Fri Jul 19, 2019 3:15 pm
To only request status of the main devices (not secondary):
    if dev.ownerProps["zwDevSubIndex"] == 0 and dev.batteryLevel == None:
Fri Jul 19, 2019 3:47 pm
Grognard offline
Now THAT is dang useful. Adding it to my startup script now
Sat Jul 20, 2019 3:09 am
Umtauscher offline
Thanks Matt,
now you are nearly there. What is missing are the battery powered devices that use z-wave plus and are able to be polled. I don't know the exact term for this feature, but my spirit thermostats can do it., for example.
Cheers
Wilhelm
Sat Jul 20, 2019 10:23 am
I'm not sure that what you need (which is that the module support frequent waking) is available via the device's properties.
However, try adding a check for dev.supportsStatusRequest. Depending on how the devices are defined that might be good enough.
Sun Jul 21, 2019 5:43 am
Umtauscher offline
Hi Matt,
I don't think that will do it, because nearly all of my battery powered devices have this set.
The magic keyword seems to be FLiRS support.
Is there any dev property that will reflect, if the device supports that?
Sun Jul 21, 2019 10:28 am
Internally Indigo knows about that, but it isn't exposed in the python accessible objects. I'll add it to the request/ToDo list.
Sun Jul 21, 2019 11:19 am
Umtauscher offline
As long as you add something to the list, I would prefer an option "poll only at server startup" to the device settings. :roll:
Cheers
Wilhelm
Users browsing this forum: Google [Bot] and 4 guests
