- Posted on
Fri Jul 19, 2019 6:20 pm
rgspb
offline
That didn't do it. Here's the log for you:
Z-Wave Syncing - started for "WallMote1"
Z-Wave Syncing - retrieved module neighbors list: 2, 7, 12, 16, 21, 28, 37, 38, 40, 41, 42, 43, 44, 45, 47, 48
Z-Wave Syncing - assigning return route to "063 - WallMote1"
Z-Wave Syncing - retrieved manufacture and model names: Aeon Labs - 0086, WallMote Quad (ZW130) - 01020082
Z-Wave Syncing - retrieved protocol version 4.62, app version 2.03
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Wall Controller : Basic Wall Controller (04 : 18 : 01, base 00)
Z-Wave Syncing - retrieved command classes: 80v1 20v1 84v2 85v1 86v1 8Ev1 59v1 5Av1 5Bv1 5Ev1 60v4 70v1 71v1 72v1 73v1 7Av1
Z-Wave Syncing - retrieved capabilities: routing, battery, beaming, waking
Z-Wave Syncing - retrieved wake interval of 60 minutes
Z-Wave Syncing - device "063 - WallMote1" wake interval changed to 60 minutes
Z-Wave Syncing - retrieved multi-endpoint types: 1:(18 : 01), 2:(18 : 01), 3:(18 : 01), 4:(18 : 01)
Z-Wave Syncing - retrieved multi-endpoint classes: 1:[5E 85 59 8E], 2:[5E 85 59 8E], 3:[5E 85 59 8E], 4:[5E 85 59 8E]
Z-Wave Syncing - retrieved group 3 associations: []
Z-Wave Syncing - retrieved group 4 associations: []
Z-Wave Syncing - retrieved group 5 associations: []
Z-Wave Syncing - retrieved group 6 associations: []
Z-Wave Syncing - retrieved group 7 associations: []
Z-Wave Syncing - retrieved group 8 associations: []
Z-Wave Syncing - retrieved group 9 associations: []
Z-Wave Syncing - retrieved parameter 4 "Scene type" is 1
Z-Wave Syncing - retrieved parameter 1 "Beep on touch" is true
Z-Wave Syncing - retrieved parameter 2 "Vibrate on touch" is true
Z-Wave Syncing - retrieved parameter 3 "Allow touch-drag up/down to brighten/dim direct associations" is false
Jul 19, 2019 at 8:18:39 PM
Z-Wave Syncing - failed to retrieve parameter 5 "Touch LED color" (skipping)
Z-Wave Syncing - retrieved battery level of 56%
Z-Wave Syncing - complete
